We upgraded from a very old version of RouterOS to 6.45.1
it completely scrambled the IPSec settings
I have been trying to rebuild it following online how-to guides
but the way IPSec settings are now in winbox are completely different than anything I can find online
I turned on debug logging for ipsec and its saying ike2 peer not setup for the IP that tries to connect
I don’t see anything setup for ike2 so I’m very confused
dose anyone on here have an updated link showing how to setup LT2P VPN Server with IPSec??
Sob
August 1, 2019, 2:08pm
2
I don’t have any up to date tutorial. But it’s very similar, only what was previously in one place is split into multiple parts (it gives more flexibility how to do stuff). If you have previously working config, you just need to find where each option went, but it should be there somewhere.
Our working config was scrambled in the upgrade in the ipsec section
I have followed the tutorials best I can redoing L2TP ipsec road worrier with 256 encryption
Clinet trying to connect gets unsuccessful
And the ipsec server logs say ike2 no configuration for the IP of clinet trying to connect
I really don’t understand the ike2 error as I did not setup anything for ike2
sindy
August 2, 2019, 8:04am
4
Can you /export hide-sensitive the current configuration (at least the scrambled IPsec part as well as the L2TP part)? Maybe we can find a way to tidy it up.
Here is the config after I followed online how to guides
if you guys can please tell me what I'm doing wrong our road worriers really need the VPN back
Thanks!
PPP Config
aug/05/2019 05:16:53 by RouterOS 6.45.1
software id = A4X7-ER4H
model = CCR1009-8G-1S-1S+
serial number = removed
/ppp profile
add change-tcp-mss=yes local-address=10.222.22.1 name=
"L2TP Remote Connection" remote-address="VPN Pool" use-encryption=
required
/ppp secret
add name=removed password=#Removed profile="L2TP Remote Connection"
IPsec Config
aug/05/2019 05:20:41 by RouterOS 6.45.1
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256,aes-128,3des name=L2TP
/ip ipsec peer
add local-address=10.222.22.1 name=L2TP-in-Server passive=yes profile=L2TP
/ip ipsec proposal
set [ find default=yes ] lifetime=0s pfs-group=none
/ip ipsec identity
add generate-policy=port-override peer=L2TP-in-Server secret=removed
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=10.222.22.1/32
sindy
August 5, 2019, 10:39am
6
In the L2TP part, you forgot to post the /interface l2tp-server server part. That’s why it always better to post the complete export and just obfuscate the sensitive information (see the hint in my automatic signature below). So either do that or post at least /interface l2tp-server export verbose hide-sensitive and /ip firewall export .
I can see that you have modified the default proposal (for phase 2) but added your own profile (for phase 1), is it because you use IPsec on the machine for anything else than L2TP? Also, can you change policy-generate from port-override to port-strict in the identity?
the output is from
ip ipsec export file=
and
ppp export file=
I don’t know why there is missing information
I have tried the port settings both ways
the ports are open in the firewall I just tried the override in hopes it would push things through
here is the interface
aug/05/2019 06:46:20 by RouterOS 6.45.1
set authentication=mschap1,mschap2 default-profile="L2TP Remote Connection"
enabled=yes ipsec-secret=removed keepalive-timeout=disabled use-ipsec=
required
aug/05/2019 06:48:27 by RouterOS 6.45.1
/ip firewall layer7-protocol
add name=torrent-wwws regexp="^.(get|GET).+(torrent|kat.cr|kickasstorrent|the
piratebay|extratorrent.cc|torrentz.eu|rarbg.to|1337x.to|torrenthound.com|y
ts.ag|torrentdownloads.me|eztv.ag). $"
add name=torrent-dns regexp="^.+(torrent|kat.cr|kickasstorrent|thepiratebay|ex
tratorrent.cc|torrentz.eu|rarbg.to|1337x.to|torrenthound.com|yts.ag|torren
tdownloads.me|eztv.ag).*$"
add name=Bittorrent regexp="^(\x13bittorrent protocol|azver\x01$|get /scrap
e\?info_hash=get /announce\?info_hash=|get /client/bitcomet/|GET /data
\?fid=)|d1:ad2:id20:|\x08'7P\)[RP]"
/ip firewall address-list
add address=1.2.3.0/24 comment="United States" list=SafeCountries
add address=3.0.0.0-4.18.65.255 comment="United States" list=SafeCountries
add address=4.18.68.0-4.34.129.255 comment="United States" list=SafeCountries
add address=4.34.130.6 comment="United States" list=SafeCountries
add address=4.34.131.0-4.69.153.192 comment="United States" list=
SafeCountries
add address=4.69.153.194-5.0.0.0 comment="United States" list=SafeCountries
add address=5.11.16.0/24 comment="United States" list=SafeCountries
add address=5.34.246.0/23 comment="United States" list=SafeCountries
add address=5.44.104.0/22 comment="United States" list=SafeCountries
add address=5.56.133.0/24 comment="United States" list=SafeCountries
add address=5.61.26.0/23 comment="United States" list=SafeCountries
add address=5.61.29.0-5.61.31.255 comment="United States" list=SafeCountries
add address=5.62.153.0/24 comment="United States" list=SafeCountries
add address=5.62.156.0/24 comment="United States" list=SafeCountries
add address=5.62.158.0/24 comment="United States" list=SafeCountries
add address=5.63.128.0/22 comment="United States" list=SafeCountries
add address=5.104.241.0/24 comment="United States" list=SafeCountries
add address=5.104.244.0/23 comment="United States" list=SafeCountries
add address=5.133.204.0/27 comment="United States" list=SafeCountries
add address=5.133.205.0/27 comment="United States" list=SafeCountries
add address=5.133.206.0/27 comment="United States" list=SafeCountries
add address=5.133.207.0/27 comment="United States" list=SafeCountries
add address=5.133.208.0/27 comment="United States" list=SafeCountries
add address=5.133.209.0/27 comment="United States" list=SafeCountries
add address=5.133.210.0/27 comment="United States" list=SafeCountries
add address=5.133.211.0/27 comment="United States" list=SafeCountries
add address=5.133.212.0/27 comment="United States" list=SafeCountries
add address=5.133.213.0/27 comment="United States" list=SafeCountries
add address=5.133.214.0/27 comment="United States" list=SafeCountries
add address=5.133.215.0/27 comment="United States" list=SafeCountries
add address=5.133.216.0/27 comment="United States" list=SafeCountries
add address=5.133.217.0/27 comment="United States" list=SafeCountries
add address=5.133.218.0/27 comment="United States" list=SafeCountries
add address=5.133.219.0/27 comment="United States" list=SafeCountries
add address=5.133.220.0/27 comment="United States" list=SafeCountries
add address=5.133.221.0/27 comment="United States" list=SafeCountries
add address=5.133.222.0/27 comment="United States" list=SafeCountries
add address=5.133.223.0/28 comment="United States" list=SafeCountries
add address=5.152.179.0/24 comment="United States" list=SafeCountries
add address=5.152.181.0-5.152.191.255 comment="United States" list=
SafeCountries
add address=5.175.137.0/24 comment="United States" list=SafeCountries
add address=5.175.171.0/24 comment="United States" list=SafeCountries
add address=5.175.174.0/24 comment="United States" list=SafeCountries
add address=5.175.175.16-5.175.175.127 comment="United States" list=
SafeCountries
add address=5.175.177.16-5.175.177.127 comment="United States" list=
SafeCountries
add address=5.175.179.16-5.175.179.127 comment="United States" list=
SafeCountries
add address=5.175.180.16-5.175.180.127 comment="United States" list=
SafeCountries
add address=5.175.183.0/25 comment="United States" list=SafeCountries
add address=5.175.186.128-5.175.186.199 comment="United States" list=
SafeCountries
add address=5.175.186.224/27 comment="United States" list=SafeCountries
add address=5.175.188.0/25 comment="United States" list=SafeCountries
add address=5.175.189.0/25 comment="United States" list=SafeCountries
add address=5.175.191.0/24 comment="United States" list=SafeCountries
add address=5.175.197.0/25 comment="United States" list=SafeCountries
add address=5.175.199.0/25 comment="United States" list=SafeCountries
add address=5.175.205.0-5.175.206.255 comment="United States" list=
SafeCountries
add address=5.175.207.128/25 comment="United States" list=SafeCountries
add address=5.175.208.128/25 comment="United States" list=SafeCountries
add address=5.175.209.128/25 comment="United States" list=SafeCountries
add address=5.175.212.128/25 comment="United States" list=SafeCountries
add address=5.175.216.0/24 comment="United States" list=SafeCountries
add address=5.175.255.14 comment="United States" list=SafeCountries
add address=5.189.203.128/25 comment="United States" list=SafeCountries
add address=5.189.204.128/25 comment="United States" list=SafeCountries
add address=5.189.206.0/25 comment="United States" list=SafeCountries
add address=5.189.207.0/25 comment="United States" list=SafeCountries
add address=5.189.252.0/24 comment="United States" list=SafeCountries
add address=5.226.169.0/24 comment="United States" list=SafeCountries
add address=5.226.173.0/24 comment="United States" list=SafeCountries
add address=5.230.1.0/26 comment="United States" list=SafeCountries
add address=5.230.5.0-5.230.5.159 comment="United States" list=SafeCountries
add address=5.230.129.0-5.230.129.39 comment="United States" list=
SafeCountries
add address=5.230.129.48-5.230.129.255 comment="United States" list=
SafeCountries
add address=5.230.132.0-5.230.132.23 comment="United States" list=
SafeCountries
add address=5.231.1.128/25 comment="United States" list=SafeCountries
add address=5.231.4.128/25 comment="United States" list=SafeCountries
add address=5.231.5.128/25 comment="United States" list=SafeCountries
add address=5.231.6.128/25 comment="United States" list=SafeCountries
add address=5.231.12.128/25 comment="United States" list=SafeCountries
add address=5.231.13.128-5.231.14.255 comment="United States" list=
SafeCountries
add address=5.231.15.128/25 comment="United States" list=SafeCountries
add address=5.231.19.128/25 comment="United States" list=SafeCountries
add address=5.231.20.128/25 comment="United States" list=SafeCountries
add address=5.231.21.128/25 comment="United States" list=SafeCountries
add address=5.231.23.0-5.231.23.111 comment="United States" list=
SafeCountries
add address=5.231.23.128/25 comment="United States" list=SafeCountries
add address=5.231.26.128/25 comment="United States" list=SafeCountries
add address=5.231.27.128/25 comment="United States" list=SafeCountries
add address=5.231.75.16-5.231.75.127 comment="United States" list=
SafeCountries
add address=5.254.108.0/26 comment="United States" list=SafeCountries
add address=5.254.109.0/24 comment="United States" list=SafeCountries
add address=5.254.114.192/26 comment="United States" list=SafeCountries
add address=5.254.127.64/26 comment="United States" list=SafeCountries
add address=5.255.4.0-5.255.63.255 comment="United States" list=SafeCountries
add address=5.255.250.0/24 comment="United States" list=SafeCountries
add address=6.0.0.0-8.0.15.255 comment="United States" list=SafeCountries
add address=8.0.16.1-8.0.17.255 comment="United States" list=SafeCountries
add address=8.0.18.1-8.0.23.255 comment="United States" list=SafeCountries
add address=8.0.24.1-8.0.25.255 comment="United States" list=SafeCountries
add address=8.0.26.1-8.0.115.255 comment="United States" list=SafeCountries
add address=8.0.116.1-8.7.243.255 comment="United States" list=SafeCountries
add address=8.7.245.0-8.14.223.255 comment="United States" list=SafeCountries
add address=8.15.0.0-8.18.127.255 comment="United States" list=SafeCountries
add address=8.18.129.0-8.18.135.255 comment="United States" list=
SafeCountries
add address=8.18.144.0-8.18.171.255 comment="United States" list=
SafeCountries
add address=8.18.173.0-8.20.109.255 comment="United States" list=
SafeCountries
add address=8.20.111.0-8.20.116.255 comment="United States" list=
SafeCountries
add address=8.20.118.0-8.21.35.255 comment="United States" list=SafeCountries
add address=8.21.40.0/24 comment="United States" list=SafeCountries
add address=8.21.42.0-8.21.50.255 comment="United States" list=SafeCountries
add address=8.21.52.0-8.23.199.255 comment="United States" list=SafeCountries
add address=8.23.201.0-8.24.6.255 comment="United States" list=SafeCountries
add address=8.24.16.0-8.26.17.255 comment="United States" list=SafeCountries
add address=8.26.20.0-8.26.93.255 comment="United States" list=SafeCountries
add address=8.26.95.0-8.28.4.255 comment="United States" list=SafeCountries
add address=8.28.6.0-8.29.223.255 comment="United States" list=SafeCountries
add address=8.29.225.0-8.30.207.255 comment="United States" list=
SafeCountries
add address=8.30.216.0-8.33.95.255 comment="United States" list=SafeCountries
add address=8.33.104.0-8.33.127.255 comment="United States" list=
SafeCountries
add address=8.33.138.0-8.37.225.255 comment="United States" list=
SafeCountries
add address=8.37.227.0-8.87.136.65 comment="United States" list=SafeCountries
add address=8.87.136.67-9.19.255.255 comment="United States" list=
SafeCountries
add address=9.20.128.0-9.255.255.255 comment="United States" list=
SafeCountries
add address=11.0.0.0-12.8.183.255 comment="United States" list=SafeCountries
add address=12.8.185.0-12.16.39.255 comment="United States" list=
SafeCountries
add address=12.16.42.0-12.21.13.255 comment="United States" list=
SafeCountries
add address=12.21.16.0-12.24.140.255 comment="United States" list=
SafeCountries
add address=12.24.142.0-12.35.150.223 comment="United States" list=
SafeCountries
add address=12.35.150.240-12.41.133.255 comment="United States" list=
SafeCountries
add address=12.41.134.128/27 comment="United States" list=SafeCountries
add address=12.41.134.176-12.69.139.255 comment="United States" list=
SafeCountries
add address=12.69.141.0-12.156.185.151 comment="United States" list=
SafeCountries
add address=12.156.185.160-12.174.223.255 comment="United States" list=
SafeCountries
add address=12.174.228.0-12.174.242.23 comment="United States" list=
SafeCountries
add address=12.174.242.32-12.204.8.255 comment="United States" list=
SafeCountries
add address=12.204.9.16-12.204.9.63 comment="United States" list=
SafeCountries
add address=12.204.9.72-12.205.101.255 comment="United States" list=
SafeCountries
add address=12.205.103.0-13.16.137.9 comment="United States" list=
SafeCountries
add address=13.16.137.12-13.21.124.255 comment="United States" list=
SafeCountries
add address=13.21.126.0-13.66.255.255 comment="United States" list=
SafeCountries
add address=13.67.128.0-13.68.255.255 comment="United States" list=
SafeCountries
add address=13.71.192.0-13.72.191.255 comment="United States" list=
SafeCountries
add address=13.73.32.0-13.73.95.255 comment="United States" list=
SafeCountries
add address=13.73.208.0/20 comment="United States" list=SafeCountries
add address=13.73.240.0/20 comment="United States" list=SafeCountries
add address=13.77.64.0-13.77.255.255 comment="United States" list=
SafeCountries
add address=13.78.128.0/17 comment="United States" list=SafeCountries
add address=13.82.0.0-13.86.255.255 comment="United States" list=
SafeCountries
add address=13.87.128.0-13.88.199.255 comment="United States" list=
SafeCountries
add address=13.89.0.0-13.92.255.255 comment="United States" list=
SafeCountries
add address=13.93.128.0/17 comment="United States" list=SafeCountries
add address=13.96.0.0-13.105.255.255 comment="United States" list=
SafeCountries
add address=13.106.20.0-13.106.39.255 comment="United States" list=
SafeCountries
add address=13.106.46.0/23 comment="United States" list=SafeCountries
add address=13.106.50.0-13.106.57.255 comment="United States" list=
SafeCountries
add address=13.106.62.0-13.255.255.255 comment="United States" list=
SafeCountries
add address=14.192.176.0/20 comment="United States" list=SafeCountries
add address=15.0.0.0-15.90.161.255 comment="United States" list=SafeCountries
add address=15.90.163.0-15.142.47.255 comment="United States" list=
SafeCountries
add address=15.142.64.0-15.195.175.255 comment="United States" list=
SafeCountries
add address=15.195.192.0/19 comment="United States" list=SafeCountries
add address=15.196.0.0/15 comment="United States" list=SafeCountries
add address=15.198.128.0/17 comment="United States" list=SafeCountries
add address=15.199.64.0-15.200.127.255 comment="United States" list=
SafeCountries
add address=15.200.144.0-15.203.127.255 comment="United States" list=
SafeCountries
add address=15.203.192.0-15.203.239.255 comment="United States" list=
SafeCountries
add address=15.204.0.0/17 comment="United States" list=SafeCountries
add address=15.205.0.0-15.211.152.255 comment="United States" list=
SafeCountries
add address=15.211.154.0-15.211.168.255 comment="United States" list=
SafeCountries
add address=15.211.170.0-15.211.177.255 comment="United States" list=
SafeCountries
add address=15.211.179.0-15.211.184.255 comment="United States" list=
SafeCountries
add address=15.211.186.0-15.219.200.255 comment="United States" list=
SafeCountries
add address=15.219.202.0-15.219.232.255 comment="United States" list=
SafeCountries
add address=15.219.234.0-15.227.248.255 comment="United States" list=
SafeCountries
add address=15.227.250.0-17.44.223.255 comment="United States" list=
SafeCountries
add address=17.44.240.0-17.45.21.255 comment="United States" list=
SafeCountries
add address=17.45.24.0-17.45.29.255 comment="United States" list=
SafeCountries
add address=17.45.32.0-17.45.55.255 comment="United States" list=
SafeCountries
add address=17.45.64.0-17.45.135.255 comment="United States" list=
SafeCountries
add address=17.45.138.0/23 comment="United States" list=SafeCountries
add address=17.45.144.0/22 comment="United States" list=SafeCountries
add address=17.45.152.0-17.45.170.110 comment="United States" list=
SafeCountries
add address=17.45.170.115-17.45.199.255 comment="United States" list=
SafeCountries
add address=17.45.208.0-17.45.239.255 comment="United States" list=
SafeCountries
add address=17.46.0.0-17.67.151.255 comment="United States" list=
SafeCountries
add address=17.67.154.0-17.67.191.255 comment="United States" list=
SafeCountries
add address=17.67.198.0/23 comment="United States" list=SafeCountries
add address=17.67.220.0/22 comment="United States" list=SafeCountries
add address=17.67.240.0/21 comment="United States" list=SafeCountries
add address=17.68.0.0-17.69.191.255 comment="United States" list=
SafeCountries
add address=17.69.216.0/21 comment="United States" list=SafeCountries
add address=17.69.232.0/22 comment="United States" list=SafeCountries
add address=17.70.0.0-17.72.68.255 comment="United States" list=SafeCountries
add address=17.72.69.128/25 comment="United States" list=SafeCountries
add address=17.72.77.0/24 comment="United States" list=SafeCountries
add address=17.72.79.0/24 comment="United States" list=SafeCountries
add address=17.72.88.0/23 comment="United States" list=SafeCountries
add address=17.72.91.0-17.72.95.255 comment="United States" list=
SafeCountries
add address=17.72.96.128/25 comment="United States" list=SafeCountries
add address=17.72.97.128/25 comment="United States" list=SafeCountries
add address=17.72.98.128/25 comment="United States" list=SafeCountries
add address=17.72.101.0/24 comment="United States" list=SafeCountries
add address=17.72.103.0/24 comment="United States" list=SafeCountries
add address=17.72.105.0/24 comment="United States" list=SafeCountries
add address=17.72.107.0/24 comment="United States" list=SafeCountries
add address=17.72.118.0-17.72.123.255 comment="United States" list=
SafeCountries
add address=17.72.128.0-17.77.23.255 comment="United States" list=
SafeCountries
add address=17.77.32.0/21 comment="United States" list=SafeCountries
add address=17.77.48.0-17.77.71.255 comment="United States" list=
SafeCountries
add address=17.77.80.0-17.77.141.255 comment="United States" list=
SafeCountries
add address=17.77.144.0/20 comment="United States" list=SafeCountries
add address=17.77.170.0/23 comment="United States" list=SafeCountries
add address=17.77.176.0/21 comment="United States" list=SafeCountries
add address=17.77.192.0/21 comment="United States" list=SafeCountries
add address=17.77.208.0-17.78.127.255 comment="United States" list=
SafeCountries
add address=17.78.160.0-17.78.207.255 comment="United States" list=
SafeCountries
add address=17.78.216.0-17.79.131.255 comment="United States" list=
SafeCountries
add address=17.79.136.0-17.82.124.255 comment="United States" list=
SafeCountries
add address=17.82.126.0-17.235.127.255 comment="United States" list=
SafeCountries
add address=17.235.160.0/20 comment="United States" list=SafeCountries
add address=17.236.0.0-17.255.252.255 comment="United States" list=
SafeCountries
add address=17.255.254.0-20.132.255.255 comment="United States" list=
SafeCountries
add address=20.133.2.0-20.133.4.146 comment="United States" list=
SafeCountries
add address=20.133.4.148-20.133.7.255 comment="United States" list=
SafeCountries
add address=20.133.9.0-20.133.32.17 comment="United States" list=
SafeCountries
add address=20.133.32.19-20.133.39.255 comment="United States" list=
SafeCountries
add address=20.133.41.0-20.138.1.255 comment="United States" list=
SafeCountries
add address=20.138.3.0-20.138.17.255 comment="United States" list=
SafeCountries
add address=20.138.19.0-20.139.34.255 comment="United States" list=
SafeCountries
add address=20.139.36.0-20.139.65.255 comment="United States" list=
SafeCountries
add address=20.139.68.0-20.139.228.255 comment="United States" list=
SafeCountries
add address=20.139.230.0-20.142.115.255 comment="United States" list=
SafeCountries
add address=20.142.117.0-20.142.119.255 comment="United States" list=
SafeCountries
add address=20.142.121.0-20.143.239.255 comment="United States" list=
SafeCountries
add address=20.143.241.0-22.50.88.191 comment="United States" list=
SafeCountries
add address=22.50.88.224-23.0.31.255 comment="United States" list=
SafeCountries
add address=23.0.48.0-23.0.160.255 comment="United States" list=SafeCountries
add address=23.0.162.0-23.0.173.255 comment="United States" list=
SafeCountries
add address=23.0.175.0-23.0.211.255 comment="United States" list=
SafeCountries
add address=23.0.216.0-23.0.227.255 comment="United States" list=
SafeCountries
add address=23.0.230.0-23.0.249.255 comment="United States" list=
SafeCountries
add address=23.0.252.0-23.1.3.255 comment="United States" list=SafeCountries
add address=23.1.8.0-23.1.35.255 comment="United States" list=SafeCountries
add address=23.1.40.0-23.1.63.255 comment="United States" list=SafeCountries
add address=23.1.80.0-23.1.237.255 comment="United States" list=SafeCountries
add address=23.1.240.0-23.1.251.255 comment="United States" list=
SafeCountries
add address=23.2.0.0-23.2.13.255 comment="United States" list=SafeCountries
add address=23.2.16.0/22 comment="United States" list=SafeCountries
add address=23.2.22.0/23 comment="United States" list=SafeCountries
add address=23.2.26.0-23.2.31.255 comment="United States" list=SafeCountries
add address=23.2.33.0-23.2.51.255 comment="United States" list=SafeCountries
add address=23.2.56.0-23.2.71.255 comment="United States" list=SafeCountries
add address=23.2.76.0-23.2.111.255 comment="United States" list=SafeCountries
add address=23.2.128.0-23.2.207.255 comment="United States" list=
SafeCountries
add address=23.2.240.0-23.3.2.255 comment="United States" list=SafeCountries
add address=23.3.4.0/23 comment="United States" list=SafeCountries
add address=23.3.8.0-23.3.14.255 comment="United States" list=SafeCountries
add address=23.3.16.0-23.3.63.255 comment="United States" list=SafeCountries
add address=23.3.68.0-23.3.89.255 comment="United States" list=SafeCountries
add address=23.3.92.0-23.3.109.255 comment="United States" list=SafeCountries
add address=23.3.112.0-23.3.143.255 comment="United States" list=
SafeCountries
add address=23.3.160.0-23.3.207.255 comment="United States" list=
SafeCountries
add address=23.3.240.0-23.5.95.255 comment="United States" list=SafeCountries
add address=23.5.112.0-23.5.159.255 comment="United States" list=
SafeCountries
add address=23.5.161.0/24 comment="United States" list=SafeCountries
add address=23.5.164.0-23.6.111.255 comment="United States" list=
SafeCountries
add address=23.6.160.0-23.7.191.255 comment="United States" list=
SafeCountries
add address=23.7.208.0-23.8.31.255 comment="United States" list=SafeCountries
add address=23.8.48.0-23.8.207.255 comment="United States" list=SafeCountries
add address=23.8.224.0/19 comment="United States" list=SafeCountries
add address=23.9.16.0-23.9.63.255 comment="United States" list=SafeCountries
add address=23.9.80.0-23.9.207.255 comment="United States" list=SafeCountries
add address=23.9.224.0-23.10.241.255 comment="United States" list=
SafeCountries
add address=23.10.248.0/23 comment="United States" list=SafeCountries
add address=23.10.253.0-23.11.63.255 comment="United States" list=
SafeCountries
add address=23.11.80.0-23.11.231.255 comment="United States" list=
SafeCountries
add address=23.11.233.0-23.11.255.255 comment="United States" list=
SafeCountries
add address=23.12.32.0-23.12.79.255 comment="United States" list=
SafeCountries
add address=23.12.112.0-23.13.31.255 comment="United States" list=
SafeCountries
add address=23.13.48.0-23.13.181.255 comment="United States" list=
SafeCountries
add address=23.13.184.0-23.14.89.255 comment="United States" list=
SafeCountries
add address=23.14.96.0-23.14.129.255 comment="United States" list=
SafeCountries
add address=23.14.132.0/22 comment="United States" list=SafeCountries
add address=23.14.140.0-23.14.191.255 comment="United States" list=
SafeCountries
add address=23.14.208.0-23.15.11.255 comment="United States" list=
SafeCountries
add address=23.15.14.0/24 comment="United States" list=SafeCountries
add address=23.15.16.0-23.15.63.255 comment="United States" list=
SafeCountries
add address=23.15.80.0-23.15.111.255 comment="United States" list=
SafeCountries
add address=23.15.128.0/22 comment="United States" list=SafeCountries
add address=23.15.134.0-23.15.175.255 comment="United States" list=
SafeCountries
add address=23.15.180.0-23.15.255.255 comment="United States" list=
SafeCountries
add address=23.19.0.0-23.29.191.255 comment="United States" list=
SafeCountries
add address=23.29.224.0-23.32.7.255 comment="United States" list=
SafeCountries
add address=23.32.12.0/23 comment="United States" list=SafeCountries
add address=23.32.22.0-23.32.27.255 comment="United States" list=
SafeCountries
add address=23.32.30.0-23.32.47.255 comment="United States" list=
SafeCountries
add address=23.32.90.0-23.32.95.255 comment="United States" list=
SafeCountries
add address=23.32.112.0-23.32.219.255 comment="United States" list=
SafeCountries
add address=23.32.224.0-23.32.241.255 comment="United States" list=
SafeCountries
add address=23.32.248.0/21 comment="United States" list=SafeCountries
add address=23.33.16.0-23.33.47.255 comment="United States" list=
SafeCountries
add address=23.33.52.0-23.33.63.255 comment="United States" list=
SafeCountries
add address=23.33.80.0-23.33.179.255 comment="United States" list=
SafeCountries
add address=23.33.184.0/22 comment="United States" list=SafeCountries
add address=23.33.192.0/20 comment="United States" list=SafeCountries
add address=23.33.244.0-23.34.175.255 comment="United States" list=
SafeCountries
add address=23.34.192.0-23.35.111.255 comment="United States" list=
SafeCountries
add address=23.35.128.0-23.35.207.255 comment="United States" list=
SafeCountries
add address=23.35.224.0-23.36.143.255 comment="United States" list=
SafeCountries
add address=23.36.192.0/20 comment="United States" list=SafeCountries
add address=23.37.0.0/19 comment="United States" list=SafeCountries
add address=23.37.64.0/19 comment="United States" list=SafeCountries
add address=23.37.112.0-23.37.159.255 comment="United States" list=
SafeCountries
add address=23.37.176.0-23.37.207.255 comment="United States" list=
SafeCountries
add address=23.37.224.0/20 comment="United States" list=SafeCountries
add address=23.38.102.0-23.38.119.255 comment="United States" list=
SafeCountries
add address=23.38.128.0-23.38.207.255 comment="United States" list=
SafeCountries
add address=23.38.224.0-23.39.63.255 comment="United States" list=
SafeCountries
add address=23.39.128.0/19 comment="United States" list=SafeCountries
add address=23.39.176.0/20 comment="United States" list=SafeCountries
add address=23.39.208.0-23.39.239.255 comment="United States" list=
SafeCountries
add address=23.40.16.0-23.40.63.255 comment="United States" list=
SafeCountries
add address=23.40.80.0-23.40.111.255 comment="United States" list=
SafeCountries
add address=23.40.128.0/19 comment="United States" list=SafeCountries
add address=23.40.176.0-23.40.207.255 comment="United States" list=
SafeCountries
add address=23.40.224.0-23.41.15.255 comment="United States" list=
SafeCountries
add address=23.41.32.0-23.42.15.255 comment="United States" list=
SafeCountries
add address=23.42.32.0-23.42.191.255 comment="United States" list=
SafeCountries
add address=23.42.208.0-23.43.15.255 comment="United States" list=
SafeCountries
add address=23.43.32.0/20 comment="United States" list=SafeCountries
add address=23.43.80.0-23.43.127.255 comment="United States" list=
SafeCountries
add address=23.43.144.0-23.44.207.255 comment="United States" list=
SafeCountries
add address=23.44.224.0-23.45.66.255 comment="United States" list=
SafeCountries
add address=23.45.68.0/22 comment="United States" list=SafeCountries
add address=23.45.76.0-23.45.95.255 comment="United States" list=
SafeCountries
add address=23.45.112.0/20 comment="United States" list=SafeCountries
add address=23.45.208.0-23.45.235.255 comment="United States" list=
SafeCountries
add address=23.45.240.0-23.46.13.255 comment="United States" list=
SafeCountries
add address=23.46.16.0/21 comment="United States" list=SafeCountries
add address=23.46.26.0/23 comment="United States" list=SafeCountries
add address=23.46.32.0-23.46.111.255 comment="United States" list=
SafeCountries
add address=23.46.128.0-23.48.87.255 comment="United States" list=
SafeCountries
add address=23.48.92.0-23.48.191.255 comment="United States" list=
SafeCountries
add address=23.48.220.0/22 comment="United States" list=SafeCountries
add address=23.48.240.0-23.49.11.255 comment="United States" list=
SafeCountries
add address=23.49.16.0-23.49.191.255 comment="United States" list=
SafeCountries
add address=23.49.208.0-23.50.95.255 comment="United States" list=
SafeCountries
add address=23.50.112.0/20 comment="United States" list=SafeCountries
add address=23.50.192.0/20 comment="United States" list=SafeCountries
add address=23.50.224.0-23.51.95.255 comment="United States" list=
SafeCountries
add address=23.51.128.0/19 comment="United States" list=SafeCountries
add address=23.52.32.0/20 comment="United States" list=SafeCountries
add address=23.52.64.0-23.52.175.255 comment="United States" list=
SafeCountries
add address=23.52.224.0/19 comment="United States" list=SafeCountries
add address=23.53.64.0-23.53.159.255 comment="United States" list=
SafeCountries
add address=23.53.192.0/20 comment="United States" list=SafeCountries
add address=23.54.32.0-23.54.79.255 comment="United States" list=
SafeCountries
add address=23.54.144.0-23.54.255.255 comment="United States" list=
SafeCountries
add address=23.55.16.0-23.55.111.255 comment="United States" list=
SafeCountries
add address=23.55.128.0/21 comment="United States" list=SafeCountries
add address=23.55.160.0-23.55.223.255 comment="United States" list=
SafeCountries
add address=23.55.240.0-23.56.209.255 comment="United States" list=
SafeCountries
add address=23.56.214.0-23.56.219.255 comment="United States" list=
SafeCountries
add address=23.56.224.0/19 comment="United States" list=SafeCountries
add address=23.57.16.0/20 comment="United States" list=SafeCountries
add address=23.57.68.0-23.57.79.255 comment="United States" list=
SafeCountries
add address=23.57.116.0-23.58.93.255 comment="United States" list=
SafeCountries
add address=23.58.96.0-23.58.207.255 comment="United States" list=
SafeCountries
add address=23.58.224.0-23.59.47.255 comment="United States" list=
SafeCountries
add address=23.59.90.0-23.59.95.255 comment="United States" list=
SafeCountries
add address=23.59.128.0-23.60.15.255 comment="United States" list=
SafeCountries
add address=23.60.68.0/24 comment="United States" list=SafeCountries
add address=23.60.72.0-23.60.207.255 comment="United States" list=
SafeCountries
add address=23.60.224.0-23.61.111.255 comment="United States" list=
SafeCountries
add address=23.61.116.0-23.61.195.255 comment="United States" list=
SafeCountries
add address=23.61.198.0/24 comment="United States" list=SafeCountries
add address=23.61.202.0-23.61.207.255 comment="United States" list=
SafeCountries
add address=23.61.244.0/22 comment="United States" list=SafeCountries
add address=23.61.249.0-23.61.250.255 comment="United States" list=
SafeCountries
add address=23.61.252.0/23 comment="United States" list=SafeCountries
add address=23.62.4.0/22 comment="United States" list=SafeCountries
add address=23.62.10.0/23 comment="United States" list=SafeCountries
add address=23.62.14.0-23.62.52.255 comment="United States" list=
SafeCountries
add address=23.62.54.0-23.62.60.255 comment="United States" list=
SafeCountries
add address=23.62.62.0-23.62.97.255 comment="United States" list=
SafeCountries
add address=23.62.101.0/24 comment="United States" list=SafeCountries
add address=23.62.106.0-23.62.111.255 comment="United States" list=
SafeCountries
add address=23.62.148.0/23 comment="United States" list=SafeCountries
add address=23.62.152.0/22 comment="United States" list=SafeCountries
add address=23.62.157.0-23.62.191.255 comment="United States" list=
SafeCountries
add address=23.62.208.0-23.62.236.255 comment="United States" list=
SafeCountries
add address=23.62.238.0-23.63.27.255 comment="United States" list=
SafeCountries
add address=23.63.32.0/19 comment="United States" list=SafeCountries
add address=23.63.102.0-23.63.111.255 comment="United States" list=
SafeCountries
add address=23.63.150.0-23.63.229.255 comment="United States" list=
SafeCountries
add address=23.63.240.0-23.64.14.255 comment="United States" list=
SafeCountries
add address=23.64.16.0-23.64.59.255 comment="United States" list=
SafeCountries
add address=23.64.64.0-23.64.141.255 comment="United States" list=
SafeCountries
add address=23.64.144.0-23.64.207.255 comment="United States" list=
SafeCountries
add address=23.64.240.0-23.65.21.255 comment="United States" list=
SafeCountries
add address=23.65.23.0-23.65.28.255 comment="United States" list=
SafeCountries
add address=23.65.48.0-23.65.115.255 comment="United States" list=
SafeCountries
add address=23.65.120.0-23.65.179.255 comment="United States" list=
SafeCountries
add address=23.65.182.0-23.65.191.255 comment="United States" list=
SafeCountries
add address=23.65.224.0-23.66.15.255 comment="United States" list=
SafeCountries
add address=23.66.32.0-23.66.233.255 comment="United States" list=
SafeCountries
add address=23.67.16.0-23.67.38.255 comment="United States" list=
SafeCountries
add address=23.67.41.0/24 comment="United States" list=SafeCountries
add address=23.67.44.0-23.67.46.255 comment="United States" list=
SafeCountries
add address=23.67.48.0-23.67.57.255 comment="United States" list=
SafeCountries
add address=23.67.59.0-23.67.69.255 comment="United States" list=
SafeCountries
add address=23.67.72.0-23.67.77.255 comment="United States" list=
SafeCountries
add address=23.67.112.0/20 comment="United States" list=SafeCountries
add address=23.67.148.0-23.67.254.255 comment="United States" list=
SafeCountries
add address=23.68.0.0-23.73.134.255 comment="United States" list=
SafeCountries
add address=23.73.136.0-23.74.23.255 comment="United States" list=
SafeCountries
add address=23.74.25.0/24 comment="United States" list=SafeCountries
add address=23.74.28.0/22 comment="United States" list=SafeCountries
add address=23.74.48.0-23.74.79.255 comment="United States" list=
SafeCountries
add address=23.74.128.0-23.74.163.255 comment="United States" list=
SafeCountries
add address=23.74.168.0/21 comment="United States" list=SafeCountries
add address=23.74.208.0-23.76.155.255 comment="United States" list=
SafeCountries
add address=23.76.158.0-23.77.83.255 comment="United States" list=
SafeCountries
add address=23.77.88.0/21 comment="United States" list=SafeCountries
add address=23.77.128.0-23.77.194.255 comment="United States" list=
SafeCountries
add address=23.77.196.0/23 comment="United States" list=SafeCountries
add address=23.77.202.0-23.77.247.255 comment="United States" list=
SafeCountries
add address=23.78.0.0/19 comment="United States" list=SafeCountries
add address=23.78.128.0-23.79.111.255 comment="United States" list=
SafeCountries
add address=23.79.128.0-23.79.223.255 comment="United States" list=
SafeCountries
add address=23.79.228.0/24 comment="United States" list=SafeCountries
add address=23.79.231.0/24 comment="United States" list=SafeCountries
add address=23.79.235.0-23.79.236.255 comment="United States" list=
SafeCountries
add address=23.79.240.0-23.79.246.255 comment="United States" list=
SafeCountries
add address=23.79.248.0-23.91.127.255 comment="United States" list=
SafeCountries
add address=23.91.192.0/19 comment="United States" list=SafeCountries
add address=23.92.0.0/17 comment="United States" list=SafeCountries
add address=23.92.160.0-23.92.220.111 comment="United States" list=
SafeCountries
add address=23.92.220.120-23.94.76.135 comment="United States" list=
SafeCountries
add address=23.94.76.144-23.95.50.207 comment="United States" list=
SafeCountries
add address=23.95.50.216-23.97.47.255 comment="United States" list=
SafeCountries
add address=23.98.0.0/19 comment="United States" list=SafeCountries
add address=23.98.45.0/24 comment="United States" list=SafeCountries
add address=23.98.47.0-23.98.55.255 comment="United States" list=
SafeCountries
add address=23.98.58.0-23.98.63.255 comment="United States" list=
SafeCountries
add address=23.98.128.0-23.99.95.255 comment="United States" list=
SafeCountries
add address=23.99.128.0/17 comment="United States" list=SafeCountries
add address=23.100.16.0-23.100.47.255 comment="United States" list=
SafeCountries
add address=23.100.64.0-23.100.87.255 comment="United States" list=
SafeCountries
add address=23.100.120.0/21 comment="United States" list=SafeCountries
add address=23.100.192.0/18 comment="United States" list=SafeCountries
add address=23.101.32.0/20 comment="United States" list=SafeCountries
add address=23.101.80.0-23.101.207.255 comment="United States" list=
SafeCountries
add address=23.102.96.0-23.102.199.255 comment="United States" list=
SafeCountries
add address=23.102.202.0-23.102.223.255 comment="United States" list=
SafeCountries
add address=23.103.0.0/17 comment="United States" list=SafeCountries
add address=23.103.129.0/25 comment="United States" list=SafeCountries
add address=23.103.131.0-23.103.131.111 comment="United States" list=
SafeCountries
add address=23.103.131.144-23.103.159.255 comment="United States" list=
SafeCountries
add address=23.103.176.0-23.103.182.127 comment="United States" list=
SafeCountries
add address=23.103.183.64-23.103.189.31 comment="United States" list=
SafeCountries
add address=23.103.189.64-23.103.189.191 comment="United States" list=
SafeCountries
add address=23.103.190.64/27 comment="United States" list=SafeCountries
add address=23.103.190.128/26 comment="United States" list=SafeCountries
add address=23.103.190.208-23.103.227.191 comment="United States" list=
SafeCountries
add address=23.103.230.128-23.103.236.15 comment="United States" list=
SafeCountries
add address=23.103.236.64/28 comment="United States" list=SafeCountries
add address=23.103.236.128/28 comment="United States" list=SafeCountries
add address=23.103.236.192/28 comment="United States" list=SafeCountries
add address=23.103.237.0/28 comment="United States" list=SafeCountries
add address=23.103.237.64/28 comment="United States" list=SafeCountries
add address=23.103.237.128/28 comment="United States" list=SafeCountries
add address=23.103.237.192/28 comment="United States" list=SafeCountries
add address=23.103.238.0/28 comment="United States" list=SafeCountries
add address=23.103.238.64/28 comment="United States" list=SafeCountries
add address=23.103.238.128-23.103.240.15 comment="United States" list=
SafeCountries
add address=23.103.240.32-23.103.240.79 comment="United States" list=
SafeCountries
add address=23.103.240.96-23.103.240.143 comment="United States" list=
SafeCountries
add address=23.103.240.160-23.103.240.207 comment="United States" list=
SafeCountries
add address=23.103.240.224-23.103.241.15 comment="United States" list=
SafeCountries
add address=23.103.241.32-23.103.246.143 comment="United States" list=
SafeCountries
add address=23.103.246.192/28 comment="United States" list=SafeCountries
add address=23.103.247.0/28 comment="United States" list=SafeCountries
add address=23.103.247.64/28 comment="United States" list=SafeCountries
add address=23.103.247.128/28 comment="United States" list=SafeCountries
add address=23.103.247.192/28 comment="United States" list=SafeCountries
add address=23.103.248.0/28 comment="United States" list=SafeCountries
add address=23.103.248.64/28 comment="United States" list=SafeCountries
add address=23.103.248.128/28 comment="United States" list=SafeCountries
add address=23.103.248.192/28 comment="United States" list=SafeCountries
add address=23.103.249.0/26 comment="United States" list=SafeCountries
add address=23.103.249.128/27 comment="United States" list=SafeCountries
add address=23.103.249.192-23.103.250.255 comment="United States" list=
SafeCountries
add address=23.103.252.192/26 comment="United States" list=SafeCountries
add address=23.103.253.128-23.103.254.127 comment="United States" list=
SafeCountries
add address=23.103.255.0-23.105.31.255 comment="United States" list=
SafeCountries
add address=23.105.33.0-23.127.255.255 comment="United States" list=
SafeCountries
add address=23.130.0.0/24 comment="United States" list=SafeCountries
add address=23.132.0.0-23.139.255.255 comment="United States" list=
SafeCountries
add address=23.144.0.0-23.148.0.255 comment="United States" list=
SafeCountries
add address=23.152.0.0/24 comment="United States" list=SafeCountries
add address=23.156.0.0-23.164.0.255 comment="United States" list=
SafeCountries
add address=23.168.0.0/13 comment="United States" list=SafeCountries
add address=23.180.0.0/24 comment="United States" list=SafeCountries
add address=23.184.0.0/24 comment="United States" list=SafeCountries
add address=23.192.0.0-23.192.161.255 comment="United States" list=
SafeCountries
add address=23.192.164.0-23.194.107.255 comment="United States" list=
SafeCountries
add address=23.194.112.0-23.194.175.255 comment="United States" list=
SafeCountries
add address=23.194.212.0/23 comment="United States" list=SafeCountries
add address=23.194.216.0/21 comment="United States" list=SafeCountries
add address=23.195.4.0/22 comment="United States" list=SafeCountries
add address=23.195.12.0-23.195.47.255 comment="United States" list=
SafeCountries
add address=23.195.80.0-23.195.111.255 comment="United States" list=
SafeCountries
add address=23.195.144.0-23.196.229.255 comment="United States" list=
SafeCountries
add address=23.196.236.0/22 comment="United States" list=SafeCountries
add address=23.197.16.0-23.197.61.255 comment="United States" list=
SafeCountries
add address=23.197.64.0-23.197.247.255 comment="United States" list=
SafeCountries
add address=23.198.0.0/20 comment="United States" list=SafeCountries
add address=23.198.98.0-23.199.207.255 comment="United States" list=
SafeCountries
add address=23.199.224.0-23.200.83.255 comment="United States" list=
SafeCountries
add address=23.200.90.0-23.200.95.255 comment="United States" list=
SafeCountries
add address=23.200.112.0-23.200.131.255 comment="United States" list=
SafeCountries
add address=23.200.136.0/21 comment="United States" list=SafeCountries
add address=23.200.176.0/20 comment="United States" list=SafeCountries
add address=23.200.208.0-23.201.107.255 comment="United States" list=
SafeCountries
add address=23.201.110.0-23.201.151.255 comment="United States" list=
SafeCountries
add address=23.201.156.0-23.201.191.255 comment="United States" list=
SafeCountries
add address=23.201.224.0-23.202.44.255 comment="United States" list=
SafeCountries
add address=23.202.46.0-23.202.115.255 comment="United States" list=
SafeCountries
add address=23.202.122.0-23.202.127.255 comment="United States" list=
SafeCountries
add address=23.202.176.0-23.205.79.255 comment="United States" list=
SafeCountries
add address=23.205.112.0/22 comment="United States" list=SafeCountries
add address=23.205.118.0-23.205.167.255 comment="United States" list=
SafeCountries
add address=23.205.172.0/23 comment="United States" list=SafeCountries
add address=23.205.176.0-23.205.211.255 comment="United States" list=
SafeCountries
add address=23.205.216.0/22 comment="United States" list=SafeCountries
add address=23.206.118.0-23.207.63.255 comment="United States" list=
SafeCountries
add address=23.207.96.0-23.209.73.255 comment="United States" list=
SafeCountries
add address=23.209.80.0-23.209.111.255 comment="United States" list=
SafeCountries
add address=23.209.182.0/24 comment="United States" list=SafeCountries
add address=23.209.184.0-23.209.189.255 comment="United States" list=
SafeCountries
add address=23.210.4.0-23.211.60.255 comment="United States" list=
SafeCountries
add address=23.211.62.0-23.211.131.255 comment="United States" list=
SafeCountries
add address=23.211.134.0-23.212.107.255 comment="United States" list=
SafeCountries
add address=23.212.110.0-23.212.179.255 comment="United States" list=
SafeCountries
add address=23.212.186.0-23.212.191.255 comment="United States" list=
SafeCountries
add address=23.212.240.0-23.213.139.255 comment="United States" list=
SafeCountries
add address=23.213.144.0-23.214.31.255 comment="United States" list=
SafeCountries
add address=23.214.74.0-23.214.79.255 comment="United States" list=
SafeCountries
add address=23.214.224.0-23.215.15.255 comment="United States" list=
SafeCountries
add address=23.215.54.0-23.215.59.255 comment="United States" list=
SafeCountries
add address=23.215.62.0-23.215.95.255 comment="United States" list=
SafeCountries
add address=23.215.134.0-23.215.214.255 comment="United States" list=
SafeCountries
add address=23.215.216.0-23.216.5.255 comment="United States" list=
SafeCountries
add address=23.216.8.0/22 comment="United States" list=SafeCountries
add address=23.216.14.0-23.216.95.255 comment="United States" list=
SafeCountries
add address=23.216.128.0-23.217.129.255 comment="United States" list=
SafeCountries
add address=23.217.132.0/23 comment="United States" list=SafeCountries
add address=23.217.136.0/21 comment="United States" list=SafeCountries
add address=23.217.180.0/22 comment="United States" list=SafeCountries
add address=23.217.188.0-23.217.223.255 comment="United States" list=
SafeCountries
add address=23.218.0.0-23.218.149.255 comment="United States" list=
SafeCountries
add address=23.218.156.0/22 comment="United States" list=SafeCountries
add address=23.218.192.0-23.219.47.255 comment="United States" list=
SafeCountries
add address=23.219.86.0-23.219.165.255 comment="United States" list=
SafeCountries
add address=23.219.168.0-23.219.215.255 comment="United States" list=
SafeCountries
add address=23.219.220.0-23.219.255.255 comment="United States" list=
SafeCountries
add address=23.220.32.0-23.221.159.255 comment="United States" list=
SafeCountries
add address=23.222.20.0/22 comment="United States" list=SafeCountries
add address=23.222.68.0-23.222.223.255 comment="United States" list=
SafeCountries
add address=23.223.144.0-23.223.207.255 comment="United States" list=
SafeCountries
add address=23.223.240.0-23.227.31.255 comment="United States" list=
SafeCountries
