Mikrotik 1200 - Net Prohibited Issue ???
Using Mikrotik Routerboard 1200 as a main router and 40 asus repeaters flashed with DD-WRT
I am using the built in Hotspot to provide Internet for clients .
RB1200 ( Ether1 - 192.168.222.1/24 ) --------- > Switch
ISP <--------- RB1200 (Ether 2)
RB1200 ( Ether3 - 192.168.0.1/20 - Hotspot Port - DHCP Pool ) --------- > Switch
------------- Floor 1
Switch ---------> ------------- Floor 2
------------- Floor 3
for the repeaters the IPs are 192.168.222.2 - 192.168.222.42
I am connecting to the Rb1200 using Winbox , usually I use Putty and web interface to manage the repeaters , of course I can do that using port forwarding .
but before I put port forwarding , I have to be able to ping those repeaters from mikrotik using the ether1 , when I am trying to ping them , they reply with net prohibited and the reply is from 192.168.0.1 .
I think it is related to firewall filter rules
ip firewall filter print all
 0 D chain=forward action=jump jump-target=hs-unauth hotspot=from-client,!auth
 1 D chain=forward action=jump jump-target=hs-unauth-to hotspot=to-client,!auth
 2 D chain=input action=jump jump-target=hs-input hotspot=from-client
 3 D chain=input action=drop protocol=tcp hotspot=!from-client
     dst-port=64872-64875
 4 I chain=hs-input action=jump jump-target=pre-hs-input
 5 D chain=hs-input action=accept protocol=udp dst-port=64872
 6 D chain=hs-input action=accept protocol=tcp dst-port=64872-64875
 7 D chain=hs-unauth action=return dst-address=x.x.x.x
 8 D chain=hs-unauth action=return dst-address=y.y.y.y
 9 D chain=hs-unauth action=return dst-address=z.z.z.z
10 D chain=hs-input action=jump jump-target=hs-unauth hotspot=!auth
11 D chain=hs-unauth action=reject reject-with=tcp-reset protocol=tcp
12 D chain=hs-unauth-to action=return src-address=x.x.x.x
13 D chain=hs-unauth-to action=return src-address=y.y.y.y
14 D chain=hs-unauth-to action=return src-address=z.z.z.z
15 D chain=hs-unauth action=reject reject-with=icmp-net-prohibited
16 D chain=hs-unauth-to action=reject reject-with=icmp-host-prohibited
17 X ;;; place hotspot rules here
     chain=unused-hs-chain action=passthrough
so any advice please ???
Reset the counters on all your rules to zero, then run the ping and see which rule increments.
Add the repeaters ip address to /ip hotspot ip-binding as bypassed
I treid adding this in Ip binding but no way
can you help me in the syntax or how I can use winbox to do that , cause I tried but no way
Look in the hotspot settings in winbox. You will see bindings.
THANKS guys for your answer
for the first suggestion
I reset all counters and when I am trying to ping more than one filter rule match and increase their counter and I delete most of them and still have the same result .
if you ckecked the rule 15&16 I deleted both of them and nothing changed
for the second one before I asked you I tried to go to winbox and I added repeaters Ip in address box and Server : all and type is : Bypassed ans still have the same result
is that what you guys both suggested ???
Did you add their ip addresses to the bindings?
Yes I told you , hotspot - IP binding - add new Ip binding and filled address and server and type as suggested
one more thing , my repeaters are Asus N12 flashed with DD-WRT , if I connect to them " using another way " and refresh or try to modify something then I can ping , after 20-3- minutes I can not any more .
ANY ANSWER ? I still have the same problem
