Port strict and NAT are unrelated. What is related is that at least Microsoft VPN client needs to be tweaked in registry to accept an L2TP server listening on a private address behind a NAT. But it can also be done without tweaking the registry using the method described here.
But as you stubbornly refuse to post obfuscated but otherwise complete configuration export, I’m only guessing that the Mikrotik itself is behind a NAT. If it is not, restricting the src-address of the policy template to a single private address is a nonsense. So either you’ve obfuscated an IP which is actually a public one using a private one, or I don’t understand how the config could have worked before the upgrade because the NAT detection mechanism is the same all the time and the intolerance of the Windows client to server-side NAT lasts for years. My only explanation for that is that the Windows settings permit fallback to IPsec-less L2TP and it worked that way all the time.
So:
post the complete config and obfuscate public addresses, if any, using symbolic names rather than randomly generated digit strings
if the Mikrotik doesn’t have a public IP on itself, provide a network diagram from the interface on the external device which holds the public IP down to the Mikrotik
If the Tik sits on public IP, then the restriction of the policy template’s src-address to 10.222.22.1 is a nonsense, as the policy needs to be bound to the public IP.
But this mistake is not the reason why the phase 1 packets from Tik’s port 500 to client’s port 11809 do not get through.
It would be fine if you could use the /tool sniffer quick port=500 command shown above to see whether these packets (the client port will be different this time) are really sent out or not. Because if they are, the issue is not in the Mikrotik and it may be some super-paranoid firewall between your test client and the Tik’s network what doesn’t let them through.