add address=23.227.64.0-23.227.207.255 comment="United States" list=
SafeCountries
add address=23.227.224.0-23.229.2.111 comment="United States" list=
SafeCountries
add address=23.229.2.128/25 comment="United States" list=SafeCountries
add address=23.229.5.0-23.229.12.255 comment="United States" list=
SafeCountries
add address=23.229.13.16-23.229.14.255 comment="United States" list=
SafeCountries
add address=23.229.16.0-23.229.18.255 comment="United States" list=
SafeCountries
add address=23.229.20.0-23.229.22.127 comment="United States" list=
SafeCountries
add address=23.229.22.144-23.229.26.159 comment="United States" list=
SafeCountries
add address=23.229.26.176-23.229.29.127 comment="United States" list=
SafeCountries
add address=23.229.29.144-23.229.30.79 comment="United States" list=
SafeCountries
add address=23.229.30.96-23.229.34.255 comment="United States" list=
SafeCountries
add address=23.229.35.16-23.229.36.127 comment="United States" list=
SafeCountries
add address=23.229.36.144-23.229.46.175 comment="United States" list=
SafeCountries
add address=23.229.46.192-23.229.106.255 comment="United States" list=
SafeCountries
add address=23.229.109.0/24 comment="Costa Rica" list=SafeCountries
add address=23.229.110.0/24 comment="United States" list=SafeCountries
add address=23.229.111.128/26 comment="United States" list=SafeCountries
add address=23.229.112.0-23.232.132.255 comment="United States" list=
SafeCountries
add address=23.232.134.0-23.232.138.255 comment="United States" list=
SafeCountries
add address=23.232.140.0-23.232.174.255 comment="United States" list=
SafeCountries
add address=23.232.176.0-23.232.192.255 comment="United States" list=
SafeCountries
add address=23.232.194.0/23 comment="United States" list=SafeCountries
add address=23.232.197.0-23.232.221.255 comment="United States" list=
SafeCountries
add address=23.232.224.0-23.232.243.255 comment="United States" list=
SafeCountries
add address=23.234.0.0-23.234.81.247 comment="United States" list=
SafeCountries
add address=23.234.82.0-23.234.97.223 comment="United States" list=
SafeCountries
add address=23.234.98.0-23.235.44.255 comment="United States" list=
SafeCountries
add address=23.235.46.0-23.235.63.255 comment="United States" list=
SafeCountries
add address=23.235.80.0-23.235.255.255 comment="United States" list=
SafeCountries
add address=23.236.16.0-23.236.130.255 comment="United States" list=
SafeCountries
add address=23.236.131.16-23.236.139.255 comment="United States" list=
SafeCountries
add address=23.236.141.0-23.236.148.127 comment="United States" list=
SafeCountries
add address=23.236.148.144-23.236.167.127 comment="United States" list=
SafeCountries
add address=23.236.167.144-23.236.171.127 comment="United States" list=
SafeCountries
add address=23.236.171.144-23.236.171.255 comment="United States" list=
SafeCountries
add address=23.236.175.0-23.236.210.127 comment="United States" list=
SafeCountries
add address=23.236.210.144-23.236.214.79 comment="United States" list=
SafeCountries
add address=23.236.214.96-23.236.221.127 comment="United States" list=
SafeCountries
add address=23.236.221.144-23.236.223.175 comment="United States" list=
SafeCountries
add address=23.236.223.192-23.236.227.127 comment="United States" list=
SafeCountries
add address=23.236.227.144-23.236.232.223 comment="United States" list=
SafeCountries
add address=23.236.232.240-23.239.31.255 comment="United States" list=
SafeCountries
add address=23.239.64.0-23.247.129.255 comment="United States" list=
SafeCountries
add address=23.247.131.0-23.247.132.255 comment="United States" list=
SafeCountries
add address=23.247.139.0-23.247.141.255 comment="United States" list=
SafeCountries
add address=23.247.143.0-23.247.162.255 comment="United States" list=
SafeCountries
add address=23.247.164.0-23.247.171.255 comment="United States" list=
SafeCountries
add address=23.247.173.0-23.247.231.255 comment="United States" list=
SafeCountries
add address=23.247.233.0-23.247.237.255 comment="United States" list=
SafeCountries
add address=23.247.239.0-23.247.255.255 comment="United States" list=
SafeCountries
add address=23.248.160.0-23.249.111.255 comment="United States" list=
SafeCountries
add address=23.249.129.0/24 comment="United States" list=SafeCountries
add address=23.249.131.0-23.249.143.255 comment="United States" list=
SafeCountries
add address=23.249.160.0-23.249.175.69 comment="United States" list=
SafeCountries
add address=23.249.175.71-23.249.175.241 comment="United States" list=
SafeCountries
add address=23.249.175.243-23.249.191.255 comment="United States" list=
SafeCountries
add address=23.249.208.0-23.250.3.127 comment="United States" list=
SafeCountries
add address=23.250.3.144-23.250.16.47 comment="United States" list=
SafeCountries
add address=23.250.16.64-23.250.77.255 comment="United States" list=
SafeCountries
add address=23.250.79.0-23.250.106.159 comment="United States" list=
SafeCountries
add address=23.250.106.176-23.251.159.255 comment="United States" list=
SafeCountries
add address=23.251.192.0-23.252.31.255 comment="United States" list=
SafeCountries
add address=23.252.48.0-23.252.95.255 comment="United States" list=
SafeCountries
add address=23.252.100.0/23 comment="United States" list=SafeCountries
add address=23.252.104.0-23.254.2.95 comment="United States" list=
SafeCountries
add address=23.254.2.112-23.254.4.95 comment="United States" list=
SafeCountries
add address=23.254.4.112-23.254.6.95 comment="United States" list=
SafeCountries
add address=23.254.6.112-23.254.17.191 comment="United States" list=
SafeCountries
add address=23.254.17.208-23.254.20.191 comment="United States" list=
SafeCountries
add address=23.254.20.208-23.254.45.191 comment="United States" list=
SafeCountries
add address=23.254.45.208-23.254.46.63 comment="United States" list=
SafeCountries
add address=23.254.46.80-23.254.47.63 comment="United States" list=
SafeCountries
add address=23.254.47.80-23.254.55.127 comment="United States" list=
SafeCountries
add address=23.254.55.144-23.254.56.63 comment="United States" list=
SafeCountries
add address=23.254.56.80-23.254.64.127 comment="United States" list=
SafeCountries
add address=23.254.64.144-23.254.65.63 comment="United States" list=
SafeCountries
add address=23.254.65.80-23.254.82.63 comment="United States" list=
SafeCountries
add address=23.254.82.80-23.254.83.63 comment="United States" list=
SafeCountries
add address=23.254.83.80-23.254.108.255 comment="United States" list=
SafeCountries
add address=23.254.112.0-23.255.103.71 comment="United States" list=
SafeCountries
add address=23.255.103.80-23.255.104.31 comment="United States" list=
SafeCountries
add address=23.255.104.40-23.255.107.15 comment="United States" list=
SafeCountries
add address=23.255.107.24-23.255.108.119 comment="United States" list=
SafeCountries
add address=23.255.108.128-23.255.255.255 comment="United States" list=
SafeCountries
add address=24.0.0.1-24.35.255.255 comment="United States" list=SafeCountries
add address=24.38.0.0-24.38.143.255 comment="United States" list=
SafeCountries
add address=24.38.160.0-24.41.95.255 comment="United States" list=
SafeCountries
add address=24.42.64.0-24.47.255.255 comment="United States" list=
SafeCountries
add address=24.48.128.0-24.48.175.255 comment="United States" list=
SafeCountries
add address=24.49.0.0-24.49.223.255 comment="United States" list=
SafeCountries
add address=24.50.0.0/19 comment="United States" list=SafeCountries
add address=24.50.128.0/19 comment="United States" list=SafeCountries
add address=24.51.32.0/19 comment="United States" list=SafeCountries
add address=24.51.128.0-24.51.223.255 comment="United States" list=
SafeCountries
add address=24.52.0.0-24.52.191.255 comment="United States" list=
SafeCountries
add address=24.53.64.0/20 comment="United States" list=SafeCountries
add address=24.53.128.0/18 comment="United States" list=SafeCountries
add address=24.54.96.0-24.54.191.255 comment="United States" list=
SafeCountries
add address=24.55.0.0/18 comment="United States" list=SafeCountries
add address=24.55.128.0/19 comment="United States" list=SafeCountries
add address=24.56.0.0/16 comment="United States" list=SafeCountries
add address=24.58.0.0-24.63.255.255 comment="United States" list=
SafeCountries
add address=24.72.144.0-24.75.175.255 comment="United States" list=
SafeCountries
add address=24.75.192.0/18 comment="United States" list=SafeCountries
add address=24.88.0.0-24.89.63.255 comment="United States" list=SafeCountries
add address=24.89.128.0/18 comment="United States" list=SafeCountries
add address=24.90.0.0-24.92.143.255 comment="United States" list=
SafeCountries
add address=24.92.160.0-24.100.191.255 comment="United States" list=
SafeCountries
add address=24.101.0.0/16 comment="United States" list=SafeCountries
add address=24.102.64.0-24.104.159.255 comment="United States" list=
SafeCountries
add address=24.104.192.0-24.105.63.255 comment="United States" list=
SafeCountries
add address=24.105.128.0-24.107.255.255 comment="United States" list=
SafeCountries
add address=24.110.0.0-24.113.255.255 comment="United States" list=
SafeCountries
add address=24.115.0.0-24.121.255.255 comment="United States" list=
SafeCountries
add address=24.123.0.0-24.129.191.255 comment="United States" list=
SafeCountries
add address=24.129.208.0/20 comment="United States" list=SafeCountries
add address=24.129.240.0-24.131.255.255 comment="United States" list=
SafeCountries
add address=24.136.0.0-24.137.31.255 comment="United States" list=
SafeCountries
add address=24.137.128.0/18 comment="United States" list=SafeCountries
add address=24.139.32.0/19 comment="United States" list=SafeCountries
add address=24.140.0.0-24.140.223.255 comment="United States" list=
SafeCountries
add address=24.142.64.0/20 comment="United States" list=SafeCountries
add address=24.142.96.0-24.142.114.255 comment="United States" list=
SafeCountries
add address=24.142.117.0-24.143.127.255 comment="United States" list=
SafeCountries
add address=24.143.192.0-24.145.255.255 comment="United States" list=
SafeCountries
add address=24.146.128.0-24.149.255.255 comment="United States" list=
SafeCountries
add address=24.151.0.0/16 comment="United States" list=SafeCountries
add address=24.152.128.0/17 comment="United States" list=SafeCountries
add address=24.153.32.0-24.153.95.255 comment="United States" list=
SafeCountries
add address=24.153.112.0-24.156.127.255 comment="United States" list=
SafeCountries
add address=24.157.0.0/20 comment="United States" list=SafeCountries
add address=24.157.32.0/19 comment="United States" list=SafeCountries
add address=24.158.0.0-24.171.191.255 comment="United States" list=
SafeCountries
add address=24.172.0.0-24.199.255.255 comment="United States" list=
SafeCountries
add address=24.204.0.0-24.204.143.255 comment="United States" list=
SafeCountries
add address=24.205.0.0/16 comment="United States" list=SafeCountries
add address=24.206.32.0-24.206.255.255 comment="United States" list=
SafeCountries
add address=24.207.128.0-24.211.255.255 comment="United States" list=
SafeCountries
add address=24.213.0.0/18 comment="United States" list=SafeCountries
add address=24.213.96.0-24.214.255.255 comment="United States" list=
SafeCountries
add address=24.215.128.0-24.221.255.255 comment="United States" list=
SafeCountries
add address=24.223.0.0-24.224.127.255 comment="United States" list=
SafeCountries
add address=24.225.0.0/17 comment="United States" list=SafeCountries
add address=24.227.32.0-24.229.255.255 comment="United States" list=
SafeCountries
add address=24.230.32.0-24.230.191.255 comment="United States" list=
SafeCountries
add address=24.231.16.0/20 comment="United States" list=SafeCountries
add address=24.231.112.0-24.231.255.255 comment="United States" list=
SafeCountries
add address=24.233.0.0-24.235.23.255 comment="United States" list=
SafeCountries
add address=24.235.64.0/19 comment="United States" list=SafeCountries
add address=24.236.0.0-24.238.255.255 comment="United States" list=
SafeCountries
add address=24.239.16.0-24.243.255.255 comment="United States" list=
SafeCountries
add address=24.244.96.0/20 comment="United States" list=SafeCountries
add address=24.245.0.0-24.245.223.255 comment="United States" list=
SafeCountries
add address=24.245.240.0/20 comment="United States" list=SafeCountries
add address=24.246.96.0-24.255.255.255 comment="United States" list=
SafeCountries
add address=26.0.0.0/8 comment="United States" list=SafeCountries
add address=27.0.16.0/22 comment="United States" list=SafeCountries
add address=27.0.21.0/24 comment="United States" list=SafeCountries
add address=27.0.23.0/24 comment="United States" list=SafeCountries
add address=27.0.28.0/24 comment="United States" list=SafeCountries
add address=27.0.30.0/23 comment="United States" list=SafeCountries
add address=27.111.12.0/24 comment="United States" list=SafeCountries
add address=27.126.204.0-27.126.219.255 comment="United States" list=
SafeCountries
add address=27.126.232.0-27.126.234.255 comment="United States" list=
SafeCountries
add address=28.0.0.0-30.255.255.255 comment="United States" list=
SafeCountries
add address=31.3.157.0/24 comment="United States" list=SafeCountries
add address=31.13.69.80 comment="United States" list=SafeCountries
add address=31.13.70.0/24 comment="United States" list=SafeCountries
add address=31.13.76.0/23 comment="United States" list=SafeCountries
add address=31.14.71.0/24 comment="United States" list=SafeCountries
add address=31.130.224.0/20 comment="United States" list=SafeCountries
add address=31.131.27.0-31.131.31.255 comment="United States" list=
SafeCountries
add address=31.133.128.0/18 comment="United States" list=SafeCountries
add address=31.170.160.0/22 comment="United States" list=SafeCountries
add address=31.170.166.0/23 comment="United States" list=SafeCountries
add address=31.171.134.0/23 comment="United States" list=SafeCountries
add address=31.186.236.160/28 comment="United States" list=SafeCountries
add address=31.187.65.0/24 comment="United States" list=SafeCountries
add address=31.187.72.0/22 comment="United States" list=SafeCountries
add address=31.214.78.0/24 comment="United States" list=SafeCountries
add address=31.220.8.0/22 comment="United States" list=SafeCountries
add address=31.220.17.0-31.220.19.255 comment="United States" list=
SafeCountries
add address=31.220.21.0-31.220.23.255 comment="United States" list=
SafeCountries
add address=31.220.28.0/24 comment="United States" list=SafeCountries
add address=31.220.32.0/21 comment="United States" list=SafeCountries
add address=31.220.46.0-31.220.71.255 comment="United States" list=
SafeCountries
add address=31.220.104.0/23 comment="United States" list=SafeCountries
add address=31.220.107.0-31.220.111.255 comment="United States" list=
SafeCountries
add address=32.0.0.0-32.41.255.255 comment="United States" list=SafeCountries
add address=32.42.48.0-32.42.127.255 comment="United States" list=
SafeCountries
add address=32.42.192.0-32.58.207.255 comment="United States" list=
SafeCountries
add address=32.58.224.0/21 comment="United States" list=SafeCountries
add address=32.60.0.0/19 comment="United States" list=SafeCountries
add address=32.60.64.0-32.60.69.223 comment="United States" list=
SafeCountries
add address=32.60.69.240-32.60.87.3 comment="United States" list=
SafeCountries
add address=32.60.87.5-32.60.91.15 comment="United States" list=SafeCountries
add address=32.60.91.32-32.60.115.63 comment="United States" list=
SafeCountries
add address=32.60.115.80-32.104.15.255 comment="United States" list=
SafeCountries
add address=32.104.17.0-32.106.14.255 comment="United States" list=
SafeCountries
add address=32.106.16.0-32.106.49.255 comment="United States" list=
SafeCountries
add address=32.106.51.0-32.106.105.255 comment="United States" list=
SafeCountries
add address=32.106.107.0-32.106.125.255 comment="United States" list=
SafeCountries
add address=32.106.127.0/24 comment="United States" list=SafeCountries
add address=32.106.131.0-32.106.147.255 comment="United States" list=
SafeCountries
add address=32.106.149.0-32.106.155.255 comment="United States" list=
SafeCountries
add address=32.106.157.0-32.106.164.255 comment="United States" list=
SafeCountries
add address=32.106.167.0-32.106.181.255 comment="United States" list=
SafeCountries
add address=32.106.183.0-32.106.185.255 comment="United States" list=
SafeCountries
add address=32.106.187.0-32.106.190.255 comment="United States" list=
SafeCountries
add address=32.106.192.0-32.106.213.255 comment="United States" list=
SafeCountries
add address=32.106.216.0-32.115.114.35 comment="United States" list=
SafeCountries
add address=32.115.114.40-34.252.138.255 comment="United States" list=
SafeCountries
add address=34.252.140.0-34.253.2.255 comment="United States" list=
SafeCountries
add address=34.253.4.0-35.255.255.255 comment="United States" list=
SafeCountries
add address=36.255.212.0/22 comment="United States" list=SafeCountries
add address=37.0.113.0-37.0.115.255 comment="United States" list=
SafeCountries
add address=37.1.208.0/21 comment="United States" list=SafeCountries
add address=37.9.44.0/23 comment="United States" list=SafeCountries
add address=37.10.24.0-37.10.25.0 comment="United States" list=SafeCountries
add address=37.16.70.80/28 comment="United States" list=SafeCountries
add address=37.18.176.0/21 comment="United States" list=SafeCountries
add address=37.18.192.0/21 comment="United States" list=SafeCountries
add address=37.35.105.196/30 comment="United States" list=SafeCountries
add address=37.35.105.204/31 comment="Costa Rica" list=SafeCountries
add address=37.39.44.0/24 comment="United States" list=SafeCountries
add address=37.46.115.0-37.46.117.255 comment="United States" list=
SafeCountries
add address=37.46.196.0/23 comment="United States" list=SafeCountries
add address=37.60.224.0-37.60.230.150 comment="United States" list=
SafeCountries
add address=37.60.230.152-37.60.238.156 comment="United States" list=
SafeCountries
add address=37.60.238.158-37.60.238.161 comment="United States" list=
SafeCountries
add address=37.60.238.163-37.60.255.255 comment="United States" list=
SafeCountries
add address=37.61.224.0/22 comment="United States" list=SafeCountries
add address=37.72.169.0/24 comment="United States" list=SafeCountries
add address=37.72.189.0-37.72.190.255 comment="United States" list=
SafeCountries
add address=37.98.239.100 comment="United States" list=SafeCountries
add address=37.123.208.0/21 comment="United States" list=SafeCountries
add address=37.140.232.0/23 comment="United States" list=SafeCountries
add address=37.140.236.0-37.140.238.255 comment="United States" list=
SafeCountries
add address=37.140.239.16-37.140.239.255 comment="United States" list=
SafeCountries
add address=37.152.61.0-37.152.63.255 comment="United States" list=
SafeCountries
add address=37.153.143.0/24 comment="United States" list=SafeCountries
add address=37.207.102.66 comment="United States" list=SafeCountries
add address=37.207.102.71 comment="United States" list=SafeCountries
add address=37.221.174.0/23 comment="United States" list=SafeCountries
add address=37.228.104.0/21 comment="United States" list=SafeCountries
add address=37.235.107.0-37.235.109.255 comment="United States" list=
SafeCountries
add address=37.252.208.0/23 comment="United States" list=SafeCountries
add address=38.0.0.0-38.64.37.255 comment="United States" list=SafeCountries
add address=38.64.39.0-38.64.128.255 comment="United States" list=
SafeCountries
add address=38.64.130.0-38.64.135.255 comment="United States" list=
SafeCountries
add address=38.64.138.0-38.64.143.255 comment="United States" list=
SafeCountries
add address=38.64.146.0-38.64.148.255 comment="United States" list=
SafeCountries
add address=38.64.151.0-38.64.156.255 comment="United States" list=
SafeCountries
add address=38.64.158.0-38.64.166.255 comment="United States" list=
SafeCountries
add address=38.64.172.0/23 comment="United States" list=SafeCountries
add address=38.64.177.0-38.64.178.255 comment="United States" list=
SafeCountries
add address=38.64.180.0/22 comment="United States" list=SafeCountries
add address=38.64.185.0-38.64.188.255 comment="United States" list=
SafeCountries
add address=38.64.190.0/23 comment="United States" list=SafeCountries
add address=38.64.193.0-38.64.197.255 comment="United States" list=
SafeCountries
add address=38.64.198.128-38.64.203.255 comment="United States" list=
SafeCountries
add address=38.64.205.0-38.64.206.255 comment="United States" list=
SafeCountries
add address=38.64.208.0-38.65.135.255 comment="United States" list=
SafeCountries
add address=38.65.137.0-38.65.140.255 comment="United States" list=
SafeCountries
add address=38.65.142.0-38.69.129.255 comment="United States" list=
SafeCountries
add address=38.69.131.0-38.69.141.255 comment="United States" list=
SafeCountries
add address=38.69.143.0-38.69.144.255 comment="United States" list=
SafeCountries
add address=38.69.146.0/23 comment="United States" list=SafeCountries
add address=38.69.150.0-38.69.223.255 comment="United States" list=
SafeCountries
add address=38.69.232.0-38.74.18.255 comment="United States" list=
SafeCountries
add address=38.74.20.0-38.74.28.255 comment="United States" list=
SafeCountries
add address=38.74.30.0-38.74.43.255 comment="United States" list=
SafeCountries
add address=38.74.45.0-38.80.63.255 comment="United States" list=
SafeCountries
add address=38.80.66.0-38.86.192.63 comment="United States" list=
SafeCountries
add address=38.86.192.68-38.86.192.70 comment="United States" list=
SafeCountries
add address=38.86.192.72-38.87.224.255 comment="United States" list=
SafeCountries
add address=38.87.226.0/24 comment="United States" list=SafeCountries
add address=38.87.228.0-38.87.230.255 comment="United States" list=
SafeCountries
add address=38.87.234.0-38.87.237.255 comment="United States" list=
SafeCountries
add address=38.87.240.0-38.87.248.255 comment="United States" list=
SafeCountries
add address=38.87.250.0-38.88.5.255 comment="United States" list=
SafeCountries
add address=38.88.8.0-38.88.63.255 comment="United States" list=SafeCountries
add address=38.88.65.0/24 comment="United States" list=SafeCountries
add address=38.88.69.0-38.88.80.255 comment="United States" list=
SafeCountries
add address=38.88.82.0-38.88.175.255 comment="United States" list=
SafeCountries
add address=38.88.178.0-38.88.239.255 comment="United States" list=
SafeCountries
add address=38.88.241.0-38.96.216.255 comment="United States" list=
SafeCountries
add address=38.96.217.128-38.99.115.255 comment="United States" list=
SafeCountries
add address=38.99.120.0-38.99.128.255 comment="United States" list=
SafeCountries
add address=38.99.135.0/24 comment="United States" list=SafeCountries
add address=38.99.138.0/23 comment="United States" list=SafeCountries
add address=38.99.143.0/24 comment="United States" list=SafeCountries
add address=38.99.146.0-38.99.149.255 comment="United States" list=
SafeCountries
add address=38.99.153.192/27 comment="United States" list=SafeCountries
add address=38.99.154.0-38.99.159.255 comment="United States" list=
SafeCountries
add address=38.99.162.0/24 comment="United States" list=SafeCountries
add address=38.99.164.0/24 comment="United States" list=SafeCountries
add address=38.99.166.0-38.99.167.31 comment="United States" list=
SafeCountries
add address=38.99.168.0/22 comment="United States" list=SafeCountries
add address=38.99.174.0/23 comment="United States" list=SafeCountries
add address=38.99.178.0/24 comment="United States" list=SafeCountries
add address=38.99.180.0-38.99.184.255 comment="United States" list=
SafeCountries
add address=38.99.188.0/23 comment="United States" list=SafeCountries
add address=38.99.192.0-38.99.242.255 comment="United States" list=
SafeCountries
add address=38.99.244.0-38.102.80.255 comment="United States" list=
SafeCountries
add address=38.102.82.0-38.102.116.255 comment="United States" list=
SafeCountries
add address=38.102.119.0-38.103.151.255 comment="United States" list=
SafeCountries
add address=38.103.153.0-38.103.154.255 comment="United States" list=
SafeCountries
add address=38.103.157.0-38.104.154.255 comment="United States" list=
SafeCountries
add address=38.104.160.0/19 comment="United States" list=SafeCountries
add address=38.104.193.0-38.104.207.255 comment="United States" list=
SafeCountries
add address=38.104.210.0-38.104.226.255 comment="United States" list=
SafeCountries
add address=38.104.228.0-38.104.250.255 comment="United States" list=
SafeCountries
add address=38.104.252.0-38.105.28.255 comment="United States" list=
SafeCountries
add address=38.105.31.0-38.106.170.63 comment="United States" list=
SafeCountries
add address=38.106.170.128-38.107.87.255 comment="United States" list=
SafeCountries
add address=38.107.93.0-38.107.94.255 comment="United States" list=
SafeCountries
add address=38.107.96.0-38.108.64.255 comment="United States" list=
SafeCountries
add address=38.108.66.0-38.108.68.255 comment="United States" list=
SafeCountries
add address=38.108.70.0-38.108.82.255 comment="United States" list=
SafeCountries
add address=38.108.84.0-38.108.86.255 comment="United States" list=
SafeCountries
add address=38.108.88.0-38.109.159.255 comment="United States" list=
SafeCountries
add address=38.109.162.0-38.109.164.255 comment="United States" list=
SafeCountries
add address=38.109.166.0-38.110.63.255 comment="United States" list=
SafeCountries
add address=38.110.65.0-38.110.67.255 comment="United States" list=
SafeCountries
add address=38.110.69.0-38.110.70.255 comment="United States" list=
SafeCountries
add address=38.110.72.0/21 comment="United States" list=SafeCountries
add address=38.110.82.0-38.110.86.255 comment="United States" list=
SafeCountries
add address=38.110.88.0-38.110.92.255 comment="United States" list=
SafeCountries
add address=38.110.94.0-38.110.96.134 comment="United States" list=
SafeCountries
add address=38.110.96.136-38.110.126.255 comment="United States" list=
SafeCountries
add address=38.110.128.0-38.111.102.255 comment="United States" list=
SafeCountries
add address=38.111.104.0-38.111.116.255 comment="United States" list=
SafeCountries
add address=38.111.121.0-38.111.123.255 comment="United States" list=
SafeCountries
add address=38.111.125.0-38.111.145.15 comment="United States" list=
SafeCountries
add address=38.111.145.17 comment="United States" list=SafeCountries
add address=38.111.145.32/29 comment="United States" list=SafeCountries
add address=38.111.146.0-38.112.0.255 comment="United States" list=
SafeCountries
add address=38.112.2.0/24 comment="United States" list=SafeCountries
add address=38.112.4.0-38.112.7.191 comment="United States" list=
SafeCountries
add address=38.112.7.224-38.112.88.255 comment="United States" list=
SafeCountries
add address=38.112.90.0/23 comment="United States" list=SafeCountries
add address=38.112.93.0-38.112.99.255 comment="United States" list=
SafeCountries
add address=38.112.101.0-38.112.105.255 comment="United States" list=
SafeCountries
add address=38.112.108.0-38.112.112.255 comment="United States" list=
SafeCountries
add address=38.112.114.0/24 comment="United States" list=SafeCountries
add address=38.112.116.0-38.112.124.255 comment="United States" list=
SafeCountries
add address=38.112.126.0-38.113.184.255 comment="United States" list=
SafeCountries
add address=38.113.187.0-38.116.191.255 comment="United States" list=
SafeCountries
add address=38.116.193.0-38.116.195.255 comment="United States" list=
SafeCountries
add address=38.116.197.0/24 comment="United States" list=SafeCountries
add address=38.116.200.0-38.117.75.255 comment="United States" list=
SafeCountries
add address=38.117.80.0/22 comment="United States" list=SafeCountries
add address=38.117.85.0-38.117.91.255 comment="United States" list=
SafeCountries
add address=38.117.93.0-38.117.99.255 comment="United States" list=
SafeCountries
add address=38.117.101.0-38.117.106.255 comment="United States" list=
SafeCountries
add address=38.117.110.0-38.121.65.255 comment="United States" list=
SafeCountries
add address=38.121.69.0/24 comment="United States" list=SafeCountries
add address=38.121.72.0-38.121.74.255 comment="United States" list=
SafeCountries
add address=38.121.76.0-38.121.78.255 comment="United States" list=
SafeCountries
add address=38.121.80.0/22 comment="United States" list=SafeCountries
add address=38.121.85.0-38.121.87.255 comment="United States" list=
SafeCountries
add address=38.121.89.0-38.121.91.255 comment="United States" list=
SafeCountries
add address=38.121.93.0-38.121.243.255 comment="United States" list=
SafeCountries
add address=38.121.245.0-38.121.250.255 comment="United States" list=
SafeCountries
add address=38.121.252.0-38.122.41.255 comment="United States" list=
SafeCountries
add address=38.122.43.0-38.122.67.255 comment="United States" list=
SafeCountries
add address=38.122.70.0-38.122.183.255 comment="United States" list=
SafeCountries
add address=38.122.185.38 comment="United States" list=SafeCountries
add address=38.122.186.0-38.123.65.255 comment="United States" list=
SafeCountries
add address=38.123.68.0-38.123.192.63 comment="United States" list=
SafeCountries
add address=38.123.192.128-38.123.194.127 comment="United States" list=
SafeCountries
add address=38.123.195.0-38.123.202.255 comment="United States" list=
SafeCountries
add address=38.123.204.0/24 comment="United States" list=SafeCountries
add address=38.123.206.0-38.124.168.255 comment="United States" list=
SafeCountries
add address=38.124.170.0/24 comment="United States" list=SafeCountries
add address=38.124.172.0-38.124.199.255 comment="United States" list=
SafeCountries
add address=38.124.201.0-38.125.45.255 comment="United States" list=
SafeCountries
add address=38.125.47.0-38.127.63.255 comment="United States" list=
SafeCountries
add address=38.127.65.0/24 comment="United States" list=SafeCountries
add address=38.127.67.0-38.127.75.255 comment="United States" list=
SafeCountries
add address=38.127.77.0-38.128.224.255 comment="United States" list=
SafeCountries
add address=38.128.226.0-38.128.239.255 comment="United States" list=
SafeCountries
add address=38.129.0.0-38.129.4.74 comment="United States" list=SafeCountries
add address=38.129.4.76-38.130.112.255 comment="United States" list=
SafeCountries
add address=38.130.115.0-38.130.117.255 comment="United States" list=
SafeCountries
add address=38.130.119.0-38.130.123.255 comment="United States" list=
SafeCountries
add address=38.130.125.0-38.131.159.255 comment="United States" list=
SafeCountries
add address=38.131.176.0-38.132.35.255 comment="United States" list=
SafeCountries
add address=38.132.38.0/23 comment="United States" list=SafeCountries
add address=38.132.42.0-38.132.51.16 comment="United States" list=
SafeCountries
add address=38.132.51.18-38.133.15.255 comment="United States" list=
SafeCountries
add address=38.133.24.0-38.140.9.255 comment="United States" list=
SafeCountries
add address=38.140.12.0-38.140.99.255 comment="United States" list=
SafeCountries
add address=38.140.102.0-38.242.169.255 comment="United States" list=
SafeCountries
add address=38.242.171.0-38.255.255.255 comment="United States" list=
SafeCountries
add address=40.0.0.0-40.0.95.255 comment="United States" list=SafeCountries
add address=40.0.97.0-40.67.255.255 comment="United States" list=
SafeCountries
add address=40.69.128.0/18 comment="United States" list=SafeCountries
add address=40.69.224.0-40.71.255.255 comment="United States" list=
SafeCountries
add address=40.74.160.0-40.77.167.92 comment="United States" list=
SafeCountries
add address=40.77.167.94-40.78.191.255 comment="United States" list=
SafeCountries
add address=40.79.0.0/17 comment="United States" list=SafeCountries
add address=40.80.144.0-40.81.255.255 comment="United States" list=
SafeCountries
add address=40.83.0.0/18 comment="United States" list=SafeCountries
add address=40.83.128.0-40.84.255.255 comment="United States" list=
SafeCountries
add address=40.85.144.0-40.85.191.255 comment="United States" list=
SafeCountries
add address=40.86.0.0-40.86.191.255 comment="United States" list=
SafeCountries
add address=40.87.0.0/17 comment="United States" list=SafeCountries
add address=40.87.160.0-40.87.183.255 comment="United States" list=
SafeCountries
add address=40.87.224.0-40.96.0.31 comment="United States" list=SafeCountries
add address=40.96.0.64-40.96.3.31 comment="United States" list=SafeCountries
add address=40.96.3.112-40.96.4.255 comment="United States" list=
SafeCountries
add address=40.96.5.48-40.96.7.127 comment="United States" list=SafeCountries
add address=40.96.7.144/28 comment="United States" list=SafeCountries
add address=40.96.7.176-40.96.9.127 comment="United States" list=
SafeCountries
add address=40.96.9.160/28 comment="United States" list=SafeCountries
add address=40.96.9.240-40.96.10.63 comment="United States" list=
SafeCountries
add address=40.96.10.72-40.96.16.207 comment="United States" list=
SafeCountries
add address=40.96.16.240-40.96.17.15 comment="United States" list=
SafeCountries
add address=40.96.17.48-40.96.17.223 comment="United States" list=
SafeCountries
add address=40.96.18.16-40.96.22.191 comment="United States" list=
SafeCountries
add address=40.96.22.208-40.96.22.239 comment="United States" list=
SafeCountries
add address=40.96.23.0/26 comment="United States" list=SafeCountries
add address=40.96.23.80-40.96.23.111 comment="United States" list=
SafeCountries
add address=40.96.23.144-40.96.23.175 comment="United States" list=
SafeCountries
add address=40.96.23.224-40.96.24.159 comment="United States" list=
SafeCountries
add address=40.96.24.176-40.96.24.255 comment="United States" list=
SafeCountries
add address=40.96.25.80/28 comment="United States" list=SafeCountries
add address=40.96.25.112/28 comment="United States" list=SafeCountries
add address=40.96.25.144/28 comment="United States" list=SafeCountries
add address=40.96.25.192/28 comment="United States" list=SafeCountries
add address=40.96.25.224/28 comment="United States" list=SafeCountries
add address=40.96.26.0/28 comment="United States" list=SafeCountries
add address=40.96.26.48-40.96.35.175 comment="United States" list=
SafeCountries
add address=40.96.35.208-40.96.37.223 comment="United States" list=
SafeCountries
add address=40.96.38.0-40.96.38.175 comment="United States" list=
SafeCountries
add address=40.96.38.240-40.96.43.63 comment="United States" list=
SafeCountries
add address=40.96.43.96-40.96.45.143 comment="United States" list=
SafeCountries
add address=40.96.45.176-40.96.47.15 comment="United States" list=
SafeCountries
add address=40.96.47.32-40.96.56.31 comment="United States" list=
SafeCountries
add address=40.96.56.128-40.96.57.79 comment="United States" list=
SafeCountries
add address=40.96.57.112-40.96.60.223 comment="United States" list=
SafeCountries
add address=40.96.60.240-40.96.61.159 comment="United States" list=
SafeCountries
add address=40.96.61.192-40.96.64.143 comment="United States" list=
SafeCountries
add address=40.96.64.160-40.97.255.255 comment="United States" list=
SafeCountries
add address=40.99.0.0/16 comment="United States" list=SafeCountries
add address=40.100.40.0-40.100.143.255 comment="United States" list=
SafeCountries
add address=40.100.144.16-40.100.151.255 comment="United States" list=
SafeCountries
add address=40.100.152.144-40.100.153.255 comment="United States" list=
SafeCountries
add address=40.100.155.0/24 comment="United States" list=SafeCountries
add address=40.100.157.0-40.100.159.255 comment="United States" list=
SafeCountries
add address=40.100.160.112-40.100.167.255 comment="United States" list=
SafeCountries
add address=40.100.172.0-40.100.255.255 comment="United States" list=
SafeCountries
add address=40.101.60.0-40.101.255.255 comment="United States" list=
SafeCountries
add address=40.102.44.0/22 comment="United States" list=SafeCountries
add address=40.102.128.0/17 comment="United States" list=SafeCountries
add address=40.103.2.0-40.103.5.191 comment="United States" list=
SafeCountries
add address=40.103.7.0-40.103.11.255 comment="United States" list=
SafeCountries
add address=40.103.14.128-40.111.255.255 comment="United States" list=
SafeCountries
add address=40.112.32.0/22 comment="United States" list=SafeCountries
add address=40.112.36.192/26 comment="United States" list=SafeCountries
add address=40.112.37.64/26 comment="United States" list=SafeCountries
add address=40.112.38.0-40.112.63.255 comment="United States" list=
SafeCountries
add address=40.112.128.0/17 comment="United States" list=SafeCountries
add address=40.113.192.0-40.114.127.255 comment="United States" list=
SafeCountries
add address=40.114.247.218 comment="United States" list=SafeCountries
add address=40.116.0.0/16 comment="United States" list=SafeCountries
add address=40.117.32.0-40.117.255.255 comment="United States" list=
SafeCountries
add address=40.118.128.0/17 comment="United States" list=SafeCountries
add address=40.121.0.0-40.123.127.255 comment="United States" list=
SafeCountries
add address=40.124.0.0-40.125.127.255 comment="United States" list=
SafeCountries
add address=40.127.112.0/20 comment="United States" list=SafeCountries
add address=40.128.0.0-40.252.56.99 comment="United States" list=
SafeCountries
add address=40.252.56.104-40.255.255.255 comment="United States" list=
SafeCountries
add address=41.189.240.0-41.189.247.192 comment="United States" list=
SafeCountries
add address=41.189.247.194-41.189.255.38 comment="United States" list=
SafeCountries
add address=41.189.255.40-41.189.255.255 comment="United States" list=
SafeCountries
add address=43.226.230.0/23 comment="United States" list=SafeCountries
add address=43.228.184.0/22 comment="United States" list=SafeCountries
add address=43.239.248.0/23 comment="United States" list=SafeCountries
add address=43.245.196.0/23 comment="United States" list=SafeCountries
add address=43.255.24.0/24 comment="United States" list=SafeCountries
add address=44.0.0.0-44.136.255.255 comment="United States" list=
SafeCountries
add address=44.138.0.0-45.1.255.255 comment="United States" list=
SafeCountries
add address=45.3.32.0-45.3.255.255 comment="United States" list=SafeCountries
add address=45.16.0.0/12 comment="United States" list=SafeCountries
add address=45.32.0.192/27 comment="United States" list=SafeCountries
add address=45.32.1.0/24 comment="United States" list=SafeCountries
add address=45.32.3.0/26 comment="United States" list=SafeCountries
add address=45.32.3.80/29 comment="United States" list=SafeCountries
add address=45.32.6.0/23 comment="United States" list=SafeCountries
add address=45.32.64.0/19 comment="United States" list=SafeCountries
add address=45.32.128.0/21 comment="United States" list=SafeCountries
add address=45.32.160.0/23 comment="United States" list=SafeCountries
add address=45.32.192.0-45.32.194.255 comment="United States" list=
SafeCountries
add address=45.32.196.0/24 comment="United States" list=SafeCountries
add address=45.32.198.0-45.32.207.255 comment="United States" list=
SafeCountries
add address=45.32.210.0-45.32.219.255 comment="United States" list=
SafeCountries
add address=45.32.224.0/21 comment="United States" list=SafeCountries
add address=45.33.0.0-45.33.191.255 comment="United States" list=
SafeCountries
add address=45.33.208.0-45.40.15.255 comment="United States" list=
SafeCountries
add address=45.40.32.0/19 comment="United States" list=SafeCountries
add address=45.40.80.0-45.40.191.255 comment="United States" list=
SafeCountries
add address=45.40.193.0-45.40.255.255 comment="United States" list=
SafeCountries
add address=45.41.1.0-45.41.3.255 comment="United States" list=SafeCountries
add address=45.41.5.0-45.41.95.255 comment="United States" list=SafeCountries
add address=45.41.128.0-45.41.134.255 comment="United States" list=
SafeCountries
add address=45.41.140.0-45.41.195.255 comment="United States" list=
SafeCountries
add address=45.41.197.0-45.41.204.255 comment="United States" list=
SafeCountries
add address=45.41.206.0-45.41.214.255 comment="United States" list=
SafeCountries
add address=45.41.216.0-45.41.233.255 comment="United States" list=
SafeCountries
add address=45.41.235.0-45.41.255.255 comment="United States" list=
SafeCountries
add address=45.42.2.0-45.42.7.255 comment="United States" list=SafeCountries
add address=45.42.16.0/21 comment="United States" list=SafeCountries
add address=45.42.28.0-45.42.35.255 comment="United States" list=
SafeCountries
add address=45.42.40.0-45.42.71.255 comment="United States" list=
SafeCountries
add address=45.42.80.0/20 comment="United States" list=SafeCountries
add address=45.42.128.0/24 comment="United States" list=SafeCountries
add address=45.42.130.0-45.42.133.255 comment="United States" list=
SafeCountries
add address=45.42.135.0/24 comment="United States" list=SafeCountries
add address=45.42.140.0/24 comment="United States" list=SafeCountries
add address=45.42.145.0-45.42.148.255 comment="United States" list=
SafeCountries
add address=45.42.150.0/24 comment="United States" list=SafeCountries
add address=45.42.152.0/23 comment="United States" list=SafeCountries
add address=45.42.155.0/24 comment="United States" list=SafeCountries
add address=45.42.157.0-45.42.158.255 comment="United States" list=
SafeCountries
add address=45.42.160.0/24 comment="United States" list=SafeCountries
add address=45.42.162.0/23 comment="United States" list=SafeCountries
add address=45.42.165.0/24 comment="United States" list=SafeCountries
add address=45.42.168.0/24 comment="United States" list=SafeCountries
add address=45.42.170.0/24 comment="United States" list=SafeCountries
add address=45.42.175.0/24 comment="United States" list=SafeCountries
add address=45.42.177.0-45.42.178.255 comment="United States" list=
SafeCountries
add address=45.42.180.0/22 comment="United States" list=SafeCountries
add address=45.42.185.0/24 comment="United States" list=SafeCountries
add address=45.42.187.0-45.42.192.255 comment="United States" list=
SafeCountries
add address=45.42.193.128-45.42.197.255 comment="United States" list=
SafeCountries
add address=45.42.198.128-45.42.202.255 comment="United States" list=
SafeCountries
add address=45.42.203.128-45.42.207.255 comment="United States" list=
SafeCountries
add address=45.42.208.128-45.42.209.255 comment="United States" list=
SafeCountries
add address=45.42.211.0/24 comment="United States" list=SafeCountries
add address=45.42.213.128-45.42.217.255 comment="United States" list=
SafeCountries
add address=45.42.218.128-45.42.219.255 comment="United States" list=
SafeCountries
add address=45.42.221.0-45.42.222.255 comment="United States" list=
SafeCountries
add address=45.42.223.128-45.42.224.255 comment="United States" list=
SafeCountries
add address=45.42.226.0/23 comment="United States" list=SafeCountries
add address=45.42.228.128-45.42.229.255 comment="United States" list=
SafeCountries
add address=45.42.231.0-45.42.232.255 comment="United States" list=
SafeCountries
add address=45.42.233.128-45.42.237.255 comment="United States" list=
SafeCountries
add address=45.42.238.128-45.42.242.255 comment="United States" list=
SafeCountries
add address=45.42.243.128-45.42.248.255 comment="United States" list=
SafeCountries
add address=45.42.250.0-45.43.255.255 comment="United States" list=
SafeCountries
add address=45.45.130.0/23 comment="United States" list=SafeCountries
add address=45.45.134.0/24 comment="United States" list=SafeCountries
add address=45.45.136.0/22 comment="United States" list=SafeCountries
add address=45.45.142.0-45.45.146.255 comment="United States" list=
SafeCountries
add address=45.45.148.0/23 comment="United States" list=SafeCountries
add address=45.45.151.0-45.45.156.255 comment="United States" list=
SafeCountries
add address=45.45.158.0-45.45.161.255 comment="United States" list=
SafeCountries
add address=45.45.163.0-45.45.168.255 comment="United States" list=
SafeCountries
add address=45.45.170.0-45.45.172.255 comment="United States" list=
SafeCountries
add address=45.45.174.0-45.45.176.255 comment="United States" list=
SafeCountries
add address=45.45.178.0-45.45.184.255 comment="United States" list=
SafeCountries
add address=45.45.186.0-45.56.145.255 comment="United States" list=
SafeCountries
add address=45.56.147.0-45.56.151.255 comment="United States" list=
SafeCountries
add address=45.56.154.0/23 comment="United States" list=SafeCountries
add address=45.56.160.0-45.56.183.255 comment="United States" list=
SafeCountries
add address=45.56.192.0-45.57.144.191 comment="United States" list=
SafeCountries
add address=45.57.144.208-45.57.216.95 comment="United States" list=
SafeCountries
add address=45.57.216.112-45.57.218.127 comment="United States" list=
SafeCountries
add address=45.57.218.144-45.58.15.255 comment="United States" list=
SafeCountries
add address=45.58.32.0/22 comment="United States" list=SafeCountries
add address=45.58.38.0-45.58.79.255 comment="United States" list=
SafeCountries
add address=45.58.112.0-45.58.191.255 comment="United States" list=
SafeCountries
add address=45.59.0.0-45.59.23.255 comment="United States" list=SafeCountries
add address=45.59.25.0/24 comment="United States" list=SafeCountries
add address=45.59.27.0-45.59.71.255 comment="United States" list=
SafeCountries
add address=45.59.73.0-45.59.128.255 comment="United States" list=
SafeCountries
add address=45.59.130.0-45.59.132.255 comment="United States" list=
SafeCountries
add address=45.59.137.0/24 comment="United States" list=SafeCountries
add address=45.59.140.0/24 comment="United States" list=SafeCountries
add address=45.59.148.0/24 comment="United States" list=SafeCountries
add address=45.59.155.0-45.59.156.255 comment="United States" list=
SafeCountries
add address=45.59.160.0/24 comment="United States" list=SafeCountries
add address=45.59.163.0-45.59.164.255 comment="United States" list=
SafeCountries
add address=45.59.181.0-45.59.182.255 comment="United States" list=
SafeCountries
add address=45.59.184.0/24 comment="United States" list=SafeCountries
add address=45.59.186.0/24 comment="United States" list=SafeCountries
add address=45.59.190.0-45.60.255.255 comment="United States" list=
SafeCountries
add address=45.61.16.0-45.61.47.255 comment="United States" list=
SafeCountries
add address=45.61.64.0-45.61.87.255 comment="United States" list=
SafeCountries
add address=45.61.100.0-45.61.111.255 comment="United States" list=
SafeCountries
add address=45.61.128.0-45.62.36.255 comment="United States" list=
SafeCountries
add address=45.62.38.0/23 comment="United States" list=SafeCountries
add address=45.62.41.0-45.62.48.255 comment="United States" list=
SafeCountries
add address=45.62.50.0-45.62.52.255 comment="United States" list=
SafeCountries
add address=45.62.54.0-45.62.58.255 comment="United States" list=
SafeCountries
add address=45.62.60.0/23 comment="United States" list=SafeCountries
add address=45.62.63.0/24 comment="United States" list=SafeCountries
add address=45.62.96.0-45.62.119.255 comment="United States" list=
SafeCountries
add address=45.62.124.0-45.62.191.255 comment="United States" list=
SafeCountries
add address=45.63.0.0-45.63.95.255 comment="United States" list=SafeCountries
add address=45.63.104.0/21 comment="United States" list=SafeCountries
add address=45.63.128.0/17 comment="United States" list=SafeCountries
add address=45.72.0.0-45.72.12.95 comment="United States" list=SafeCountries
add address=45.72.12.112-45.72.23.95 comment="United States" list=
SafeCountries
add address=45.72.23.112-45.72.127.255 comment="United States" list=
SafeCountries
add address=45.73.128.0-45.74.0.255 comment="United States" list=
SafeCountries
add address=45.74.2.0/24 comment="Costa Rica" list=SafeCountries
add address=45.74.5.0-45.74.16.255 comment="United States" list=SafeCountries
add address=45.74.29.0/25 comment="United States" list=SafeCountries
add address=45.74.35.0-45.74.63.255 comment="United States" list=
SafeCountries
add address=45.74.80.0/20 comment="United States" list=SafeCountries
add address=45.74.240.0/20 comment="United States" list=SafeCountries
add address=45.76.0.0-45.78.95.255 comment="United States" list=SafeCountries
add address=45.78.128.0/19 comment="United States" list=SafeCountries
add address=45.79.0.0/16 comment="United States" list=SafeCountries
add address=45.113.81.0-45.113.83.255 comment="United States" list=
SafeCountries
add address=45.115.24.0/24 comment="United States" list=SafeCountries
add address=45.126.72.0/22 comment="United States" list=SafeCountries
add address=45.127.112.0/22 comment="United States" list=SafeCountries
add address=45.223.0.0/16 comment="United States" list=SafeCountries
add address=46.8.254.0/24 comment="United States" list=SafeCountries
add address=46.18.80.0/24 comment="United States" list=SafeCountries
add address=46.21.150.0-46.21.152.95 comment="United States" list=
SafeCountries
add address=46.21.152.104-46.21.154.39 comment="United States" list=
SafeCountries
add address=46.21.154.48-46.21.155.255 comment="United States" list=
SafeCountries
add address=46.21.157.32-46.21.157.255 comment="United States" list=
SafeCountries
add address=46.21.159.0/24 comment="United States" list=SafeCountries
add address=46.22.64.0/23 comment="United States" list=SafeCountries
add address=46.22.69.0/24 comment="United States" list=SafeCountries
add address=46.22.76.0/22 comment="United States" list=SafeCountries
add address=46.29.252.0/22 comment="United States" list=SafeCountries
add address=46.33.80.249 comment="United States" list=SafeCountries
add address=46.33.84.18 comment="United States" list=SafeCountries
add address=46.35.40.0-46.35.46.255 comment="United States" list=
SafeCountries
add address=46.36.200.171-46.36.200.190 comment="United States" list=
SafeCountries
add address=46.36.200.226-46.36.200.230 comment="United States" list=
SafeCountries
add address=46.36.200.236-46.36.200.240 comment="United States" list=
SafeCountries
add address=46.36.200.251-46.36.200.255 comment="United States" list=
SafeCountries
add address=46.36.201.1-46.36.201.5 comment="United States" list=
SafeCountries
add address=46.36.201.16-46.36.201.50 comment="United States" list=
SafeCountries
add address=46.36.201.56-46.36.201.90 comment="United States" list=
SafeCountries
add address=46.36.201.121-46.36.201.125 comment="United States" list=
SafeCountries
add address=46.36.201.136-46.36.201.140 comment="United States" list=
SafeCountries
add address=46.36.201.176-46.36.201.200 comment="United States" list=
SafeCountries
add address=46.36.203.200-46.36.203.211 comment="United States" list=
SafeCountries
add address=46.166.164.96/27 comment="Costa Rica" list=SafeCountries
add address=46.182.109.0/24 comment="United States" list=SafeCountries
add address=46.211.113.61 comment="United States" list=SafeCountries
add address=46.218.181.0-46.218.181.113 comment="United States" list=
SafeCountries
add address=46.218.181.115-46.218.181.255 comment="United States" list=
SafeCountries
add address=46.229.160.0/20 comment="United States" list=SafeCountries
add address=46.231.240.0/21 comment="United States" list=SafeCountries
add address=46.234.113.0/24 comment="United States" list=SafeCountries
add address=46.255.120.0/24 comment="United States" list=SafeCountries
add address=46.255.123.0-46.255.124.255 comment="United States" list=
SafeCountries
add address=47.16.0.0/13 comment="United States" list=SafeCountries
add address=47.32.0.0-47.51.255.255 comment="United States" list=
SafeCountries
add address=47.142.150.0/24 comment="United States" list=SafeCountries
add address=47.208.52.0-47.208.54.255 comment="United States" list=
SafeCountries
add address=47.208.112.0-47.208.114.255 comment="United States" list=
SafeCountries
add address=47.208.116.0/24 comment="United States" list=SafeCountries
add address=47.208.169.0-47.208.182.255 comment="United States" list=
SafeCountries
add address=47.210.129.0-47.210.134.255 comment="United States" list=
SafeCountries
add address=47.210.136.0/24 comment="United States" list=SafeCountries
add address=47.210.138.0-47.210.154.255 comment="United States" list=
SafeCountries
add address=47.210.156.0-47.210.162.255 comment="United States" list=
SafeCountries
add address=47.210.164.0-47.210.172.255 comment="United States" list=
SafeCountries
add address=47.210.174.0-47.210.177.255 comment="United States" list=
SafeCountries
add address=47.210.179.0-47.210.187.255 comment="United States" list=
SafeCountries
add address=47.213.60.0/24 comment="United States" list=SafeCountries
add address=47.213.63.0/24 comment="United States" list=SafeCountries
add address=47.213.220.0-47.213.232.255 comment="United States" list=
SafeCountries
add address=47.214.180.0/23 comment="United States" list=SafeCountries
add address=47.214.183.0-47.214.188.255 comment="United States" list=
SafeCountries
add address=47.214.190.0-47.214.195.255 comment="United States" list=
SafeCountries
add address=47.214.236.0-47.214.243.255 comment="United States" list=
SafeCountries
add address=47.215.224.0-47.215.240.255 comment="United States" list=
SafeCountries
add address=47.216.0.0/23 comment="United States" list=SafeCountries
add address=47.216.3.0-47.216.5.255 comment="United States" list=
SafeCountries
add address=47.216.8.0/24 comment="United States" list=SafeCountries
add address=47.216.10.0-47.216.12.255 comment="United States" list=
SafeCountries
add address=47.216.14.0-47.216.17.255 comment="United States" list=
SafeCountries
add address=47.216.80.0-47.216.86.255 comment="United States" list=
SafeCountries
add address=47.216.88.0/21 comment="United States" list=SafeCountries
add address=47.216.196.0-47.216.213.255 comment="United States" list=
SafeCountries
add address=47.216.224.0/24 comment="United States" list=SafeCountries
add address=47.216.226.0/24 comment="United States" list=SafeCountries
add address=47.216.229.0-47.216.231.255 comment="United States" list=
SafeCountries
add address=47.216.235.0-47.216.236.255 comment="United States" list=
SafeCountries
add address=47.216.240.0-47.216.248.255 comment="United States" list=
SafeCountries
add address=47.217.1.0-47.217.15.255 comment="United States" list=
SafeCountries
add address=47.217.128.0/22 comment="United States" list=SafeCountries
add address=47.217.133.0-47.217.143.255 comment="United States" list=
SafeCountries
add address=47.217.145.0-47.217.151.255 comment="United States" list=
SafeCountries
add address=47.217.153.0-47.217.162.255 comment="United States" list=
SafeCountries
add address=47.218.248.0/24 comment="United States" list=SafeCountries
add address=47.218.251.0/24 comment="United States" list=SafeCountries
add address=47.218.253.0/24 comment="United States" list=SafeCountries
add address=47.218.255.0/24 comment="United States" list=SafeCountries
add address=47.219.16.0/24 comment="United States" list=SafeCountries
add address=47.219.18.0-47.219.34.255 comment="United States" list=
SafeCountries
add address=47.219.36.0/22 comment="United States" list=SafeCountries
add address=47.219.96.0-47.219.106.255 comment="United States" list=
SafeCountries
add address=47.219.108.0/23 comment="United States" list=SafeCountries
add address=47.219.111.0-47.219.124.255 comment="United States" list=
SafeCountries
add address=47.219.172.0-47.219.188.255 comment="United States" list=
SafeCountries
add address=47.219.190.0/23 comment="United States" list=SafeCountries
add address=47.220.0.0/24 comment="United States" list=SafeCountries
add address=47.220.2.0-47.220.20.255 comment="United States" list=
SafeCountries
add address=47.220.22.0/24 comment="United States" list=SafeCountries
add address=47.222.196.0-47.222.209.255 comment="United States" list=
SafeCountries
add address=47.222.211.0/24 comment="United States" list=SafeCountries
add address=47.223.36.0-47.223.46.255 comment="United States" list=
SafeCountries
add address=47.223.48.0/24 comment="United States" list=SafeCountries
add address=47.223.109.0-47.223.111.255 comment="United States" list=
SafeCountries
add address=47.223.113.0-47.223.114.255 comment="United States" list=
SafeCountries
add address=47.223.117.0-47.223.120.255 comment="United States" list=
SafeCountries
add address=47.223.122.0/24 comment="United States" list=SafeCountries
add address=47.223.132.0-47.223.146.255 comment="United States" list=
SafeCountries
add address=47.223.152.0-47.223.163.255 comment="United States" list=
SafeCountries
add address=47.223.166.0/23 comment="United States" list=SafeCountries
add address=48.0.0.0/8 comment="United States" list=SafeCountries
add address=50.0.0.0-50.2.19.255 comment="United States" list=SafeCountries
add address=50.2.21.0-50.2.94.255 comment="United States" list=SafeCountries
add address=50.2.96.0-50.2.252.63 comment="United States" list=SafeCountries
add address=50.2.252.72-50.3.213.255 comment="United States" list=
SafeCountries
add address=50.3.215.0-50.7.78.87 comment="United States" list=SafeCountries
add address=50.7.78.90-50.7.79.255 comment="United States" list=SafeCountries
add address=50.7.84.0/24 comment="United States" list=SafeCountries
add address=50.7.86.0/24 comment="United States" list=SafeCountries
add address=50.7.96.0/20 comment="United States" list=SafeCountries
add address=50.8.0.0-50.21.127.255 comment="United States" list=SafeCountries
add address=50.21.144.0/20 comment="United States" list=SafeCountries
add address=50.21.176.0-50.21.223.255 comment="United States" list=
SafeCountries
add address=50.21.240.0-50.30.36.25 comment="United States" list=
SafeCountries
add address=50.30.36.29-50.30.45.28 comment="United States" list=
SafeCountries
add address=50.30.45.30-50.30.45.53 comment="United States" list=
SafeCountries
add address=50.30.45.55-50.30.45.108 comment="United States" list=
SafeCountries
add address=50.30.45.110 comment="United States" list=SafeCountries
add address=50.30.45.113-50.30.151.255 comment="United States" list=
SafeCountries
add address=50.30.153.0-50.31.239.255 comment="United States" list=
SafeCountries
add address=50.31.242.0-50.31.251.255 comment="United States" list=
SafeCountries
add address=50.32.0.0/11 comment="United States" list=SafeCountries
add address=50.73.0.0-50.91.255.255 comment="United States" list=
SafeCountries
add address=50.93.128.0-50.97.19.33 comment="United States" list=
SafeCountries
add address=50.97.19.35-50.97.255.255 comment="United States" list=
SafeCountries
add address=50.102.0.0-50.109.6.255 comment="United States" list=
SafeCountries
add address=50.109.7.128-50.115.175.255 comment="United States" list=
SafeCountries
add address=50.115.192.0-50.117.35.255 comment="United States" list=
SafeCountries
add address=50.117.37.0-50.117.127.255 comment="United States" list=
SafeCountries
add address=50.118.0.0/17 comment="United States" list=SafeCountries
add address=50.118.129.0-50.118.161.255 comment="United States" list=
SafeCountries
add address=50.118.163.0-50.118.198.19 comment="United States" list=
SafeCountries
add address=50.118.198.21-50.255.255.255 comment="United States" list=
SafeCountries
add address=52.0.0.0/12 comment="United States" list=SafeCountries
add address=52.18.201.131 comment="United States" list=SafeCountries
add address=52.19.16.34 comment="United States" list=SafeCountries
add address=52.20.0.0-52.27.255.255 comment="United States" list=
SafeCountries
add address=52.32.0.0/12 comment="United States" list=SafeCountries
add address=52.52.0.0-52.57.255.255 comment="United States" list=
SafeCountries
add address=52.60.0.0/15 comment="United States" list=SafeCountries
add address=52.66.0.0/16 comment="United States" list=SafeCountries
add address=52.70.0.0-52.73.255.255 comment="United States" list=
SafeCountries
add address=52.75.0.0/16 comment="United States" list=SafeCountries
add address=52.84.0.0-52.91.255.255 comment="United States" list=
SafeCountries
add address=52.92.16.0-52.92.38.255 comment="United States" list=
SafeCountries
add address=52.92.48.0/22 comment="United States" list=SafeCountries
add address=52.92.76.0/22 comment="United States" list=SafeCountries
add address=52.92.84.0-52.92.255.255 comment="United States" list=
SafeCountries
add address=52.93.1.0/24 comment="United States" list=SafeCountries
add address=52.93.3.0-52.93.7.255 comment="United States" list=SafeCountries
add address=52.93.12.0-52.94.4.255 comment="United States" list=SafeCountries
add address=52.94.9.0-52.94.10.255 comment="United States" list=SafeCountries
add address=52.94.12.0/24 comment="United States" list=SafeCountries
add address=52.94.14.0-52.95.29.255 comment="United States" list=
SafeCountries
add address=52.95.32.0/23 comment="United States" list=SafeCountries
add address=52.95.40.0-52.95.45.255 comment="United States" list=
SafeCountries
add address=52.95.48.0/21 comment="United States" list=SafeCountries
add address=52.95.62.0-52.95.103.255 comment="United States" list=
SafeCountries
add address=52.95.108.0-52.95.191.255 comment="United States" list=
SafeCountries
add address=52.95.208.0/22 comment="United States" list=SafeCountries
add address=52.95.216.0-52.95.239.255 comment="United States" list=
SafeCountries
add address=52.95.245.0-52.95.247.255 comment="United States" list=
SafeCountries
add address=52.95.250.0/23 comment="United States" list=SafeCountries
add address=52.95.253.0-52.95.254.255 comment="United States" list=
SafeCountries
add address=52.95.255.80-52.95.255.127 comment="United States" list=
SafeCountries
add address=52.95.255.160-52.129.31.255 comment="United States" list=
SafeCountries
add address=52.129.34.0-52.129.47.255 comment="United States" list=
SafeCountries
add address=52.129.49.0-52.159.30.201 comment="United States" list=
SafeCountries
add address=52.159.30.204-52.159.32.103 comment="United States" list=
SafeCountries
add address=52.159.32.106-52.159.64.102 comment="United States" list=
SafeCountries
add address=52.159.64.104-52.162.255.255 comment="United States" list=
SafeCountries
add address=52.163.96.0/19 comment="United States" list=SafeCountries
add address=52.163.192.0/18 comment="United States" list=SafeCountries
add address=52.165.0.0/16 comment="United States" list=SafeCountries
add address=52.167.0.0-52.168.255.255 comment="United States" list=
SafeCountries
add address=52.170.0.0/15 comment="United States" list=SafeCountries
add address=52.172.64.0/18 comment="United States" list=SafeCountries
add address=52.172.192.0-52.173.255.255 comment="United States" list=
SafeCountries
add address=52.175.160.0-52.177.255.255 comment="United States" list=
SafeCountries
add address=52.178.64.0/18 comment="United States" list=SafeCountries
add address=52.178.192.0-52.191.255.255 comment="United States" list=
SafeCountries
add address=52.194.0.0/15 comment="United States" list=SafeCountries
add address=52.200.0.0/13 comment="United States" list=SafeCountries
add address=52.216.0.0/14 comment="United States" list=SafeCountries
add address=52.222.0.0-52.255.255.255 comment="United States" list=
SafeCountries
add address=54.0.0.0/10 comment="United States" list=SafeCountries
add address=54.64.129.246 comment="United States" list=SafeCountries
add address=54.67.0.0-54.71.255.255 comment="United States" list=
SafeCountries
add address=54.80.0.0-54.91.255.255 comment="United States" list=
SafeCountries
add address=54.92.128.0/17 comment="United States" list=SafeCountries
add address=54.96.0.0-54.149.255.255 comment="United States" list=
SafeCountries
add address=54.151.0.0/17 comment="United States" list=SafeCountries
add address=54.152.0.0-54.153.127.255 comment="United States" list=
SafeCountries
add address=54.156.0.0-54.167.255.255 comment="United States" list=
SafeCountries
add address=54.172.0.0-54.177.255.255 comment="United States" list=
SafeCountries
add address=54.180.0.0-54.193.255.255 comment="United States" list=
SafeCountries
add address=54.196.0.0-54.198.255.255 comment="United States" list=
SafeCountries
add address=54.200.0.0-54.205.255.255 comment="United States" list=
SafeCountries
add address=54.208.0.0/13 comment="United States" list=SafeCountries
add address=54.218.0.0/15 comment="United States" list=SafeCountries
add address=54.221.0.0/16 comment="United States" list=SafeCountries
add address=54.224.0.0/14 comment="United States" list=SafeCountries
add address=54.230.0.0-54.231.127.255 comment="United States" list=
SafeCountries
add address=54.231.160.0/19 comment="United States" list=SafeCountries
add address=54.231.208.0/20 comment="United States" list=SafeCountries
add address=54.231.232.0/21 comment="United States" list=SafeCountries
add address=54.231.244.0/22 comment="United States" list=SafeCountries
add address=54.231.254.0/23 comment="United States" list=SafeCountries
add address=54.234.0.0-54.237.255.255 comment="United States" list=
SafeCountries
add address=54.239.0.0/22 comment="United States" list=SafeCountries
add address=54.239.8.0-54.239.31.255 comment="United States" list=
SafeCountries
add address=54.239.40.0-54.239.51.255 comment="United States" list=
SafeCountries
add address=54.239.64.0/19 comment="United States" list=SafeCountries
add address=54.239.97.0-54.239.98.255 comment="United States" list=
SafeCountries
add address=54.239.102.0-54.239.113.255 comment="United States" list=
SafeCountries
add address=54.239.115.0/24 comment="United States" list=SafeCountries
add address=54.239.128.0-54.240.191.255 comment="United States" list=
SafeCountries
add address=54.240.196.0/24 comment="United States" list=SafeCountries
add address=54.240.198.0/24 comment="United States" list=SafeCountries
add address=54.240.201.0-54.240.202.255 comment="United States" list=
SafeCountries
add address=54.240.208.0-54.240.219.255 comment="United States" list=
SafeCountries
add address=54.240.224.0/24 comment="United States" list=SafeCountries
add address=54.240.228.0-54.240.235.255 comment="United States" list=
SafeCountries
add address=54.240.241.0-54.240.243.255 comment="United States" list=
SafeCountries
add address=54.240.248.0-54.245.255.255 comment="United States" list=
SafeCountries
add address=54.251.32.242 comment="United States" list=SafeCountries
add address=54.251.33.56 comment="United States" list=SafeCountries
add address=55.0.0.0-56.255.255.255 comment="United States" list=
SafeCountries
add address=57.48.0.0/16 comment="United States" list=SafeCountries
add address=57.67.136.0/24 comment="United States" list=SafeCountries
add address=57.68.0.0/15 comment="United States" list=SafeCountries
add address=57.75.224.0/20 comment="Costa Rica" list=SafeCountries
add address=57.76.128.0-57.77.127.255 comment="United States" list=
SafeCountries
add address=57.80.0.0/15 comment="United States" list=SafeCountries
add address=57.97.88.0-57.97.119.255 comment="United States" list=
SafeCountries
add address=57.191.128.0/22 comment="United States" list=SafeCountries
add address=58.84.36.0/24 comment="United States" list=SafeCountries
add address=59.152.124.0/22 comment="United States" list=SafeCountries
add address=60.254.128.0-60.254.142.255 comment="United States" list=
SafeCountries
add address=60.254.144.0-60.254.149.255 comment="United States" list=
SafeCountries
add address=60.254.152.0-60.254.191.255 comment="United States" list=
SafeCountries
add address=61.14.0.0/24 comment="United States" list=SafeCountries
add address=61.14.1.8-61.14.3.255 comment="United States" list=SafeCountries
add address=61.14.16.0-61.14.47.255 comment="United States" list=
SafeCountries
add address=61.14.52.0-61.14.63.255 comment="United States" list=
SafeCountries
add address=61.14.224.0-61.14.226.255 comment="United States" list=
SafeCountries
add address=61.28.217.0-61.28.218.255 comment="United States" list=
SafeCountries
add address=61.44.69.0-61.44.69.106 comment="United States" list=
SafeCountries
add address=61.44.69.108-61.44.69.255 comment="United States" list=
SafeCountries
add address=61.45.254.64-61.45.254.80 comment="United States" list=
SafeCountries
add address=62.41.20.0/24 comment="United States" list=SafeCountries
add address=62.72.8.0/22 comment="United States" list=SafeCountries
add address=62.72.60.0/22 comment="United States" list=SafeCountries
add address=62.75.64.0/24 comment="United States" list=SafeCountries
add address=62.78.0.0/19 comment="United States" list=SafeCountries
add address=62.128.176.1-62.128.191.255 comment="United States" list=
SafeCountries
add address=62.150.91.0-62.150.92.255 comment="United States" list=
SafeCountries
add address=62.150.117.251 comment="United States" list=SafeCountries
add address=62.150.121.0/24 comment="United States" list=SafeCountries
add address=62.192.157.0/24 comment="United States" list=SafeCountries
add address=62.208.183.0/27 comment="United States" list=SafeCountries
add address=62.216.150.52 comment="United States" list=SafeCountries
add address=62.221.20.0/24 comment="United States" list=SafeCountries
add address=62.232.113.0/24 comment="United States" list=SafeCountries
add address=63.0.0.0-63.65.10.255 comment="United States" list=SafeCountries
add address=63.65.12.0-63.70.23.255 comment="United States" list=
SafeCountries
add address=63.70.28.0-63.70.142.255 comment="United States" list=
SafeCountries
add address=63.70.144.0-63.74.153.255 comment="United States" list=
SafeCountries
add address=63.74.156.0-63.75.233.255 comment="United States" list=
SafeCountries
add address=63.75.236.0-63.77.227.255 comment="United States" list=
SafeCountries
add address=63.77.232.0-63.80.46.255 comment="United States" list=
SafeCountries
add address=63.80.48.0-63.80.215.255 comment="United States" list=
SafeCountries
add address=63.80.217.0-63.84.64.255 comment="United States" list=
SafeCountries
add address=63.84.66.0-63.84.235.255 comment="United States" list=
SafeCountries
add address=63.84.240.0-63.85.41.255 comment="United States" list=
SafeCountries
add address=63.85.44.0-63.85.242.255 comment="United States" list=
SafeCountries
add address=63.85.244.0-63.87.153.255 comment="United States" list=
SafeCountries
add address=63.87.155.0-63.90.33.255 comment="United States" list=
SafeCountries
add address=63.90.36.0-63.92.232.255 comment="United States" list=
SafeCountries
add address=63.92.233.64/26 comment="United States" list=SafeCountries
add address=63.92.233.176/28 comment="United States" list=SafeCountries
add address=63.92.234.0-63.92.248.24 comment="United States" list=
SafeCountries
add address=63.92.248.26-63.96.193.255 comment="United States" list=
SafeCountries
add address=63.96.195.0-63.97.154.255 comment="United States" list=
SafeCountries
add address=63.97.156.0-63.98.11.255 comment="United States" list=
SafeCountries
add address=63.98.13.0-63.100.191.255 comment="United States" list=
SafeCountries
add address=63.100.224.0-63.103.127.255 comment="United States" list=
SafeCountries
add address=63.103.134.0/23 comment="United States" list=SafeCountries
add address=63.103.144.0-63.103.148.255 comment="United States" list=
SafeCountries
add address=63.103.150.0-63.105.191.255 comment="United States" list=
SafeCountries
add address=63.105.208.0-63.109.65.255 comment="United States" list=
SafeCountries
add address=63.109.69.0/24 comment="United States" list=SafeCountries
add address=63.109.71.0-63.109.72.255 comment="United States" list=
SafeCountries
add address=63.109.74.0/23 comment="United States" list=SafeCountries
add address=63.109.78.0-63.109.244.255 comment="United States" list=
SafeCountries
add address=63.109.250.0-63.110.119.255 comment="United States" list=
SafeCountries
add address=63.110.124.0-63.110.188.255 comment="United States" list=
SafeCountries
add address=63.110.190.0-63.114.36.255 comment="United States" list=
SafeCountries
add address=63.114.38.0-63.130.136.143 comment="United States" list=
SafeCountries
add address=63.130.136.160-63.130.136.199 comment="United States" list=
SafeCountries
add address=63.130.136.208-63.130.138.255 comment="United States" list=
SafeCountries
add address=63.130.140.0-63.130.144.255 comment="United States" list=
SafeCountries
add address=63.130.160.0-63.130.162.31 comment="United States" list=
SafeCountries
add address=63.130.162.48-63.130.191.255 comment="United States" list=
SafeCountries
add address=63.130.208.0/21 comment="United States" list=SafeCountries
add address=63.130.217.0-63.131.239.255 comment="United States" list=
SafeCountries
add address=63.132.0.0-63.134.255.255 comment="United States" list=
SafeCountries
add address=63.135.32.0-63.135.239.255 comment="United States" list=
SafeCountries
add address=63.136.0.0-63.136.111.255 comment="United States" list=
SafeCountries
add address=63.136.120.0-63.141.194.127 comment="United States" list=
SafeCountries
add address=63.141.195.0-63.142.159.255 comment="United States" list=
SafeCountries
add address=63.142.161.19 comment="United States" list=SafeCountries
add address=63.142.176.0-63.143.63.255 comment="United States" list=
SafeCountries
add address=63.143.128.0-63.150.137.223 comment="United States" list=
SafeCountries
add address=63.150.137.232-63.150.140.223 comment="United States" list=
SafeCountries
add address=63.150.140.232-63.150.141.79 comment="United States" list=
SafeCountries
add address=63.150.141.88-63.150.141.231 comment="United States" list=
SafeCountries
add address=63.150.141.240-63.156.193.255 comment="United States" list=
SafeCountries
add address=63.156.196.0-63.157.159.255 comment="United States" list=
SafeCountries
add address=63.157.161.0-63.160.122.255 comment="United States" list=
SafeCountries
add address=63.160.124.0-63.161.63.255 comment="United States" list=
SafeCountries
add address=63.161.66.0-63.161.231.255 comment="United States" list=
SafeCountries
add address=63.161.240.0-63.162.141.255 comment="United States" list=
SafeCountries
add address=63.162.143.0-63.163.179.255 comment="United States" list=
SafeCountries
add address=63.163.182.0-63.164.55.255 comment="United States" list=
SafeCountries
add address=63.164.58.0-63.164.94.255 comment="United States" list=
SafeCountries
add address=63.164.96.0-63.164.107.255 comment="United States" list=
SafeCountries
add address=63.164.112.0-63.165.9.255 comment="United States" list=
SafeCountries
add address=63.165.11.0-63.165.182.255 comment="United States" list=
SafeCountries
add address=63.165.184.0-63.168.56.255 comment="United States" list=
SafeCountries
add address=63.168.58.0-63.168.92.255 comment="United States" list=
SafeCountries
add address=63.168.94.0-63.168.115.255 comment="United States" list=
SafeCountries
add address=63.168.117.0-63.168.167.255 comment="United States" list=
SafeCountries
add address=63.168.170.0-63.170.67.255 comment="United States" list=
SafeCountries
add address=63.170.70.0-63.171.17.255 comment="United States" list=
SafeCountries
add address=63.171.20.0-63.171.111.255 comment="United States" list=
SafeCountries
add address=63.171.128.0-63.171.231.255 comment="United States" list=
SafeCountries
add address=63.171.233.0-63.173.95.255 comment="United States" list=
SafeCountries
add address=63.173.97.0-63.173.171.255 comment="United States" list=
SafeCountries
add address=63.173.174.0-63.174.199.255 comment="United States" list=
SafeCountries
add address=63.174.208.0-63.174.226.255 comment="United States" list=
SafeCountries
add address=63.174.228.0-63.175.155.255 comment="United States" list=
SafeCountries
add address=63.175.160.0-63.175.185.255 comment="United States" list=
SafeCountries
add address=63.175.188.0-63.175.225.255 comment="United States" list=
SafeCountries
add address=63.175.227.0-63.210.8.255 comment="United States" list=
SafeCountries
add address=63.210.10.0-63.215.179.255 comment="United States" list=
SafeCountries
add address=63.215.184.0-63.215.201.255 comment="United States" list=
SafeCountries
add address=63.215.203.0-63.216.95.255 comment="United States" list=
SafeCountries
add address=63.216.128.0-63.216.196.255 comment="United States" list=
SafeCountries
add address=63.216.198.0-63.217.81.255 comment="United States" list=
SafeCountries
add address=63.217.83.0-63.218.15.229 comment="United States" list=
SafeCountries
add address=63.218.15.231-63.218.17.31 comment="United States" list=
SafeCountries
add address=63.218.17.40-63.218.74.255 comment="United States" list=
SafeCountries
add address=63.218.76.0/24 comment="United States" list=SafeCountries
add address=63.218.77.96/28 comment="United States" list=SafeCountries
add address=63.218.77.192-63.218.107.111 comment="United States" list=
SafeCountries
add address=63.218.107.116-63.218.156.255 comment="United States" list=
SafeCountries
add address=63.218.158.0-63.218.172.255 comment="United States" list=
SafeCountries
add address=63.218.174.0-63.219.6.255 comment="United States" list=
SafeCountries
add address=63.219.8.0-63.221.95.255 comment="United States" list=
SafeCountries
add address=63.221.112.0/23 comment="United States" list=SafeCountries
add address=63.221.128.0-63.222.36.1 comment="United States" list=
SafeCountries
add address=63.222.36.3-63.225.65.103 comment="United States" list=
SafeCountries
add address=63.225.65.108-63.225.65.175 comment="United States" list=
SafeCountries
add address=63.225.65.180-63.228.185.47 comment="United States" list=
SafeCountries
add address=63.228.185.56-63.228.185.127 comment="United States" list=
SafeCountries
add address=63.228.185.144/29 comment="United States" list=SafeCountries
add address=63.228.185.160-63.228.185.215 comment="United States" list=
SafeCountries
add address=63.228.185.224-63.229.104.23 comment="United States" list=
SafeCountries
add address=63.229.104.28-63.230.239.255 comment="United States" list=
SafeCountries
add address=63.230.241.0-63.231.211.63 comment="United States" list=
SafeCountries
add address=63.231.211.72-63.231.211.191 comment="United States" list=
SafeCountries
add address=63.231.211.224-63.232.233.255 comment="United States" list=
SafeCountries
add address=63.232.236.0-63.234.239.255 comment="United States" list=
SafeCountries
add address=63.234.241.0-63.235.155.209 comment="United States" list=
SafeCountries
add address=63.235.155.211-63.240.54.255 comment="United States" list=
SafeCountries
add address=63.240.56.0-63.243.129.255 comment="United States" list=
SafeCountries
add address=63.243.131.0-63.243.133.255 comment="United States" list=
SafeCountries
add address=63.243.136.0/23 comment="United States" list=SafeCountries
add address=63.243.142.0/23 comment="United States" list=SafeCountries
add address=63.243.147.0-63.243.150.255 comment="United States" list=
SafeCountries
add address=63.243.152.0/24 comment="United States" list=SafeCountries
add address=63.243.155.0-63.243.157.255 comment="United States" list=
SafeCountries
add address=63.243.161.0/24 comment="United States" list=SafeCountries
add address=63.243.165.0/24 comment="United States" list=SafeCountries
add address=63.243.168.0/22 comment="United States" list=SafeCountries
add address=63.243.174.0-63.243.175.119 comment="United States" list=
SafeCountries
add address=63.243.175.128-63.243.177.255 comment="United States" list=
SafeCountries
add address=63.243.179.0-63.243.180.255 comment="United States" list=
SafeCountries
add address=63.243.183.0-63.243.184.255 comment="United States" list=
SafeCountries
add address=63.243.186.0/24 comment="United States" list=SafeCountries
add address=63.243.190.0/23 comment="United States" list=SafeCountries
add address=63.243.193.0-63.243.199.255 comment="United States" list=
SafeCountries
add address=63.243.204.0/22 comment="United States" list=SafeCountries
add address=63.243.216.0-63.243.248.255 comment="United States" list=
SafeCountries
add address=63.243.249.8-63.245.7.255 comment="United States" list=
SafeCountries
add address=63.245.20.0/24 comment="United States" list=SafeCountries
add address=63.245.29.0/24 comment="United States" list=SafeCountries
add address=63.245.32.0-63.245.40.255 comment="United States" list=
SafeCountries
add address=63.245.43.0-63.245.55.255 comment="United States" list=
SafeCountries
add address=63.245.60.0/24 comment="United States" list=SafeCountries
add address=63.245.68.0/22 comment="United States" list=SafeCountries
add address=63.245.90.0-63.245.92.255 comment="United States" list=
SafeCountries
add address=63.245.94.0/24 comment="United States" list=SafeCountries
add address=63.245.104.0-63.245.109.255 comment="United States" list=
SafeCountries
add address=63.245.111.0/24 comment="United States" list=SafeCountries
add address=63.245.124.0-63.250.95.255 comment="United States" list=
SafeCountries
add address=63.250.128.0/24 comment="United States" list=SafeCountries
add address=63.250.130.0-63.251.93.255 comment="United States" list=
SafeCountries
add address=63.251.95.0-63.251.157.255 comment="United States" list=
SafeCountries
add address=63.251.159.0-64.4.18.63 comment="United States" list=
SafeCountries
add address=64.4.18.128-64.4.33.255 comment="United States" list=
SafeCountries
add address=64.4.36.0-64.4.63.255 comment="United States" list=SafeCountries
add address=64.4.96.0-64.5.191.255 comment="United States" list=SafeCountries
add address=64.5.201.0/24 comment="United States" list=SafeCountries
add address=64.5.217.0/24 comment="United States" list=SafeCountries
add address=64.5.224.0/23 comment="United States" list=SafeCountries
add address=64.5.240.0/24 comment="United States" list=SafeCountries
add address=64.6.0.0-64.6.191.255 comment="United States" list=SafeCountries
add address=64.6.208.0-64.7.127.255 comment="United States" list=
SafeCountries
add address=64.7.160.0-64.10.0.255 comment="United States" list=SafeCountries
add address=64.10.7.0/24 comment="United States" list=SafeCountries
add address=64.10.37.0-64.10.38.255 comment="United States" list=
SafeCountries
add address=64.10.43.0/24 comment="United States" list=SafeCountries
add address=64.10.48.0/24 comment="United States" list=SafeCountries
add address=64.10.52.0/23 comment="United States" list=SafeCountries
add address=64.10.64.0/24 comment="United States" list=SafeCountries
add address=64.10.79.0-64.10.82.255 comment="United States" list=
SafeCountries
add address=64.10.89.0/24 comment="United States" list=SafeCountries
add address=64.10.94.0/24 comment="United States" list=SafeCountries
add address=64.10.115.0-64.10.116.255 comment="United States" list=
SafeCountries
add address=64.10.123.0/24 comment="United States" list=SafeCountries
add address=64.10.129.0/24 comment="United States" list=SafeCountries
add address=64.10.142.0/24 comment="United States" list=SafeCountries
add address=64.10.156.0/24 comment="United States" list=SafeCountries
add address=64.10.163.0/24 comment="United States" list=SafeCountries
add address=64.10.174.0/24 comment="United States" list=SafeCountries
add address=64.10.183.0/24 comment="United States" list=SafeCountries
add address=64.10.188.0/24 comment="United States" list=SafeCountries
add address=64.10.191.0/24 comment="United States" list=SafeCountries
add address=64.10.219.0/24 comment="United States" list=SafeCountries
add address=64.10.226.0/24 comment="United States" list=SafeCountries
add address=64.10.231.0/24 comment="United States" list=SafeCountries
add address=64.10.242.0/24 comment="United States" list=SafeCountries
add address=64.10.254.0-64.11.3.255 comment="United States" list=
SafeCountries
add address=64.11.11.0/24 comment="United States" list=SafeCountries
add address=64.11.16.0/24 comment="United States" list=SafeCountries
add address=64.11.28.0/24 comment="United States" list=SafeCountries
add address=64.11.37.0/24 comment="United States" list=SafeCountries
add address=64.11.47.0-64.11.48.255 comment="United States" list=
SafeCountries
add address=64.11.67.0/24 comment="United States" list=SafeCountries
add address=64.11.76.0/24 comment="United States" list=SafeCountries
add address=64.11.85.0/24 comment="United States" list=SafeCountries
add address=64.11.100.0/23 comment="United States" list=SafeCountries
add address=64.11.121.0-64.11.122.255 comment="United States" list=
SafeCountries
add address=64.11.125.0-64.11.128.255 comment="United States" list=
SafeCountries
add address=64.11.134.0/24 comment="United States" list=SafeCountries
add address=64.11.141.0/24 comment="United States" list=SafeCountries
add address=64.11.151.0/24 comment="United States" list=SafeCountries
add address=64.11.161.0/24 comment="United States" list=SafeCountries
add address=64.11.166.0/24 comment="United States" list=SafeCountries
add address=64.11.177.0/24 comment="United States" list=SafeCountries
add address=64.11.184.0/24 comment="United States" list=SafeCountries
add address=64.11.197.0-64.12.118.22 comment="United States" list=
SafeCountries
add address=64.12.118.24-64.12.118.87 comment="United States" list=
SafeCountries
add address=64.12.118.89-64.14.172.255 comment="United States" list=
SafeCountries
add address=64.14.174.0/23 comment="United States" list=SafeCountries
add address=64.14.177.0-64.14.189.255 comment="United States" list=
SafeCountries
add address=64.14.191.0-64.14.193.255 comment="United States" list=
SafeCountries
add address=64.14.195.0-64.15.31.255 comment="United States" list=
SafeCountries
add address=64.15.80.0-64.15.127.255 comment="United States" list=
SafeCountries
add address=64.15.160.0-64.15.204.255 comment="United States" list=
SafeCountries
add address=64.15.206.0-64.17.61.39 comment="United States" list=
SafeCountries
add address=64.17.61.48-64.17.62.255 comment="United States" list=
SafeCountries
add address=64.17.64.0-64.18.63.255 comment="United States" list=
SafeCountries
add address=64.18.96.0-64.18.159.255 comment="United States" list=
SafeCountries
add address=64.18.192.0-64.23.63.255 comment="United States" list=
SafeCountries
add address=64.23.80.0-64.25.159.255 comment="United States" list=
SafeCountries
add address=64.25.192.0-64.26.127.255 comment="United States" list=
SafeCountries
add address=64.26.192.0-64.27.184.255 comment="United States" list=
SafeCountries
add address=64.27.186.0-64.27.255.255 comment="United States" list=
SafeCountries
add address=64.28.32.0-64.28.127.255 comment="United States" list=
SafeCountries
add address=64.28.144.0-64.30.143.255 comment="United States" list=
SafeCountries
add address=64.30.160.0-64.32.63.255 comment="United States" list=
SafeCountries
add address=64.32.128.0-64.33.255.255 comment="United States" list=
SafeCountries
add address=64.34.9.0-64.34.19.255 comment="United States" list=SafeCountries
add address=64.34.22.0/23 comment="United States" list=SafeCountries
add address=64.34.25.0-64.34.27.95 comment="United States" list=SafeCountries
add address=64.34.27.112-64.34.47.255 comment="United States" list=
SafeCountries
add address=64.34.49.0/24 comment="United States" list=SafeCountries
add address=64.34.51.0/24 comment="United States" list=SafeCountries
add address=64.34.55.0-64.34.61.255 comment="United States" list=
SafeCountries
add address=64.34.65.0/24 comment="United States" list=SafeCountries
add address=64.34.67.0-64.34.69.255 comment="United States" list=
SafeCountries
add address=64.34.71.0-64.34.71.95 comment="United States" list=SafeCountries
add address=64.34.71.128/25 comment="United States" list=SafeCountries
add address=64.34.74.0-64.34.74.239 comment="United States" list=
SafeCountries
add address=64.34.74.248-64.34.75.255 comment="United States" list=
SafeCountries
add address=64.34.77.0/24 comment="United States" list=SafeCountries
add address=64.34.80.0/20 comment="United States" list=SafeCountries
add address=64.34.97.128-64.34.97.223 comment="United States" list=
SafeCountries
add address=64.34.98.0/23 comment="United States" list=SafeCountries
add address=64.34.104.0/23 comment="United States" list=SafeCountries
add address=64.34.107.0-64.34.109.167 comment="United States" list=
SafeCountries
add address=64.34.109.176-64.34.109.255 comment="United States" list=
SafeCountries
add address=64.34.110.64-64.34.110.255 comment="United States" list=
SafeCountries
add address=64.34.114.0-64.34.116.255 comment="United States" list=
SafeCountries
add address=64.34.118.0/23 comment="United States" list=SafeCountries
add address=64.34.125.0-64.34.128.255 comment="United States" list=
SafeCountries
add address=64.34.130.0/24 comment="United States" list=SafeCountries
add address=64.34.134.0/23 comment="United States" list=SafeCountries
add address=64.34.137.0-64.34.137.191 comment="United States" list=
SafeCountries
add address=64.34.137.200-64.34.137.255 comment="United States" list=
SafeCountries
add address=64.34.139.0-64.34.141.255 comment="United States" list=
SafeCountries
add address=64.34.143.0/24 comment="United States" list=SafeCountries
add address=64.34.145.0/24 comment="United States" list=SafeCountries
add address=64.34.148.0/23 comment="United States" list=SafeCountries
add address=64.34.153.0-64.34.154.255 comment="United States" list=
SafeCountries
add address=64.34.156.0-64.34.220.255 comment="United States" list=
SafeCountries
add address=64.34.222.0-64.34.222.139 comment="United States" list=
SafeCountries
add address=64.34.222.144-64.34.226.255 comment="United States" list=
SafeCountries
add address=64.34.228.0/23 comment="United States" list=SafeCountries
add address=64.34.231.0/24 comment="United States" list=SafeCountries
add address=64.34.235.0-64.34.240.255 comment="United States" list=
SafeCountries
add address=64.34.242.0/24 comment="United States" list=SafeCountries
add address=64.34.244.0-64.34.255.191 comment="United States" list=
SafeCountries
add address=64.35.0.0-64.35.52.255 comment="United States" list=SafeCountries
add address=64.35.54.0/23 comment="United States" list=SafeCountries
add address=64.35.57.0-64.37.31.255 comment="United States" list=
SafeCountries
add address=64.37.48.0-64.37.66.255 comment="United States" list=
SafeCountries
add address=64.37.68.0-64.37.108.255 comment="United States" list=
SafeCountries
add address=64.37.110.0/24 comment="United States" list=SafeCountries
add address=64.37.112.0-64.37.114.255 comment="United States" list=
SafeCountries
add address=64.37.116.0-64.37.118.255 comment="United States" list=
SafeCountries
add address=64.37.120.0-64.37.124.255 comment="United States" list=
SafeCountries
add address=64.37.126.0-64.38.201.255 comment="United States" list=
SafeCountries
add address=64.38.203.0-64.39.39.255 comment="United States" list=
SafeCountries
add address=64.39.41.0-64.39.47.255 comment="United States" list=
SafeCountries
add address=64.39.49.0-64.39.159.255 comment="United States" list=
SafeCountries
add address=64.39.192.0-64.40.95.255 comment="United States" list=
SafeCountries
add address=64.40.119.0-64.40.120.255 comment="United States" list=
SafeCountries
add address=64.40.128.0/19 comment="United States" list=SafeCountries
add address=64.40.173.0/24 comment="United States" list=SafeCountries
add address=64.40.175.0/24 comment="United States" list=SafeCountries
add address=64.40.192.0-64.40.229.255 comment="United States" list=
SafeCountries
add address=64.40.231.0-64.40.239.255 comment="United States" list=
SafeCountries
add address=64.41.0.0-64.42.191.255 comment="United States" list=
SafeCountries
add address=64.43.0.0/16 comment="United States" list=SafeCountries
add address=64.45.0.0/16 comment="United States" list=SafeCountries
add address=64.46.64.0-64.47.111.255 comment="United States" list=
SafeCountries
add address=64.47.113.0-64.47.129.4 comment="United States" list=
SafeCountries
add address=64.47.129.6-64.47.227.255 comment="United States" list=
SafeCountries
add address=64.47.230.0-64.50.143.255 comment="United States" list=
SafeCountries
add address=64.50.160.0-64.56.127.255 comment="United States" list=
SafeCountries
add address=64.56.192.0/19 comment="United States" list=SafeCountries
add address=64.57.0.0-64.57.111.255 comment="United States" list=
SafeCountries
add address=64.57.128.0/21 comment="United States" list=SafeCountries
add address=64.57.144.0-64.59.127.255 comment="United States" list=
SafeCountries
add address=64.59.192.0-64.62.140.255 comment="United States" list=
SafeCountries
add address=64.62.142.0-64.62.169.255 comment="United States" list=
SafeCountries
add address=64.62.171.0-64.62.203.255 comment="United States" list=
SafeCountries
add address=64.62.205.0-64.62.237.255 comment="United States" list=
SafeCountries
add address=64.62.239.0-64.64.107.255 comment="United States" list=
SafeCountries
add address=64.64.109.0-64.64.120.255 comment="United States" list=
SafeCountries
add address=64.64.122.0/24 comment="United States" list=SafeCountries
add address=64.64.124.0-64.64.159.255 comment="United States" list=
SafeCountries
add address=64.64.192.0/19 comment="United States" list=SafeCountries
add address=64.65.0.0/16 comment="United States" list=SafeCountries
add address=64.66.32.0-64.66.223.255 comment="United States" list=
SafeCountries
add address=64.66.240.0-64.68.191.255 comment="United States" list=
SafeCountries
add address=64.68.208.0-64.69.63.255 comment="United States" list=
SafeCountries
add address=64.69.65.0/25 comment="United States" list=SafeCountries
add address=64.69.65.136-64.69.67.111 comment="United States" list=
SafeCountries
add address=64.69.67.120-64.69.68.84 comment="United States" list=
SafeCountries
add address=64.69.68.86-64.69.69.39 comment="United States" list=
SafeCountries
add address=64.69.69.48-64.69.69.127 comment="United States" list=
SafeCountries
add address=64.69.69.192/26 comment="United States" list=SafeCountries
add address=64.69.70.8-64.69.71.255 comment="United States" list=
SafeCountries
add address=64.69.75.8-64.69.78.55 comment="United States" list=SafeCountries
add address=64.69.78.64-64.69.78.255 comment="United States" list=
SafeCountries
add address=64.69.80.0-64.69.80.191 comment="United States" list=
SafeCountries
add address=64.69.81.0-64.69.81.159 comment="United States" list=
SafeCountries
add address=64.69.81.176/28 comment="United States" list=SafeCountries
add address=64.69.81.208-64.69.82.63 comment="United States" list=
SafeCountries
add address=64.69.82.192-64.69.83.95 comment="United States" list=
SafeCountries
add address=64.69.83.112-64.69.83.199 comment="United States" list=
SafeCountries
add address=64.69.83.204-64.69.83.255 comment="United States" list=
SafeCountries
add address=64.69.85.0-64.69.88.15 comment="United States" list=SafeCountries
add address=64.69.88.32-64.69.91.127 comment="United States" list=
SafeCountries
add address=64.69.91.136-64.69.91.255 comment="United States" list=
SafeCountries
add address=64.69.93.0-64.69.93.191 comment="United States" list=
SafeCountries
add address=64.69.93.224/27 comment="United States" list=SafeCountries
add address=64.69.96.0-64.70.77.255 comment="United States" list=
SafeCountries
add address=64.70.80.0-64.71.135.255 comment="United States" list=
SafeCountries
add address=64.71.137.0-64.71.169.255 comment="United States" list=
SafeCountries
add address=64.71.171.0/24 comment="United States" list=SafeCountries
add address=64.71.172.18 comment="United States" list=SafeCountries
add address=64.71.173.0-64.71.174.255 comment="United States" list=
SafeCountries
add address=64.71.176.0-64.71.230.175 comment="United States" list=
SafeCountries
add address=64.71.230.192-64.71.233.175 comment="United States" list=
SafeCountries
add address=64.71.233.192-64.71.236.47 comment="United States" list=
SafeCountries
add address=64.71.236.64-64.71.236.255 comment="United States" list=
SafeCountries
add address=64.71.238.0/23 comment="United States" list=SafeCountries
add address=64.72.0.0-64.72.223.255 comment="United States" list=
SafeCountries
add address=64.73.0.0-64.73.192.255 comment="United States" list=
SafeCountries
add address=64.73.194.0-64.75.255.255 comment="United States" list=
SafeCountries
add address=64.76.66.0/23 comment="United States" list=SafeCountries
add address=64.76.82.0/24 comment="United States" list=SafeCountries
add address=64.76.228.0-64.76.233.255 comment="United States" list=
SafeCountries
add address=64.76.235.0-64.78.161.255 comment="United States" list=
SafeCountries
add address=64.78.163.0-64.79.100.255 comment="United States" list=
SafeCountries
add address=64.79.102.0-64.79.146.255 comment="United States" list=
SafeCountries
add address=64.79.148.0-64.85.31.255 comment="United States" list=
SafeCountries
add address=64.85.40.208/29 comment="United States" list=SafeCountries
add address=64.85.64.0-64.85.255.255 comment="United States" list=
SafeCountries
add address=64.86.4.0/24 comment="United States" list=SafeCountries
add address=64.86.6.0-64.86.19.255 comment="United States" list=SafeCountries
add address=64.86.21.0-64.86.22.255 comment="United States" list=
SafeCountries
add address=64.86.28.0/23 comment="United States" list=SafeCountries
add address=64.86.36.0-64.86.38.255 comment="United States" list=
SafeCountries
add address=64.86.44.0-64.86.46.255 comment="United States" list=
SafeCountries
add address=64.86.48.0-64.86.53.255 comment="United States" list=
SafeCountries
add address=64.86.62.0/23 comment="United States" list=SafeCountries
add address=64.86.68.0-64.86.70.255 comment="United States" list=
SafeCountries
add address=64.86.77.0-64.86.89.255 comment="United States" list=
SafeCountries
add address=64.86.91.0-64.86.95.255 comment="United States" list=
SafeCountries
add address=64.86.99.0/24 comment="United States" list=SafeCountries
add address=64.86.101.0-64.86.107.255 comment="United States" list=
SafeCountries
add address=64.86.110.32-64.86.120.255 comment="United States" list=
SafeCountries
add address=64.86.123.0-64.86.124.255 comment="United States" list=
SafeCountries
add address=64.86.126.0-64.86.130.255 comment="United States" list=
SafeCountries
add address=64.86.132.0-64.86.139.255 comment="United States" list=
SafeCountries
add address=64.86.142.0-64.86.144.255 comment="United States" list=
SafeCountries
add address=64.86.146.0-64.86.152.255 comment="United States" list=
SafeCountries
add address=64.86.160.0/20 comment="United States" list=SafeCountries
add address=64.86.180.0-64.86.186.255 comment="United States" list=
SafeCountries
add address=64.86.188.0-64.86.192.255 comment="United States" list=
SafeCountries
add address=64.86.196.0-64.86.200.175 comment="United States" list=
SafeCountries
add address=64.86.200.192-64.86.209.255 comment="United States" list=
SafeCountries
add address=64.86.212.0-64.86.214.255 comment="United States" list=
SafeCountries
add address=64.86.216.0/21 comment="Costa Rica" list=SafeCountries
add address=64.86.227.0-64.86.243.63 comment="United States" list=
SafeCountries
add address=64.86.243.80-64.87.63.255 comment="United States" list=
SafeCountries
add address=64.88.0.0-64.88.225.255 comment="United States" list=
SafeCountries
add address=64.88.227.0/24 comment="United States" list=SafeCountries
add address=64.88.229.0-64.88.255.255 comment="United States" list=
SafeCountries
add address=64.89.16.0-64.89.191.255 comment="United States" list=
SafeCountries
add address=64.89.208.0-64.90.95.255 comment="United States" list=
SafeCountries
add address=64.90.112.0/23 comment="United States" list=SafeCountries
add address=64.90.116.0-64.93.95.255 comment="United States" list=
SafeCountries
add address=64.93.112.0-64.94.57.255 comment="United States" list=
SafeCountries
add address=64.94.59.0-64.94.236.255 comment="United States" list=
SafeCountries
add address=64.94.238.0-64.95.187.255 comment="United States" list=
SafeCountries
add address=64.95.190.0-64.95.220.255 comment="United States" list=
SafeCountries
add address=64.95.222.0-64.95.255.255 comment="United States" list=
SafeCountries
add address=64.98.240.0/20 comment="United States" list=SafeCountries
add address=64.100.0.0-64.103.25.232 comment="United States" list=
SafeCountries
add address=64.103.25.234-64.103.36.255 comment="United States" list=
SafeCountries
add address=64.103.38.0-64.104.43.255 comment="United States" list=
SafeCountries
add address=64.104.45.0-64.104.94.255 comment="United States" list=
SafeCountries
add address=64.104.96.0-64.104.124.255 comment="United States" list=
SafeCountries
add address=64.104.126.0-64.104.206.255 comment="United States" list=
SafeCountries
add address=64.104.208.0-64.104.247.255 comment="United States" list=
SafeCountries
add address=64.104.250.0-64.110.27.255 comment="United States" list=
SafeCountries
add address=64.110.51.0-64.110.63.255 comment="United States" list=
SafeCountries
add address=64.110.128.0/20 comment="United States" list=SafeCountries
add address=64.110.148.0-64.110.152.255 comment="United States" list=
SafeCountries
add address=64.110.154.0-64.110.191.255 comment="United States" list=
SafeCountries
add address=64.111.0.0-64.111.81.255 comment="United States" list=
SafeCountries
add address=64.111.83.0-64.111.85.255 comment="United States" list=
SafeCountries
add address=64.111.96.0-64.113.255.255 comment="United States" list=
SafeCountries
add address=64.115.0.0-64.116.99.255 comment="United States" list=
SafeCountries
add address=64.116.102.0-64.116.131.127 comment="United States" list=
SafeCountries
add address=64.116.132.0-64.116.134.191 comment="United States" list=
SafeCountries
add address=64.116.135.0-64.116.137.255 comment="United States" list=
SafeCountries
add address=64.116.140.0-64.116.160.255 comment="United States" list=
SafeCountries
add address=64.116.162.0-64.116.169.255 comment="United States" list=
SafeCountries
add address=64.116.171.0-64.116.183.255 comment="United States" list=
SafeCountries
add address=64.116.192.0/24 comment="United States" list=SafeCountries
add address=64.116.194.0/24 comment="United States" list=SafeCountries
add address=64.116.208.0/23 comment="United States" list=SafeCountries
add address=64.116.214.0/23 comment="United States" list=SafeCountries
add address=64.116.224.0/23 comment="United States" list=SafeCountries
add address=64.116.228.0-64.116.230.255 comment="United States" list=
SafeCountries
add address=64.116.232.0-64.117.0.255 comment="United States" list=
SafeCountries
add address=64.117.2.0/23 comment="United States" list=SafeCountries
add address=64.117.8.0-64.117.25.255 comment="United States" list=
SafeCountries
add address=64.117.27.0-64.117.39.255 comment="United States" list=
SafeCountries
add address=64.117.42.0-64.117.45.255 comment="United States" list=
SafeCountries
add address=64.117.47.0-64.117.131.255 comment="United States" list=
SafeCountries
add address=64.117.136.0/22 comment="United States" list=SafeCountries
add address=64.117.144.0-64.117.199.255 comment="United States" list=
SafeCountries
add address=64.117.208.0-64.117.208.72 comment="United States" list=
SafeCountries
add address=64.117.208.74-64.118.15.255 comment="United States" list=
SafeCountries
add address=64.118.32.0/20 comment="United States" list=SafeCountries
add address=64.118.52.0-64.118.56.255 comment="United States" list=
SafeCountries
add address=64.118.58.0-64.119.95.255 comment="United States" list=
SafeCountries
add address=64.119.128.0/18 comment="United States" list=SafeCountries
add address=64.119.224.0-64.120.129.255 comment="United States" list=
SafeCountries
add address=64.120.131.0-64.128.31.255 comment="United States" list=
SafeCountries
add address=64.128.40.0-64.130.207.255 comment="United States" list=
SafeCountries
add address=64.130.224.0-64.132.104.255 comment="United States" list=
SafeCountries
add address=64.132.106.0-64.136.111.255 comment="United States" list=
SafeCountries
add address=64.136.128.0-64.137.127.255 comment="United States" list=
SafeCountries
add address=64.138.0.0-64.138.10.255 comment="United States" list=
SafeCountries
add address=64.138.12.0-64.138.19.255 comment="United States" list=
SafeCountries
add address=64.138.22.0-64.140.111.255 comment="United States" list=
SafeCountries
add address=64.140.128.0/17 comment="United States" list=SafeCountries
add address=64.141.128.0-64.145.89.255 comment="United States" list=
SafeCountries
add address=64.145.92.0-64.147.79.255 comment="United States" list=
SafeCountries
add address=64.147.96.0-64.147.239.255 comment="United States" list=
SafeCountries
add address=64.148.0.0-64.150.191.255 comment="United States" list=
SafeCountries
add address=64.151.0.0-64.151.191.255 comment="United States" list=
SafeCountries
add address=64.152.0.0-64.152.135.255 comment="United States" list=
SafeCountries
add address=64.152.144.0-64.157.142.255 comment="United States" list=
SafeCountries
add address=64.157.144.0-64.158.222.255 comment="United States" list=
SafeCountries
add address=64.158.224.0-64.178.127.255 comment="United States" list=
SafeCountries
add address=64.178.160.0/19 comment="United States" list=SafeCountries
add address=64.178.198.0/24 comment="United States" list=SafeCountries
add address=64.178.224.0-64.179.207.255 comment="United States" list=
SafeCountries
add address=64.179.224.0/19 comment="United States" list=SafeCountries
add address=64.181.0.0-64.184.191.255 comment="United States" list=
SafeCountries
add address=64.184.224.0-64.185.191.255 comment="United States" list=
SafeCountries
add address=64.185.224.0-64.186.255.255 comment="United States" list=
SafeCountries
add address=64.187.64.0-64.187.175.255 comment="United States" list=
SafeCountries
add address=64.187.192.0-64.187.209.255 comment="United States" list=
SafeCountries
add address=64.187.212.0-64.191.31.255 comment="United States" list=
SafeCountries
add address=64.191.48.0-64.193.121.255 comment="United States" list=
SafeCountries
add address=64.193.124.0-64.201.31.255 comment="United States" list=
SafeCountries
add address=64.201.64.0-64.201.110.255 comment="United States" list=
SafeCountries
add address=64.201.112.0-64.201.159.255 comment="United States" list=
SafeCountries
add address=64.201.224.0-64.202.143.255 comment="United States" list=
SafeCountries
add address=64.202.160.0-64.208.48.255 comment="United States" list=
SafeCountries
add address=64.208.50.0-64.208.125.95 comment="United States" list=
SafeCountries
add address=64.208.125.112-64.208.158.135 comment="United States" list=
SafeCountries
add address=64.208.158.144-64.208.161.255 comment="United States" list=
SafeCountries
add address=64.208.163.0-64.208.170.153 comment="United States" list=
SafeCountries
add address=64.208.170.155-64.208.178.255 comment="United States" list=
SafeCountries
add address=64.208.180.0/23 comment="United States" list=SafeCountries
add address=64.208.183.0-64.208.209.255 comment="United States" list=
SafeCountries
add address=64.208.211.0-64.208.222.47 comment="United States" list=
SafeCountries
add address=64.208.222.52-64.209.7.255 comment="United States" list=
SafeCountries
add address=64.209.16.0-64.209.20.255 comment="United States" list=
SafeCountries
add address=64.209.22.0-64.209.37.255 comment="United States" list=
SafeCountries
add address=64.209.39.0-64.209.109.131 comment="United States" list=
SafeCountries
add address=64.209.109.136-64.209.225.255 comment="United States" list=
SafeCountries
add address=64.209.227.0-64.209.244.159 comment="United States" list=
SafeCountries
add address=64.209.244.168-64.209.244.223 comment="United States" list=
SafeCountries
add address=64.209.246.0-64.210.14.193 comment="United States" list=
SafeCountries
add address=64.210.14.195-64.210.39.255 comment="United States" list=
SafeCountries
add address=64.210.48.0-64.211.42.255 comment="United States" list=
SafeCountries
add address=64.211.44.0-64.211.74.255 comment="United States" list=
SafeCountries
add address=64.211.75.128-64.211.83.69 comment="United States" list=
SafeCountries
add address=64.211.83.71-64.211.149.255 comment="United States" list=
SafeCountries
add address=64.211.151.0-64.211.219.127 comment="United States" list=
SafeCountries
add address=64.211.220.0-64.212.76.255 comment="United States" list=
SafeCountries
add address=64.212.77.128-64.212.199.255 comment="United States" list=
SafeCountries
add address=64.212.201.0-64.212.225.95 comment="United States" list=
SafeCountries
add address=64.212.225.100-64.213.29.255 comment="United States" list=
SafeCountries
add address=64.213.31.0-64.213.52.31 comment="United States" list=
SafeCountries
add address=64.213.52.64-64.213.55.255 comment="United States" list=
SafeCountries
add address=64.213.64.0-64.213.97.191 comment="United States" list=
SafeCountries
add address=64.213.97.224-64.213.135.191 comment="United States" list=
SafeCountries
add address=64.213.136.0-64.213.165.255 comment="United States" list=
SafeCountries
add address=64.213.167.0-64.213.223.255 comment="United States" list=
SafeCountries
add address=64.214.0.0-64.214.65.255 comment="United States" list=
SafeCountries
add address=64.214.67.0-64.214.91.255 comment="United States" list=
SafeCountries
add address=64.214.93.0-64.214.126.159 comment="United States" list=
SafeCountries
add address=64.214.126.192-64.214.146.255 comment="United States" list=
SafeCountries
add address=64.214.148.0-64.214.214.255 comment="United States" list=
SafeCountries
add address=64.214.216.0-64.215.20.175 comment="United States" list=
SafeCountries
add address=64.215.20.184-64.215.21.255 comment="United States" list=
SafeCountries
add address=64.215.23.0-64.215.27.255 comment="United States" list=
SafeCountries
add address=64.215.29.0-64.215.81.255 comment="United States" list=
SafeCountries
add address=64.215.83.0-64.215.119.255 comment="United States" list=
SafeCountries
add address=64.215.128.0-64.215.160.255 comment="United States" list=
SafeCountries
add address=64.215.162.0-64.215.199.255 comment="United States" list=
SafeCountries
add address=64.215.201.0-64.216.81.175 comment="United States" list=
SafeCountries
add address=64.216.81.184-64.216.205.31 comment="United States" list=
SafeCountries
add address=64.216.205.40-64.217.193.223 comment="United States" list=
SafeCountries
add address=64.217.193.232-64.227.255.255 comment="United States" list=
SafeCountries
add address=64.232.0.0-64.233.172.255 comment="United States" list=
SafeCountries
add address=64.233.174.0-64.233.177.255 comment="United States" list=
SafeCountries
add address=64.233.179.0-64.235.32.255 comment="United States" list=
SafeCountries
add address=64.235.34.0-64.235.95.255 comment="United States" list=
SafeCountries
add address=64.235.114.0-64.235.116.255 comment="United States" list=
SafeCountries
add address=64.235.119.0-64.235.122.255 comment="United States" list=
SafeCountries
add address=64.235.128.0-64.235.157.255 comment="United States" list=
SafeCountries
add address=64.235.159.0-64.235.191.255 comment="United States" list=
SafeCountries
add address=64.235.224.0-64.236.8.255 comment="United States" list=
SafeCountries
add address=64.236.12.0-64.236.44.255 comment="United States" list=
SafeCountries
add address=64.236.46.0-64.236.99.255 comment="United States" list=
SafeCountries
add address=64.236.101.0-64.236.105.255 comment="United States" list=
SafeCountries
add address=64.236.108.0-64.236.159.255 comment="United States" list=
SafeCountries
add address=64.236.161.0-64.236.163.22 comment="United States" list=
SafeCountries
add address=64.236.163.24-64.236.215.255 comment="United States" list=
SafeCountries
add address=64.236.220.0/22 comment="United States" list=SafeCountries
add address=64.236.225.0-64.236.226.255 comment="United States" list=
SafeCountries
add address=64.236.229.0-64.237.34.127 comment="United States" list=
SafeCountries
add address=64.237.34.144-64.237.45.63 comment="United States" list=
SafeCountries
add address=64.237.45.80-64.237.127.255 comment="United States" list=
SafeCountries
add address=64.238.0.0-64.238.210.71 comment="United States" list=
SafeCountries
add address=64.238.210.80-64.238.210.191 comment="United States" list=
SafeCountries
add address=64.238.210.208-64.239.247.255 comment="United States" list=
SafeCountries
add address=64.239.249.0-64.240.219.255 comment="United States" list=
SafeCountries
add address=64.240.221.0-64.241.169.255 comment="United States" list=
SafeCountries
add address=64.241.172.0-64.246.69.255 comment="United States" list=
SafeCountries
add address=64.246.72.0/23 comment="United States" list=SafeCountries
add address=64.246.76.0-64.246.91.255 comment="United States" list=
SafeCountries
add address=64.246.94.0-64.247.127.255 comment="United States" list=
SafeCountries
add address=64.247.176.0-64.250.79.255 comment="United States" list=
SafeCountries
add address=64.250.96.0-64.251.63.255 comment="United States" list=
SafeCountries
add address=64.251.96.0-64.253.127.255 comment="United States" list=
SafeCountries
add address=64.253.160.0-64.253.255.255 comment="United States" list=
SafeCountries
add address=64.254.32.0-64.254.153.255 comment="United States" list=
SafeCountries
add address=64.254.155.0-64.254.223.255 comment="United States" list=
SafeCountries
add address=64.255.0.0-65.19.151.255 comment="United States" list=
SafeCountries
add address=65.19.153.0-65.19.167.255 comment="United States" list=
SafeCountries
add address=65.19.169.0-65.19.170.255 comment="United States" list=
SafeCountries
add address=65.19.172.0-65.19.187.255 comment="United States" list=
SafeCountries
add address=65.19.189.0-65.21.255.255 comment="United States" list=
SafeCountries
add address=65.23.0.0-65.23.191.255 comment="United States" list=
SafeCountries
add address=65.24.0.0-65.38.31.255 comment="United States" list=SafeCountries
add address=65.38.48.0/20 comment="United States" list=SafeCountries
add address=65.38.96.0-65.38.179.255 comment="United States" list=
SafeCountries
add address=65.38.181.0-65.38.191.255 comment="United States" list=
SafeCountries
add address=65.38.224.0/19 comment="United States" list=SafeCountries
add address=65.39.64.0-65.39.128.255 comment="United States" list=
SafeCountries
add address=65.39.130.0-65.39.132.255 comment="United States" list=
SafeCountries
add address=65.39.134.0/24 comment="United States" list=SafeCountries
add address=65.39.136.0-65.39.136.111 comment="United States" list=
SafeCountries
add address=65.39.136.120-65.39.136.255 comment="United States" list=
SafeCountries
add address=65.39.138.0/24 comment="United States" list=SafeCountries
add address=65.39.140.0-65.39.140.143 comment="United States" list=
SafeCountries
add address=65.39.140.152-65.39.140.255 comment="United States" list=
SafeCountries
add address=65.39.143.0-65.39.143.175 comment="United States" list=
SafeCountries
add address=65.39.143.192-65.39.144.95 comment="United States" list=
SafeCountries
add address=65.39.144.128-65.39.151.255 comment="United States" list=
SafeCountries
add address=65.39.153.0-65.39.155.219 comment="United States" list=
SafeCountries
add address=65.39.155.224/27 comment="United States" list=SafeCountries
add address=65.39.159.0/24 comment="United States" list=SafeCountries
add address=65.39.162.0/23 comment="United States" list=SafeCountries
add address=65.39.165.0-65.39.167.255 comment="United States" list=
SafeCountries
add address=65.39.170.0-65.39.175.255 comment="United States" list=
SafeCountries
add address=65.39.177.0-65.39.177.159 comment="United States" list=
SafeCountries
add address=65.39.177.176-65.39.177.255 comment="United States" list=
SafeCountries
add address=65.39.179.0/24 comment="United States" list=SafeCountries
add address=65.39.184.0/25 comment="United States" list=SafeCountries
add address=65.39.185.0-65.39.186.191 comment="United States" list=
SafeCountries
add address=65.39.186.208-65.39.186.255 comment="United States" list=
SafeCountries
add address=65.39.191.0-65.39.191.111 comment="United States" list=
SafeCountries
add address=65.39.191.128-65.39.199.255 comment="United States" list=
SafeCountries
add address=65.39.201.0-65.39.202.255 comment="United States" list=
SafeCountries
add address=65.39.204.0-65.39.208.255 comment="United States" list=
SafeCountries
add address=65.39.212.0-65.39.217.255 comment="United States" list=
SafeCountries
add address=65.39.220.0-65.39.224.255 comment="United States" list=
SafeCountries
add address=65.39.227.0-65.39.235.255 comment="United States" list=
SafeCountries
add address=65.39.237.0/28 comment="United States" list=SafeCountries
add address=65.39.237.24-65.39.237.255 comment="United States" list=
SafeCountries
add address=65.39.241.0/24 comment="United States" list=SafeCountries
add address=65.39.243.0/24 comment="United States" list=SafeCountries
add address=65.39.245.128/25 comment="United States" list=SafeCountries
add address=65.39.247.0/25 comment="United States" list=SafeCountries
add address=65.39.247.144-65.39.252.255 comment="United States" list=
SafeCountries
add address=65.39.255.0-65.48.127.255 comment="United States" list=
SafeCountries
add address=65.49.0.0-65.49.14.165 comment="United States" list=SafeCountries
add address=65.49.14.167-65.52.63.255 comment="United States" list=
SafeCountries
add address=65.52.80.0-65.52.127.255 comment="United States" list=
SafeCountries
add address=65.52.192.0/19 comment="United States" list=SafeCountries
add address=65.52.232.0-65.52.247.255 comment="United States" list=
SafeCountries
add address=65.53.0.0-65.54.23.255 comment="United States" list=SafeCountries
add address=65.54.25.192/26 comment="United States" list=SafeCountries
add address=65.54.26.160/27 comment="United States" list=SafeCountries
add address=65.54.26.224/29 comment="United States" list=SafeCountries
add address=65.54.26.240-65.54.27.191 comment="United States" list=
SafeCountries
add address=65.54.27.224/27 comment="United States" list=SafeCountries
add address=65.54.32.232-65.54.34.223 comment="United States" list=
SafeCountries
add address=65.54.35.32-65.54.35.255 comment="United States" list=
SafeCountries
add address=65.54.41.0-65.54.65.255 comment="United States" list=
SafeCountries
add address=65.54.67.32-65.54.75.255 comment="United States" list=
SafeCountries
add address=65.54.77.0-65.54.81.255 comment="United States" list=
SafeCountries
add address=65.54.83.0-65.54.84.255 comment="United States" list=
SafeCountries
add address=65.54.86.0/23 comment="United States" list=SafeCountries
add address=65.54.90.0-65.54.119.255 comment="United States" list=
SafeCountries
add address=65.54.128.0-65.54.162.15 comment="United States" list=
SafeCountries
add address=65.54.162.32-65.54.162.95 comment="United States" list=
SafeCountries
add address=65.54.162.112-65.55.94.47 comment="United States" list=
SafeCountries
add address=65.55.94.64-65.61.191.255 comment="United States" list=
SafeCountries
add address=65.62.0.0-65.75.63.255 comment="United States" list=SafeCountries
add address=65.75.128.0-65.77.243.255 comment="United States" list=
SafeCountries
add address=65.77.246.0-65.87.223.255 comment="United States" list=
SafeCountries
add address=65.88.0.0-65.88.253.255 comment="United States" list=
SafeCountries
add address=65.89.0.0-65.91.255.255 comment="United States" list=
SafeCountries
add address=65.96.0.0-65.97.31.255 comment="United States" list=SafeCountries
add address=65.97.48.0-65.97.57.255 comment="United States" list=
SafeCountries
add address=65.97.59.0-65.97.191.255 comment="United States" list=
SafeCountries
add address=65.98.0.0-65.100.13.155 comment="United States" list=
SafeCountries
add address=65.100.13.160-65.109.255.255 comment="United States" list=
SafeCountries
add address=65.110.32.0-65.110.159.255 comment="United States" list=
SafeCountries
add address=65.110.224.0-65.111.143.255 comment="United States" list=
SafeCountries
add address=65.111.160.0-65.112.144.255 comment="United States" list=
SafeCountries
add address=65.112.146.72/29 comment="United States" list=SafeCountries
add address=65.112.149.0-65.113.87.255 comment="United States" list=
SafeCountries
add address=65.113.88.16/28 comment="United States" list=SafeCountries
add address=65.113.88.72/29 comment="United States" list=SafeCountries
add address=65.113.88.192/26 comment="United States" list=SafeCountries
add address=65.113.92.168/29 comment="United States" list=SafeCountries
add address=65.113.96.0/21 comment="United States" list=SafeCountries
add address=65.113.112.0-65.115.56.255 comment="United States" list=
SafeCountries
add address=65.115.57.8-65.115.57.23 comment="United States" list=
SafeCountries
add address=65.115.57.32-65.127.193.103 comment="United States" list=
SafeCountries
add address=65.127.193.112-65.152.96.39 comment="United States" list=
SafeCountries
add address=65.152.96.48-65.161.199.255 comment="United States" list=
SafeCountries
add address=65.161.201.0-65.162.183.255 comment="United States" list=
SafeCountries
add address=65.162.186.0-65.162.213.255 comment="United States" list=
SafeCountries
add address=65.162.216.0-65.163.91.255 comment="United States" list=
SafeCountries
add address=65.163.93.0-65.163.240.255 comment="United States" list=
SafeCountries
add address=65.163.242.0-65.164.2.255 comment="United States" list=
SafeCountries
add address=65.164.4.0-65.164.144.255 comment="United States" list=
SafeCountries
add address=65.164.146.0/23 comment="United States" list=SafeCountries
add address=65.164.152.0-65.165.79.255 comment="United States" list=
SafeCountries
add address=65.165.88.0-65.166.15.175 comment="United States" list=
SafeCountries
add address=65.166.15.192-65.166.108.255 comment="United States" list=
SafeCountries
add address=65.166.110.0-65.166.239.255 comment="United States" list=
SafeCountries
add address=65.166.248.0/24 comment="United States" list=SafeCountries
add address=65.166.250.0-65.167.23.255 comment="United States" list=
SafeCountries
add address=65.167.32.0/20 comment="United States" list=SafeCountries
add address=65.167.64.0/20 comment="United States" list=SafeCountries
add address=65.167.96.0-65.168.51.255 comment="United States" list=
SafeCountries
add address=65.168.54.0-65.168.177.255 comment="United States" list=
SafeCountries
add address=65.168.180.0-65.169.158.255 comment="United States" list=
SafeCountries
add address=65.169.160.0-65.169.217.255 comment="United States" list=
SafeCountries
add address=65.169.220.0-65.170.30.255 comment="United States" list=
SafeCountries
add address=65.170.32.0/19 comment="United States" list=SafeCountries
add address=65.170.72.0-65.170.82.255 comment="United States" list=
SafeCountries
add address=65.170.84.0-65.171.97.255 comment="United States" list=
SafeCountries
add address=65.171.100.0-65.171.163.255 comment="United States" list=
SafeCountries
add address=65.171.166.0-65.172.1.255 comment="United States" list=
SafeCountries
add address=65.172.3.0/24 comment="United States" list=SafeCountries
add address=65.172.6.0-65.172.23.255 comment="United States" list=
SafeCountries
add address=65.172.28.0-65.172.47.255 comment="United States" list=
SafeCountries
add address=65.172.52.0-65.172.179.255 comment="United States" list=
SafeCountries
add address=65.172.181.0-65.173.47.255 comment="United States" list=
SafeCountries
add address=65.173.50.0-65.173.55.255 comment="United States" list=
SafeCountries
add address=65.173.64.0-65.173.189.255 comment="United States" list=
SafeCountries
add address=65.173.191.0-65.175.16.127 comment="United States" list=
SafeCountries
add address=65.175.17.0-65.175.65.255 comment="United States" list=
SafeCountries
add address=65.175.67.0/24 comment="United States" list=SafeCountries
add address=65.175.70.0/23 comment="United States" list=SafeCountries
add address=65.175.73.0-65.175.75.255 comment="United States" list=
SafeCountries
add address=65.175.77.0-65.175.88.255 comment="United States" list=
SafeCountries
add address=65.175.90.0-65.181.31.255 comment="United States" list=
SafeCountries
add address=65.181.48.0-65.181.255.255 comment="United States" list=
SafeCountries
add address=65.182.7.0-65.182.9.255 comment="United States" list=
SafeCountries
add address=65.182.11.0-65.182.30.255 comment="Costa Rica" list=SafeCountries
add address=65.182.32.0-65.182.255.255 comment="United States" list=
SafeCountries
add address=65.183.16.0-65.194.45.255 comment="United States" list=
SafeCountries
add address=65.194.47.0-65.198.207.255 comment="United States" list=
SafeCountries
add address=65.198.216.0-65.199.167.255 comment="United States" list=
SafeCountries
add address=65.199.176.0-65.199.243.255 comment="United States" list=
SafeCountries
add address=65.199.246.0-65.204.165.255 comment="United States" list=
SafeCountries
add address=65.204.167.0-65.205.132.255 comment="United States" list=
SafeCountries
add address=65.205.134.0-65.205.149.255 comment="United States" list=
SafeCountries
add address=65.205.151.0-65.205.167.255 comment="United States" list=
SafeCountries
add address=65.205.170.0-65.208.63.255 comment="United States" list=
SafeCountries
add address=65.208.72.0-65.209.191.255 comment="United States" list=
SafeCountries
add address=65.209.194.0-65.213.54.255 comment="United States" list=
SafeCountries
add address=65.213.56.0-65.218.143.255 comment="United States" list=
SafeCountries
add address=65.218.152.0-65.219.110.255 comment="United States" list=
SafeCountries
add address=65.219.112.0-65.222.122.255 comment="United States" list=
SafeCountries
add address=65.222.124.0-65.231.239.255 comment="United States" list=
SafeCountries
add address=65.232.0.0-65.242.9.143 comment="United States" list=
SafeCountries
add address=65.242.9.152-65.243.99.255 comment="United States" list=
SafeCountries
add address=65.243.104.0-65.243.119.255 comment="United States" list=
SafeCountries
add address=65.243.122.0-65.247.134.255 comment="United States" list=
SafeCountries
add address=65.247.135.0/24 comment="Costa Rica" list=SafeCountries
add address=65.247.136.0-65.247.203.255 comment="United States" list=
SafeCountries
add address=65.247.208.0-65.247.239.255 comment="United States" list=
SafeCountries
add address=65.247.248.0-65.255.35.255 comment="United States" list=
SafeCountries
add address=65.255.40.0/21 comment="United States" list=SafeCountries
add address=65.255.64.0-65.255.175.255 comment="United States" list=
SafeCountries
add address=65.255.192.0/19 comment="United States" list=SafeCountries
add address=65.255.240.0-66.6.47.255 comment="United States" list=
SafeCountries
add address=66.6.64.0-66.7.255.255 comment="United States" list=SafeCountries
add address=66.8.128.0-66.9.34.255 comment="United States" list=SafeCountries
add address=66.9.38.0-66.9.47.255 comment="United States" list=SafeCountries
add address=66.9.54.0-66.9.56.255 comment="United States" list=SafeCountries
add address=66.9.58.0-66.9.79.255 comment="United States" list=SafeCountries
add address=66.9.82.0-66.9.84.255 comment="United States" list=SafeCountries
add address=66.9.86.0-66.9.90.255 comment="United States" list=SafeCountries
add address=66.9.92.0/24 comment="United States" list=SafeCountries
add address=66.9.94.0-66.9.159.255 comment="United States" list=SafeCountries
add address=66.9.162.0-66.9.193.255 comment="United States" list=
SafeCountries
add address=66.9.198.0-66.9.235.255 comment="United States" list=
SafeCountries
add address=66.9.238.0-66.9.240.255 comment="United States" list=
SafeCountries
add address=66.9.242.0/23 comment="United States" list=SafeCountries
add address=66.9.245.0-66.11.31.255 comment="United States" list=
SafeCountries
add address=66.11.48.0/20 comment="United States" list=SafeCountries
add address=66.11.96.0-66.11.143.255 comment="United States" list=
SafeCountries
add address=66.11.192.0-66.18.63.255 comment="United States" list=
SafeCountries
add address=66.18.96.0-66.18.191.255 comment="United States" list=
SafeCountries
add address=66.19.0.0-66.36.127.255 comment="United States" list=
SafeCountries
add address=66.36.160.0-66.36.195.255 comment="United States" list=
SafeCountries
add address=66.36.197.0-66.36.200.255 comment="United States" list=
SafeCountries
add address=66.36.202.0/24 comment="United States" list=SafeCountries
add address=66.36.204.0-66.36.211.255 comment="United States" list=
SafeCountries
add address=66.36.217.0-66.38.127.255 comment="United States" list=
SafeCountries
add address=66.39.0.0-66.40.2.255 comment="United States" list=SafeCountries
add address=66.40.4.0/22 comment="United States" list=SafeCountries
add address=66.40.9.0-66.40.36.255 comment="United States" list=SafeCountries
add address=66.40.38.0-66.40.65.255 comment="United States" list=
SafeCountries
add address=66.40.67.0-66.43.47.255 comment="United States" list=
SafeCountries
add address=66.43.64.0-66.45.96.255 comment="United States" list=
SafeCountries
add address=66.45.97.128/26 comment="United States" list=SafeCountries
add address=66.45.97.224-66.45.255.255 comment="United States" list=
SafeCountries
add address=66.47.0.0-66.48.6.15 comment="United States" list=SafeCountries
add address=66.48.6.24-66.48.8.255 comment="United States" list=SafeCountries
add address=66.48.11.0/24 comment="United States" list=SafeCountries
add address=66.48.18.0-66.48.20.255 comment="United States" list=
SafeCountries
add address=66.48.25.0/24 comment="United States" list=SafeCountries
add address=66.48.27.0/24 comment="United States" list=SafeCountries
add address=66.48.30.0/24 comment="United States" list=SafeCountries
add address=66.48.32.0/24 comment="United States" list=SafeCountries
add address=66.48.35.0-66.48.36.255 comment="United States" list=
SafeCountries
add address=66.48.38.0/24 comment="United States" list=SafeCountries
add address=66.48.44.0-66.48.85.255 comment="United States" list=
SafeCountries
add address=66.48.89.0/24 comment="United States" list=SafeCountries
add address=66.48.92.0/23 comment="United States" list=SafeCountries
add address=66.48.95.0-66.48.118.255 comment="United States" list=
SafeCountries
add address=66.48.124.0/24 comment="United States" list=SafeCountries
add address=66.48.126.0-66.49.127.255 comment="United States" list=
SafeCountries
add address=66.50.56.0/24 comment="United States" list=SafeCountries
add address=66.50.59.0-66.50.65.255 comment="United States" list=
SafeCountries
add address=66.50.67.0-66.50.84.255 comment="United States" list=
SafeCountries
add address=66.50.86.0-66.50.88.192 comment="United States" list=
SafeCountries
add address=66.50.100.0/23 comment="United States" list=SafeCountries
add address=66.51.0.0-66.51.61.255 comment="United States" list=SafeCountries
add address=66.51.63.0-66.51.95.255 comment="United States" list=
SafeCountries
add address=66.51.144.0/20 comment="United States" list=SafeCountries
add address=66.51.176.0-66.51.239.255 comment="United States" list=
SafeCountries
add address=66.52.0.0-66.54.71.255 comment="United States" list=SafeCountries
add address=66.54.76.0-66.54.85.255 comment="United States" list=
SafeCountries
add address=66.54.87.0-66.54.92.255 comment="United States" list=
SafeCountries
add address=66.54.94.0-66.54.111.255 comment="United States" list=
SafeCountries
add address=66.54.128.0-66.54.203.255 comment="United States" list=
SafeCountries
add address=66.54.205.0-66.55.111.255 comment="United States" list=
SafeCountries
add address=66.55.128.0-66.59.127.255 comment="United States" list=
SafeCountries
add address=66.59.192.0/18 comment="United States" list=SafeCountries
add address=66.60.64.0-66.71.127.255 comment="United States" list=
SafeCountries
add address=66.71.192.0-66.78.63.255 comment="United States" list=
SafeCountries
add address=66.78.128.0-66.79.223.255 comment="United States" list=
SafeCountries
add address=66.80.0.0-66.85.11.255 comment="United States" list=SafeCountries
add address=66.85.14.0/23 comment="United States" list=SafeCountries
add address=66.85.20.0-66.85.27.255 comment="United States" list=
SafeCountries
add address=66.85.32.0/23 comment="United States" list=SafeCountries
add address=66.85.35.0-66.85.89.255 comment="United States" list=
SafeCountries
add address=66.85.92.0-66.85.159.255 comment="United States" list=
SafeCountries
add address=66.85.160.8-66.85.251.255 comment="United States" list=
SafeCountries
add address=66.85.254.0/24 comment="United States" list=SafeCountries
add address=66.86.0.0-66.96.15.255 comment="United States" list=SafeCountries
add address=66.96.37.0/24 comment="United States" list=SafeCountries
add address=66.96.42.0-66.96.45.255 comment="United States" list=
SafeCountries
add address=66.96.48.0/24 comment="United States" list=SafeCountries
add address=66.96.62.0/24 comment="United States" list=SafeCountries
add address=66.96.64.0-66.96.191.255 comment="United States" list=
SafeCountries
add address=66.97.0.0/20 comment="United States" list=SafeCountries
add address=66.97.32.0/19 comment="United States" list=SafeCountries
add address=66.97.96.0-66.97.255.255 comment="United States" list=
SafeCountries
add address=66.98.96.0-66.100.16.255 comment="United States" list=
SafeCountries
add address=66.100.18.0/23 comment="United States" list=SafeCountries
add address=66.100.22.0-66.102.14.131 comment="United States" list=
SafeCountries
add address=66.102.14.134-66.102.63.255 comment="United States" list=
SafeCountries
add address=66.102.96.0-66.103.31.255 comment="United States" list=
SafeCountries
add address=66.103.64.0-66.103.191.255 comment="United States" list=
SafeCountries
add address=66.103.224.0-66.109.255.255 comment="United States" list=
SafeCountries
add address=66.110.4.0/23 comment="United States" list=SafeCountries
add address=66.110.8.0-66.110.25.255 comment="United States" list=
SafeCountries
add address=66.110.27.0-66.110.31.255 comment="United States" list=
SafeCountries
add address=66.110.32.64-66.110.32.163 comment="United States" list=
SafeCountries
add address=66.110.32.192-66.110.36.255 comment="United States" list=
SafeCountries
add address=66.110.40.0/29 comment="United States" list=SafeCountries
add address=66.110.40.16-66.110.47.255 comment="United States" list=
SafeCountries
add address=66.110.50.0-66.110.57.255 comment="United States" list=
SafeCountries
add address=66.110.59.0/24 comment="United States" list=SafeCountries
add address=66.110.61.0-66.110.73.255 comment="United States" list=
SafeCountries
add address=66.110.76.0-66.110.109.255 comment="United States" list=
SafeCountries
add address=66.110.176.0-66.112.175.255 comment="United States" list=
SafeCountries
add address=66.112.192.0-66.113.111.255 comment="United States" list=
SafeCountries
add address=66.113.128.0-66.115.172.255 comment="United States" list=
SafeCountries
add address=66.115.174.0/23 comment="United States" list=SafeCountries
add address=66.115.177.0-66.119.68.127 comment="United States" list=
SafeCountries
add address=66.119.68.160-66.119.71.255 comment="United States" list=
SafeCountries
add address=66.119.78.0/23 comment="United States" list=SafeCountries
add address=66.119.84.0/23 comment="United States" list=SafeCountries
add address=66.119.87.0/24 comment="United States" list=SafeCountries
add address=66.119.96.0/19 comment="United States" list=SafeCountries
add address=66.119.144.0-66.119.148.255 comment="United States" list=
SafeCountries
add address=66.119.150.0/26 comment="United States" list=SafeCountries
add address=66.119.150.128-66.119.155.255 comment="United States" list=
SafeCountries
add address=66.119.157.144-66.119.158.127 comment="United States" list=
SafeCountries
add address=66.119.158.160-66.119.159.255 comment="United States" list=
SafeCountries
add address=66.119.192.0-66.128.31.255 comment="United States" list=
SafeCountries
add address=66.128.48.0-66.128.79.255 comment="United States" list=
SafeCountries
add address=66.128.96.0-66.129.127.255 comment="United States" list=
SafeCountries
add address=66.129.192.0/18 comment="United States" list=SafeCountries
add address=66.132.0.0-66.133.5.255 comment="United States" list=
SafeCountries
add address=66.133.7.0/24 comment="United States" list=SafeCountries
add address=66.133.9.0-66.133.12.255 comment="United States" list=
SafeCountries
add address=66.133.14.0-66.133.44.255 comment="United States" list=
SafeCountries
add address=66.133.46.0-66.133.56.255 comment="United States" list=
SafeCountries
add address=66.133.60.0-66.133.74.255 comment="United States" list=
SafeCountries
add address=66.133.76.0/24 comment="United States" list=SafeCountries
add address=66.133.78.0/24 comment="United States" list=SafeCountries
add address=66.133.96.0-66.135.95.255 comment="United States" list=
SafeCountries
add address=66.135.128.0-66.146.127.255 comment="United States" list=
SafeCountries
add address=66.146.160.0-66.150.43.255 comment="United States" list=
SafeCountries
add address=66.150.45.0-66.150.60.255 comment="United States" list=
SafeCountries
add address=66.150.62.0-66.151.24.255 comment="United States" list=
SafeCountries
add address=66.151.26.0-66.152.63.255 comment="United States" list=
SafeCountries
add address=66.152.96.0-66.154.95.255 comment="United States" list=
SafeCountries
add address=66.154.108.0/24 comment="United States" list=SafeCountries
add address=66.154.123.128/27 comment="United States" list=SafeCountries
add address=66.154.128.0-66.155.17.223 comment="United States" list=
SafeCountries
add address=66.155.18.0-66.155.22.255 comment="United States" list=
SafeCountries
add address=66.155.23.64-66.155.25.255 comment="United States" list=
SafeCountries
add address=66.155.27.0-66.155.63.255 comment="United States" list=
SafeCountries
add address=66.155.66.0-66.155.100.255 comment="United States" list=
SafeCountries
add address=66.155.101.64-66.158.127.255 comment="United States" list=
SafeCountries
add address=66.158.160.0-66.159.31.255 comment="United States" list=
SafeCountries
add address=66.159.48.0-66.159.107.255 comment="United States" list=
SafeCountries
add address=66.159.128.0-66.160.129.255 comment="United States" list=
SafeCountries
add address=66.160.131.0-66.160.160.255 comment="United States" list=
SafeCountries
add address=66.160.163.0/24 comment="United States" list=SafeCountries
add address=66.160.166.0-66.160.184.255 comment="United States" list=
SafeCountries
add address=66.160.186.0-66.162.255.255 comment="United States" list=
SafeCountries
add address=66.163.32.0/19 comment="United States" list=SafeCountries
add address=66.163.80.0-66.163.191.255 comment="United States" list=
SafeCountries
add address=66.163.208.0-66.165.64.255 comment="United States" list=
SafeCountries
add address=66.165.66.0-66.165.81.255 comment="United States" list=
SafeCountries
add address=66.165.84.0-66.165.86.255 comment="United States" list=
SafeCountries
add address=66.165.89.0-66.165.90.255 comment="United States" list=
SafeCountries
add address=66.165.92.0-66.165.101.255 comment="United States" list=
SafeCountries
add address=66.165.103.0-66.165.113.255 comment="United States" list=
SafeCountries
add address=66.165.115.0-66.165.117.255 comment="United States" list=
SafeCountries
add address=66.165.120.0-66.165.122.255 comment="United States" list=
SafeCountries
add address=66.165.124.0/24 comment="United States" list=SafeCountries
add address=66.165.126.0-66.165.191.255 comment="United States" list=
SafeCountries
add address=66.165.224.0-66.170.143.255 comment="United States" list=
SafeCountries
add address=66.170.160.0-66.170.179.255 comment="United States" list=
SafeCountries
add address=66.170.184.0-66.171.47.255 comment="United States" list=
SafeCountries
add address=66.171.64.0/19 comment="United States" list=SafeCountries
add address=66.171.112.0/20 comment="United States" list=SafeCountries
add address=66.171.144.0/20 comment="United States" list=SafeCountries
add address=66.171.176.0-66.175.99.255 comment="United States" list=
SafeCountries
add address=66.175.101.0-66.175.110.255 comment="United States" list=
SafeCountries
add address=66.175.112.0-66.175.122.255 comment="United States" list=
SafeCountries
add address=66.175.124.0-66.177.255.255 comment="United States" list=
SafeCountries
add address=66.178.46.0/24 comment="United States" list=SafeCountries
add address=66.178.99.0/24 comment="United States" list=SafeCountries
add address=66.178.128.0-66.180.63.255 comment="United States" list=
SafeCountries
add address=66.180.72.0-66.181.58.15 comment="United States" list=
SafeCountries
add address=66.181.58.24-66.181.58.47 comment="United States" list=
SafeCountries
add address=66.181.58.56/29 comment="United States" list=SafeCountries
add address=66.181.58.80-66.181.58.127 comment="United States" list=
SafeCountries
add address=66.181.58.136-66.181.58.159 comment="United States" list=
SafeCountries
add address=66.181.58.176-66.181.59.223 comment="United States" list=
SafeCountries
add address=66.181.59.232-66.181.61.175 comment="United States" list=
SafeCountries
add address=66.181.61.184-66.181.61.247 comment="United States" list=
SafeCountries
add address=66.181.62.0-66.181.62.39 comment="United States" list=
SafeCountries
add address=66.181.62.48-66.181.62.79 comment="United States" list=
SafeCountries
add address=66.181.62.88-66.181.63.7 comment="United States" list=
SafeCountries
add address=66.181.63.16-66.181.207.255 comment="United States" list=
SafeCountries
add address=66.181.224.0-66.182.255.255 comment="United States" list=
SafeCountries
add address=66.184.0.0-66.185.31.255 comment="United States" list=
SafeCountries
add address=66.185.43.240-66.185.45.255 comment="United States" list=
SafeCountries
add address=66.185.64.0/20 comment="United States" list=SafeCountries
add address=66.185.96.0-66.185.191.255 comment="United States" list=
SafeCountries
add address=66.185.224.0-66.186.3.63 comment="United States" list=
SafeCountries
add address=66.186.3.128-66.186.63.255 comment="United States" list=
SafeCountries
add address=66.186.96.0-66.187.25.255 comment="United States" list=
SafeCountries
add address=66.187.28.0-66.187.79.255 comment="United States" list=
SafeCountries
add address=66.187.96.0/20 comment="United States" list=SafeCountries
add address=66.187.128.0-66.187.235.255 comment="United States" list=
SafeCountries
add address=66.187.237.0-66.187.238.255 comment="United States" list=
SafeCountries
add address=66.188.0.0-66.196.31.255 comment="United States" list=
SafeCountries
add address=66.196.48.0-66.196.70.255 comment="United States" list=
SafeCountries
add address=66.196.72.0-66.198.9.255 comment="United States" list=
SafeCountries
add address=66.198.10.48-66.198.38.255 comment="United States" list=
SafeCountries
add address=66.198.40.0/24 comment="United States" list=SafeCountries
add address=66.198.42.0/23 comment="United States" list=SafeCountries
add address=66.198.56.0-66.198.87.255 comment="United States" list=
SafeCountries
add address=66.198.97.0-66.198.133.255 comment="United States" list=
SafeCountries
add address=66.198.135.0/24 comment="United States" list=SafeCountries
add address=66.198.140.0-66.198.146.255 comment="United States" list=
SafeCountries
add address=66.198.150.0-66.198.156.255 comment="United States" list=
SafeCountries
add address=66.198.158.0-66.198.167.255 comment="United States" list=
SafeCountries
add address=66.198.176.0-66.199.31.255 comment="United States" list=
SafeCountries
add address=66.199.48.0-66.199.127.255 comment="United States" list=
SafeCountries
add address=66.199.130.0-66.199.131.111 comment="United States" list=
SafeCountries
add address=66.199.131.128-66.199.133.255 comment="United States" list=
SafeCountries
add address=66.199.135.0-66.199.136.255 comment="United States" list=
SafeCountries
add address=66.199.138.0/24 comment="United States" list=SafeCountries
add address=66.199.141.0-66.199.142.247 comment="United States" list=
SafeCountries
add address=66.199.142.252-66.199.143.255 comment="United States" list=
SafeCountries
add address=66.199.145.0-66.199.146.255 comment="United States" list=
SafeCountries
add address=66.199.149.0-66.199.149.239 comment="United States" list=
SafeCountries
add address=66.199.150.0-66.199.150.159 comment="United States" list=
SafeCountries
add address=66.199.150.175-66.199.150.239 comment="United States" list=
SafeCountries
add address=66.199.151.0/24 comment="United States" list=SafeCountries
add address=66.199.153.0/24 comment="United States" list=SafeCountries
add address=66.199.155.0/24 comment="United States" list=SafeCountries
add address=66.199.158.0/24 comment="United States" list=SafeCountries
add address=66.199.160.0-66.199.161.63 comment="United States" list=
SafeCountries
add address=66.199.161.128/27 comment="United States" list=SafeCountries
add address=66.199.161.176-66.199.161.255 comment="United States" list=
SafeCountries
add address=66.199.164.0-66.199.166.37 comment="United States" list=
SafeCountries
add address=66.199.166.39-66.199.166.255 comment="United States" list=
SafeCountries
add address=66.199.168.64-66.199.168.159 comment="United States" list=
SafeCountries
add address=66.199.168.168-66.199.168.255 comment="United States" list=
SafeCountries
add address=66.199.173.0-66.199.173.231 comment="United States" list=
SafeCountries
add address=66.199.173.240/28 comment="United States" list=SafeCountries
add address=66.199.176.0-66.199.184.255 comment="United States" list=
SafeCountries
add address=66.199.186.0-66.199.189.255 comment="United States" list=
SafeCountries
add address=66.199.192.0-66.201.68.255 comment="United States" list=
SafeCountries
add address=66.201.70.0/23 comment="United States" list=SafeCountries
add address=66.201.73.0-66.201.79.255 comment="United States" list=
SafeCountries
add address=66.201.81.0-66.201.87.255 comment="United States" list=
SafeCountries
add address=66.201.89.0-66.201.91.255 comment="United States" list=
SafeCountries
add address=66.201.94.0-66.201.96.255 comment="United States" list=
SafeCountries
add address=66.201.98.0/24 comment="United States" list=SafeCountries
add address=66.201.100.0-66.201.107.255 comment="United States" list=
SafeCountries
add address=66.201.109.0-66.201.110.255 comment="United States" list=
SafeCountries
add address=66.201.112.0-66.201.116.255 comment="United States" list=
SafeCountries
add address=66.201.118.0-66.201.125.255 comment="United States" list=
SafeCountries
add address=66.201.127.0-66.201.159.255 comment="United States" list=
SafeCountries
add address=66.201.184.0/22 comment="United States" list=SafeCountries
add address=66.201.190.0/24 comment="United States" list=SafeCountries
add address=66.202.0.0-66.203.159.255 comment="United States" list=
SafeCountries
add address=66.203.224.0-66.205.22.255 comment="United States" list=
SafeCountries
add address=66.205.24.0-66.205.35.255 comment="United States" list=
SafeCountries
add address=66.205.40.0/24 comment="United States" list=SafeCountries
add address=66.205.42.0-66.205.47.255 comment="United States" list=
SafeCountries
add address=66.205.49.0-66.205.51.255 comment="United States" list=
SafeCountries
add address=66.205.53.0-66.206.223.255 comment="United States" list=
SafeCountries
add address=66.207.0.0-66.207.48.255 comment="United States" list=
SafeCountries
add address=66.207.51.0-66.207.53.255 comment="United States" list=
SafeCountries
add address=66.207.58.0/23 comment="United States" list=SafeCountries
add address=66.207.61.0-66.207.62.255 comment="United States" list=
SafeCountries
add address=66.207.64.0/19 comment="United States" list=SafeCountries
add address=66.207.128.0/18 comment="United States" list=SafeCountries
add address=66.207.224.0-66.209.47.255 comment="United States" list=
SafeCountries
add address=66.209.64.0-66.209.175.255 comment="United States" list=
SafeCountries
add address=66.209.192.0-66.212.159.255 comment="United States" list=
SafeCountries
add address=66.212.192.0/19 comment="United States" list=SafeCountries
add address=66.213.0.0-66.220.191.255 comment="United States" list=
SafeCountries
add address=66.220.208.0-66.222.127.255 comment="United States" list=
SafeCountries
add address=66.223.0.0-66.225.127.255 comment="United States" list=
SafeCountries
add address=66.225.180.0/24 comment="United States" list=SafeCountries
add address=66.225.192.0-66.225.198.255 comment="United States" list=
SafeCountries
add address=66.225.200.0-66.226.127.255 comment="United States" list=
SafeCountries
add address=66.226.192.0-66.227.117.255 comment="United States" list=
SafeCountries
add address=66.227.119.0-66.230.166.255 comment="United States" list=
SafeCountries
add address=66.230.168.0-66.230.174.255 comment="United States" list=
SafeCountries
add address=66.230.176.0-66.230.182.255 comment="United States" list=
SafeCountries
add address=66.230.184.0-66.230.188.255 comment="United States" list=
SafeCountries
add address=66.230.190.0-66.230.247.255 comment="United States" list=
SafeCountries
add address=66.230.252.0-66.231.63.255 comment="United States" list=
SafeCountries
add address=66.231.80.0-66.231.159.255 comment="United States" list=
SafeCountries
add address=66.231.176.0-66.231.243.47 comment="United States" list=
SafeCountries
add address=66.231.243.64-66.231.249.255 comment="United States" list=
SafeCountries
add address=66.231.251.0-66.232.127.255 comment="United States" list=
SafeCountries
add address=66.232.148.0-66.234.15.255 comment="United States" list=
SafeCountries
add address=66.234.32.0-66.241.127.255 comment="United States" list=
SafeCountries
add address=66.241.144.0-66.242.95.255 comment="United States" list=
SafeCountries
add address=66.242.112.0-66.244.191.255 comment="United States" list=
SafeCountries
add address=66.245.0.0-66.245.163.255 comment="United States" list=
SafeCountries
add address=66.245.164.128/26 comment="United States" list=SafeCountries
add address=66.245.165.0-66.247.199.255 comment="United States" list=
SafeCountries
add address=66.247.208.0-66.248.157.255 comment="United States" list=
SafeCountries
add address=66.248.159.0/24 comment="United States" list=SafeCountries
add address=66.248.193.0-66.249.80.255 comment="United States" list=
SafeCountries
add address=66.249.83.0-66.249.92.255 comment="United States" list=
SafeCountries
add address=66.249.94.0-66.249.143.255 comment="United States" list=
SafeCountries
add address=66.249.160.0/19 comment="United States" list=SafeCountries
add address=66.249.216.0/22 comment="United States" list=SafeCountries
add address=66.249.224.0-66.250.55.255 comment="United States" list=
SafeCountries
add address=66.250.57.0-66.251.127.255 comment="United States" list=
SafeCountries
add address=66.251.193.0-66.251.215.255 comment="United States" list=
SafeCountries
add address=66.251.217.0-66.252.143.255 comment="United States" list=
SafeCountries
add address=66.252.160.0-66.254.31.255 comment="United States" list=
SafeCountries
add address=66.254.64.0-67.15.31.255 comment="United States" list=
SafeCountries
add address=67.15.34.0-67.15.98.255 comment="United States" list=
SafeCountries
add address=67.15.100.0/24 comment="United States" list=SafeCountries
add address=67.15.102.0-67.15.122.255 comment="United States" list=
SafeCountries
add address=67.15.124.0-67.15.168.255 comment="United States" list=
SafeCountries
add address=67.15.170.0-67.15.182.255 comment="United States" list=
SafeCountries
add address=67.15.183.128-67.15.219.255 comment="United States" list=
SafeCountries
add address=67.15.221.0-67.15.233.255 comment="United States" list=
SafeCountries
add address=67.15.235.0-67.15.236.255 comment="United States" list=
SafeCountries
add address=67.15.238.0-67.15.248.255 comment="United States" list=
SafeCountries
add address=67.15.250.0-67.16.99.232 comment="United States" list=
SafeCountries
add address=67.16.99.234-67.16.133.208 comment="United States" list=
SafeCountries
add address=67.16.133.210-67.17.194.29 comment="United States" list=
SafeCountries
add address=67.17.194.31-67.17.196.159 comment="United States" list=
SafeCountries
add address=67.17.196.164-67.17.248.255 comment="United States" list=
SafeCountries
add address=67.17.250.0-67.21.95.255 comment="United States" list=
SafeCountries
add address=67.21.112.0-67.21.122.255 comment="United States" list=
SafeCountries
add address=67.21.125.0-67.21.143.255 comment="United States" list=
SafeCountries
add address=67.21.160.0/19 comment="United States" list=SafeCountries
add address=67.21.253.0/24 comment="United States" list=SafeCountries
add address=67.22.0.0/18 comment="United States" list=SafeCountries
add address=67.22.111.208/28 comment="United States" list=SafeCountries
add address=67.22.112.0/21 comment="United States" list=SafeCountries
add address=67.22.136.0/24 comment="United States" list=SafeCountries
add address=67.22.144.0-67.22.223.255 comment="United States" list=
SafeCountries
add address=67.22.240.0-67.23.127.255 comment="United States" list=
SafeCountries
add address=67.23.144.0-67.43.127.255 comment="United States" list=
SafeCountries
add address=67.43.144.0-67.43.155.255 comment="United States" list=
SafeCountries
add address=67.43.157.0-67.43.223.255 comment="United States" list=
SafeCountries
add address=67.43.240.0-67.54.255.255 comment="United States" list=
SafeCountries
add address=67.55.64.0-67.58.191.255 comment="United States" list=
SafeCountries
add address=67.58.224.0-67.67.255.255 comment="United States" list=
SafeCountries
add address=67.69.178.0/23 comment="United States" list=SafeCountries
add address=67.72.0.0-67.72.98.255 comment="United States" list=SafeCountries
add address=67.72.100.0-67.98.155.255 comment="United States" list=
SafeCountries
add address=67.98.157.0-67.98.161.255 comment="United States" list=
SafeCountries
add address=67.98.164.0-67.98.166.255 comment="United States" list=
SafeCountries
add address=67.98.168.0-67.143.62.255 comment="United States" list=
SafeCountries
add address=67.143.64.0-67.148.49.7 comment="United States" list=
SafeCountries
add address=67.148.49.16-67.148.49.95 comment="United States" list=
SafeCountries
add address=67.148.49.128/28 comment="United States" list=SafeCountries
add address=67.148.49.152-67.148.65.255 comment="United States" list=
SafeCountries
add address=67.148.66.128/26 comment="United States" list=SafeCountries
add address=67.148.66.208-67.151.233.255 comment="United States" list=
SafeCountries
add address=67.151.235.0-67.158.63.255 comment="United States" list=
SafeCountries
add address=67.158.80.0-67.159.151.255 comment="United States" list=
SafeCountries
add address=67.159.152.128-67.159.207.255 comment="United States" list=
SafeCountries
add address=67.159.224.0-67.192.255.255 comment="United States" list=
SafeCountries
add address=67.194.0.0-67.200.57.255 comment="United States" list=
SafeCountries
add address=67.200.59.0-67.201.127.255 comment="United States" list=
SafeCountries
add address=67.201.144.0/20 comment="United States" list=SafeCountries
add address=67.201.192.0-67.202.226.127 comment="United States" list=
SafeCountries
add address=67.202.226.160-67.202.226.255 comment="United States" list=
SafeCountries
add address=67.202.228.0-67.202.251.255 comment="United States" list=
SafeCountries
add address=67.202.253.32/27 comment="United States" list=SafeCountries
add address=67.202.253.80-67.202.253.111 comment="United States" list=
SafeCountries
add address=67.202.253.160-67.202.253.207 comment="United States" list=
SafeCountries
add address=67.202.253.232/29 comment="United States" list=SafeCountries
add address=67.202.254.0-67.203.191.255 comment="United States" list=
SafeCountries
add address=67.204.64.0-67.204.191.255 comment="United States" list=
SafeCountries
add address=67.205.0.0/18 comment="United States" list=SafeCountries
add address=67.205.128.0-67.206.191.255 comment="United States" list=
SafeCountries
add address=67.207.0.0-67.207.162.63 comment="United States" list=
SafeCountries
add address=67.207.162.80-67.207.255.255 comment="United States" list=
SafeCountries
add address=67.208.29.0/24 comment="United States" list=SafeCountries
add address=67.208.32.0-67.208.207.255 comment="United States" list=
SafeCountries
add address=67.208.209.0-67.209.95.255 comment="United States" list=
SafeCountries
add address=67.209.112.0-67.209.255.255 comment="United States" list=
SafeCountries
add address=67.210.17.0-67.210.127.255 comment="United States" list=
SafeCountries
add address=67.210.144.0/20 comment="United States" list=SafeCountries
add address=67.210.176.0-67.210.207.255 comment="United States" list=
SafeCountries
add address=67.210.224.0-67.211.63.255 comment="United States" list=
SafeCountries
add address=67.211.80.0/20 comment="United States" list=SafeCountries
add address=67.211.128.0/18 comment="United States" list=SafeCountries
add address=67.211.198.0/23 comment="United States" list=SafeCountries
add address=67.211.206.0-67.211.239.255 comment="United States" list=
SafeCountries
add address=67.212.32.0/19 comment="United States" list=SafeCountries
add address=67.212.96.0-67.213.63.255 comment="United States" list=
SafeCountries
add address=67.213.82.0/24 comment="United States" list=SafeCountries
add address=67.213.112.0-67.213.143.255 comment="United States" list=
SafeCountries
add address=67.213.160.0-67.214.255.255 comment="United States" list=
SafeCountries
add address=67.215.16.0-67.215.47.255 comment="United States" list=
SafeCountries
add address=67.215.64.0-67.215.80.10 comment="United States" list=
SafeCountries
add address=67.215.80.12-67.215.82.10 comment="United States" list=
SafeCountries
add address=67.215.82.12-67.215.82.255 comment="United States" list=
SafeCountries
add address=67.215.87.0-67.215.95.255 comment="United States" list=
SafeCountries
add address=67.215.112.0/20 comment="United States" list=SafeCountries
add address=67.215.160.0/19 comment="United States" list=SafeCountries
add address=67.215.208.0-67.218.52.255 comment="United States" list=
SafeCountries
add address=67.218.54.0/24 comment="United States" list=SafeCountries
add address=67.218.58.0/24 comment="United States" list=SafeCountries
add address=67.218.60.0-67.218.231.255 comment="United States" list=
SafeCountries
add address=67.218.233.0-67.220.31.255 comment="United States" list=
SafeCountries
add address=67.220.48.0-67.220.67.31 comment="United States" list=
SafeCountries
add address=67.220.67.48-67.220.71.255 comment="United States" list=
SafeCountries
add address=67.220.76.0-67.220.143.255 comment="United States" list=
SafeCountries
add address=67.220.145.0-67.220.208.255 comment="United States" list=
SafeCountries
add address=67.220.210.0-67.220.237.255 comment="United States" list=
SafeCountries
add address=67.220.239.0-67.220.248.255 comment="United States" list=
SafeCountries
add address=67.220.250.0-67.220.252.255 comment="United States" list=
SafeCountries
add address=67.220.255.0-67.221.143.255 comment="United States" list=
SafeCountries
add address=67.221.160.0-67.223.63.255 comment="United States" list=
SafeCountries
add address=67.223.112.0/20 comment="United States" list=SafeCountries
add address=67.223.160.0-67.224.79.255 comment="United States" list=
SafeCountries
add address=67.224.96.0-67.224.104.255 comment="United States" list=
SafeCountries
add address=67.224.106.8-67.224.107.255 comment="United States" list=
SafeCountries
add address=67.224.109.0-67.224.127.255 comment="United States" list=
SafeCountries
add address=67.225.128.0-67.226.127.255 comment="United States" list=
SafeCountries
add address=67.226.208.0/20 comment="United States" list=SafeCountries
add address=67.227.0.0-67.229.255.255 comment="United States" list=
SafeCountries
add address=67.230.80.0/23 comment="United States" list=SafeCountries
add address=67.230.86.0/23 comment="United States" list=SafeCountries
add address=67.230.90.0/24 comment="United States" list=SafeCountries
add address=67.230.92.0-67.230.113.77 comment="United States" list=
SafeCountries
add address=67.230.113.79-67.230.113.113 comment="United States" list=
SafeCountries
add address=67.230.113.115-67.230.127.255 comment="United States" list=
SafeCountries
add address=67.230.192.0-67.231.15.255 comment="United States" list=
SafeCountries
add address=67.231.32.0-67.231.207.255 comment="United States" list=
SafeCountries
add address=67.231.224.0-68.66.47.255 comment="United States" list=
SafeCountries
add address=68.66.64.0-68.67.1.255 comment="United States" list=SafeCountries
add address=68.67.3.0-68.67.5.255 comment="United States" list=SafeCountries
add address=68.67.7.0/24 comment="United States" list=SafeCountries
add address=68.67.11.0-68.67.31.255 comment="United States" list=
SafeCountries
add address=68.67.64.0-68.67.68.239 comment="United States" list=
SafeCountries
add address=68.67.68.244-68.67.175.255 comment="United States" list=
SafeCountries
add address=68.67.178.0/23 comment="United States" list=SafeCountries
add address=68.67.181.0/24 comment="United States" list=SafeCountries
add address=68.67.183.0-68.67.255.255 comment="United States" list=
SafeCountries
add address=68.68.16.0-68.69.15.255 comment="United States" list=
SafeCountries
add address=68.69.32.0-68.69.127.255 comment="United States" list=
SafeCountries
add address=68.69.160.0/19 comment="United States" list=SafeCountries
add address=68.69.224.0-68.70.143.255 comment="United States" list=
SafeCountries
add address=68.70.160.0-68.70.255.255 comment="United States" list=
SafeCountries
add address=68.71.64.0-68.140.67.255 comment="United States" list=
SafeCountries
add address=68.140.72.0-68.143.255.255 comment="United States" list=
SafeCountries
add address=68.152.0.0-68.168.111.255 comment="United States" list=
SafeCountries
add address=68.168.144.0-68.171.63.255 comment="United States" list=
SafeCountries
add address=68.171.80.0-68.171.108.160 comment="United States" list=
SafeCountries
add address=68.171.108.177-68.171.223.255 comment="United States" list=
SafeCountries
add address=68.171.247.0/24 comment="United States" list=SafeCountries
add address=68.172.0.0-68.178.255.255 comment="United States" list=
SafeCountries
add address=68.179.128.0-68.181.255.255 comment="United States" list=
SafeCountries
add address=68.183.0.0-68.208.23.255 comment="United States" list=
SafeCountries
add address=68.208.26.0-68.232.63.255 comment="United States" list=
SafeCountries
add address=68.232.96.0-68.234.223.255 comment="United States" list=
SafeCountries
add address=68.234.232.0-68.234.247.255 comment="United States" list=
SafeCountries
add address=68.234.252.0-68.235.47.255 comment="United States" list=
SafeCountries
add address=68.235.56.0-68.235.175.255 comment="United States" list=
SafeCountries
add address=68.235.192.0-69.1.232.255 comment="United States" list=
SafeCountries
add address=69.1.234.0-69.1.252.255 comment="United States" list=
SafeCountries
add address=69.1.254.0-69.4.90.127 comment="United States" list=SafeCountries
add address=69.4.90.192-69.4.94.82 comment="United States" list=SafeCountries
add address=69.4.94.91-69.4.94.122 comment="United States" list=SafeCountries
add address=69.4.94.128-69.4.94.146 comment="United States" list=
SafeCountries
add address=69.4.94.155-69.4.159.255 comment="United States" list=
SafeCountries
add address=69.4.176.0-69.4.207.255 comment="United States" list=
SafeCountries
add address=69.4.224.0-69.6.23.255 comment="United States" list=SafeCountries
add address=69.6.25.0-69.6.27.255 comment="United States" list=SafeCountries
add address=69.6.29.0-69.7.133.255 comment="United States" list=SafeCountries
add address=69.7.135.0-69.7.239.255 comment="United States" list=
SafeCountries
add address=69.8.0.0-69.9.63.255 comment="United States" list=SafeCountries
add address=69.9.95.0/24 comment="United States" list=SafeCountries
add address=69.9.125.0-69.10.48.255 comment="United States" list=
SafeCountries
add address=69.10.50.0-69.10.127.255 comment="United States" list=
SafeCountries
add address=69.10.152.0-69.10.152.42 comment="United States" list=
SafeCountries
add address=69.10.152.44/30 comment="United States" list=SafeCountries
add address=69.10.152.64-69.10.152.255 comment="United States" list=
SafeCountries
add address=69.10.160.0-69.10.223.255 comment="United States" list=
SafeCountries
add address=69.10.240.0/20 comment="United States" list=SafeCountries
add address=69.11.128.0-69.12.31.255 comment="United States" list=
SafeCountries
add address=69.12.36.0-69.12.51.255 comment="United States" list=
SafeCountries
add address=69.12.54.0-69.12.103.255 comment="United States" list=
SafeCountries
add address=69.12.105.0/24 comment="United States" list=SafeCountries
add address=69.12.112.0-69.17.127.255 comment="United States" list=
SafeCountries
add address=69.17.204.0/24 comment="United States" list=SafeCountries
add address=69.18.0.0-69.20.223.255 comment="United States" list=
SafeCountries
add address=69.21.0.0-69.24.47.255 comment="United States" list=SafeCountries
add address=69.24.64.0-69.24.191.255 comment="United States" list=
SafeCountries
add address=69.24.208.0-69.24.241.11 comment="United States" list=
SafeCountries
add address=69.24.241.16/29 comment="United States" list=SafeCountries
add address=69.24.241.28-69.25.10.255 comment="United States" list=
SafeCountries
add address=69.25.12.0-69.25.31.255 comment="United States" list=
SafeCountries
add address=69.25.33.0-69.25.40.255 comment="United States" list=
SafeCountries
add address=69.25.42.0-69.25.60.255 comment="United States" list=
SafeCountries
add address=69.25.62.0-69.25.133.255 comment="United States" list=
SafeCountries
add address=69.25.135.0-69.26.36.47 comment="United States" list=
SafeCountries
add address=69.26.36.56-69.26.63.255 comment="United States" list=
SafeCountries
add address=69.26.96.0-69.27.95.255 comment="United States" list=
SafeCountries
add address=69.27.128.0-69.28.66.255 comment="United States" list=
SafeCountries
add address=69.28.68.0-69.28.81.255 comment="United States" list=
SafeCountries
add address=69.28.84.0-69.28.193.255 comment="United States" list=
SafeCountries
add address=69.28.195.0-69.28.197.255 comment="United States" list=
SafeCountries
add address=69.28.203.0/24 comment="United States" list=SafeCountries
add address=69.28.206.0/24 comment="United States" list=SafeCountries
add address=69.28.208.0/24 comment="United States" list=SafeCountries
add address=69.28.210.0-69.28.213.255 comment="United States" list=
SafeCountries
add address=69.28.215.0/26 comment="United States" list=SafeCountries
add address=69.28.215.96-69.28.221.255 comment="United States" list=
SafeCountries
add address=69.28.224.0-69.28.228.255 comment="United States" list=
SafeCountries
add address=69.28.230.0-69.28.231.175 comment="United States" list=
SafeCountries
add address=69.28.231.192-69.28.233.255 comment="United States" list=
SafeCountries
add address=69.28.235.0-69.28.236.255 comment="United States" list=
SafeCountries
add address=69.28.240.0/22 comment="United States" list=SafeCountries
add address=69.28.248.0-69.28.253.255 comment="United States" list=
SafeCountries
add address=69.28.255.0-69.29.124.15 comment="United States" list=
SafeCountries
add address=69.29.124.24-69.31.34.255 comment="United States" list=
SafeCountries
add address=69.31.36.0-69.31.136.255 comment="United States" list=
SafeCountries
add address=69.31.138.0-69.31.159.255 comment="United States" list=
SafeCountries
add address=69.32.0.0-69.36.95.255 comment="United States" list=SafeCountries
add address=69.36.128.0-69.41.191.255 comment="United States" list=
SafeCountries
add address=69.41.208.0-69.41.227.255 comment="United States" list=
SafeCountries
add address=69.41.229.0-69.42.47.255 comment="United States" list=
SafeCountries
add address=69.42.49.0-69.42.51.255 comment="United States" list=
SafeCountries
add address=69.42.64.0-69.42.98.255 comment="United States" list=
SafeCountries
add address=69.42.100.0-69.42.101.47 comment="United States" list=
SafeCountries
add address=69.42.101.64-69.42.108.255 comment="United States" list=
SafeCountries
add address=69.42.110.0-69.42.113.255 comment="United States" list=
SafeCountries
add address=69.42.116.0-69.42.117.143 comment="United States" list=
SafeCountries
add address=69.42.117.152-69.42.117.183 comment="United States" list=
SafeCountries
add address=69.42.117.192-69.42.175.255 comment="United States" list=
SafeCountries
add address=69.42.192.0-69.43.159.255 comment="United States" list=
SafeCountries
add address=69.43.162.0-69.44.141.255 comment="United States" list=
SafeCountries
add address=69.44.144.0-69.44.201.255 comment="United States" list=
SafeCountries
add address=69.44.204.0-69.45.127.255 comment="United States" list=
SafeCountries
add address=69.45.132.0-69.46.89.255 comment="United States" list=
SafeCountries
add address=69.46.91.0-69.46.95.255 comment="United States" list=
SafeCountries
add address=69.46.128.0-69.46.139.255 comment="United States" list=
SafeCountries
add address=69.46.141.0-69.46.159.255 comment="United States" list=
SafeCountries
add address=69.46.192.0-69.48.143.255 comment="United States" list=
SafeCountries
add address=69.48.145.0-69.49.31.255 comment="United States" list=
SafeCountries
add address=69.49.64.0-69.49.96.255 comment="United States" list=
SafeCountries
add address=69.49.98.0-69.50.63.255 comment="United States" list=
SafeCountries
add address=69.50.80.0-69.50.159.255 comment="United States" list=
SafeCountries
add address=69.50.192.0-69.51.191.255 comment="United States" list=
SafeCountries
add address=69.52.0.0-69.52.65.255 comment="United States" list=SafeCountries
add address=69.52.67.0-69.52.68.255 comment="United States" list=
SafeCountries
add address=69.52.70.0-69.55.239.255 comment="United States" list=
SafeCountries
add address=69.56.0.0/16 comment="United States" list=SafeCountries
add address=69.57.16.0-69.57.207.255 comment="United States" list=
SafeCountries
add address=69.58.0.0/24 comment="United States" list=SafeCountries
add address=69.58.1.128/27 comment="United States" list=SafeCountries
add address=69.58.2.0-69.58.3.191 comment="United States" list=SafeCountries
add address=69.58.4.0-69.58.6.255 comment="United States" list=SafeCountries
add address=69.58.7.96/27 comment="United States" list=SafeCountries
add address=69.58.7.160/27 comment="United States" list=SafeCountries
add address=69.58.8.0/24 comment="United States" list=SafeCountries
add address=69.58.9.64-69.58.11.255 comment="United States" list=
SafeCountries
add address=69.58.12.63-69.58.12.255 comment="United States" list=
SafeCountries
add address=69.58.14.0/23 comment="United States" list=SafeCountries
add address=69.58.32.0-69.58.95.255 comment="United States" list=
SafeCountries
add address=69.58.112.0-69.60.63.255 comment="United States" list=
SafeCountries
add address=69.60.80.0-69.60.223.255 comment="United States" list=
SafeCountries
add address=69.61.0.0-69.61.23.135 comment="United States" list=SafeCountries
add address=69.61.23.144-69.61.92.255 comment="United States" list=
SafeCountries
add address=69.61.94.0-69.63.31.255 comment="United States" list=
SafeCountries
add address=69.63.80.0-69.63.239.255 comment="United States" list=
SafeCountries
add address=69.64.0.0-69.64.32.25 comment="United States" list=SafeCountries
add address=69.64.32.27-69.64.32.196 comment="United States" list=
SafeCountries
add address=69.64.32.198-69.64.34.178 comment="United States" list=
SafeCountries
add address=69.64.34.180-69.64.35.137 comment="United States" list=
SafeCountries
add address=69.64.35.139-69.64.35.216 comment="United States" list=
SafeCountries
add address=69.64.35.218-69.64.40.35 comment="United States" list=
SafeCountries
add address=69.64.40.37-69.64.45.239 comment="United States" list=
SafeCountries
add address=69.64.45.248-69.64.50.217 comment="United States" list=
SafeCountries
add address=69.64.50.219-69.64.50.222 comment="United States" list=
SafeCountries
add address=69.64.50.224-69.64.51.74 comment="United States" list=
SafeCountries
add address=69.64.51.76-69.64.59.255 comment="United States" list=
SafeCountries
add address=69.64.61.0-69.64.247.255 comment="United States" list=
SafeCountries
add address=69.64.250.0-69.64.253.255 comment="United States" list=
SafeCountries
add address=69.65.0.0-69.65.147.255 comment="United States" list=
SafeCountries
add address=69.65.149.0-69.65.150.255 comment="United States" list=
SafeCountries
add address=69.65.152.0-69.66.255.255 comment="United States" list=
SafeCountries
add address=69.67.16.0/20 comment="United States" list=SafeCountries
add address=69.67.48.0-69.67.52.159 comment="United States" list=
SafeCountries
add address=69.67.52.176-69.67.159.255 comment="United States" list=
SafeCountries
add address=69.67.192.0-69.69.255.255 comment="United States" list=
SafeCountries
add address=69.71.0.0/18 comment="United States" list=SafeCountries
add address=69.71.96.0/19 comment="United States" list=SafeCountries
add address=69.71.153.0/24 comment="United States" list=SafeCountries
add address=69.71.160.0-69.73.191.255 comment="United States" list=
SafeCountries
add address=69.74.0.0-69.77.159.255 comment="United States" list=
SafeCountries
add address=69.77.192.0-69.79.4.255 comment="United States" list=
SafeCountries
add address=69.79.6.0/23 comment="United States" list=SafeCountries
add address=69.79.16.0/21 comment="United States" list=SafeCountries
add address=69.79.25.0-69.79.26.255 comment="United States" list=
SafeCountries
add address=69.79.32.0-69.79.71.255 comment="United States" list=
SafeCountries
add address=69.79.80.0-69.79.103.255 comment="United States" list=
SafeCountries
add address=69.79.123.0/24 comment="United States" list=SafeCountries
add address=69.79.136.0-69.79.187.255 comment="United States" list=
SafeCountries
add address=69.79.208.0-69.79.255.255 comment="United States" list=
SafeCountries
add address=69.80.64.0-69.88.15.255 comment="United States" list=
SafeCountries
add address=69.88.17.0-69.88.22.255 comment="United States" list=
SafeCountries
add address=69.88.24.0/24 comment="United States" list=SafeCountries
add address=69.88.26.0-69.88.47.255 comment="United States" list=
SafeCountries
add address=69.88.64.0-69.89.31.255 comment="United States" list=
SafeCountries
add address=69.89.33.0/24 comment="United States" list=SafeCountries
add address=69.89.48.0-69.89.72.255 comment="United States" list=
SafeCountries
add address=69.89.74.0-69.89.255.255 comment="United States" list=
SafeCountries
add address=69.90.1.0/24 comment="United States" list=SafeCountries
add address=69.90.3.0/24 comment="United States" list=SafeCountries
add address=69.90.6.0/24 comment="United States" list=SafeCountries
add address=69.90.12.0-69.90.17.159 comment="United States" list=
SafeCountries
add address=69.90.17.168-69.90.18.239 comment="United States" list=
SafeCountries
add address=69.90.26.0/24 comment="United States" list=SafeCountries
add address=69.90.28.0-69.90.29.239 comment="United States" list=
SafeCountries
add address=69.90.30.0-69.90.31.175 comment="United States" list=
SafeCountries
add address=69.90.31.192-69.90.38.255 comment="United States" list=
SafeCountries
add address=69.90.40.0-69.90.44.255 comment="United States" list=
SafeCountries
add address=69.90.48.0/27 comment="United States" list=SafeCountries
add address=69.90.48.48-69.90.48.143 comment="United States" list=
SafeCountries
add address=69.90.48.160-69.90.50.255 comment="United States" list=
SafeCountries
add address=69.90.52.0-69.90.55.127 comment="United States" list=
SafeCountries
add address=69.90.56.0/24 comment="United States" list=SafeCountries
add address=69.90.60.0/23 comment="United States" list=SafeCountries
add address=69.90.64.0-69.90.66.255 comment="United States" list=
SafeCountries
add address=69.90.68.0-69.90.72.255 comment="United States" list=
SafeCountries
add address=69.90.74.0/24 comment="United States" list=SafeCountries
add address=69.90.76.0-69.90.77.159 comment="United States" list=
SafeCountries
add address=69.90.77.176-69.90.79.255 comment="United States" list=
SafeCountries
add address=69.90.81.0/24 comment="United States" list=SafeCountries
add address=69.90.83.0-69.90.85.255 comment="United States" list=
SafeCountries
add address=69.90.89.0/24 comment="United States" list=SafeCountries
add address=69.90.92.0/24 comment="United States" list=SafeCountries
add address=69.90.94.0-69.90.96.95 comment="United States" list=SafeCountries
add address=69.90.96.112/28 comment="United States" list=SafeCountries
add address=69.90.97.0-69.90.98.63 comment="United States" list=SafeCountries
add address=69.90.98.80-69.90.98.223 comment="United States" list=
SafeCountries
add address=69.90.99.0-69.90.99.143 comment="United States" list=
SafeCountries
add address=69.90.99.160-69.90.99.255 comment="United States" list=
SafeCountries
add address=69.90.102.0-69.90.103.7 comment="United States" list=
SafeCountries
add address=69.90.103.16/28 comment="United States" list=SafeCountries
add address=69.90.103.48-69.90.103.95 comment="United States" list=
SafeCountries
add address=69.90.103.112-69.90.103.255 comment="United States" list=
SafeCountries
add address=69.90.108.0/24 comment="United States" list=SafeCountries
add address=69.90.111.0/24 comment="United States" list=SafeCountries
add address=69.90.116.0/24 comment="United States" list=SafeCountries
add address=69.90.119.0-69.90.135.255 comment="United States" list=
SafeCountries
add address=69.90.140.0/24 comment="United States" list=SafeCountries
add address=69.90.144.0/22 comment="United States" list=SafeCountries
add address=69.90.153.0-69.90.159.255 comment="United States" list=
SafeCountries
add address=69.90.164.0-69.90.175.255 comment="United States" list=
SafeCountries
add address=69.90.179.0/24 comment="United States" list=SafeCountries
add address=69.90.181.0-69.90.184.191 comment="United States" list=
SafeCountries
add address=69.90.185.0-69.90.190.255 comment="United States" list=
SafeCountries
add address=69.90.197.0-69.90.209.255 comment="United States" list=
SafeCountries
add address=69.90.211.0-69.90.213.255 comment="United States" list=
SafeCountries
add address=69.90.215.0-69.90.216.255 comment="United States" list=
SafeCountries
add address=69.90.218.0-69.90.218.51 comment="United States" list=
SafeCountries
add address=69.90.218.56-69.90.218.79 comment="United States" list=
SafeCountries
add address=69.90.218.88-69.90.218.127 comment="United States" list=
SafeCountries
add address=69.90.218.160-69.90.219.255 comment="United States" list=
SafeCountries
add address=69.90.224.0/20 comment="United States" list=SafeCountries
add address=69.90.241.0-69.90.242.255 comment="United States" list=
SafeCountries
add address=69.90.244.0/24 comment="United States" list=SafeCountries
add address=69.90.248.0-69.155.255.255 comment="United States" list=
SafeCountries
add address=69.160.0.0-69.160.95.255 comment="United States" list=
SafeCountries
add address=69.160.128.0-69.161.127.255 comment="United States" list=
SafeCountries
add address=69.161.160.0-69.163.43.255 comment="United States" list=
SafeCountries
add address=69.163.45.0-69.164.67.255 comment="United States" list=
SafeCountries
add address=69.164.69.0/27 comment="United States" list=SafeCountries
add address=69.164.69.48-69.164.69.71 comment="United States" list=
SafeCountries
add address=69.164.69.96-69.164.69.191 comment="United States" list=
SafeCountries
add address=69.164.71.0-69.164.71.159 comment="United States" list=
SafeCountries
add address=69.164.71.168-69.164.72.39 comment="United States" list=
SafeCountries
add address=69.164.72.64-69.164.72.159 comment="United States" list=
SafeCountries
add address=69.164.72.168-69.164.72.191 comment="United States" list=
SafeCountries
add address=69.164.72.208-69.164.72.239 comment="United States" list=
SafeCountries
add address=69.164.73.0-69.164.73.79 comment="United States" list=
SafeCountries
add address=69.164.73.96-69.164.73.223 comment="United States" list=
SafeCountries
add address=69.164.74.0-69.164.175.255 comment="United States" list=
SafeCountries
add address=69.164.192.0-69.165.79.255 comment="United States" list=
SafeCountries
add address=69.165.96.0/19 comment="United States" list=SafeCountries
add address=69.166.0.0/20 comment="United States" list=SafeCountries
add address=69.166.32.0-69.166.111.255 comment="United States" list=
SafeCountries
add address=69.166.128.0-69.167.80.255 comment="United States" list=
SafeCountries
add address=69.167.81.128-69.168.127.255 comment="United States" list=
SafeCountries
add address=69.168.192.0-69.168.232.255 comment="United States" list=
SafeCountries
add address=69.168.236.0-69.169.93.255 comment="United States" list=
SafeCountries
add address=69.169.95.0-69.171.95.255 comment="United States" list=
SafeCountries
add address=69.171.112.0/20 comment="United States" list=SafeCountries
add address=69.171.160.0-69.172.63.255 comment="United States" list=
SafeCountries
add address=69.172.128.0/20 comment="United States" list=SafeCountries
add address=69.172.192.0/24 comment="United States" list=SafeCountries
add address=69.172.194.0/23 comment="United States" list=SafeCountries
add address=69.172.200.0-69.172.204.255 comment="United States" list=
SafeCountries
add address=69.172.206.0-69.172.206.55 comment="United States" list=
SafeCountries
add address=69.172.206.64-69.172.216.255 comment="United States" list=
SafeCountries
add address=69.172.220.0-69.172.222.255 comment="United States" list=
SafeCountries
add address=69.172.223.128/25 comment="United States" list=SafeCountries
add address=69.172.227.0/26 comment="United States" list=SafeCountries
add address=69.172.227.96-69.172.228.63 comment="United States" list=
SafeCountries
add address=69.172.228.96-69.172.236.159 comment="United States" list=
SafeCountries
add address=69.172.236.192-69.172.239.255 comment="United States" list=
SafeCountries
add address=69.172.241.0/28 comment="United States" list=SafeCountries
add address=69.172.241.24-69.172.241.95 comment="United States" list=
SafeCountries
add address=69.172.241.128-69.172.242.255 comment="United States" list=
SafeCountries
add address=69.172.244.0/23 comment="United States" list=SafeCountries
add address=69.173.0.0/19 comment="United States" list=SafeCountries
add address=69.173.64.0-69.176.80.255 comment="United States" list=
SafeCountries
add address=69.176.83.0-69.176.87.255 comment="United States" list=
SafeCountries
add address=69.176.89.0-69.176.90.255 comment="United States" list=
SafeCountries
add address=69.176.94.0-69.176.159.255 comment="United States" list=
SafeCountries
add address=69.176.192.0-69.191.175.255 comment="United States" list=
SafeCountries
add address=69.191.177.0/24 comment="United States" list=SafeCountries
add address=69.191.179.0/24 comment="United States" list=SafeCountries
add address=69.191.184.0-69.192.5.255 comment="United States" list=
SafeCountries
add address=69.192.7.0-69.192.63.255 comment="United States" list=
SafeCountries
add address=69.192.80.0-69.195.209.255 comment="United States" list=
SafeCountries
add address=69.195.212.0-69.195.227.255 comment="United States" list=
SafeCountries
add address=69.195.229.0-69.195.235.255 comment="United States" list=
SafeCountries
add address=69.195.238.0-69.195.247.255 comment="United States" list=
SafeCountries
add address=69.195.248.35 comment="United States" list=SafeCountries
add address=69.195.249.0-69.195.255.255 comment="United States" list=
SafeCountries
add address=69.196.32.0/19 comment="United States" list=SafeCountries
add address=69.196.96.0/19 comment="United States" list=SafeCountries
add address=69.196.192.0-70.23.255.255 comment="United States" list=
SafeCountries
add address=70.25.96.72/29 comment="United States" list=SafeCountries
add address=70.25.96.96/28 comment="United States" list=SafeCountries
add address=70.32.0.0-70.33.191.255 comment="United States" list=
SafeCountries
add address=70.33.204.0-70.33.205.159 comment="United States" list=
SafeCountries
add address=70.33.205.192-70.33.208.255 comment="United States" list=
SafeCountries
add address=70.33.210.0/23 comment="United States" list=SafeCountries
add address=70.33.213.0/24 comment="United States" list=SafeCountries
add address=70.33.216.0-70.33.218.255 comment="United States" list=
SafeCountries
add address=70.33.224.0-70.33.227.191 comment="United States" list=
SafeCountries
add address=70.33.227.208-70.33.243.255 comment="United States" list=
SafeCountries
add address=70.33.248.0-70.35.15.255 comment="United States" list=
SafeCountries
add address=70.35.32.0-70.35.127.255 comment="United States" list=
SafeCountries
add address=70.35.153.0/24 comment="United States" list=SafeCountries
add address=70.35.157.0/24 comment="United States" list=SafeCountries
add address=70.35.176.0-70.35.207.255 comment="United States" list=
SafeCountries
add address=70.35.224.0/19 comment="United States" list=SafeCountries
add address=70.36.16.0-70.36.25.111 comment="United States" list=
SafeCountries
add address=70.36.25.120-70.36.26.255 comment="United States" list=
SafeCountries
add address=70.36.29.0-70.36.47.255 comment="United States" list=
SafeCountries
add address=70.36.64.0-70.37.135.255 comment="United States" list=
SafeCountries
add address=70.37.139.0-70.37.148.255 comment="United States" list=
SafeCountries
add address=70.37.152.0-70.37.190.15 comment="United States" list=
SafeCountries
add address=70.37.190.48-70.37.255.255 comment="United States" list=
SafeCountries
add address=70.38.6.24/29 comment="United States" list=SafeCountries
add address=70.38.20.128/29 comment="United States" list=SafeCountries
add address=70.38.36.64/29 comment="United States" list=SafeCountries
add address=70.38.36.168/29 comment="United States" list=SafeCountries
add address=70.38.128.0-70.39.154.255 comment="United States" list=
SafeCountries
add address=70.39.155.8/29 comment="United States" list=SafeCountries
add address=70.39.155.32/28 comment="United States" list=SafeCountries
add address=70.39.155.56-70.39.241.255 comment="United States" list=
SafeCountries
add address=70.39.243.0-70.40.15.255 comment="United States" list=
SafeCountries
add address=70.40.28.0-70.40.127.255 comment="United States" list=
SafeCountries
add address=70.40.136.0-70.40.138.255 comment="United States" list=
SafeCountries
add address=70.40.191.0-70.42.26.127 comment="United States" list=
SafeCountries
add address=70.42.27.0-70.42.28.63 comment="United States" list=SafeCountries
add address=70.42.28.96-70.42.28.255 comment="United States" list=
SafeCountries
add address=70.42.30.0-70.44.255.255 comment="United States" list=
SafeCountries
add address=70.45.176.0/24 comment="United States" list=SafeCountries
add address=70.46.0.0/15 comment="United States" list=SafeCountries
add address=70.56.0.0/13 comment="United States" list=SafeCountries
add address=70.84.0.0-70.87.27.255 comment="United States" list=SafeCountries
add address=70.87.30.0-70.159.15.255 comment="United States" list=
SafeCountries
add address=70.159.17.0-70.232.244.255 comment="United States" list=
SafeCountries
add address=70.232.246.0-71.7.127.255 comment="United States" list=
SafeCountries
add address=71.8.0.0-71.16.4.191 comment="United States" list=SafeCountries
add address=71.16.4.224-71.16.255.255 comment="United States" list=
SafeCountries
add address=71.18.0.0/16 comment="United States" list=SafeCountries
add address=71.19.144.0/20 comment="United States" list=SafeCountries
add address=71.19.192.0-71.19.239.255 comment="United States" list=
SafeCountries
add address=71.20.0.0-72.0.63.255 comment="United States" list=SafeCountries
add address=72.0.80.0-72.0.191.255 comment="United States" list=SafeCountries
add address=72.0.224.0/20 comment="United States" list=SafeCountries
add address=72.1.0.0-72.1.100.255 comment="United States" list=SafeCountries
add address=72.1.102.0-72.1.191.255 comment="United States" list=
SafeCountries
add address=72.1.224.0/19 comment="United States" list=SafeCountries
add address=72.2.64.0-72.5.197.255 comment="United States" list=SafeCountries
add address=72.5.199.0-72.9.159.255 comment="United States" list=
SafeCountries
add address=72.9.192.0-72.10.127.255 comment="United States" list=
SafeCountries
add address=72.10.176.0-72.11.159.255 comment="United States" list=
SafeCountries
add address=72.11.192.0-72.12.95.255 comment="United States" list=
SafeCountries
add address=72.12.112.0/20 comment="United States" list=SafeCountries
add address=72.12.192.0-72.13.159.255 comment="United States" list=
SafeCountries
add address=72.13.192.0-72.14.159.255 comment="United States" list=
SafeCountries
add address=72.14.176.0-72.14.192.255 comment="United States" list=
SafeCountries
add address=72.14.194.0-72.14.229.255 comment="United States" list=
SafeCountries
add address=72.14.230.68/30 comment="United States" list=SafeCountries
add address=72.14.230.80/28 comment="United States" list=SafeCountries
add address=72.14.230.112-72.14.230.255 comment="United States" list=
SafeCountries
add address=72.14.231.72-72.14.231.103 comment="United States" list=
SafeCountries
add address=72.14.231.108-72.14.231.119 comment="United States" list=
SafeCountries
add address=72.14.231.122-72.15.47.255 comment="United States" list=
SafeCountries
add address=72.15.64.0/18 comment="United States" list=SafeCountries
add address=72.15.160.0-72.15.235.255 comment="United States" list=
SafeCountries
add address=72.15.240.0-72.21.88.255 comment="United States" list=
SafeCountries
add address=72.21.91.0-72.22.127.255 comment="United States" list=
SafeCountries
add address=72.22.160.0-72.25.191.255 comment="United States" list=
SafeCountries
add address=72.26.0.0-72.26.215.255 comment="United States" list=
SafeCountries
add address=72.26.224.0/19 comment="United States" list=SafeCountries
add address=72.27.224.0-72.28.63.255 comment="United States" list=
SafeCountries
add address=72.28.96.0-72.28.112.255 comment="United States" list=
SafeCountries
add address=72.28.113.32-72.28.113.55 comment="United States" list=
SafeCountries
add address=72.28.113.64-72.28.116.191 comment="United States" list=
SafeCountries
add address=72.28.118.0-72.29.3.255 comment="United States" list=
SafeCountries
add address=72.29.5.0-72.29.7.255 comment="United States" list=SafeCountries
add address=72.29.9.0-72.29.11.255 comment="United States" list=SafeCountries
add address=72.29.14.0/24 comment="United States" list=SafeCountries
add address=72.29.16.0-72.29.27.255 comment="United States" list=
SafeCountries
add address=72.29.29.0-72.29.223.255 comment="United States" list=
SafeCountries
add address=72.30.0.0-72.35.6.87 comment="United States" list=SafeCountries
add address=72.35.6.96-72.35.10.255 comment="United States" list=
SafeCountries
add address=72.35.12.0-72.35.25.255 comment="United States" list=
SafeCountries
add address=72.35.27.0-72.35.239.255 comment="United States" list=
SafeCountries
add address=72.35.241.0-72.35.243.255 comment="United States" list=
SafeCountries
add address=72.35.245.0/24 comment="United States" list=SafeCountries
add address=72.35.247.0/24 comment="United States" list=SafeCountries
add address=72.35.252.0-72.37.139.255 comment="United States" list=
SafeCountries
add address=72.37.141.0-72.37.144.255 comment="United States" list=
SafeCountries
add address=72.37.145.48-72.37.255.255 comment="United States" list=
SafeCountries
add address=72.40.0.0-72.45.63.255 comment="United States" list=SafeCountries
add address=72.45.128.0-72.46.226.207 comment="United States" list=
SafeCountries
add address=72.46.226.224-72.46.229.255 comment="United States" list=
SafeCountries
add address=72.46.232.0-72.46.240.63 comment="United States" list=
SafeCountries
add address=72.46.240.128-72.46.251.255 comment="United States" list=
SafeCountries
add address=72.46.253.0-72.49.255.255 comment="United States" list=
SafeCountries
add address=72.50.128.0-72.51.6.255 comment="United States" list=
SafeCountries
add address=72.51.8.0-72.51.9.31 comment="United States" list=SafeCountries
add address=72.51.9.48-72.51.9.255 comment="United States" list=SafeCountries
add address=72.51.11.0-72.51.19.31 comment="United States" list=SafeCountries
add address=72.51.19.128-72.51.23.255 comment="United States" list=
SafeCountries
add address=72.51.24.128/29 comment="United States" list=SafeCountries
add address=72.51.24.144-72.51.24.255 comment="United States" list=
SafeCountries
add address=72.51.26.0-72.51.26.175 comment="United States" list=
SafeCountries
add address=72.51.26.184-72.51.26.255 comment="United States" list=
SafeCountries
add address=72.51.32.0-72.51.56.255 comment="United States" list=
SafeCountries
add address=72.51.59.0-72.51.60.255 comment="United States" list=
SafeCountries
add address=72.51.62.0/23 comment="United States" list=SafeCountries
add address=72.51.128.0-72.52.1.255 comment="United States" list=
SafeCountries
add address=72.52.4.0-72.52.92.5 comment="United States" list=SafeCountries
add address=72.52.92.7-72.52.92.13 comment="United States" list=SafeCountries
add address=72.52.92.15-72.52.92.240 comment="United States" list=
SafeCountries
add address=72.52.92.242-72.52.255.255 comment="United States" list=
SafeCountries
add address=72.53.160.0-72.55.127.255 comment="United States" list=
SafeCountries
add address=72.55.163.240/30 comment="United States" list=SafeCountries
add address=72.55.192.0-72.135.255.255 comment="United States" list=
SafeCountries
add address=72.144.0.0-72.163.215.255 comment="United States" list=
SafeCountries
add address=72.163.218.0/23 comment="United States" list=SafeCountries
add address=72.163.221.0-72.168.68.255 comment="United States" list=
SafeCountries
add address=72.168.70.0-72.172.95.255 comment="United States" list=
SafeCountries
add address=72.172.128.0/19 comment="United States" list=SafeCountries
add address=72.172.176.0-72.246.40.255 comment="United States" list=
SafeCountries
add address=72.246.42.0-72.246.45.255 comment="United States" list=
SafeCountries
add address=72.246.47.0-72.246.50.255 comment="United States" list=
SafeCountries
add address=72.246.52.0/24 comment="United States" list=SafeCountries
add address=72.246.55.0-72.246.69.255 comment="United States" list=
SafeCountries
add address=72.246.72.0-72.246.98.255 comment="United States" list=
SafeCountries
add address=72.246.102.0-72.246.167.255 comment="United States" list=
SafeCountries
add address=72.246.176.0-72.247.15.255 comment="United States" list=
SafeCountries
add address=72.247.22.0-72.247.95.255 comment="United States" list=
SafeCountries
add address=72.247.104.0-72.247.144.255 comment="United States" list=
SafeCountries
add address=72.247.146.0-72.247.167.255 comment="United States" list=
SafeCountries
add address=72.247.176.0/20 comment="United States" list=SafeCountries
add address=72.247.194.0/23 comment="United States" list=SafeCountries
add address=72.247.200.0/21 comment="United States" list=SafeCountries
add address=72.247.211.0/24 comment="United States" list=SafeCountries
add address=72.247.216.0-72.247.235.255 comment="United States" list=
SafeCountries
add address=72.247.238.0-72.247.247.255 comment="United States" list=
SafeCountries
add address=72.248.0.0-72.251.239.255 comment="United States" list=
SafeCountries
add address=72.251.252.0/22 comment="United States" list=SafeCountries
add address=72.252.4.0/22 comment="United States" list=SafeCountries
add address=72.252.9.0-72.252.9.48 comment="United States" list=SafeCountries
add address=72.252.9.50-72.252.9.255 comment="United States" list=
SafeCountries
add address=72.252.11.0/24 comment="United States" list=SafeCountries
add address=72.252.16.0/21 comment="United States" list=SafeCountries
add address=72.252.72.0-72.252.87.255 comment="United States" list=
SafeCountries
add address=72.252.191.0-72.252.191.38 comment="United States" list=
SafeCountries
add address=72.252.191.40-72.252.191.255 comment="United States" list=
SafeCountries
add address=72.252.199.1-72.252.199.255 comment="United States" list=
SafeCountries
add address=72.252.255.1-74.3.127.255 comment="United States" list=
SafeCountries
add address=74.3.192.0-74.11.255.255 comment="United States" list=
SafeCountries
add address=74.16.0.0-74.47.255.255 comment="United States" list=
SafeCountries
add address=74.50.0.0-74.50.159.255 comment="United States" list=
SafeCountries
add address=74.50.192.0/19 comment="United States" list=SafeCountries
add address=74.50.240.0-74.51.31.255 comment="United States" list=
SafeCountries
add address=74.51.64.0-74.55.101.255 comment="United States" list=
SafeCountries
add address=74.55.103.0-74.55.255.255 comment="United States" list=
SafeCountries
add address=74.60.0.0-74.82.9.191 comment="United States" list=SafeCountries
add address=74.82.10.0-74.82.57.255 comment="United States" list=
SafeCountries
add address=74.82.59.0-74.82.64.255 comment="United States" list=
SafeCountries
add address=74.82.68.0/24 comment="United States" list=SafeCountries
add address=74.82.96.0-74.82.138.255 comment="United States" list=
SafeCountries
add address=74.82.140.0-74.82.191.255 comment="United States" list=
SafeCountries
add address=74.82.224.0-74.84.31.255 comment="United States" list=
SafeCountries
add address=74.84.64.0-74.84.213.255 comment="United States" list=
SafeCountries
add address=74.84.216.0-74.85.65.255 comment="United States" list=
SafeCountries
add address=74.85.67.0-74.85.175.255 comment="United States" list=
SafeCountries
add address=74.85.192.0-74.112.39.255 comment="United States" list=
SafeCountries
add address=74.112.48.0-74.112.123.255 comment="United States" list=
SafeCountries
add address=74.112.128.0-74.112.175.255 comment="United States" list=
SafeCountries
add address=74.112.180.0-74.112.187.255 comment="United States" list=
SafeCountries
add address=74.112.192.0-74.112.231.255 comment="United States" list=
SafeCountries
add address=74.112.240.0/20 comment="United States" list=SafeCountries
add address=74.113.4.0/22 comment="United States" list=SafeCountries
add address=74.113.16.0-74.113.67.255 comment="United States" list=
SafeCountries
add address=74.113.76.0-74.113.103.255 comment="United States" list=
SafeCountries
add address=74.113.108.0-74.113.151.255 comment="United States" list=
SafeCountries
add address=74.113.156.0-74.113.175.255 comment="United States" list=
SafeCountries
add address=74.113.184.0-74.114.71.255 comment="United States" list=
SafeCountries
add address=74.114.80.0-74.114.99.255 comment="United States" list=
SafeCountries
add address=74.114.104.0-74.114.135.255 comment="United States" list=
SafeCountries
add address=74.114.140.0-74.114.171.255 comment="United States" list=
SafeCountries
add address=74.114.176.0-74.114.199.255 comment="United States" list=
SafeCountries
add address=74.114.204.0/22 comment="United States" list=SafeCountries
add address=74.114.216.0-74.114.239.255 comment="United States" list=
SafeCountries
add address=74.114.244.0-74.114.255.255 comment="United States" list=
SafeCountries
add address=74.115.8.0-74.115.33.255 comment="United States" list=
SafeCountries
add address=74.115.36.0-74.115.159.255 comment="United States" list=
SafeCountries
add address=74.115.164.0-74.115.191.255 comment="United States" list=
SafeCountries
add address=74.115.204.0/24 comment="United States" list=SafeCountries
add address=74.115.208.0-74.115.219.255 comment="United States" list=
SafeCountries
add address=74.115.224.0-74.116.55.255 comment="United States" list=
SafeCountries
add address=74.116.60.0-74.116.91.255 comment="United States" list=
SafeCountries
add address=74.116.96.0-74.116.100.255 comment="United States" list=
SafeCountries
add address=74.116.102.0-74.116.119.255 comment="United States" list=
SafeCountries
add address=74.116.124.0-74.116.183.255 comment="United States" list=
SafeCountries
add address=74.116.192.0/23 comment="United States" list=SafeCountries
add address=74.116.196.0-74.116.215.255 comment="United States" list=
SafeCountries
add address=74.116.224.0-74.117.39.255 comment="United States" list=
SafeCountries
add address=74.117.48.0/22 comment="United States" list=SafeCountries
add address=74.117.56.0-74.117.83.255 comment="United States" list=
SafeCountries
add address=74.117.88.0-74.117.111.255 comment="United States" list=
SafeCountries
add address=74.117.120.0-74.117.139.255 comment="United States" list=
SafeCountries
add address=74.117.144.0-74.117.177.255 comment="United States" list=
SafeCountries
add address=74.117.179.0-74.117.206.255 comment="United States" list=
SafeCountries
add address=74.117.208.0/21 comment="United States" list=SafeCountries
add address=74.117.224.0-74.117.247.255 comment="United States" list=
SafeCountries
add address=74.118.0.0-74.118.35.255 comment="United States" list=
SafeCountries
add address=74.118.40.0-74.118.51.255 comment="United States" list=
SafeCountries
add address=74.118.56.0-74.118.79.255 comment="United States" list=
SafeCountries
add address=74.118.83.0-74.118.99.255 comment="United States" list=
SafeCountries
add address=74.118.104.0-74.118.247.255 comment="United States" list=
SafeCountries
add address=74.118.252.0/22 comment="United States" list=SafeCountries
add address=74.119.4.0-74.119.87.255 comment="United States" list=
SafeCountries
add address=74.119.96.0-74.119.183.255 comment="United States" list=
SafeCountries
add address=74.119.192.0-74.120.3.255 comment="United States" list=
SafeCountries
add address=74.120.8.0-74.120.19.255 comment="United States" list=
SafeCountries
add address=74.120.32.0-74.120.51.255 comment="United States" list=
SafeCountries
add address=74.120.56.0-74.120.71.255 comment="United States" list=
SafeCountries
add address=74.120.80.0-74.120.119.255 comment="United States" list=
SafeCountries
add address=74.120.124.0-74.120.219.255 comment="United States" list=
SafeCountries
add address=74.120.224.0-74.121.31.255 comment="United States" list=
SafeCountries
add address=74.121.36.0-74.121.119.255 comment="United States" list=
SafeCountries
add address=74.121.124.0-74.121.137.255 comment="United States" list=
SafeCountries
add address=74.121.139.0/24 comment="United States" list=SafeCountries
add address=74.121.142.0-74.121.159.255 comment="United States" list=
SafeCountries
add address=74.121.168.0-74.121.190.255 comment="United States" list=
SafeCountries
add address=74.121.192.0-74.121.243.255 comment="United States" list=
SafeCountries
add address=74.121.248.0-74.122.51.255 comment="United States" list=
SafeCountries
add address=74.122.56.0-74.122.87.255 comment="United States" list=
SafeCountries
add address=74.122.96.0/19 comment="United States" list=SafeCountries
add address=74.122.136.0-74.122.207.255 comment="United States" list=
SafeCountries
add address=74.122.216.0-74.122.243.255 comment="United States" list=
SafeCountries
add address=74.122.248.0-74.123.7.255 comment="United States" list=
SafeCountries
add address=74.123.12.0-74.123.67.255 comment="United States" list=
SafeCountries
add address=74.123.72.0-74.123.91.255 comment="United States" list=
SafeCountries
add address=74.123.96.0-74.125.16.63 comment="United States" list=
SafeCountries
add address=74.125.19.0-74.125.40.255 comment="United States" list=
SafeCountries
add address=74.125.42.0-74.125.45.255 comment="United States" list=
SafeCountries
add address=74.125.48.0/21 comment="United States" list=SafeCountries
add address=74.125.58.0/23 comment="United States" list=SafeCountries
add address=74.125.60.196/30 comment="United States" list=SafeCountries
add address=74.125.60.208-74.125.60.255 comment="United States" list=
SafeCountries
add address=74.125.61.216-74.125.61.233 comment="United States" list=
SafeCountries
add address=74.125.61.236-74.125.62.255 comment="United States" list=
SafeCountries
add address=74.125.64.0-74.125.72.255 comment="United States" list=
SafeCountries
add address=74.125.75.0-74.125.120.255 comment="United States" list=
SafeCountries
add address=74.125.123.0-74.125.180.255 comment="United States" list=
SafeCountries
add address=74.125.182.0-74.125.187.255 comment="United States" list=
SafeCountries
add address=74.125.189.0-74.125.189.22 comment="United States" list=
SafeCountries
add address=74.125.189.24-74.125.189.255 comment="United States" list=
SafeCountries
add address=74.125.191.0-74.126.95.255 comment="United States" list=
SafeCountries
add address=74.126.128.0-74.127.57.255 comment="United States" list=
SafeCountries
add address=74.127.59.0-74.127.191.255 comment="United States" list=
SafeCountries
add address=74.128.0.0-74.197.255.255 comment="United States" list=
SafeCountries
add address=74.199.0.0/16 comment="United States" list=SafeCountries
add address=74.200.32.0-74.205.116.191 comment="United States" list=
SafeCountries
add address=74.205.116.208-74.205.159.255 comment="United States" list=
SafeCountries
add address=74.205.162.0/24 comment="United States" list=SafeCountries
add address=74.205.192.0/20 comment="United States" list=SafeCountries
add address=74.205.224.0-74.205.228.255 comment="United States" list=
SafeCountries
add address=74.205.230.0-74.205.244.255 comment="United States" list=
SafeCountries
add address=74.205.246.0-74.206.127.255 comment="United States" list=
SafeCountries
add address=74.206.160.0-74.208.253.255 comment="United States" list=
SafeCountries
add address=74.209.0.0-74.209.208.255 comment="United States" list=
SafeCountries
add address=74.209.210.0-74.209.247.255 comment="United States" list=
SafeCountries
add address=74.209.249.0-74.209.255.255 comment="United States" list=
SafeCountries
add address=74.211.0.0-74.211.97.255 comment="United States" list=
SafeCountries
add address=74.211.99.0-74.213.63.255 comment="United States" list=
SafeCountries
add address=74.213.128.0/19 comment="United States" list=SafeCountries
add address=74.213.192.0-74.214.127.255 comment="United States" list=
SafeCountries
add address=74.214.160.0-74.214.193.255 comment="United States" list=
SafeCountries
add address=74.214.195.0-74.215.255.255 comment="United States" list=
SafeCountries
add address=74.217.0.0-74.217.136.255 comment="United States" list=
SafeCountries
add address=74.217.138.0-74.217.221.255 comment="United States" list=
SafeCountries
add address=74.217.223.0-74.220.159.255 comment="United States" list=
SafeCountries
add address=74.220.192.0-74.221.15.255 comment="United States" list=
SafeCountries
add address=74.221.32.0-74.221.127.255 comment="United States" list=
SafeCountries
add address=74.221.144.0-74.221.222.127 comment="United States" list=
SafeCountries
add address=74.221.224.0-74.222.63.255 comment="United States" list=
SafeCountries
add address=74.222.96.0-75.98.15.255 comment="United States" list=
SafeCountries
add address=75.98.17.0-75.98.18.255 comment="United States" list=
SafeCountries
add address=75.98.20.0/24 comment="United States" list=SafeCountries
add address=75.98.24.0-75.98.128.31 comment="United States" list=
SafeCountries
add address=75.98.128.48-75.98.129.255 comment="United States" list=
SafeCountries
add address=75.98.132.0-75.98.191.255 comment="United States" list=
SafeCountries
add address=75.98.208.0-75.102.60.79 comment="United States" list=
SafeCountries
add address=75.102.60.88-75.119.223.255 comment="United States" list=
SafeCountries
add address=75.120.0.0-75.151.255.255 comment="United States" list=
SafeCountries
add address=75.160.0.0-76.8.31.255 comment="United States" list=SafeCountries
add address=76.8.48.0-76.8.111.255 comment="United States" list=SafeCountries
add address=76.8.128.0/17 comment="United States" list=SafeCountries
add address=76.9.1.0-76.9.2.255 comment="United States" list=SafeCountries
add address=76.9.4.0-76.9.26.255 comment="United States" list=SafeCountries
add address=76.9.28.0/22 comment="United States" list=SafeCountries
add address=76.9.64.0-76.9.191.255 comment="United States" list=SafeCountries
add address=76.9.208.0/22 comment="United States" list=SafeCountries
add address=76.9.218.0/23 comment="United States" list=SafeCountries
add address=76.9.224.0-76.10.127.255 comment="United States" list=
SafeCountries
add address=76.10.192.0/18 comment="United States" list=SafeCountries
add address=76.11.128.0-76.12.226.55 comment="United States" list=
SafeCountries
add address=76.12.226.80-76.63.255.255 comment="United States" list=
SafeCountries
add address=76.72.0.0-76.72.239.255 comment="United States" list=
SafeCountries
add address=76.73.0.0-76.74.127.255 comment="United States" list=
SafeCountries
add address=76.74.129.0/25 comment="United States" list=SafeCountries
add address=76.74.133.0/24 comment="United States" list=SafeCountries
add address=76.74.136.0/24 comment="United States" list=SafeCountries
add address=76.74.139.0-76.74.139.95 comment="United States" list=
SafeCountries
add address=76.74.139.128-76.74.161.255 comment="United States" list=
SafeCountries
add address=76.74.163.0-76.74.165.159 comment="United States" list=
SafeCountries
add address=76.74.165.192-76.74.175.255 comment="United States" list=
SafeCountries
add address=76.74.177.0-76.74.183.255 comment="United States" list=
SafeCountries
add address=76.74.188.0/22 comment="United States" list=SafeCountries
add address=76.74.193.0-76.74.195.127 comment="United States" list=
SafeCountries
add address=76.74.196.0-76.74.200.63 comment="United States" list=
SafeCountries
add address=76.74.200.128-76.74.201.127 comment="United States" list=
SafeCountries
add address=76.74.202.0/24 comment="United States" list=SafeCountries
add address=76.74.204.0/24 comment="United States" list=SafeCountries
add address=76.74.206.0/25 comment="United States" list=SafeCountries
add address=76.74.207.0-76.74.208.255 comment="United States" list=
SafeCountries
add address=76.74.211.0-76.74.218.95 comment="United States" list=
SafeCountries
add address=76.74.218.128-76.74.223.255 comment="United States" list=
SafeCountries
add address=76.74.225.0-76.74.226.255 comment="United States" list=
SafeCountries
add address=76.74.230.0/24 comment="United States" list=SafeCountries
add address=76.74.232.0/24 comment="United States" list=SafeCountries
add address=76.74.234.0-76.74.240.255 comment="United States" list=
SafeCountries
add address=76.74.242.0/24 comment="United States" list=SafeCountries
add address=76.74.248.0-76.75.63.255 comment="United States" list=
SafeCountries
add address=76.75.192.0/19 comment="United States" list=SafeCountries
add address=76.76.0.0-76.76.95.255 comment="United States" list=SafeCountries
add address=76.76.128.0/19 comment="United States" list=SafeCountries
add address=76.76.208.0-76.77.47.255 comment="United States" list=
SafeCountries
add address=76.77.96.0-76.78.241.255 comment="United States" list=
SafeCountries
add address=76.78.242.1-76.255.255.255 comment="United States" list=
SafeCountries
add address=77.67.28.0/23 comment="United States" list=SafeCountries
add address=77.67.79.72/29 comment="United States" list=SafeCountries
add address=77.67.86.0/24 comment="United States" list=SafeCountries
add address=77.67.92.0/24 comment="United States" list=SafeCountries
add address=77.67.101.0/24 comment="United States" list=SafeCountries
add address=77.67.106.0/24 comment="United States" list=SafeCountries
add address=77.67.108.96/28 comment="United States" list=SafeCountries
add address=77.67.116.0/24 comment="United States" list=SafeCountries
add address=77.67.127.0/24 comment="United States" list=SafeCountries
add address=77.74.152.0/21 comment="United States" list=SafeCountries
add address=77.81.93.0/24 comment="United States" list=SafeCountries
add address=77.88.47.0/24 comment="United States" list=SafeCountries
add address=77.234.41.0-77.234.42.255 comment="United States" list=
SafeCountries
add address=77.234.44.0/24 comment="United States" list=SafeCountries
add address=77.237.225.0-77.237.226.255 comment="United States" list=
SafeCountries
add address=77.237.230.0/23 comment="United States" list=SafeCountries
add address=77.239.106.0/24 comment="United States" list=SafeCountries
add address=78.45.83.216 comment="United States" list=SafeCountries
add address=78.89.133.0/24 comment="United States" list=SafeCountries
add address=78.93.118.0/24 comment="United States" list=SafeCountries
add address=78.129.193.0/24 comment="United States" list=SafeCountries
add address=78.152.39.32/29 comment="United States" list=SafeCountries
add address=78.152.50.224/28 comment="United States" list=SafeCountries
add address=78.158.88.0/21 comment="United States" list=SafeCountries
add address=79.110.28.128/25 comment="United States" list=SafeCountries
add address=79.142.72.0/24 comment="United States" list=SafeCountries
add address=80.12.96.0-80.12.98.255 comment="United States" list=
SafeCountries
add address=80.15.249.192-80.15.249.239 comment="United States" list=
SafeCountries
add address=80.67.64.0-80.67.77.255 comment="United States" list=
SafeCountries
add address=80.67.81.0-80.67.82.255 comment="United States" list=
SafeCountries
add address=80.67.84.0-80.67.95.255 comment="United States" list=
SafeCountries
add address=80.76.167.0/24 comment="United States" list=SafeCountries
add address=80.78.16.217-80.78.16.223 comment="United States" list=
SafeCountries
add address=80.78.17.1-80.78.17.7 comment="United States" list=SafeCountries
add address=80.78.17.152-80.78.17.160 comment="United States" list=
SafeCountries
add address=80.78.17.177-80.78.17.183 comment="United States" list=
SafeCountries
add address=80.78.17.241-80.78.17.248 comment="United States" list=
SafeCountries
add address=80.78.18.28 comment="United States" list=SafeCountries
add address=80.78.18.33-80.78.18.48 comment="United States" list=
SafeCountries
add address=80.78.18.105-80.78.18.111 comment="United States" list=
SafeCountries
add address=80.78.18.217-80.78.18.224 comment="United States" list=
SafeCountries
add address=80.78.18.249-80.78.19.0 comment="United States" list=
SafeCountries
add address=80.78.19.33-80.78.19.39 comment="United States" list=
SafeCountries
add address=80.78.19.64/29 comment="United States" list=SafeCountries
add address=80.78.19.105-80.78.19.120 comment="United States" list=
SafeCountries
add address=80.78.19.136/29 comment="United States" list=SafeCountries
add address=80.78.19.225-80.78.19.232 comment="United States" list=
SafeCountries
add address=80.78.20.25-80.78.20.32 comment="United States" list=
SafeCountries
add address=80.78.20.96 comment="United States" list=SafeCountries
add address=80.78.20.145-80.78.20.160 comment="United States" list=
SafeCountries
add address=80.78.20.217 comment="United States" list=SafeCountries
add address=80.78.20.219-80.78.20.224 comment="United States" list=
SafeCountries
add address=80.78.20.240/28 comment="United States" list=SafeCountries
add address=80.78.21.1-80.78.21.32 comment="United States" list=SafeCountries
add address=80.78.23.17-80.78.23.32 comment="United States" list=
SafeCountries
add address=80.78.23.177-80.78.23.183 comment="United States" list=
SafeCountries
add address=80.78.23.241-80.78.23.247 comment="United States" list=
SafeCountries
add address=80.78.26.1 comment="United States" list=SafeCountries
add address=80.78.26.5-80.78.26.8 comment="United States" list=SafeCountries
add address=80.78.26.193-80.78.26.232 comment="United States" list=
SafeCountries
add address=80.78.26.241-80.78.26.248 comment="United States" list=
SafeCountries
add address=80.78.27.0/29 comment="United States" list=SafeCountries
add address=80.78.27.9-80.78.27.32 comment="United States" list=SafeCountries
add address=80.78.27.41-80.78.27.44 comment="United States" list=
SafeCountries
add address=80.78.27.57-80.78.27.80 comment="United States" list=
SafeCountries
add address=80.78.27.105-80.78.27.112 comment="United States" list=
SafeCountries
add address=80.78.27.137-80.78.27.144 comment="United States" list=
SafeCountries
add address=80.78.27.161-80.78.27.168 comment="United States" list=
SafeCountries
add address=80.78.27.177-80.78.27.184 comment="United States" list=
SafeCountries
add address=80.78.27.193-80.78.27.200 comment="United States" list=
SafeCountries
add address=80.78.27.225-80.78.27.232 comment="United States" list=
SafeCountries
add address=80.78.28.9-80.78.28.16 comment="United States" list=SafeCountries
add address=80.78.31.48/29 comment="United States" list=SafeCountries
add address=80.78.128.0/20 comment="United States" list=SafeCountries
add address=80.84.140.0/24 comment="United States" list=SafeCountries
add address=80.154.117.0/24 comment="United States" list=SafeCountries
add address=80.169.36.216/29 comment="United States" list=SafeCountries
add address=80.169.244.0/24 comment="United States" list=SafeCountries
add address=80.240.184.0/22 comment="United States" list=SafeCountries
add address=80.251.6.0/23 comment="United States" list=SafeCountries
add address=80.254.152.0/23 comment="United States" list=SafeCountries
add address=80.254.156.0/24 comment="United States" list=SafeCountries
add address=80.255.42.0/24 comment="United States" list=SafeCountries
add address=81.7.210.0/24 comment="United States" list=SafeCountries
add address=81.19.167.0-81.19.174.255 comment="United States" list=
SafeCountries
add address=81.23.243.0/24 comment="United States" list=SafeCountries
add address=81.31.0.158 comment="United States" list=SafeCountries
add address=81.31.0.188 comment="United States" list=SafeCountries
add address=81.31.0.245-81.31.0.246 comment="United States" list=
SafeCountries
add address=81.31.1.0/27 comment="United States" list=SafeCountries
add address=81.31.1.64/28 comment="United States" list=SafeCountries
add address=81.31.2.8/30 comment="United States" list=SafeCountries
add address=81.31.2.132-81.31.2.139 comment="United States" list=
SafeCountries
add address=81.52.130.0/25 comment="United States" list=SafeCountries
add address=81.52.130.160-81.52.130.255 comment="United States" list=
SafeCountries
add address=81.52.134.0/24 comment="United States" list=SafeCountries
add address=81.92.112.0-81.92.125.95 comment="United States" list=
SafeCountries
add address=81.92.125.112-81.92.127.255 comment="United States" list=
SafeCountries
add address=81.171.81.0/24 comment="United States" list=SafeCountries
add address=81.171.108.0/24 comment="United States" list=SafeCountries
add address=81.171.110.0/24 comment="United States" list=SafeCountries
add address=81.215.4.0/22 comment="United States" list=SafeCountries
add address=82.118.65.0/28 comment="United States" list=SafeCountries
add address=82.118.65.64/27 comment="United States" list=SafeCountries
add address=82.146.48.0/22 comment="United States" list=SafeCountries
add address=82.150.101.0/24 comment="United States" list=SafeCountries
add address=82.163.248.0/24 comment="United States" list=SafeCountries
add address=82.163.250.0/24 comment="United States" list=SafeCountries
add address=82.198.3.120-82.198.3.135 comment="United States" list=
SafeCountries
add address=82.198.3.252/30 comment="United States" list=SafeCountries
add address=82.205.130.0-82.205.131.31 comment="United States" list=
SafeCountries
add address=82.205.192.0/24 comment="United States" list=SafeCountries
add address=82.205.197.0-82.205.198.255 comment="United States" list=
SafeCountries
add address=82.205.224.0/24 comment="United States" list=SafeCountries
add address=82.214.192.0/22 comment="United States" list=SafeCountries
add address=82.214.197.0-82.214.203.255 comment="United States" list=
SafeCountries
add address=82.214.205.0-82.214.225.255 comment="United States" list=
SafeCountries
add address=82.214.227.0/24 comment="United States" list=SafeCountries
add address=82.214.229.0/24 comment="United States" list=SafeCountries
add address=82.214.231.0-82.214.239.3 comment="United States" list=
SafeCountries
add address=82.214.239.5-82.214.239.255 comment="United States" list=
SafeCountries
add address=82.214.248.0/21 comment="United States" list=SafeCountries
add address=83.96.66.0/24 comment="United States" list=SafeCountries
add address=83.143.246.0/24 comment="United States" list=SafeCountries
add address=83.151.96.0/22 comment="United States" list=SafeCountries
add address=83.151.198.0/24 comment="United States" list=SafeCountries
add address=83.168.246.0/24 comment="United States" list=SafeCountries
add address=83.222.124.0-83.222.127.127 comment="United States" list=
SafeCountries
add address=83.229.26.0/24 comment="United States" list=SafeCountries
add address=84.19.36.0/24 comment="United States" list=SafeCountries
add address=84.21.42.0/24 comment="United States" list=SafeCountries
add address=84.21.53.0/24 comment="United States" list=SafeCountries
add address=84.40.16.0/20 comment="United States" list=SafeCountries
add address=84.53.128.0/22 comment="United States" list=SafeCountries
add address=84.53.134.0-84.53.141.255 comment="United States" list=
SafeCountries
add address=84.53.144.0-84.53.175.255 comment="United States" list=
SafeCountries
add address=84.53.177.0-84.53.179.255 comment="United States" list=
SafeCountries
add address=84.53.182.0-84.53.191.255 comment="United States" list=
SafeCountries
add address=84.63.160.69 comment="United States" list=SafeCountries
add address=84.125.189.0/24 comment="United States" list=SafeCountries
add address=84.200.79.128/27 comment="United States" list=SafeCountries
add address=84.233.183.0/24 comment="United States" list=SafeCountries
add address=85.9.29.50 comment="United States" list=SafeCountries
add address=85.31.80.0/24 comment="United States" list=SafeCountries
add address=85.31.93.0/24 comment="United States" list=SafeCountries
add address=85.92.152.0/21 comment="United States" list=SafeCountries
add address=85.115.40.0/21 comment="United States" list=SafeCountries
add address=85.190.152.0/23 comment="United States" list=SafeCountries
add address=85.190.156.0/22 comment="United States" list=SafeCountries
add address=85.190.176.0/21 comment="United States" list=SafeCountries
add address=85.190.224.0/22 comment="United States" list=SafeCountries
add address=85.190.252.0/23 comment="United States" list=SafeCountries
add address=85.203.47.0/24 comment="United States" list=SafeCountries
add address=85.203.60.0/22 comment="United States" list=SafeCountries
add address=85.238.144.0/22 comment="United States" list=SafeCountries
add address=87.237.219.0/24 comment="United States" list=SafeCountries
add address=87.239.136.0-87.239.142.255 comment="United States" list=
SafeCountries
add address=87.254.200.0/22 comment="United States" list=SafeCountries
add address=88.151.228.0-88.151.230.255 comment="United States" list=
SafeCountries
add address=88.205.101.64/27 comment="United States" list=SafeCountries
add address=88.205.104.16/28 comment="United States" list=SafeCountries
add address=88.221.4.0/22 comment="United States" list=SafeCountries
add address=88.221.28.0/22 comment="United States" list=SafeCountries
add address=88.221.100.0/22 comment="United States" list=SafeCountries
add address=88.221.120.0/22 comment="United States" list=SafeCountries
add address=88.221.136.0/21 comment="United States" list=SafeCountries
add address=89.21.160.0/19 comment="United States" list=SafeCountries
add address=89.31.240.0/21 comment="United States" list=SafeCountries
add address=89.32.64.0/21 comment="United States" list=SafeCountries
add address=89.32.121.0/24 comment="United States" list=SafeCountries
add address=89.33.41.0/24 comment="United States" list=SafeCountries
add address=89.35.106.0/24 comment="United States" list=SafeCountries
add address=89.36.64.0/24 comment="United States" list=SafeCountries
add address=89.149.160.0/22 comment="United States" list=SafeCountries
add address=89.149.169.0/24 comment="United States" list=SafeCountries
add address=89.163.186.8/29 comment="United States" list=SafeCountries
add address=89.211.58.0/24 comment="United States" list=SafeCountries
add address=89.211.62.0/24 comment="United States" list=SafeCountries
add address=89.251.0.0/20 comment="United States" list=SafeCountries
add address=90.84.51.0-90.84.52.255 comment="United States" list=
SafeCountries
add address=90.84.62.0/23 comment="United States" list=SafeCountries
add address=90.84.133.0-90.84.134.255 comment="United States" list=
SafeCountries
add address=90.84.137.0/24 comment="United States" list=SafeCountries
add address=91.140.226.0/24 comment="United States" list=SafeCountries
add address=91.140.241.0/24 comment="United States" list=SafeCountries
add address=91.189.91.0/24 comment="United States" list=SafeCountries
add address=91.200.83.0/25 comment="United States" list=SafeCountries
add address=91.203.106.0/24 comment="United States" list=SafeCountries
add address=91.204.14.0/25 comment="United States" list=SafeCountries
add address=91.204.173.0/24 comment="United States" list=SafeCountries
add address=91.204.175.0/24 comment="United States" list=SafeCountries
add address=91.205.100.0/22 comment="United States" list=SafeCountries
add address=91.205.232.0/22 comment="United States" list=SafeCountries
add address=91.209.6.0/24 comment="United States" list=SafeCountries
add address=91.209.57.0/24 comment="United States" list=SafeCountries
add address=91.218.120.0/22 comment="United States" list=SafeCountries
add address=91.225.248.0/23 comment="United States" list=SafeCountries
add address=91.225.251.0/24 comment="United States" list=SafeCountries
add address=91.234.22.0/24 comment="United States" list=SafeCountries
add address=91.236.29.0/24 comment="United States" list=SafeCountries
add address=91.243.72.0/24 comment="United States" list=SafeCountries
add address=92.42.140.56/29 comment="United States" list=SafeCountries
add address=92.51.202.0/24 comment="United States" list=SafeCountries
add address=92.52.208.0/22 comment="United States" list=SafeCountries
add address=92.61.248.0-92.61.250.255 comment="United States" list=
SafeCountries
add address=92.71.96.0/23 comment="United States" list=SafeCountries
add address=92.114.7.0/24 comment="United States" list=SafeCountries
add address=92.210.183.0/24 comment="United States" list=SafeCountries
add address=92.223.118.0-92.223.121.255 comment="United States" list=
SafeCountries
add address=92.223.213.0-92.223.213.171 comment="United States" list=
SafeCountries
add address=92.223.213.173-92.223.213.255 comment="United States" list=
SafeCountries
add address=93.93.98.0/26 comment="United States" list=SafeCountries
add address=93.93.98.128/25 comment="United States" list=SafeCountries
add address=93.170.102.20 comment="United States" list=SafeCountries
add address=93.174.249.0/24 comment="United States" list=SafeCountries
add address=93.174.252.0/24 comment="United States" list=SafeCountries
add address=93.179.89.128/25 comment="United States" list=SafeCountries
add address=93.179.91.0/25 comment="United States" list=SafeCountries
add address=93.183.8.0/22 comment="United States" list=SafeCountries
add address=93.184.215.0-93.184.216.255 comment="United States" list=
SafeCountries
add address=93.184.218.0-93.184.223.255 comment="United States" list=
SafeCountries
add address=93.188.160.0/21 comment="United States" list=SafeCountries
add address=94.46.48.0-94.46.57.13 comment="United States" list=SafeCountries
add address=94.46.57.15-94.46.63.14 comment="United States" list=
SafeCountries
add address=94.46.63.16-94.46.63.255 comment="United States" list=
SafeCountries
add address=94.46.98.0/24 comment="United States" list=SafeCountries
add address=94.46.144.0/20 comment="United States" list=SafeCountries
add address=94.76.22.0/24 comment="United States" list=SafeCountries
add address=94.142.33.0-94.142.33.138 comment="United States" list=
SafeCountries
add address=94.142.33.140-94.142.33.255 comment="United States" list=
SafeCountries
add address=94.142.98.0/24 comment="United States" list=SafeCountries
add address=94.142.186.0/24 comment="United States" list=SafeCountries
add address=94.229.2.0-94.229.5.255 comment="United States" list=
SafeCountries
add address=94.249.182.0/26 comment="United States" list=SafeCountries
add address=94.249.182.80-94.249.182.255 comment="United States" list=
SafeCountries
add address=94.249.242.0/25 comment="United States" list=SafeCountries
add address=94.249.242.144-94.249.242.255 comment="United States" list=
SafeCountries
add address=95.85.81.0/24 comment="United States" list=SafeCountries
add address=95.141.18.0/25 comment="United States" list=SafeCountries
add address=95.141.20.64/28 comment="United States" list=SafeCountries
add address=95.141.222.0/24 comment="United States" list=SafeCountries
add address=95.142.18.0/23 comment="United States" list=SafeCountries
add address=95.142.103.192/28 comment="United States" list=SafeCountries
add address=95.142.105.104/29 comment="United States" list=SafeCountries
add address=95.172.74.46 comment="United States" list=SafeCountries
add address=95.181.218.0/25 comment="United States" list=SafeCountries
add address=95.183.1.0-95.183.3.255 comment="United States" list=
SafeCountries
add address=95.183.5.0/24 comment="United States" list=SafeCountries
add address=95.183.7.0/24 comment="United States" list=SafeCountries
add address=96.0.0.0/16 comment="United States" list=SafeCountries
add address=96.2.0.0-96.5.255.255 comment="United States" list=SafeCountries
add address=96.6.8.0/22 comment="United States" list=SafeCountries
add address=96.6.16.0-96.6.41.255 comment="United States" list=SafeCountries
add address=96.6.43.0-96.6.119.255 comment="United States" list=SafeCountries
add address=96.6.122.0-96.7.48.255 comment="United States" list=SafeCountries
add address=96.7.51.0-96.7.57.255 comment="United States" list=SafeCountries
add address=96.7.60.0-96.7.175.255 comment="United States" list=SafeCountries
add address=96.7.180.0-96.7.223.255 comment="United States" list=
SafeCountries
add address=96.7.232.0-96.9.63.255 comment="United States" list=SafeCountries
add address=96.9.129.0/24 comment="United States" list=SafeCountries
add address=96.9.192.0-96.16.3.255 comment="United States" list=SafeCountries
add address=96.16.6.0-96.16.121.255 comment="United States" list=
SafeCountries
add address=96.16.126.0-96.17.195.255 comment="United States" list=
SafeCountries
add address=96.17.197.0-96.17.199.255 comment="United States" list=
SafeCountries
add address=96.17.202.0-96.19.255.255 comment="United States" list=
SafeCountries
add address=96.24.0.0-96.30.126.255 comment="United States" list=
SafeCountries
add address=96.30.224.0-96.43.159.255 comment="United States" list=
SafeCountries
add address=96.43.193.0-96.43.223.255 comment="United States" list=
SafeCountries
add address=96.43.240.0-96.44.31.255 comment="United States" list=
SafeCountries
add address=96.44.128.0/18 comment="United States" list=SafeCountries
add address=96.45.16.0-96.45.88.255 comment="United States" list=
SafeCountries
add address=96.45.90.0/23 comment="United States" list=SafeCountries
add address=96.45.94.0-96.45.175.255 comment="United States" list=
SafeCountries
add address=96.45.208.0-96.46.31.255 comment="United States" list=
SafeCountries
add address=96.46.50.0/25 comment="United States" list=SafeCountries
add address=96.46.51.0/25 comment="United States" list=SafeCountries
add address=96.46.62.0/25 comment="United States" list=SafeCountries
add address=96.46.64.0-96.46.191.255 comment="United States" list=
SafeCountries
add address=96.46.208.0-96.47.175.255 comment="United States" list=
SafeCountries
add address=96.47.192.0-96.47.226.19 comment="United States" list=
SafeCountries
add address=96.47.226.21-96.47.255.255 comment="United States" list=
SafeCountries
add address=96.56.0.0-96.62.255.255 comment="United States" list=
SafeCountries
add address=96.63.64.0/18 comment="United States" list=SafeCountries
add address=96.63.176.0-96.125.127.255 comment="United States" list=
SafeCountries
add address=96.125.144.0-96.125.175.255 comment="United States" list=
SafeCountries
add address=96.125.178.0/24 comment="United States" list=SafeCountries
add address=96.125.224.0/20 comment="United States" list=SafeCountries
add address=96.126.0.0-96.127.191.255 comment="United States" list=
SafeCountries
add address=96.128.0.0-97.68.73.255 comment="United States" list=
SafeCountries
add address=97.68.75.0-97.74.255.255 comment="United States" list=
SafeCountries
add address=97.75.64.0-97.75.191.255 comment="United States" list=
SafeCountries
add address=97.75.224.0-97.107.47.255 comment="United States" list=
SafeCountries
add address=97.107.64.0-97.107.175.255 comment="United States" list=
SafeCountries
add address=97.107.192.0/20 comment="United States" list=SafeCountries
add address=97.107.224.0/19 comment="United States" list=SafeCountries
add address=97.112.0.0-98.123.255.255 comment="United States" list=
SafeCountries
add address=98.124.64.0-98.126.220.255 comment="United States" list=
SafeCountries
add address=98.126.223.0-98.142.107.255 comment="United States" list=
SafeCountries
add address=98.142.108.248/29 comment="United States" list=SafeCountries
add address=98.142.110.0-98.142.239.255 comment="United States" list=
SafeCountries
add address=98.143.0.0/18 comment="United States" list=SafeCountries
add address=98.143.112.0/20 comment="United States" list=SafeCountries
add address=98.143.144.0/20 comment="United States" list=SafeCountries
add address=98.143.176.0-98.143.207.255 comment="United States" list=
SafeCountries
add address=98.143.224.0/20 comment="United States" list=SafeCountries
add address=98.144.0.0-98.158.79.255 comment="United States" list=
SafeCountries
add address=98.158.112.0/20 comment="United States" list=SafeCountries
add address=98.158.144.0-98.159.239.255 comment="United States" list=
SafeCountries
add address=98.160.0.0-99.191.255.255 comment="United States" list=
SafeCountries
add address=99.192.128.0-99.192.206.255 comment="United States" list=
SafeCountries
add address=99.192.208.0-99.198.255.255 comment="United States" list=
SafeCountries
add address=99.200.0.0/13 comment="United States" list=SafeCountries
add address=100.0.0.0-100.42.239.255 comment="United States" list=
SafeCountries
add address=100.43.0.0-100.43.95.255 comment="United States" list=
SafeCountries
add address=100.43.128.0-100.63.255.255 comment="United States" list=
SafeCountries
add address=100.128.0.0/9 comment="United States" list=SafeCountries
add address=103.1.61.0/24 comment="United States" list=SafeCountries
add address=103.3.164.0-103.3.166.255 comment="United States" list=
SafeCountries
add address=103.4.247.0/24 comment="United States" list=SafeCountries
add address=103.6.66.0/23 comment="United States" list=SafeCountries
add address=103.11.64.0/22 comment="United States" list=SafeCountries
add address=103.12.212.0/23 comment="United States" list=SafeCountries
add address=103.13.65.0/24 comment="United States" list=SafeCountries
add address=103.14.68.32/29 comment="United States" list=SafeCountries
add address=103.21.244.0/24 comment="United States" list=SafeCountries
add address=103.21.246.0/23 comment="United States" list=SafeCountries
add address=103.22.200.128-103.22.201.255 comment="United States" list=
SafeCountries
add address=103.22.203.0/24 comment="United States" list=SafeCountries
add address=103.28.132.0/23 comment="United States" list=SafeCountries
add address=103.31.6.0/23 comment="United States" list=SafeCountries
add address=103.31.184.48-103.31.184.255 comment="United States" list=
SafeCountries
add address=103.46.209.0/24 comment="United States" list=SafeCountries
add address=103.47.204.0/22 comment="United States" list=SafeCountries
add address=103.52.195.0/24 comment="United States" list=SafeCountries
add address=103.52.215.0/24 comment="United States" list=SafeCountries
add address=103.195.100.0/22 comment="United States" list=SafeCountries
add address=103.196.36.0/22 comment="United States" list=SafeCountries
add address=103.196.180.0/22 comment="United States" list=SafeCountries
add address=103.202.232.0/22 comment="United States" list=SafeCountries
add address=103.203.40.0/22 comment="United States" list=SafeCountries
add address=103.205.84.0/24 comment="United States" list=SafeCountries
add address=103.208.93.0/24 comment="United States" list=SafeCountries
add address=103.210.12.0/24 comment="United States" list=SafeCountries
add address=103.210.14.0/23 comment="United States" list=SafeCountries
add address=103.211.27.0/24 comment="United States" list=SafeCountries
add address=103.211.160.0/22 comment="United States" list=SafeCountries
add address=103.211.180.0/22 comment="United States" list=SafeCountries
add address=103.211.252.0/22 comment="United States" list=SafeCountries
add address=103.214.69.0-103.214.70.255 comment="United States" list=
SafeCountries
add address=103.224.215.0/24 comment="United States" list=SafeCountries
add address=103.225.164.0/24 comment="United States" list=SafeCountries
add address=103.231.172.0/22 comment="United States" list=SafeCountries
add address=103.235.176.0/24 comment="United States" list=SafeCountries
add address=103.236.212.0/22 comment="United States" list=SafeCountries
add address=103.241.215.0/24 comment="United States" list=SafeCountries
add address=103.243.179.0/24 comment="United States" list=SafeCountries
add address=103.244.144.0/23 comment="United States" list=SafeCountries
add address=103.246.96.0/24 comment="United States" list=SafeCountries
add address=103.246.248.0/24 comment="United States" list=SafeCountries
add address=103.252.112.132 comment="United States" list=SafeCountries
add address=104.0.0.0-104.8.216.255 comment="United States" list=
SafeCountries
add address=104.8.217.160/29 comment="United States" list=SafeCountries
add address=104.8.218.0-104.36.7.255 comment="United States" list=
SafeCountries
add address=104.36.16.0-104.36.99.255 comment="United States" list=
SafeCountries
add address=104.36.104.0-104.36.115.255 comment="United States" list=
SafeCountries
add address=104.36.120.0-104.36.147.255 comment="United States" list=
SafeCountries
add address=104.36.152.0-104.36.179.255 comment="United States" list=
SafeCountries
add address=104.36.184.0-104.37.1.255 comment="United States" list=
SafeCountries
add address=104.37.3.0/24 comment="United States" list=SafeCountries
add address=104.37.8.0-104.37.19.255 comment="United States" list=
SafeCountries
add address=104.37.24.0-104.37.59.255 comment="United States" list=
SafeCountries
add address=104.37.68.0/22 comment="United States" list=SafeCountries
add address=104.37.76.0/22 comment="United States" list=SafeCountries
add address=104.37.84.0-104.37.111.255 comment="United States" list=
SafeCountries
add address=104.37.116.0-104.37.147.255 comment="United States" list=
SafeCountries
add address=104.37.152.0-104.37.191.255 comment="United States" list=
SafeCountries
add address=104.37.208.0-104.37.239.255 comment="United States" list=
SafeCountries
add address=104.37.244.0-104.40.127.255 comment="United States" list=
SafeCountries
add address=104.41.128.0/19 comment="United States" list=SafeCountries
add address=104.42.0.0/16 comment="United States" list=SafeCountries
add address=104.43.128.0-104.44.96.255 comment="United States" list=
SafeCountries
add address=104.44.98.0-104.44.102.255 comment="United States" list=
SafeCountries
add address=104.44.105.0-104.44.106.31 comment="United States" list=
SafeCountries
add address=104.44.106.96/27 comment="United States" list=SafeCountries
add address=104.44.106.160/27 comment="United States" list=SafeCountries
add address=104.44.107.32-104.44.107.79 comment="United States" list=
SafeCountries
add address=104.44.107.112-104.44.108.191 comment="United States" list=
SafeCountries
add address=104.44.108.224-104.44.114.255 comment="United States" list=
SafeCountries
add address=104.44.117.0-104.44.119.255 comment="United States" list=
SafeCountries
add address=104.44.128.0-104.44.193.63 comment="United States" list=
SafeCountries
add address=104.44.193.128-104.44.193.223 comment="United States" list=
SafeCountries
add address=104.44.194.128-104.44.202.223 comment="United States" list=
SafeCountries
add address=104.44.203.0-104.44.203.135 comment="United States" list=
SafeCountries
add address=104.44.203.152-104.44.203.191 comment="United States" list=
SafeCountries
add address=104.44.204.0-104.44.208.159 comment="United States" list=
SafeCountries
add address=104.44.208.192/26 comment="United States" list=SafeCountries
add address=104.44.209.64-104.44.210.63 comment="United States" list=
SafeCountries
add address=104.44.210.144-104.44.219.127 comment="United States" list=
SafeCountries
add address=104.44.220.0/24 comment="United States" list=SafeCountries
add address=104.44.221.192-104.44.222.63 comment="United States" list=
SafeCountries
add address=104.44.223.0-104.44.248.143 comment="United States" list=
SafeCountries
add address=104.44.248.208-104.44.253.255 comment="United States" list=
SafeCountries
add address=104.44.254.128-104.44.255.255 comment="United States" list=
SafeCountries
add address=104.45.128.0-104.46.7.255 comment="United States" list=
SafeCountries
add address=104.46.96.0/19 comment="United States" list=SafeCountries
add address=104.46.192.0/20 comment="United States" list=SafeCountries
add address=104.47.0.0-104.47.121.255 comment="United States" list=
SafeCountries
add address=104.47.123.0-104.47.127.255 comment="United States" list=
SafeCountries
add address=104.47.192.0-104.47.209.255 comment="United States" list=
SafeCountries
add address=104.47.216.0/23 comment="United States" list=SafeCountries
add address=104.47.220.0-104.64.143.255 comment="United States" list=
SafeCountries
add address=104.64.176.0-104.65.15.255 comment="United States" list=
SafeCountries
add address=104.65.32.0-104.66.63.255 comment="United States" list=
SafeCountries
add address=104.66.128.0/19 comment="United States" list=SafeCountries
add address=104.66.192.0/19 comment="United States" list=SafeCountries
add address=104.67.64.0-104.68.159.255 comment="United States" list=
SafeCountries
add address=104.68.224.0-104.69.47.255 comment="United States" list=
SafeCountries
add address=104.69.144.0-104.69.175.255 comment="United States" list=
SafeCountries
add address=104.69.212.0-104.69.239.255 comment="United States" list=
SafeCountries
add address=104.70.16.0-104.70.123.255 comment="United States" list=
SafeCountries
add address=104.70.126.0-104.70.229.255 comment="United States" list=
SafeCountries
add address=104.71.50.0-104.71.55.255 comment="United States" list=
SafeCountries
add address=104.71.62.0-104.71.95.255 comment="United States" list=
SafeCountries
add address=104.71.128.0/23 comment="United States" list=SafeCountries
add address=104.71.131.0/24 comment="United States" list=SafeCountries
add address=104.71.136.0-104.71.141.255 comment="United States" list=
SafeCountries
add address=104.71.144.0-104.71.175.255 comment="United States" list=
SafeCountries
add address=104.71.218.0-104.71.223.255 comment="United States" list=
SafeCountries
add address=104.72.0.0-104.72.69.255 comment="United States" list=
SafeCountries
add address=104.72.71.0-104.72.147.255 comment="United States" list=
SafeCountries
add address=104.72.154.0-104.72.159.255 comment="United States" list=
SafeCountries
add address=104.72.192.0-104.74.19.255 comment="United States" list=
SafeCountries
add address=104.74.26.0-104.74.63.255 comment="United States" list=
SafeCountries
add address=104.74.70.0/23 comment="United States" list=SafeCountries
add address=104.74.148.0-104.75.13.255 comment="United States" list=
SafeCountries
add address=104.75.16.0-104.75.47.255 comment="United States" list=
SafeCountries
add address=104.75.84.0/23 comment="United States" list=SafeCountries
add address=104.75.92.0/22 comment="United States" list=SafeCountries
add address=104.75.128.0-104.76.21.255 comment="United States" list=
SafeCountries
add address=104.76.28.0/22 comment="United States" list=SafeCountries
add address=104.76.64.0-104.76.103.255 comment="United States" list=
SafeCountries
add address=104.76.108.0-104.76.198.255 comment="United States" list=
SafeCountries
add address=104.76.200.0/22 comment="United States" list=SafeCountries
add address=104.76.205.0-104.76.214.255 comment="United States" list=
SafeCountries
add address=104.76.216.0-104.76.218.255 comment="United States" list=
SafeCountries
add address=104.76.220.0/23 comment="United States" list=SafeCountries
add address=104.76.223.0-104.80.25.255 comment="United States" list=
SafeCountries
add address=104.80.32.0/19 comment="United States" list=SafeCountries
add address=104.80.128.0-104.82.143.255 comment="United States" list=
SafeCountries
add address=104.82.188.0/22 comment="United States" list=SafeCountries
add address=104.82.224.0-104.83.3.255 comment="United States" list=
SafeCountries
add address=104.83.82.0-104.83.87.255 comment="United States" list=
SafeCountries
add address=104.83.96.0/19 comment="United States" list=SafeCountries
add address=104.83.202.0-104.83.207.255 comment="United States" list=
SafeCountries
add address=104.83.240.0-104.84.143.255 comment="United States" list=
SafeCountries
add address=104.84.148.0/22 comment="United States" list=SafeCountries
add address=104.84.154.0-104.86.109.255 comment="United States" list=
SafeCountries
add address=104.86.112.0-104.86.189.255 comment="United States" list=
SafeCountries
add address=104.86.192.0/19 comment="United States" list=SafeCountries
add address=104.87.4.0-104.87.191.255 comment="United States" list=
SafeCountries
add address=104.88.0.0-104.89.163.255 comment="United States" list=
SafeCountries
add address=104.89.240.0-104.101.219.255 comment="United States" list=
SafeCountries
add address=104.101.222.0-104.128.127.255 comment="United States" list=
SafeCountries
add address=104.128.160.0-104.128.239.255 comment="United States" list=
SafeCountries
add address=104.129.0.0-104.129.95.255 comment="United States" list=
SafeCountries
add address=104.129.128.0-104.129.223.255 comment="United States" list=
SafeCountries
add address=104.129.240.0-104.132.7.255 comment="United States" list=
SafeCountries
add address=104.132.10.0-104.132.13.63 comment="United States" list=
SafeCountries
add address=104.132.13.112-104.132.16.255 comment="United States" list=
SafeCountries
add address=104.132.18.0/23 comment="United States" list=SafeCountries
add address=104.132.21.0-104.132.23.255 comment="United States" list=
SafeCountries
add address=104.132.25.0-104.132.31.255 comment="United States" list=
SafeCountries
add address=104.132.33.0-104.132.34.255 comment="United States" list=
SafeCountries
add address=104.132.37.0-104.132.51.255 comment="United States" list=
SafeCountries
add address=104.132.53.0-104.132.137.255 comment="United States" list=
SafeCountries
add address=104.132.139.0-104.132.141.255 comment="United States" list=
SafeCountries
add address=104.132.143.0-104.132.145.255 comment="United States" list=
SafeCountries
add address=104.132.147.0-104.132.160.255 comment="United States" list=
SafeCountries
add address=104.132.162.0-104.132.174.255 comment="United States" list=
SafeCountries
add address=104.132.176.0-104.132.178.255 comment="United States" list=
SafeCountries
add address=104.132.180.0-104.132.186.255 comment="United States" list=
SafeCountries
add address=104.132.188.0-104.132.199.255 comment="United States" list=
SafeCountries
add address=104.132.201.0-104.133.0.255 comment="United States" list=
SafeCountries
add address=104.133.2.0-104.135.223.255 comment="United States" list=
SafeCountries
add address=104.136.0.0-104.141.255.255 comment="United States" list=
SafeCountries
add address=104.142.128.0-104.143.17.255 comment="United States" list=
SafeCountries
add address=104.143.32.0-104.143.83.255 comment="United States" list=
SafeCountries
add address=104.143.84.16-104.143.192.255 comment="United States" list=
SafeCountries
add address=104.143.194.0/24 comment="United States" list=SafeCountries
add address=104.143.196.0/24 comment="United States" list=SafeCountries
add address=104.143.198.0/24 comment="United States" list=SafeCountries
add address=104.143.200.0/24 comment="United States" list=SafeCountries
add address=104.143.202.0/24 comment="United States" list=SafeCountries
add address=104.143.205.0/24 comment="United States" list=SafeCountries
add address=104.143.207.0/24 comment="United States" list=SafeCountries
add address=104.143.209.0/24 comment="United States" list=SafeCountries
add address=104.143.211.0/24 comment="United States" list=SafeCountries
add address=104.143.213.0/24 comment="United States" list=SafeCountries
add address=104.143.215.0/24 comment="United States" list=SafeCountries
add address=104.143.217.0/24 comment="United States" list=SafeCountries
add address=104.143.219.0/24 comment="United States" list=SafeCountries
add address=104.143.221.0/24 comment="United States" list=SafeCountries
add address=104.143.223.0-104.144.103.31 comment="United States" list=
SafeCountries
add address=104.144.103.48-104.144.174.255 comment="United States" list=
SafeCountries
add address=104.144.175.16-104.144.186.207 comment="United States" list=
SafeCountries
add address=104.144.186.224-104.144.255.255 comment="United States" list=
SafeCountries
add address=104.145.16.0-104.145.238.255 comment="United States" list=
SafeCountries
add address=104.145.240.0-104.146.15.255 comment="United States" list=
SafeCountries
add address=104.146.24.0/22 comment="United States" list=SafeCountries
add address=104.146.28.176-104.146.29.255 comment="United States" list=
SafeCountries
add address=104.146.30.128-104.146.182.255 comment="United States" list=
SafeCountries
add address=104.146.184.0-104.146.192.255 comment="United States" list=
SafeCountries
add address=104.146.194.0/23 comment="United States" list=SafeCountries
add address=104.146.205.0-104.146.212.255 comment="United States" list=
SafeCountries
add address=104.146.217.0-104.146.221.255 comment="United States" list=
SafeCountries
add address=104.146.224.0/22 comment="United States" list=SafeCountries
add address=104.146.229.0-104.152.3.255 comment="United States" list=
SafeCountries
add address=104.152.8.0-104.152.27.255 comment="United States" list=
SafeCountries
add address=104.152.32.0-104.152.119.255 comment="United States" list=
SafeCountries
add address=104.152.124.0-104.152.151.255 comment="United States" list=
SafeCountries
add address=104.152.156.0/22 comment="United States" list=SafeCountries
add address=104.152.172.0-104.152.190.167 comment="United States" list=
SafeCountries
add address=104.152.190.176-104.152.207.255 comment="United States" list=
SafeCountries
add address=104.152.212.0-104.152.223.255 comment="United States" list=
SafeCountries
add address=104.152.228.0-104.152.235.255 comment="United States" list=
SafeCountries
add address=104.152.240.0-104.153.23.255 comment="United States" list=
SafeCountries
add address=104.153.28.0-104.153.47.255 comment="United States" list=
SafeCountries
add address=104.153.52.0/22 comment="United States" list=SafeCountries
add address=104.153.60.0-104.153.127.255 comment="United States" list=
SafeCountries
add address=104.153.144.0-104.153.163.255 comment="United States" list=
SafeCountries
add address=104.153.168.0-104.153.211.255 comment="United States" list=
SafeCountries
add address=104.153.216.0-104.153.247.255 comment="United States" list=
SafeCountries
add address=104.153.252.0-104.156.31.255 comment="United States" list=
SafeCountries
add address=104.156.48.0/20 comment="United States" list=SafeCountries
add address=104.156.80.0/23 comment="United States" list=SafeCountries
add address=104.156.83.0-104.156.192.255 comment="United States" list=
SafeCountries
add address=104.156.194.0/24 comment="United States" list=SafeCountries
add address=104.156.196.0/24 comment="United States" list=SafeCountries
add address=104.156.198.0/24 comment="United States" list=SafeCountries
add address=104.156.200.0-104.156.202.255 comment="United States" list=
SafeCountries
add address=104.156.204.0/24 comment="United States" list=SafeCountries
add address=104.156.206.0/24 comment="United States" list=SafeCountries
add address=104.156.208.0/24 comment="United States" list=SafeCountries
add address=104.156.210.0/24 comment="United States" list=SafeCountries
add address=104.156.212.0/24 comment="United States" list=SafeCountries
add address=104.156.214.0/24 comment="United States" list=SafeCountries
add address=104.156.216.0/24 comment="United States" list=SafeCountries
add address=104.156.218.0/24 comment="United States" list=SafeCountries
add address=104.156.220.0/24 comment="United States" list=SafeCountries
add address=104.156.222.0/24 comment="United States" list=SafeCountries
add address=104.156.224.0/21 comment="United States" list=SafeCountries
add address=104.156.234.0-104.156.237.255 comment="United States" list=
SafeCountries
add address=104.156.240.0/20 comment="United States" list=SafeCountries
add address=104.159.128.0-104.160.13.255 comment="United States" list=
SafeCountries
add address=104.160.16.0/23 comment="United States" list=SafeCountries
add address=104.160.20.0/22 comment="United States" list=SafeCountries
add address=104.160.26.0/24 comment="United States" list=SafeCountries
add address=104.160.28.0-104.160.191.255 comment="United States" list=
SafeCountries
add address=104.160.224.0-104.162.255.255 comment="United States" list=
SafeCountries
add address=104.164.0.0-104.166.31.255 comment="United States" list=
SafeCountries
add address=104.166.48.0-104.166.96.255 comment="United States" list=
SafeCountries
add address=104.166.99.0-104.166.100.255 comment="United States" list=
SafeCountries
add address=104.166.104.0/24 comment="United States" list=SafeCountries
add address=104.166.107.0/24 comment="United States" list=SafeCountries
add address=104.166.115.0/24 comment="United States" list=SafeCountries
add address=104.166.122.0/23 comment="United States" list=SafeCountries
add address=104.166.128.0-104.167.95.255 comment="United States" list=
SafeCountries
add address=104.167.128.0/18 comment="United States" list=SafeCountries
add address=104.167.195.0/24 comment="United States" list=SafeCountries
add address=104.167.237.0/24 comment="United States" list=SafeCountries
add address=104.168.0.0-104.171.47.255 comment="United States" list=
SafeCountries
add address=104.171.64.0-104.171.115.159 comment="United States" list=
SafeCountries
add address=104.171.115.192-104.171.119.79 comment="United States" list=
SafeCountries
add address=104.171.119.88-104.171.122.95 comment="United States" list=
SafeCountries
add address=104.171.122.128-104.171.126.63 comment="United States" list=
SafeCountries
add address=104.171.126.96-104.171.126.191 comment="United States" list=
SafeCountries
add address=104.171.126.224-104.171.127.63 comment="United States" list=
SafeCountries
add address=104.171.127.96-104.171.127.183 comment="United States" list=
SafeCountries
add address=104.171.127.192-104.171.191.255 comment="United States" list=
SafeCountries
add address=104.171.208.0-104.192.15.255 comment="United States" list=
SafeCountries
add address=104.192.24.0-104.192.43.255 comment="United States" list=
SafeCountries
add address=104.192.48.0/22 comment="United States" list=SafeCountries
add address=104.192.56.0-104.192.115.255 comment="United States" list=
SafeCountries
add address=104.192.128.0/22 comment="United States" list=SafeCountries
add address=104.192.132.176 comment="United States" list=SafeCountries
add address=104.192.136.0/21 comment="United States" list=SafeCountries
add address=104.192.148.0/22 comment="United States" list=SafeCountries
add address=104.192.156.0-104.192.171.255 comment="United States" list=
SafeCountries
add address=104.192.176.0/21 comment="United States" list=SafeCountries
add address=104.192.192.0-104.192.231.255 comment="United States" list=
SafeCountries
add address=104.192.236.0-104.193.31.255 comment="United States" list=
SafeCountries
add address=104.193.40.0/21 comment="United States" list=SafeCountries
add address=104.193.72.0-104.193.91.255 comment="United States" list=
SafeCountries
add address=104.193.96.0/21 comment="United States" list=SafeCountries
add address=104.193.108.0-104.193.131.255 comment="United States" list=
SafeCountries
add address=104.193.136.0-104.193.171.255 comment="United States" list=
SafeCountries
add address=104.193.176.0-104.193.195.255 comment="United States" list=
SafeCountries
add address=104.193.200.0/21 comment="United States" list=SafeCountries
add address=104.193.212.0-104.193.251.127 comment="United States" list=
SafeCountries
add address=104.193.251.160-104.194.31.255 comment="United States" list=
SafeCountries
add address=104.194.64.0-104.194.202.255 comment="United States" list=
SafeCountries
add address=104.194.204.0/22 comment="United States" list=SafeCountries
add address=104.194.216.0-104.195.127.255 comment="United States" list=
SafeCountries
add address=104.196.0.0/14 comment="United States" list=SafeCountries
add address=104.200.16.0-104.200.77.255 comment="United States" list=
SafeCountries
add address=104.200.79.0/24 comment="United States" list=SafeCountries
add address=104.200.112.0-104.203.255.255 comment="United States" list=
SafeCountries
add address=104.206.0.0-104.207.63.255 comment="United States" list=
SafeCountries
add address=104.207.67.0-104.207.69.255 comment="United States" list=
SafeCountries
add address=104.207.72.0/24 comment="United States" list=SafeCountries
add address=104.207.77.0/24 comment="United States" list=SafeCountries
add address=104.207.79.0/24 comment="United States" list=SafeCountries
add address=104.207.85.0/24 comment="United States" list=SafeCountries
add address=104.207.88.0/24 comment="United States" list=SafeCountries
add address=104.207.89.0/24 comment="Costa Rica" list=SafeCountries
add address=104.207.90.0-104.207.92.255 comment="United States" list=
SafeCountries
add address=104.207.96.0-104.207.129.255 comment="United States" list=
SafeCountries
add address=104.207.132.0-104.208.63.255 comment="United States" list=
SafeCountries
add address=104.208.128.0-104.209.63.255 comment="United States" list=
SafeCountries
add address=104.209.96.0-104.210.63.255 comment="United States" list=
SafeCountries
add address=104.210.128.0-104.211.63.255 comment="United States" list=
SafeCountries
add address=104.212.0.0-104.214.127.255 comment="United States" list=
SafeCountries
add address=104.215.64.0/18 comment="United States" list=SafeCountries
add address=104.216.0.0-104.218.43.255 comment="United States" list=
SafeCountries
add address=104.218.48.0/21 comment="United States" list=SafeCountries
add address=104.218.64.0-104.218.83.255 comment="United States" list=
SafeCountries
add address=104.218.88.0/22 comment="United States" list=SafeCountries
add address=104.218.96.0-104.218.123.255 comment="United States" list=
SafeCountries
add address=104.218.128.0-104.218.167.255 comment="United States" list=
SafeCountries
add address=104.218.180.0-104.218.191.255 comment="United States" list=
SafeCountries
add address=104.218.196.24-104.218.215.255 comment="United States" list=
SafeCountries
add address=104.218.220.0-104.218.239.255 comment="United States" list=
SafeCountries
add address=104.218.244.0-104.219.6.255 comment="United States" list=
SafeCountries
add address=104.219.16.0/21 comment="United States" list=SafeCountries
add address=104.219.32.0-104.219.71.255 comment="United States" list=
SafeCountries
add address=104.219.76.0-104.219.99.255 comment="United States" list=
SafeCountries
add address=104.219.104.0-104.219.115.255 comment="United States" list=
SafeCountries
add address=104.219.136.0-104.219.155.255 comment="United States" list=
SafeCountries
add address=104.219.160.0-104.219.187.255 comment="United States" list=
SafeCountries
add address=104.219.196.0/22 comment="United States" list=SafeCountries
add address=104.219.208.0-104.219.219.255 comment="United States" list=
SafeCountries
add address=104.219.224.0-104.220.255.255 comment="United States" list=
SafeCountries
add address=104.221.128.0-104.222.111.255 comment="United States" list=
SafeCountries
add address=104.222.128.0-104.222.130.255 comment="United States" list=
SafeCountries
add address=104.222.132.0/22 comment="United States" list=SafeCountries
add address=104.222.137.0-104.222.139.255 comment="United States" list=
SafeCountries
add address=104.222.141.0-104.222.144.255 comment="United States" list=
SafeCountries
add address=104.222.146.0-104.222.148.255 comment="United States" list=
SafeCountries
add address=104.222.150.0-104.222.191.255 comment="United States" list=
SafeCountries
add address=104.222.193.0/24 comment="United States" list=SafeCountries
add address=104.222.211.0-104.222.212.255 comment="United States" list=
SafeCountries
add address=104.222.217.0/24 comment="United States" list=SafeCountries
add address=104.222.222.0-104.223.255.255 comment="United States" list=
SafeCountries
add address=104.224.39.0/24 comment="United States" list=SafeCountries
add address=104.224.64.0/19 comment="United States" list=SafeCountries
add address=104.224.128.0/20 comment="United States" list=SafeCountries
add address=104.224.148.0-104.227.62.223 comment="United States" list=
SafeCountries
add address=104.227.62.240-104.227.167.47 comment="United States" list=
SafeCountries
add address=104.227.167.64-104.232.47.255 comment="United States" list=
SafeCountries
add address=104.232.64.0-104.232.191.255 comment="United States" list=
SafeCountries
add address=104.232.208.0-104.233.63.255 comment="United States" list=
SafeCountries
add address=104.233.128.0/17 comment="United States" list=SafeCountries
add address=104.235.0.0-104.237.82.255 comment="United States" list=
SafeCountries
add address=104.237.86.0/24 comment="United States" list=SafeCountries
add address=104.237.88.0/24 comment="United States" list=SafeCountries
add address=104.237.90.0/24 comment="United States" list=SafeCountries
add address=104.237.92.0/24 comment="United States" list=SafeCountries
add address=104.237.94.0/24 comment="United States" list=SafeCountries
add address=104.237.96.0-104.238.49.255 comment="United States" list=
SafeCountries
add address=104.238.52.0-104.238.59.255 comment="United States" list=
SafeCountries
add address=104.238.64.0-104.238.147.255 comment="United States" list=
SafeCountries
add address=104.238.152.0-104.238.157.255 comment="United States" list=
SafeCountries
add address=104.238.162.0-104.238.165.255 comment="United States" list=
SafeCountries
add address=104.238.178.0-104.238.183.255 comment="United States" list=
SafeCountries
add address=104.238.192.0-104.241.127.255 comment="United States" list=
SafeCountries
add address=104.241.208.0-104.241.255.255 comment="United States" list=
SafeCountries
add address=104.243.0.0-104.243.79.255 comment="United States" list=
SafeCountries
add address=104.243.112.0-104.243.240.255 comment="United States" list=
SafeCountries
add address=104.243.254.0-104.244.63.255 comment="United States" list=
SafeCountries
add address=104.244.72.0-104.244.74.187 comment="United States" list=
SafeCountries
add address=104.244.74.189-104.244.179.255 comment="United States" list=
SafeCountries
add address=104.244.184.0/22 comment="United States" list=SafeCountries
add address=104.244.192.0/22 comment="United States" list=SafeCountries
add address=104.244.200.0-104.244.223.255 comment="United States" list=
SafeCountries
add address=104.244.232.0-104.244.243.255 comment="United States" list=
SafeCountries
add address=104.244.248.0/21 comment="United States" list=SafeCountries
add address=104.245.8.0/24 comment="United States" list=SafeCountries
add address=104.245.11.0-104.245.14.255 comment="United States" list=
SafeCountries
add address=104.245.16.0-104.245.36.255 comment="United States" list=
SafeCountries
add address=104.245.38.0-104.245.47.255 comment="United States" list=
SafeCountries
add address=104.245.52.0-104.245.63.255 comment="United States" list=
SafeCountries
add address=104.245.68.0-104.245.87.255 comment="United States" list=
SafeCountries
add address=104.245.96.0/20 comment="United States" list=SafeCountries
add address=104.245.120.0-104.245.143.255 comment="United States" list=
SafeCountries
add address=104.245.148.0/22 comment="United States" list=SafeCountries
add address=104.245.168.0-104.245.199.255 comment="United States" list=
SafeCountries
add address=104.245.208.0/20 comment="United States" list=SafeCountries
add address=104.245.228.0-104.246.127.255 comment="United States" list=
SafeCountries
add address=104.247.0.0-104.247.6.255 comment="United States" list=
SafeCountries
add address=104.247.8.0-104.247.20.255 comment="United States" list=
SafeCountries
add address=104.247.22.0-104.247.100.255 comment="United States" list=
SafeCountries
add address=104.247.102.0/23 comment="United States" list=SafeCountries
add address=104.247.105.0-104.247.111.255 comment="United States" list=
SafeCountries
add address=104.247.113.0-104.247.117.255 comment="United States" list=
SafeCountries
add address=104.247.119.0-104.247.223.255 comment="United States" list=
SafeCountries
add address=104.248.0.0-104.249.127.255 comment="United States" list=
SafeCountries
add address=104.249.129.0-104.249.135.255 comment="United States" list=
SafeCountries
add address=104.249.137.0-104.249.140.255 comment="United States" list=
SafeCountries
add address=104.249.142.0/24 comment="United States" list=SafeCountries
add address=104.249.145.0/24 comment="United States" list=SafeCountries
add address=104.249.147.0/24 comment="United States" list=SafeCountries
add address=104.249.149.0/24 comment="United States" list=SafeCountries
add address=104.249.151.0-104.249.152.255 comment="United States" list=
SafeCountries
add address=104.249.154.0-104.249.158.255 comment="United States" list=
SafeCountries
add address=104.249.161.0-104.249.166.255 comment="United States" list=
SafeCountries
add address=104.249.168.0-104.249.170.255 comment="United States" list=
SafeCountries
add address=104.249.172.0-104.249.174.255 comment="United States" list=
SafeCountries
add address=104.249.176.0/24 comment="United States" list=SafeCountries
add address=104.249.179.0/24 comment="United States" list=SafeCountries
add address=104.249.181.0-104.249.191.255 comment="United States" list=
SafeCountries
add address=104.250.32.0/19 comment="United States" list=SafeCountries
add address=104.250.96.0-104.250.159.255 comment="United States" list=
SafeCountries
add address=104.250.179.0/24 comment="United States" list=SafeCountries
add address=104.250.188.0/24 comment="United States" list=SafeCountries
add address=104.250.190.0-104.250.228.255 comment="United States" list=
SafeCountries
add address=104.250.230.0/24 comment="United States" list=SafeCountries
add address=104.250.232.0-104.250.237.255 comment="United States" list=
SafeCountries
add address=104.250.239.0-104.251.31.255 comment="United States" list=
SafeCountries
add address=104.251.48.0-104.251.85.255 comment="United States" list=
SafeCountries
add address=104.251.87.0/24 comment="United States" list=SafeCountries
add address=104.251.89.0-104.251.95.255 comment="United States" list=
SafeCountries
add address=104.251.112.0-104.251.189.255 comment="United States" list=
SafeCountries
add address=104.251.191.0-104.251.238.255 comment="United States" list=
SafeCountries
add address=104.251.240.0-104.254.7.255 comment="United States" list=
SafeCountries
add address=104.254.12.0-104.254.31.255 comment="United States" list=
SafeCountries
add address=104.254.36.0-104.254.47.255 comment="United States" list=
SafeCountries
add address=104.254.52.0-104.254.87.255 comment="United States" list=
SafeCountries
add address=104.254.100.0-104.254.121.31 comment="United States" list=
SafeCountries
add address=104.254.121.128-104.254.151.255 comment="United States" list=
SafeCountries
add address=104.254.160.0/21 comment="United States" list=SafeCountries
add address=104.254.176.0/22 comment="United States" list=SafeCountries
add address=104.254.184.0-104.254.195.255 comment="United States" list=
SafeCountries
add address=104.254.200.0-104.255.7.255 comment="United States" list=
SafeCountries
add address=104.255.16.0-104.255.47.255 comment="United States" list=
SafeCountries
add address=104.255.52.0-104.255.151.255 comment="United States" list=
SafeCountries
add address=104.255.160.0/20 comment="United States" list=SafeCountries
add address=104.255.184.0-104.255.207.255 comment="United States" list=
SafeCountries
add address=104.255.212.0-104.255.231.255 comment="United States" list=
SafeCountries
add address=104.255.236.0-104.255.251.255 comment="United States" list=
SafeCountries
add address=105.25.96.0/19 comment="United States" list=SafeCountries
add address=105.30.0.0/20 comment="United States" list=SafeCountries
add address=107.0.0.0-107.6.1.255 comment="United States" list=SafeCountries
add address=107.6.2.16-107.6.3.255 comment="United States" list=SafeCountries
add address=107.6.5.0-107.6.7.255 comment="United States" list=SafeCountries
add address=107.6.9.0-107.6.15.255 comment="United States" list=SafeCountries
add address=107.6.17.0-107.6.19.255 comment="United States" list=
SafeCountries
add address=107.6.22.0-107.6.23.31 comment="United States" list=SafeCountries
add address=107.6.23.128-107.6.25.255 comment="United States" list=
SafeCountries
add address=107.6.28.0-107.6.29.159 comment="United States" list=
SafeCountries
add address=107.6.29.192-107.6.30.255 comment="United States" list=
SafeCountries
add address=107.6.32.0/23 comment="United States" list=SafeCountries
add address=107.6.36.0-107.6.40.255 comment="United States" list=
SafeCountries
add address=107.6.42.0/24 comment="United States" list=SafeCountries
add address=107.6.44.0-107.6.49.255 comment="United States" list=
SafeCountries
add address=107.6.52.0/22 comment="United States" list=SafeCountries
add address=107.6.58.0-107.6.61.143 comment="United States" list=
SafeCountries
add address=107.6.61.160-107.6.111.255 comment="United States" list=
SafeCountries
add address=107.6.128.0-107.6.139.255 comment="United States" list=
SafeCountries
add address=107.6.144.0-107.6.149.255 comment="United States" list=
SafeCountries
add address=107.6.158.0/23 comment="United States" list=SafeCountries
add address=107.6.188.0-107.150.29.122 comment="United States" list=
SafeCountries
add address=107.150.29.124-107.150.91.255 comment="United States" list=
SafeCountries
add address=107.150.112.0-107.150.223.255 comment="United States" list=
SafeCountries
add address=107.151.0.0-107.152.79.255 comment="United States" list=
SafeCountries
add address=107.152.96.0-107.152.169.255 comment="United States" list=
SafeCountries
add address=107.152.171.0-107.152.186.31 comment="United States" list=
SafeCountries
add address=107.152.186.40-107.152.187.151 comment="United States" list=
SafeCountries
add address=107.152.187.160-107.152.188.31 comment="United States" list=
SafeCountries
add address=107.152.188.48-107.152.232.31 comment="United States" list=
SafeCountries
add address=107.152.232.48-107.152.241.63 comment="United States" list=
SafeCountries
add address=107.152.241.80-107.152.249.239 comment="United States" list=
SafeCountries
add address=107.152.250.0-107.152.252.47 comment="United States" list=
SafeCountries
add address=107.152.252.64-107.153.4.255 comment="United States" list=
SafeCountries
add address=107.153.7.0-107.153.19.255 comment="United States" list=
SafeCountries
add address=107.153.21.0-107.153.27.255 comment="United States" list=
SafeCountries
add address=107.153.29.0-107.153.33.255 comment="United States" list=
SafeCountries
add address=107.153.35.0-107.153.83.255 comment="United States" list=
SafeCountries
add address=107.153.85.0-107.153.109.255 comment="United States" list=
SafeCountries
add address=107.153.111.0-107.153.125.255 comment="United States" list=
SafeCountries
add address=107.153.127.0-107.153.243.255 comment="United States" list=
SafeCountries
add address=107.153.253.0/24 comment="United States" list=SafeCountries
add address=107.153.255.0-107.154.117.255 comment="United States" list=
SafeCountries
add address=107.154.119.0-107.158.255.255 comment="United States" list=
SafeCountries
add address=107.160.0.0/16 comment="United States" list=SafeCountries
add address=107.161.16.0/20 comment="United States" list=SafeCountries
add address=107.161.48.0/20 comment="United States" list=SafeCountries
add address=107.161.80.0/20 comment="United States" list=SafeCountries
add address=107.161.112.0-107.161.152.255 comment="United States" list=
SafeCountries
add address=107.161.155.0-107.161.158.255 comment="United States" list=
SafeCountries
add address=107.161.160.0-107.167.255.255 comment="United States" list=
SafeCountries
add address=107.168.6.0/23 comment="United States" list=SafeCountries
add address=107.168.9.0-107.168.31.255 comment="United States" list=
SafeCountries
add address=107.168.33.0-107.168.47.255 comment="United States" list=
SafeCountries
add address=107.168.50.0-107.168.54.255 comment="United States" list=
SafeCountries
add address=107.168.57.0-107.168.69.255 comment="United States" list=
SafeCountries
add address=107.168.72.0-107.168.101.255 comment="United States" list=
SafeCountries
add address=107.168.103.0-107.168.121.255 comment="United States" list=
SafeCountries
add address=107.168.123.0-107.168.128.255 comment="United States" list=
SafeCountries
add address=107.168.130.0-107.169.100.255 comment="United States" list=
SafeCountries
add address=107.169.102.0-107.171.127.255 comment="United States" list=
SafeCountries
add address=107.172.0.0-107.179.127.255 comment="United States" list=
SafeCountries
add address=107.180.0.0-107.181.127.255 comment="United States" list=
SafeCountries
add address=107.181.129.0-107.181.130.255 comment="United States" list=
SafeCountries
add address=107.181.132.0-107.188.255.255 comment="United States" list=
SafeCountries
add address=107.189.2.0-107.189.191.255 comment="United States" list=
SafeCountries
add address=107.190.128.0-107.190.162.255 comment="United States" list=
SafeCountries
add address=107.190.164.0/23 comment="United States" list=SafeCountries
add address=107.190.167.0-107.190.171.255 comment="United States" list=
SafeCountries
add address=107.190.175.0-107.191.45.255 comment="United States" list=
SafeCountries
add address=107.191.48.0/22 comment="United States" list=SafeCountries
add address=107.191.54.0/23 comment="United States" list=SafeCountries
add address=107.191.57.0-107.191.59.255 comment="United States" list=
SafeCountries
add address=107.191.77.0/24 comment="United States" list=SafeCountries
add address=107.191.80.0-107.191.108.175 comment="United States" list=
SafeCountries
add address=107.191.108.177-107.191.207.255 comment="United States" list=
SafeCountries
add address=107.191.224.0-108.59.63.255 comment="United States" list=
SafeCountries
add address=108.59.80.0-108.59.255.255 comment="United States" list=
SafeCountries
add address=108.60.32.0-108.60.159.255 comment="United States" list=
SafeCountries
add address=108.60.192.0/19 comment="United States" list=SafeCountries
add address=108.61.0.0-108.61.12.15 comment="United States" list=
SafeCountries
add address=108.61.12.32-108.61.51.111 comment="United States" list=
SafeCountries
add address=108.61.51.128-108.61.55.143 comment="United States" list=
SafeCountries
add address=108.61.55.160-108.61.56.47 comment="United States" list=
SafeCountries
add address=108.61.56.64-108.61.81.63 comment="United States" list=
SafeCountries
add address=108.61.81.128-108.61.95.255 comment="United States" list=
SafeCountries
add address=108.61.100.0-108.61.102.255 comment="United States" list=
SafeCountries
add address=108.61.104.0/24 comment="United States" list=SafeCountries
add address=108.61.108.0/22 comment="United States" list=SafeCountries
add address=108.61.114.0/23 comment="United States" list=SafeCountries
add address=108.61.119.0-108.61.121.255 comment="United States" list=
SafeCountries
add address=108.61.124.0/23 comment="United States" list=SafeCountries
add address=108.61.128.0/19 comment="United States" list=SafeCountries
add address=108.61.186.0/23 comment="United States" list=SafeCountries
add address=108.61.191.0-108.61.195.255 comment="United States" list=
SafeCountries
add address=108.61.202.0-108.61.207.255 comment="United States" list=
SafeCountries
add address=108.61.214.0-108.61.220.255 comment="United States" list=
SafeCountries
add address=108.61.222.0/24 comment="United States" list=SafeCountries
add address=108.61.224.0/24 comment="United States" list=SafeCountries
add address=108.61.226.0/24 comment="United States" list=SafeCountries
add address=108.61.228.0/23 comment="United States" list=SafeCountries
add address=108.61.232.0-108.61.236.255 comment="United States" list=
SafeCountries
add address=108.61.238.0-108.61.246.63 comment="United States" list=
SafeCountries
add address=108.61.248.0/23 comment="United States" list=SafeCountries
add address=108.61.252.0/24 comment="United States" list=SafeCountries
add address=108.62.0.0/16 comment="United States" list=SafeCountries
add address=108.64.0.0-108.122.163.174 comment="United States" list=
SafeCountries
add address=108.122.163.176-108.160.15.255 comment="United States" list=
SafeCountries
add address=108.160.32.0-108.160.79.255 comment="United States" list=
SafeCountries
add address=108.160.102.0-108.160.239.255 comment="United States" list=
SafeCountries
add address=108.161.0.0/19 comment="United States" list=SafeCountries
add address=108.161.48.0-108.161.111.255 comment="United States" list=
SafeCountries
add address=108.161.128.0/19 comment="United States" list=SafeCountries
add address=108.161.176.0-108.161.241.255 comment="United States" list=
SafeCountries
add address=108.161.244.0/24 comment="United States" list=SafeCountries
add address=108.161.246.0/24 comment="United States" list=SafeCountries
add address=108.161.248.0-108.162.63.255 comment="United States" list=
SafeCountries
add address=108.162.192.0-108.162.221.255 comment="United States" list=
SafeCountries
add address=108.162.224.0/23 comment="United States" list=SafeCountries
add address=108.162.227.0/24 comment="United States" list=SafeCountries
add address=108.162.230.0-108.162.239.255 comment="United States" list=
SafeCountries
add address=108.162.241.0/24 comment="United States" list=SafeCountries
add address=108.162.243.0-108.162.247.255 comment="United States" list=
SafeCountries
add address=108.162.251.0-108.163.127.255 comment="United States" list=
SafeCountries
add address=108.163.158.0/24 comment="United States" list=SafeCountries
add address=108.163.192.0-108.167.255.255 comment="United States" list=
SafeCountries
add address=108.168.128.0-108.170.127.255 comment="United States" list=
SafeCountries
add address=108.170.192.0-108.171.63.255 comment="United States" list=
SafeCountries
add address=108.171.96.0/19 comment="United States" list=SafeCountries
add address=108.171.130.0-108.171.133.255 comment="United States" list=
SafeCountries
add address=108.171.135.0-108.171.136.255 comment="United States" list=
SafeCountries
add address=108.171.144.0-108.171.158.255 comment="United States" list=
SafeCountries
add address=108.171.160.0-108.171.255.255 comment="United States" list=
SafeCountries
add address=108.174.0.0/20 comment="United States" list=SafeCountries
add address=108.174.32.0-108.174.74.255 comment="United States" list=
SafeCountries
add address=108.174.77.0-108.174.127.255 comment="United States" list=
SafeCountries
add address=108.174.144.0/20 comment="United States" list=SafeCountries
add address=108.174.176.0-108.175.79.255 comment="United States" list=
SafeCountries
add address=108.175.96.0-108.175.223.255 comment="United States" list=
SafeCountries
add address=108.175.240.0-108.179.255.255 comment="United States" list=
SafeCountries
add address=108.182.0.0-108.255.255.255 comment="United States" list=
SafeCountries
add address=109.70.67.0-109.70.67.66 comment="United States" list=
SafeCountries
add address=109.70.67.68-109.70.67.255 comment="United States" list=
SafeCountries
add address=109.70.88.0/21 comment="United States" list=SafeCountries
add address=109.73.224.0/20 comment="United States" list=SafeCountries
add address=109.109.201.132/30 comment="United States" list=SafeCountries
add address=109.199.96.0/19 comment="United States" list=SafeCountries
add address=109.205.10.0/24 comment="United States" list=SafeCountries
add address=109.205.12.0/23 comment="United States" list=SafeCountries
add address=109.234.224.0/24 comment="United States" list=SafeCountries
add address=109.235.203.32/28 comment="United States" list=SafeCountries
add address=109.235.203.96/28 comment="United States" list=SafeCountries
add address=110.34.240.0/20 comment="United States" list=SafeCountries
add address=113.29.0.0/23 comment="United States" list=SafeCountries
add address=113.29.2.64-113.29.17.255 comment="United States" list=
SafeCountries
add address=113.29.19.0-113.29.36.127 comment="United States" list=
SafeCountries
add address=113.29.37.0-113.29.40.159 comment="United States" list=
SafeCountries
add address=113.29.40.192-113.29.79.255 comment="United States" list=
SafeCountries
add address=113.29.81.0-113.29.127.255 comment="United States" list=
SafeCountries
add address=113.197.105.0/24 comment="United States" list=SafeCountries
add address=113.197.107.0/24 comment="United States" list=SafeCountries
add address=113.208.92.0/24 comment="United States" list=SafeCountries
add address=114.31.208.0/22 comment="United States" list=SafeCountries
add address=114.141.112.0/22 comment="United States" list=SafeCountries
add address=114.141.119.0-114.141.120.255 comment="United States" list=
SafeCountries
add address=114.141.123.0-114.141.127.255 comment="United States" list=
SafeCountries
add address=114.179.172.0/23 comment="United States" list=SafeCountries
add address=115.85.133.0-115.85.133.191 comment="United States" list=
SafeCountries
add address=115.85.135.0/24 comment="United States" list=SafeCountries
add address=115.124.118.0/23 comment="United States" list=SafeCountries
add address=116.66.130.0/23 comment="United States" list=SafeCountries
add address=116.66.134.0-116.66.139.255 comment="United States" list=
SafeCountries
add address=116.66.144.0/22 comment="United States" list=SafeCountries
add address=117.18.37.0/24 comment="United States" list=SafeCountries
add address=117.55.193.0/24 comment="United States" list=SafeCountries
add address=117.55.200.0/24 comment="United States" list=SafeCountries
add address=117.104.130.0/23 comment="United States" list=SafeCountries
add address=117.121.243.0/24 comment="United States" list=SafeCountries
add address=117.121.247.0/24 comment="United States" list=SafeCountries
add address=119.27.62.0/24 comment="United States" list=SafeCountries
add address=119.81.226.144/28 comment="United States" list=SafeCountries
add address=119.81.227.0/27 comment="United States" list=SafeCountries
add address=119.81.239.16-119.81.239.63 comment="United States" list=
SafeCountries
add address=119.81.240.80/28 comment="United States" list=SafeCountries
add address=119.81.246.48/28 comment="United States" list=SafeCountries
add address=119.81.246.168/29 comment="United States" list=SafeCountries
add address=119.81.248.48/30 comment="United States" list=SafeCountries
add address=119.81.248.54-119.81.248.56 comment="United States" list=
SafeCountries
add address=119.81.248.58/31 comment="United States" list=SafeCountries
add address=119.81.248.61-119.81.248.63 comment="United States" list=
SafeCountries
add address=119.81.249.128/30 comment="United States" list=SafeCountries
add address=119.81.249.134-119.81.249.137 comment="United States" list=
SafeCountries
add address=119.81.249.140/30 comment="United States" list=SafeCountries
add address=119.81.250.144/31 comment="United States" list=SafeCountries
add address=119.81.250.148 comment="United States" list=SafeCountries
add address=119.81.250.150/31 comment="United States" list=SafeCountries
add address=119.81.250.153 comment="United States" list=SafeCountries
add address=119.81.250.155-119.81.250.159 comment="United States" list=
SafeCountries
add address=119.81.253.192-119.81.253.213 comment="United States" list=
SafeCountries
add address=119.81.253.215-119.81.253.228 comment="United States" list=
SafeCountries
add address=119.81.253.231-119.81.253.236 comment="United States" list=
SafeCountries
add address=119.81.253.238-119.81.253.240 comment="United States" list=
SafeCountries
add address=119.81.253.244-119.81.253.255 comment="United States" list=
SafeCountries
add address=120.29.147.0/24 comment="United States" list=SafeCountries
add address=120.88.48.0/23 comment="United States" list=SafeCountries
add address=120.89.64.0/21 comment="United States" list=SafeCountries
add address=121.100.51.0/24 comment="United States" list=SafeCountries
add address=121.119.215.0/24 comment="United States" list=SafeCountries
add address=122.10.120.0/21 comment="United States" list=SafeCountries
add address=124.6.40.0/21 comment="United States" list=SafeCountries
add address=124.40.43.0/24 comment="United States" list=SafeCountries
add address=124.40.48.0/24 comment="United States" list=SafeCountries
add address=124.47.143.0/24 comment="United States" list=SafeCountries
add address=124.47.148.0/23 comment="United States" list=SafeCountries
add address=125.56.128.0/17 comment="United States" list=SafeCountries
add address=128.1.0.0-128.6.255.255 comment="United States" list=
SafeCountries
add address=128.8.0.0/13 comment="United States" list=SafeCountries
add address=128.17.0.0-128.27.255.255 comment="United States" list=
SafeCountries
add address=128.29.0.0-128.38.255.255 comment="United States" list=
SafeCountries
add address=128.42.0.0/16 comment="United States" list=SafeCountries
add address=128.44.0.0/16 comment="United States" list=SafeCountries
add address=128.46.0.0-128.52.255.255 comment="United States" list=
SafeCountries
add address=128.54.0.0-128.64.255.255 comment="United States" list=
SafeCountries
add address=128.65.64.0/19 comment="United States" list=SafeCountries
add address=128.80.0.0-128.85.255.255 comment="United States" list=
SafeCountries
add address=128.88.0.0-128.88.254.255 comment="United States" list=
SafeCountries
add address=128.89.0.0-128.90.9.255 comment="United States" list=
SafeCountries
add address=128.90.15.192/26 comment="United States" list=SafeCountries
add address=128.90.26.0-128.90.58.255 comment="United States" list=
SafeCountries
add address=128.90.64.0/19 comment="United States" list=SafeCountries
add address=128.90.107.0/24 comment="Costa Rica" list=SafeCountries
add address=128.90.110.0/24 comment="United States" list=SafeCountries
add address=128.90.114.0/24 comment="Costa Rica" list=SafeCountries
add address=128.90.117.0/24 comment="United States" list=SafeCountries
add address=128.90.122.0-128.92.255.255 comment="United States" list=
SafeCountries
add address=128.94.0.0-128.97.255.255 comment="United States" list=
SafeCountries
add address=128.99.0.0/16 comment="United States" list=SafeCountries
add address=128.101.0.0-128.123.255.255 comment="United States" list=
SafeCountries
add address=128.125.0.0-128.126.255.255 comment="United States" list=
SafeCountries
add address=128.128.0.0/15 comment="United States" list=SafeCountries
add address=128.132.0.0/15 comment="United States" list=SafeCountries
add address=128.135.0.0-128.138.255.255 comment="United States" list=
SafeCountries
add address=128.143.0.0/16 comment="United States" list=SafeCountries
add address=128.145.0.0-128.175.255.255 comment="United States" list=
SafeCountries
add address=128.177.0.0-128.177.105.65 comment="United States" list=
SafeCountries
add address=128.177.105.67-128.177.255.255 comment="United States" list=
SafeCountries
add address=128.180.0.0/14 comment="United States" list=SafeCountries
add address=128.186.0.0-128.188.255.255 comment="United States" list=
SafeCountries
add address=128.190.0.0-128.198.255.255 comment="United States" list=
SafeCountries
add address=128.200.0.0/14 comment="United States" list=SafeCountries
add address=128.205.0.0-128.213.255.255 comment="United States" list=
SafeCountries
add address=128.215.0.0-128.231.255.255 comment="United States" list=
SafeCountries
add address=128.235.0.0-128.239.255.255 comment="United States" list=
SafeCountries
add address=128.241.0.0-128.242.255.255 comment="United States" list=
SafeCountries
add address=128.244.0.0/15 comment="United States" list=SafeCountries
add address=128.246.128.0/24 comment="United States" list=SafeCountries
add address=128.247.0.0-128.249.255.255 comment="United States" list=
SafeCountries
add address=128.251.0.0-128.255.255.255 comment="United States" list=
SafeCountries
add address=129.1.0.0-129.10.255.255 comment="United States" list=
SafeCountries
add address=129.14.0.0/15 comment="United States" list=SafeCountries
add address=129.17.0.0/16 comment="United States" list=SafeCountries
add address=129.19.0.0/16 comment="United States" list=SafeCountries
add address=129.21.0.0-129.25.255.255 comment="United States" list=
SafeCountries
add address=129.28.0.0-129.30.255.255 comment="United States" list=
SafeCountries
add address=129.32.0.0-129.35.63.255 comment="United States" list=
SafeCountries
add address=129.35.80.0-129.35.156.3 comment="United States" list=
SafeCountries
add address=129.35.156.5-129.44.255.255 comment="United States" list=
SafeCountries
add address=129.46.0.0-129.55.255.255 comment="United States" list=
SafeCountries
add address=129.57.0.0-129.59.255.255 comment="United States" list=
SafeCountries
add address=129.61.0.0-129.66.255.255 comment="United States" list=
SafeCountries
add address=129.68.0.0/16 comment="United States" list=SafeCountries
add address=129.71.0.0-129.75.233.255 comment="United States" list=
SafeCountries
add address=129.75.234.64-129.77.255.255 comment="United States" list=
SafeCountries
add address=129.79.0.0-129.87.255.255 comment="United States" list=
SafeCountries
add address=129.89.0.0/16 comment="United States" list=SafeCountries
add address=129.91.0.0-129.93.255.255 comment="United States" list=
SafeCountries
add address=129.95.0.0/16 comment="United States" list=SafeCountries
add address=129.98.0.0/15 comment="United States" list=SafeCountries
add address=129.101.0.0/16 comment="United States" list=SafeCountries
add address=129.105.0.0-129.121.255.255 comment="United States" list=
SafeCountries
add address=129.123.0.0-129.124.255.255 comment="United States" list=
SafeCountries
add address=129.126.0.0/16 comment="United States" list=SafeCountries
add address=129.130.0.0/15 comment="United States" list=SafeCountries
add address=129.133.0.0-129.135.255.255 comment="United States" list=
SafeCountries
add address=129.137.0.0-129.139.255.255 comment="United States" list=
SafeCountries
add address=129.141.0.0/16 comment="United States" list=SafeCountries
add address=129.144.0.0-129.168.255.255 comment="United States" list=
SafeCountries
add address=129.170.0.0-129.172.255.255 comment="United States" list=
SafeCountries
add address=129.174.0.0/16 comment="United States" list=SafeCountries
add address=129.176.0.0/16 comment="United States" list=SafeCountries
add address=129.179.0.0/16 comment="United States" list=SafeCountries
add address=129.186.0.0/16 comment="United States" list=SafeCountries
add address=129.188.0.0-129.192.96.255 comment="United States" list=
SafeCountries
add address=129.192.98.0-129.192.195.255 comment="United States" list=
SafeCountries
add address=129.192.197.0-129.192.207.255 comment="United States" list=
SafeCountries
add address=129.192.209.0-129.193.255.255 comment="United States" list=
SafeCountries
add address=129.196.0.0-129.198.255.255 comment="United States" list=
SafeCountries
add address=129.200.0.0-129.204.255.255 comment="United States" list=
SafeCountries
add address=129.207.0.0/16 comment="United States" list=SafeCountries
add address=129.209.0.0-129.214.255.255 comment="United States" list=
SafeCountries
add address=129.216.0.0/16 comment="United States" list=SafeCountries
add address=129.218.0.0-129.231.255.255 comment="United States" list=
SafeCountries
add address=129.235.0.0-129.239.255.255 comment="United States" list=
SafeCountries
add address=129.243.0.0-129.246.255.255 comment="United States" list=
SafeCountries
add address=129.248.0.0/16 comment="United States" list=SafeCountries
add address=129.250.0.0-129.250.2.41 comment="United States" list=
SafeCountries
add address=129.250.2.43-129.250.3.137 comment="United States" list=
SafeCountries
add address=129.250.3.139-129.250.4.103 comment="United States" list=
SafeCountries
add address=129.250.4.105-129.250.4.136 comment="United States" list=
SafeCountries
add address=129.250.4.138-129.250.6.216 comment="United States" list=
SafeCountries
add address=129.250.6.218-129.250.8.40 comment="United States" list=
SafeCountries
add address=129.250.8.42-129.250.16.45 comment="United States" list=
SafeCountries
add address=129.250.16.47-129.253.255.255 comment="United States" list=
SafeCountries
add address=129.255.0.0/16 comment="United States" list=SafeCountries
add address=130.1.0.0-130.11.255.255 comment="United States" list=
SafeCountries
add address=130.13.0.0-130.14.255.255 comment="United States" list=
SafeCountries
add address=130.16.0.0/13 comment="United States" list=SafeCountries
add address=130.26.0.0/15 comment="United States" list=SafeCountries
add address=130.29.0.0-130.31.255.255 comment="United States" list=
SafeCountries
add address=130.33.0.0/16 comment="United States" list=SafeCountries
add address=130.35.0.0-130.36.74.255 comment="United States" list=
SafeCountries
add address=130.36.76.0-130.36.86.255 comment="United States" list=
SafeCountries
add address=130.36.88.0-130.36.94.255 comment="United States" list=
SafeCountries
add address=130.36.96.0-130.36.154.255 comment="United States" list=
SafeCountries
add address=130.36.156.0-130.36.255.255 comment="United States" list=
SafeCountries
add address=130.38.0.0-130.42.255.255 comment="United States" list=
SafeCountries
add address=130.44.0.0-130.53.255.255 comment="United States" list=
SafeCountries
add address=130.55.0.0/16 comment="United States" list=SafeCountries
add address=130.57.0.0-130.57.117.255 comment="United States" list=
SafeCountries
add address=130.57.120.0-130.58.255.255 comment="United States" list=
SafeCountries
add address=130.61.0.0-130.62.255.255 comment="United States" list=
SafeCountries
add address=130.64.0.0/15 comment="United States" list=SafeCountries
add address=130.68.0.0/16 comment="United States" list=SafeCountries
add address=130.70.0.0-130.72.255.255 comment="United States" list=
SafeCountries
add address=130.74.0.0/16 comment="United States" list=SafeCountries
add address=130.76.0.0/15 comment="United States" list=SafeCountries
add address=130.80.0.0/15 comment="United States" list=SafeCountries
add address=130.85.0.0-130.86.255.255 comment="United States" list=
SafeCountries
add address=130.90.0.0/15 comment="United States" list=SafeCountries
add address=130.93.0.0-130.94.255.255 comment="United States" list=
SafeCountries
add address=130.96.0.0/15 comment="United States" list=SafeCountries
add address=130.99.0.0/16 comment="United States" list=SafeCountries
add address=130.101.0.0/16 comment="United States" list=SafeCountries
add address=130.103.0.0/16 comment="United States" list=SafeCountries
add address=130.106.0.0-130.111.255.255 comment="United States" list=
SafeCountries
add address=130.114.0.0/16 comment="United States" list=SafeCountries
add address=130.118.0.0-130.119.247.255 comment="United States" list=
SafeCountries
add address=130.119.249.0-130.119.255.255 comment="United States" list=
SafeCountries
add address=130.121.0.0-130.122.255.255 comment="United States" list=
SafeCountries
add address=130.124.0.0/16 comment="United States" list=SafeCountries
add address=130.126.0.0-130.129.255.255 comment="United States" list=
SafeCountries
add address=130.132.0.0/16 comment="United States" list=SafeCountries
add address=130.134.0.0/15 comment="United States" list=SafeCountries
add address=130.137.0.0/16 comment="United States" list=SafeCountries
add address=130.150.0.0-130.152.255.255 comment="United States" list=
SafeCountries
add address=130.154.0.0/16 comment="United States" list=SafeCountries
add address=130.156.0.0/15 comment="United States" list=SafeCountries
add address=130.160.0.0/16 comment="United States" list=SafeCountries
add address=130.162.0.0-130.178.255.255 comment="United States" list=
SafeCountries
add address=130.181.0.0-130.182.255.255 comment="United States" list=
SafeCountries
add address=130.184.0.0/16 comment="United States" list=SafeCountries
add address=130.185.156.0/22 comment="United States" list=SafeCountries
add address=130.187.0.0/16 comment="United States" list=SafeCountries
add address=130.189.0.0/16 comment="United States" list=SafeCountries
add address=130.191.0.0/16 comment="United States" list=SafeCountries
add address=130.196.0.0/15 comment="United States" list=SafeCountries
add address=130.199.0.0-130.203.255.255 comment="United States" list=
SafeCountries
add address=130.205.0.0/16 comment="United States" list=SafeCountries
add address=130.207.0.0/16 comment="United States" list=SafeCountries
add address=130.210.0.0-130.211.87.61 comment="United States" list=
SafeCountries
add address=130.211.87.63-130.211.97.190 comment="United States" list=
SafeCountries
add address=130.211.97.192-130.214.25.252 comment="United States" list=
SafeCountries
add address=130.214.25.254-130.214.39.255 comment="United States" list=
SafeCountries
add address=130.214.41.0-130.215.255.255 comment="United States" list=
SafeCountries
add address=130.218.0.0/15 comment="United States" list=SafeCountries
add address=130.221.0.0-130.222.255.255 comment="United States" list=
SafeCountries
add address=130.224.0.0/16 comment="United States" list=SafeCountries
add address=130.245.0.0/16 comment="United States" list=SafeCountries
add address=130.247.0.0-130.249.255.255 comment="United States" list=
SafeCountries
add address=130.252.0.0-130.254.255.255 comment="United States" list=
SafeCountries
add address=131.0.72.0/22 comment="Costa Rica" list=SafeCountries
add address=131.2.0.0-131.71.255.255 comment="United States" list=
SafeCountries
add address=131.73.0.0-131.96.255.255 comment="United States" list=
SafeCountries
add address=131.98.0.0/16 comment="United States" list=SafeCountries
add address=131.101.0.0/16 comment="United States" list=SafeCountries
add address=131.103.0.0/16 comment="United States" list=SafeCountries
add address=131.105.0.0-131.107.255.255 comment="United States" list=
SafeCountries
add address=131.108.19.48/28 comment="Costa Rica" list=SafeCountries
add address=131.108.36.0/22 comment="Costa Rica" list=SafeCountries
add address=131.108.232.192/29 comment="United States" list=SafeCountries
add address=131.109.0.0-131.110.255.255 comment="United States" list=
SafeCountries
add address=131.118.0.0-131.128.255.255 comment="United States" list=
SafeCountries
add address=131.131.0.0/16 comment="United States" list=SafeCountries
add address=131.142.0.0-131.146.255.255 comment="United States" list=
SafeCountries
add address=131.150.7.0/24 comment="United States" list=SafeCountries
add address=131.150.11.0-131.150.15.255 comment="United States" list=
SafeCountries
add address=131.150.31.0/24 comment="United States" list=SafeCountries
add address=131.150.55.0/24 comment="United States" list=SafeCountries
add address=131.150.62.0/24 comment="United States" list=SafeCountries
add address=131.150.80.0/22 comment="United States" list=SafeCountries
add address=131.150.130.0/23 comment="United States" list=SafeCountries
add address=131.150.144.0/20 comment="United States" list=SafeCountries
add address=131.150.190.0/24 comment="United States" list=SafeCountries
add address=131.151.0.0/16 comment="United States" list=SafeCountries
add address=131.153.0.0/16 comment="United States" list=SafeCountries
add address=131.156.0.0-131.158.255.255 comment="United States" list=
SafeCountries
add address=131.167.0.0-131.168.255.255 comment="United States" list=
SafeCountries
add address=131.171.0.0/16 comment="United States" list=SafeCountries
add address=131.176.0.0/16 comment="United States" list=SafeCountries
add address=131.179.0.0/16 comment="United States" list=SafeCountries
add address=131.182.0.0-131.184.255.255 comment="United States" list=
SafeCountries
add address=131.186.0.0/15 comment="United States" list=SafeCountries
add address=131.189.0.0-131.194.255.255 comment="United States" list=
SafeCountries
add address=131.196.0.0-131.201.255.255 comment="United States" list=
SafeCountries
add address=131.204.0.0/16 comment="United States" list=SafeCountries
add address=131.208.0.0-131.210.255.255 comment="United States" list=
SafeCountries
add address=131.212.0.0/16 comment="United States" list=SafeCountries
add address=131.214.0.0-131.216.255.255 comment="United States" list=
SafeCountries
add address=131.218.0.0/15 comment="United States" list=SafeCountries
add address=131.222.0.0/15 comment="United States" list=SafeCountries
add address=131.225.0.0-131.226.255.255 comment="United States" list=
SafeCountries
add address=131.228.196.0/22 comment="United States" list=SafeCountries
add address=131.229.0.0-131.230.255.255 comment="United States" list=
SafeCountries
add address=131.233.0.0/16 comment="United States" list=SafeCountries
add address=131.238.0.0-131.241.255.255 comment="United States" list=
SafeCountries
add address=131.243.0.0/16 comment="United States" list=SafeCountries
add address=131.247.0.0/16 comment="United States" list=SafeCountries
add address=131.249.0.0-131.250.255.255 comment="United States" list=
SafeCountries
add address=131.252.0.0-131.253.130.191 comment="United States" list=
SafeCountries
add address=131.253.131.0-131.253.179.63 comment="United States" list=
SafeCountries
add address=131.253.179.96-131.253.255.255 comment="United States" list=
SafeCountries
add address=132.0.0.0/10 comment="United States" list=SafeCountries
add address=132.79.0.0-132.145.255.255 comment="United States" list=
SafeCountries
add address=132.147.0.0/18 comment="United States" list=SafeCountries
add address=132.147.128.0-132.148.255.255 comment="United States" list=
SafeCountries
add address=132.151.0.0-132.152.255.255 comment="United States" list=
SafeCountries
add address=132.154.0.0/16 comment="United States" list=SafeCountries
add address=132.158.0.0-132.163.255.255 comment="United States" list=
SafeCountries
add address=132.170.0.0/16 comment="United States" list=SafeCountries
add address=132.172.0.0/14 comment="United States" list=SafeCountries
add address=132.177.0.0-132.178.255.255 comment="United States" list=
SafeCountries
add address=132.183.0.0/16 comment="United States" list=SafeCountries
add address=132.188.0.0/19 comment="United States" list=SafeCountries
add address=132.188.33.0-132.190.31.255 comment="United States" list=
SafeCountries
add address=132.190.33.0-132.190.255.255 comment="United States" list=
SafeCountries
add address=132.192.0.0-132.194.255.255 comment="United States" list=
SafeCountries
add address=132.197.0.0-132.198.255.255 comment="United States" list=
SafeCountries
add address=132.200.0.0/15 comment="United States" list=SafeCountries
add address=132.223.0.0-132.224.255.255 comment="United States" list=
SafeCountries
add address=132.226.0.0/16 comment="United States" list=SafeCountries
add address=132.228.0.0/16 comment="United States" list=SafeCountries
add address=132.233.0.0/16 comment="United States" list=SafeCountries
add address=132.235.0.0-132.243.255.255 comment="United States" list=
SafeCountries
add address=132.244.80.0/20 comment="United States" list=SafeCountries
add address=132.245.0.0-132.245.3.95 comment="United States" list=
SafeCountries
add address=132.245.3.128-132.245.16.135 comment="United States" list=
SafeCountries
add address=132.245.16.208-132.245.26.71 comment="United States" list=
SafeCountries
add address=132.245.26.224-132.245.27.31 comment="United States" list=
SafeCountries
add address=132.245.27.48-132.245.36.95 comment="United States" list=
SafeCountries
add address=132.245.36.128-132.245.64.79 comment="United States" list=
SafeCountries
add address=132.245.64.144-132.245.67.47 comment="United States" list=
SafeCountries
add address=132.245.67.80-132.245.68.239 comment="United States" list=
SafeCountries
add address=132.245.69.64-132.245.92.23 comment="United States" list=
SafeCountries
add address=132.245.92.32/28 comment="United States" list=SafeCountries
add address=132.245.92.192-132.245.127.255 comment="United States" list=
SafeCountries
add address=132.245.131.176-132.245.131.239 comment="United States" list=
SafeCountries
add address=132.245.144.208-132.245.144.239 comment="United States" list=
SafeCountries
add address=132.245.152.0/23 comment="United States" list=SafeCountries
add address=132.245.176.32-132.245.176.175 comment="United States" list=
SafeCountries
add address=132.245.176.208-132.245.191.255 comment="United States" list=
SafeCountries
add address=132.245.230.0-132.245.241.143 comment="United States" list=
SafeCountries
add address=132.245.241.192/28 comment="United States" list=SafeCountries
add address=132.245.242.0/28 comment="United States" list=SafeCountries
add address=132.245.242.48/28 comment="United States" list=SafeCountries
add address=132.245.242.96-132.245.245.47 comment="United States" list=
SafeCountries
add address=132.245.245.64/28 comment="United States" list=SafeCountries
add address=132.245.245.144-132.245.253.63 comment="United States" list=
SafeCountries
add address=132.245.253.96-132.245.254.191 comment="United States" list=
SafeCountries
add address=132.245.254.224-132.245.255.143 comment="United States" list=
SafeCountries
add address=132.245.255.176-132.245.255.255 comment="United States" list=
SafeCountries
add address=132.249.0.0-132.250.255.255 comment="United States" list=
SafeCountries
add address=132.253.0.0/16 comment="United States" list=SafeCountries
add address=132.255.134.200/29 comment="United States" list=SafeCountries
add address=133.130.0.0/22 comment="United States" list=SafeCountries
add address=134.0.64.0/23 comment="United States" list=SafeCountries
add address=134.0.72.0/21 comment="United States" list=SafeCountries
add address=134.4.0.0-134.6.255.255 comment="United States" list=
SafeCountries
add address=134.8.0.0-134.16.255.255 comment="United States" list=
SafeCountries
add address=134.20.0.0/16 comment="United States" list=SafeCountries
add address=134.23.0.0-134.24.18.255 comment="United States" list=
SafeCountries
add address=134.24.20.0-134.24.255.255 comment="United States" list=
SafeCountries
add address=134.26.0.0/16 comment="United States" list=SafeCountries
add address=134.29.0.0/16 comment="United States" list=SafeCountries
add address=134.32.0.0/15 comment="United States" list=SafeCountries
add address=134.35.0.0-134.35.16.138 comment="United States" list=
SafeCountries
add address=134.35.16.140-134.35.255.255 comment="United States" list=
SafeCountries
add address=134.38.0.0-134.42.223.255 comment="United States" list=
SafeCountries
add address=134.42.228.0-134.46.255.255 comment="United States" list=
SafeCountries
add address=134.48.0.0-134.53.255.255 comment="United States" list=
SafeCountries
add address=134.55.0.0-134.57.255.255 comment="United States" list=
SafeCountries
add address=134.62.0.0-134.72.255.255 comment="United States" list=
SafeCountries
add address=134.74.0.0/16 comment="United States" list=SafeCountries
add address=134.77.0.0-134.80.255.255 comment="United States" list=
SafeCountries
add address=134.82.0.0/16 comment="United States" list=SafeCountries
add address=134.84.0.0-134.86.255.255 comment="United States" list=
SafeCountries
add address=134.88.0.0/15 comment="United States" list=SafeCountries
add address=134.90.148.0/24 comment="United States" list=SafeCountries
add address=134.111.0.0-134.114.255.255 comment="United States" list=
SafeCountries
add address=134.116.0.0/16 comment="United States" list=SafeCountries
add address=134.118.0.0/16 comment="United States" list=SafeCountries
add address=134.120.0.0-134.128.63.255 comment="United States" list=
SafeCountries
add address=134.129.0.0/16 comment="United States" list=SafeCountries
add address=134.131.0.0-134.132.29.255 comment="United States" list=
SafeCountries
add address=134.132.31.0-134.132.55.255 comment="United States" list=
SafeCountries
add address=134.132.57.0-134.137.255.255 comment="United States" list=
SafeCountries
add address=134.139.0.0-134.141.255.255 comment="United States" list=
SafeCountries
add address=134.149.0.0/16 comment="United States" list=SafeCountries
add address=134.152.0.0/16 comment="United States" list=SafeCountries
add address=134.154.0.0/16 comment="United States" list=SafeCountries
add address=134.156.0.0/16 comment="United States" list=SafeCountries
add address=134.159.0.0/22 comment="United States" list=SafeCountries
add address=134.159.5.0-134.159.60.255 comment="United States" list=
SafeCountries
add address=134.159.61.8-134.159.63.255 comment="United States" list=
SafeCountries
add address=134.161.0.0-134.168.255.255 comment="United States" list=
SafeCountries
add address=134.170.0.0-134.170.39.255 comment="United States" list=
SafeCountries
add address=134.170.48.0/20 comment="United States" list=SafeCountries
add address=134.170.104.0-134.170.127.255 comment="United States" list=
SafeCountries
add address=134.170.144.0-134.170.167.255 comment="United States" list=
SafeCountries
add address=134.170.176.0/20 comment="United States" list=SafeCountries
add address=134.170.200.0/22 comment="United States" list=SafeCountries
add address=134.170.208.0/22 comment="United States" list=SafeCountries
add address=134.170.218.0-134.170.235.255 comment="United States" list=
SafeCountries
add address=134.170.238.0-134.170.251.255 comment="United States" list=
SafeCountries
add address=134.170.255.0/24 comment="United States" list=SafeCountries
add address=134.172.0.0/14 comment="United States" list=SafeCountries
add address=134.177.0.0/16 comment="United States" list=SafeCountries
add address=134.179.0.0/16 comment="United States" list=SafeCountries
add address=134.181.0.0-134.182.255.255 comment="United States" list=
SafeCountries
add address=134.185.0.0-134.187.255.255 comment="United States" list=
SafeCountries
add address=134.189.0.0/16 comment="United States" list=SafeCountries
add address=134.192.0.0/14 comment="United States" list=SafeCountries
add address=134.197.0.0-134.198.255.255 comment="United States" list=
SafeCountries
add address=134.200.0.0/15 comment="United States" list=SafeCountries
add address=134.204.0.0/15 comment="United States" list=SafeCountries
add address=134.207.0.0/16 comment="United States" list=SafeCountries
add address=134.209.0.0-134.210.255.255 comment="United States" list=
SafeCountries
add address=134.215.0.0-134.218.255.255 comment="United States" list=
SafeCountries
add address=134.223.0.0-134.224.255.255 comment="United States" list=
SafeCountries
add address=134.228.0.0-134.235.255.255 comment="United States" list=
SafeCountries
add address=134.238.0.0/16 comment="United States" list=SafeCountries
add address=134.240.0.0-134.244.255.255 comment="United States" list=
SafeCountries
add address=134.248.0.0/16 comment="United States" list=SafeCountries
add address=134.250.0.0-134.254.255.255 comment="United States" list=
SafeCountries
add address=135.1.0.0/16 comment="United States" list=SafeCountries
add address=135.8.0.0-135.10.102.255 comment="United States" list=
SafeCountries
add address=135.10.104.0-135.12.0.255 comment="United States" list=
SafeCountries
add address=135.14.0.0-135.17.255.255 comment="United States" list=
SafeCountries
add address=135.20.0.0-135.22.255.255 comment="United States" list=
SafeCountries
add address=135.24.0.0-135.27.3.255 comment="United States" list=
SafeCountries
add address=135.27.5.0-135.84.208.255 comment="United States" list=
SafeCountries
add address=135.84.210.0-135.84.213.255 comment="United States" list=
SafeCountries
add address=135.84.215.0-135.84.231.255 comment="United States" list=
SafeCountries
add address=135.89.0.0-135.91.255.255 comment="United States" list=
SafeCountries
add address=135.94.0.0-135.102.255.255 comment="United States" list=
SafeCountries
add address=135.105.0.0-135.108.255.255 comment="United States" list=
SafeCountries
add address=135.110.0.0-135.180.255.255 comment="United States" list=
SafeCountries
add address=135.182.0.0/16 comment="United States" list=SafeCountries
add address=135.184.0.0/16 comment="United States" list=SafeCountries
add address=135.186.0.0-135.195.255.255 comment="United States" list=
SafeCountries
add address=135.197.0.0-135.219.255.255 comment="United States" list=
SafeCountries
add address=135.245.8.0/24 comment="United States" list=SafeCountries
add address=135.245.10.0/24 comment="United States" list=SafeCountries
add address=135.245.48.0/23 comment="United States" list=SafeCountries
add address=135.245.224.0/24 comment="United States" list=SafeCountries
add address=136.0.16.0-136.8.1.99 comment="United States" list=SafeCountries
add address=136.8.1.101-136.8.1.255 comment="United States" list=
SafeCountries
add address=136.8.2.71 comment="United States" list=SafeCountries
add address=136.8.3.0-136.8.4.255 comment="United States" list=SafeCountries
add address=136.8.6.0-136.8.32.255 comment="United States" list=SafeCountries
add address=136.8.34.0-136.8.149.255 comment="United States" list=
SafeCountries
add address=136.8.151.0/24 comment="United States" list=SafeCountries
add address=136.8.153.0-136.144.255.255 comment="United States" list=
SafeCountries
add address=136.146.0.0/15 comment="United States" list=SafeCountries
add address=136.149.0.0-136.152.255.255 comment="United States" list=
SafeCountries
add address=136.157.0.0/16 comment="United States" list=SafeCountries
add address=136.160.0.0-136.162.255.255 comment="United States" list=
SafeCountries
add address=136.165.0.0-136.168.255.255 comment="United States" list=
SafeCountries
add address=136.171.0.0/16 comment="United States" list=SafeCountries
add address=136.174.0.0-136.184.255.255 comment="United States" list=
SafeCountries
add address=136.188.0.0-136.197.255.255 comment="United States" list=
SafeCountries
add address=136.200.0.0/16 comment="United States" list=SafeCountries
add address=136.202.0.0-136.205.255.255 comment="United States" list=
SafeCountries
add address=136.207.0.0-136.224.255.255 comment="United States" list=
SafeCountries
add address=136.226.0.0-136.229.255.255 comment="United States" list=
SafeCountries
add address=136.232.0.0/14 comment="United States" list=SafeCountries
add address=136.237.0.0/16 comment="United States" list=SafeCountries
add address=136.239.0.0-136.242.255.255 comment="United States" list=
SafeCountries
add address=136.244.0.0-137.14.255.255 comment="United States" list=
SafeCountries
add address=137.16.0.0/16 comment="United States" list=SafeCountries
add address=137.18.0.0-137.32.255.255 comment="United States" list=
SafeCountries
add address=137.35.0.0-137.42.255.255 comment="United States" list=
SafeCountries
add address=137.45.0.0-137.46.255.255 comment="United States" list=
SafeCountries
add address=137.48.0.0/15 comment="United States" list=SafeCountries
add address=137.51.0.0-137.54.255.255 comment="United States" list=
SafeCountries
add address=137.57.0.0/16 comment="United States" list=SafeCountries
add address=137.65.0.0-137.67.255.255 comment="United States" list=
SafeCountries
add address=137.69.0.0-137.71.229.255 comment="United States" list=
SafeCountries
add address=137.71.231.0-137.72.255.255 comment="United States" list=
SafeCountries
add address=137.75.0.0/16 comment="United States" list=SafeCountries
add address=137.77.0.0-137.81.255.255 comment="United States" list=
SafeCountries
add address=137.83.0.0-137.91.255.255 comment="United States" list=
SafeCountries
add address=137.95.0.0/16 comment="United States" list=SafeCountries
add address=137.99.0.0-137.100.255.255 comment="United States" list=
SafeCountries
add address=137.102.0.0-137.104.255.255 comment="United States" list=
SafeCountries
add address=137.106.0.0/15 comment="United States" list=SafeCountries
add address=137.110.0.0/16 comment="United States" list=SafeCountries
add address=137.112.0.0-137.114.255.255 comment="United States" list=
SafeCountries
add address=137.116.0.0/17 comment="United States" list=SafeCountries
add address=137.116.176.0/20 comment="United States" list=SafeCountries
add address=137.117.0.0/17 comment="United States" list=SafeCountries
add address=137.118.0.0/15 comment="United States" list=SafeCountries
add address=137.123.0.0-137.128.255.255 comment="United States" list=
SafeCountries
add address=137.130.0.0/15 comment="United States" list=SafeCountries
add address=137.134.0.0-137.135.127.255 comment="United States" list=
SafeCountries
add address=137.136.0.0/15 comment="United States" list=SafeCountries
add address=137.139.0.0-137.146.255.255 comment="United States" list=
SafeCountries
add address=137.148.0.0/16 comment="United States" list=SafeCountries
add address=137.150.0.0-137.152.255.255 comment="United States" list=
SafeCountries
add address=137.155.0.0/16 comment="United States" list=SafeCountries
add address=137.159.0.0-137.162.255.255 comment="United States" list=
SafeCountries
add address=137.164.0.0/15 comment="United States" list=SafeCountries
add address=137.167.0.0-137.170.255.255 comment="United States" list=
SafeCountries
add address=137.173.0.0/16 comment="United States" list=SafeCountries
add address=137.175.0.0/17 comment="United States" list=SafeCountries
add address=137.176.0.0-137.185.255.255 comment="United States" list=
SafeCountries
add address=137.187.0.0-137.188.255.255 comment="United States" list=
SafeCountries
add address=137.190.0.0/16 comment="United States" list=SafeCountries
add address=137.192.0.0/16 comment="United States" list=SafeCountries
add address=137.197.0.0-137.203.255.255 comment="United States" list=
SafeCountries
add address=137.206.0.0/16 comment="United States" list=SafeCountries
add address=137.209.0.0-137.212.255.255 comment="United States" list=
SafeCountries
add address=137.216.0.0/16 comment="United States" list=SafeCountries
add address=137.220.0.0/16 comment="United States" list=SafeCountries
add address=137.225.0.0/16 comment="United States" list=SafeCountries
add address=137.227.0.0-137.247.255.255 comment="United States" list=
SafeCountries
add address=137.249.0.0/16 comment="United States" list=SafeCountries
add address=137.252.0.0/16 comment="United States" list=SafeCountries
add address=137.254.0.0/16 comment="United States" list=SafeCountries
add address=138.1.0.0-138.2.255.255 comment="United States" list=
SafeCountries
add address=138.5.0.0/16 comment="United States" list=SafeCountries
add address=138.8.0.0/15 comment="United States" list=SafeCountries
add address=138.12.0.0/15 comment="United States" list=SafeCountries
add address=138.15.0.0-138.18.255.255 comment="United States" list=
SafeCountries
add address=138.20.0.0-138.20.184.255 comment="United States" list=
SafeCountries
add address=138.20.186.0-138.20.255.255 comment="United States" list=
SafeCountries
add address=138.23.0.0/16 comment="United States" list=SafeCountries
add address=138.26.0.0-138.29.255.255 comment="United States" list=
SafeCountries
add address=138.31.0.0-138.32.167.255 comment="United States" list=
SafeCountries
add address=138.32.169.0-138.32.175.255 comment="United States" list=
SafeCountries
add address=138.32.177.0-138.32.234.255 comment="United States" list=
SafeCountries
add address=138.32.237.0-138.32.240.255 comment="United States" list=
SafeCountries
add address=138.32.242.0-138.32.253.255 comment="United States" list=
SafeCountries
add address=138.32.255.0-138.33.255.255 comment="United States" list=
SafeCountries
add address=138.34.13.0/24 comment="United States" list=SafeCountries
add address=138.35.0.0/16 comment="United States" list=SafeCountries
add address=138.39.0.0/16 comment="United States" list=SafeCountries
add address=138.42.0.0/15 comment="United States" list=SafeCountries
add address=138.45.0.0-138.47.255.255 comment="United States" list=
SafeCountries
add address=138.49.0.0-138.50.255.255 comment="United States" list=
SafeCountries
add address=138.52.0.0-138.58.255.255 comment="United States" list=
SafeCountries
add address=138.59.16.0/22 comment="Costa Rica" list=SafeCountries
add address=138.59.132.0/22 comment="Costa Rica" list=SafeCountries
add address=138.60.0.0/15 comment="United States" list=SafeCountries
add address=138.64.0.0/15 comment="United States" list=SafeCountries
add address=138.67.0.0-138.69.255.255 comment="United States" list=
SafeCountries
add address=138.72.0.0/16 comment="United States" list=SafeCountries
add address=138.74.0.0/16 comment="United States" list=SafeCountries
add address=138.76.0.0/16 comment="United States" list=SafeCountries
add address=138.78.0.0/16 comment="United States" list=SafeCountries
add address=138.83.0.0-138.90.255.255 comment="United States" list=
SafeCountries
add address=138.91.64.0-138.93.255.255 comment="United States" list=
SafeCountries
add address=138.94.56.0/22 comment="Costa Rica" list=SafeCountries
add address=138.94.199.1 comment="United States" list=SafeCountries
add address=138.95.0.0/16 comment="United States" list=SafeCountries
add address=138.98.0.0/16 comment="United States" list=SafeCountries
add address=138.105.0.0/16 comment="United States" list=SafeCountries
add address=138.108.0.0-138.108.135.255 comment="United States" list=
SafeCountries
add address=138.108.137.0-138.111.129.255 comment="United States" list=
SafeCountries
add address=138.111.131.0-138.116.255.255 comment="United States" list=
SafeCountries
add address=138.118.80.0/22 comment="Costa Rica" list=SafeCountries
add address=138.118.156.0/22 comment="Costa Rica" list=SafeCountries
add address=138.120.0.0/16 comment="United States" list=SafeCountries
add address=138.121.140.0/22 comment="Costa Rica" list=SafeCountries
add address=138.122.24.0/22 comment="Costa Rica" list=SafeCountries
add address=138.122.244.0/22 comment="Costa Rica" list=SafeCountries
add address=138.123.0.0/16 comment="United States" list=SafeCountries
add address=138.125.0.0-138.128.3.31 comment="United States" list=
SafeCountries
add address=138.128.3.48-138.128.21.191 comment="United States" list=
SafeCountries
add address=138.128.21.208-138.128.43.31 comment="United States" list=
SafeCountries
add address=138.128.43.48-138.128.67.95 comment="United States" list=
SafeCountries
add address=138.128.67.112-138.128.110.223 comment="United States" list=
SafeCountries
add address=138.128.110.240-138.128.179.255 comment="United States" list=
SafeCountries
add address=138.128.181.0-138.128.215.255 comment="United States" list=
SafeCountries
add address=138.128.220.0-138.129.255.255 comment="United States" list=
SafeCountries
add address=138.133.0.0-138.133.191.255 comment="United States" list=
SafeCountries
add address=138.133.193.0-138.133.255.255 comment="United States" list=
SafeCountries
add address=138.135.0.0-138.184.255.255 comment="United States" list=
SafeCountries
add address=138.185.248.0/22 comment="Costa Rica" list=SafeCountries
add address=138.192.0.0/15 comment="United States" list=SafeCountries
add address=138.196.0.0/15 comment="United States" list=SafeCountries
add address=138.202.0.0/16 comment="United States" list=SafeCountries
add address=138.207.0.0-138.210.255.255 comment="United States" list=
SafeCountries
add address=138.220.0.0/16 comment="United States" list=SafeCountries
add address=138.226.0.0/16 comment="United States" list=SafeCountries
add address=138.229.0.0/20 comment="United States" list=SafeCountries
add address=138.229.32.0-138.230.255.255 comment="United States" list=
SafeCountries
add address=138.234.0.0/16 comment="United States" list=SafeCountries
add address=138.236.0.0-138.239.145.255 comment="United States" list=
SafeCountries
add address=138.239.147.0/24 comment="United States" list=SafeCountries
add address=138.239.150.0-138.239.191.255 comment="United States" list=
SafeCountries
add address=138.239.193.0-138.242.255.255 comment="United States" list=
SafeCountries
add address=138.247.0.0/16 comment="United States" list=SafeCountries
add address=138.254.0.0/16 comment="United States" list=SafeCountries
add address=138.255.55.0/24 comment="United States" list=SafeCountries
add address=139.5.84.0/22 comment="United States" list=SafeCountries
add address=139.5.185.0-139.5.187.255 comment="United States" list=
SafeCountries
add address=139.31.0.0-139.43.255.255 comment="United States" list=
SafeCountries
add address=139.45.0.0-139.47.255.255 comment="United States" list=
SafeCountries
add address=139.49.0.0/16 comment="United States" list=SafeCountries
add address=139.51.0.0-139.52.255.255 comment="United States" list=
SafeCountries
add address=139.55.0.0-139.56.255.255 comment="United States" list=
SafeCountries
add address=139.60.0.0-139.62.255.255 comment="United States" list=
SafeCountries
add address=139.65.0.0/16 comment="United States" list=SafeCountries
add address=139.67.0.0-139.73.255.255 comment="United States" list=
SafeCountries
add address=139.76.0.0-139.78.255.255 comment="United States" list=
SafeCountries
add address=139.81.0.0/16 comment="United States" list=SafeCountries
add address=139.84.0.0/15 comment="United States" list=SafeCountries
add address=139.87.0.0-139.88.255.255 comment="United States" list=
SafeCountries
add address=139.93.0.0-139.95.255.255 comment="United States" list=
SafeCountries
add address=139.99.0.0/16 comment="United States" list=SafeCountries
add address=139.102.0.0/16 comment="United States" list=SafeCountries
add address=139.104.0.0/16 comment="United States" list=SafeCountries
add address=139.121.0.0/16 comment="United States" list=SafeCountries
add address=139.125.0.0-139.127.255.255 comment="United States" list=
SafeCountries
add address=139.131.0.0/16 comment="United States" list=SafeCountries
add address=139.135.0.0-139.140.255.255 comment="United States" list=
SafeCountries
add address=139.144.0.0/16 comment="United States" list=SafeCountries
add address=139.146.0.0/15 comment="United States" list=SafeCountries
add address=139.151.0.0/16 comment="United States" list=SafeCountries
add address=139.161.0.0-139.162.0.0 comment="United States" list=
SafeCountries
add address=139.162.32.0-139.162.127.255 comment="United States" list=
SafeCountries
add address=139.162.160.0-139.162.196.215 comment="United States" list=
SafeCountries
add address=139.162.196.217-139.162.201.96 comment="United States" list=
SafeCountries
add address=139.162.201.98-139.162.215.16 comment="United States" list=
SafeCountries
add address=139.162.215.18-139.162.215.224 comment="United States" list=
SafeCountries
add address=139.162.215.226-139.162.220.18 comment="United States" list=
SafeCountries
add address=139.162.220.20-139.162.255.255 comment="United States" list=
SafeCountries
add address=139.169.0.0/16 comment="United States" list=SafeCountries
add address=139.171.0.0-139.172.255.255 comment="United States" list=
SafeCountries
add address=139.177.0.0/16 comment="United States" list=SafeCountries
add address=139.180.0.0-139.181.115.255 comment="United States" list=
SafeCountries
add address=139.181.120.0-139.181.155.255 comment="United States" list=
SafeCountries
add address=139.181.160.0-139.182.255.255 comment="United States" list=
SafeCountries
add address=139.185.0.0/16 comment="United States" list=SafeCountries
add address=139.187.0.0/16 comment="United States" list=SafeCountries
add address=139.225.0.0/16 comment="United States" list=SafeCountries
add address=139.229.0.0/16 comment="United States" list=SafeCountries
add address=139.231.0.0-139.254.255.255 comment="United States" list=
SafeCountries
add address=140.1.0.0-140.74.255.255 comment="United States" list=
SafeCountries
add address=140.76.0.0/16 comment="United States" list=SafeCountries
add address=140.82.0.0/16 comment="United States" list=SafeCountries
add address=140.84.0.0/16 comment="United States" list=SafeCountries
add address=140.87.0.0-140.91.255.255 comment="United States" list=
SafeCountries
add address=140.95.0.0/16 comment="United States" list=SafeCountries
add address=140.98.0.0-140.101.147.255 comment="United States" list=
SafeCountries
add address=140.101.149.0-140.104.255.255 comment="United States" list=
SafeCountries
add address=140.106.0.0-140.108.255.255 comment="United States" list=
SafeCountries
add address=140.139.0.0-140.142.255.255 comment="United States" list=
SafeCountries
add address=140.144.0.0/14 comment="United States" list=SafeCountries
add address=140.152.0.0-140.153.83.255 comment="United States" list=
SafeCountries
add address=140.153.85.0-140.158.255.255 comment="United States" list=
SafeCountries
add address=140.160.0.0/16 comment="United States" list=SafeCountries
add address=140.162.0.0/15 comment="United States" list=SafeCountries
add address=140.165.0.0/16 comment="United States" list=SafeCountries
add address=140.169.0.0-140.180.255.255 comment="United States" list=
SafeCountries
add address=140.182.0.0/15 comment="United States" list=SafeCountries
add address=140.185.0.0-140.190.255.255 comment="United States" list=
SafeCountries
add address=140.192.0.0/16 comment="United States" list=SafeCountries
add address=140.194.0.0-140.199.255.255 comment="United States" list=
SafeCountries
add address=140.201.0.0-140.202.255.255 comment="United States" list=
SafeCountries
add address=140.208.0.0/15 comment="United States" list=SafeCountries
add address=140.211.0.0-140.212.255.255 comment="United States" list=
SafeCountries
add address=140.214.0.0-140.223.255.255 comment="United States" list=
SafeCountries
add address=140.225.0.0-140.229.255.255 comment="United States" list=
SafeCountries
add address=140.231.0.0-140.236.255.255 comment="United States" list=
SafeCountries
add address=140.238.0.0/15 comment="United States" list=SafeCountries
add address=140.241.0.0-140.242.5.255 comment="United States" list=
SafeCountries
add address=140.242.7.0-140.242.22.255 comment="United States" list=
SafeCountries
add address=140.242.24.0-140.242.26.255 comment="United States" list=
SafeCountries
add address=140.242.28.0-140.242.45.255 comment="United States" list=
SafeCountries
add address=140.242.47.0-140.242.213.255 comment="United States" list=
SafeCountries
add address=140.242.215.0-140.242.216.255 comment="United States" list=
SafeCountries
add address=140.242.218.0-140.242.225.255 comment="United States" list=
SafeCountries
add address=140.242.227.0-140.242.255.255 comment="United States" list=
SafeCountries
add address=140.244.0.0/15 comment="United States" list=SafeCountries
add address=140.247.0.0-140.248.255.255 comment="United States" list=
SafeCountries
add address=140.251.0.0-140.252.255.255 comment="United States" list=
SafeCountries
add address=140.254.0.0/16 comment="United States" list=SafeCountries
add address=141.0.8.0/22 comment="United States" list=SafeCountries
add address=141.8.143.128/25 comment="United States" list=SafeCountries
add address=141.86.0.0/16 comment="United States" list=SafeCountries
add address=141.95.2.0/24 comment="United States" list=SafeCountries
add address=141.101.73.0-141.101.74.255 comment="United States" list=
SafeCountries
add address=141.101.125.138 comment="United States" list=SafeCountries
add address=141.102.0.0/16 comment="United States" list=SafeCountries
add address=141.104.0.0/16 comment="United States" list=SafeCountries
add address=141.106.0.0/15 comment="United States" list=SafeCountries
add address=141.110.0.0-141.112.255.255 comment="United States" list=
SafeCountries
add address=141.113.150.0/24 comment="United States" list=SafeCountries
add address=141.113.168.0/21 comment="United States" list=SafeCountries
add address=141.114.0.0/16 comment="United States" list=SafeCountries
add address=141.116.0.0/16 comment="United States" list=SafeCountries
add address=141.121.0.0/16 comment="United States" list=SafeCountries
add address=141.123.0.0-141.126.255.255 comment="United States" list=
SafeCountries
add address=141.128.0.0/15 comment="United States" list=SafeCountries
add address=141.131.0.0/16 comment="United States" list=SafeCountries
add address=141.133.0.0/16 comment="United States" list=SafeCountries
add address=141.139.0.0-141.142.255.255 comment="United States" list=
SafeCountries
add address=141.146.0.0/16 comment="United States" list=SafeCountries
add address=141.149.0.0-141.162.255.255 comment="United States" list=
SafeCountries
add address=141.164.0.0/14 comment="United States" list=SafeCountries
add address=141.173.0.0-141.174.255.255 comment="United States" list=
SafeCountries
add address=141.177.0.0/16 comment="United States" list=SafeCountries
add address=141.179.0.0-141.180.255.255 comment="United States" list=
SafeCountries
add address=141.182.0.0-141.186.255.255 comment="United States" list=
SafeCountries
add address=141.188.0.0-141.189.141.255 comment="United States" list=
SafeCountries
add address=141.189.143.0-141.189.191.255 comment="United States" list=
SafeCountries
add address=141.189.194.0-141.189.203.255 comment="United States" list=
SafeCountries
add address=141.189.208.0-141.191.255.255 comment="United States" list=
SafeCountries
add address=141.193.0.0/16 comment="United States" list=SafeCountries
add address=141.195.0.0/16 comment="United States" list=SafeCountries
add address=141.197.0.0-141.197.9.255 comment="United States" list=
SafeCountries
add address=141.197.11.0-141.197.13.255 comment="United States" list=
SafeCountries
add address=141.197.15.0-141.199.255.255 comment="United States" list=
SafeCountries
add address=141.202.0.0/16 comment="United States" list=SafeCountries
add address=141.204.0.0-141.206.169.255 comment="United States" list=
SafeCountries
add address=141.206.171.0-141.207.255.255 comment="United States" list=
SafeCountries
add address=141.209.0.0-141.222.255.255 comment="United States" list=
SafeCountries
add address=141.224.0.0/15 comment="United States" list=SafeCountries
add address=141.227.3.0/24 comment="United States" list=SafeCountries
add address=141.230.0.0/16 comment="United States" list=SafeCountries
add address=141.232.0.0-141.236.255.255 comment="United States" list=
SafeCountries
add address=141.238.0.0-141.240.255.255 comment="United States" list=
SafeCountries
add address=141.242.0.0/16 comment="United States" list=SafeCountries
add address=141.246.0.0-141.248.255.255 comment="United States" list=
SafeCountries
add address=141.251.0.0-141.251.116.255 comment="United States" list=
SafeCountries
add address=141.251.117.64-141.251.117.255 comment="United States" list=
SafeCountries
add address=141.251.118.64-141.251.118.255 comment="United States" list=
SafeCountries
add address=141.251.119.64-141.251.119.255 comment="United States" list=
SafeCountries
add address=141.251.120.64-141.251.120.255 comment="United States" list=
SafeCountries
add address=141.251.121.64-141.251.121.255 comment="United States" list=
SafeCountries
add address=141.251.122.64-141.251.122.255 comment="United States" list=
SafeCountries
add address=141.251.123.64-141.251.123.255 comment="United States" list=
SafeCountries
add address=141.251.124.64-141.251.124.255 comment="United States" list=
SafeCountries
add address=141.251.125.64-141.251.186.191 comment="United States" list=
SafeCountries
add address=141.251.187.0-141.251.187.191 comment="United States" list=
SafeCountries
add address=141.251.188.0/25 comment="United States" list=SafeCountries
add address=141.251.189.0-141.251.189.191 comment="United States" list=
SafeCountries
add address=141.251.190.0-141.251.190.191 comment="United States" list=
SafeCountries
add address=141.251.191.0-141.251.191.191 comment="United States" list=
SafeCountries
add address=141.251.192.0-141.251.192.191 comment="United States" list=
SafeCountries
add address=141.251.193.0-141.251.193.191 comment="United States" list=
SafeCountries
add address=141.251.194.0-141.251.194.191 comment="United States" list=
SafeCountries
add address=141.251.195.0-141.251.195.191 comment="United States" list=
SafeCountries
add address=141.251.196.0/24 comment="United States" list=SafeCountries
add address=141.251.203.0-141.251.220.255 comment="United States" list=
SafeCountries
add address=141.251.222.0-141.251.243.255 comment="United States" list=
SafeCountries
add address=141.251.244.128/26 comment="United States" list=SafeCountries
add address=141.251.245.0-141.251.253.255 comment="United States" list=
SafeCountries
add address=141.251.254.64-141.251.255.255 comment="United States" list=
SafeCountries
add address=141.254.0.0/16 comment="United States" list=SafeCountries
add address=142.0.0.0/20 comment="United States" list=SafeCountries
add address=142.0.32.0-142.0.72.105 comment="United States" list=
SafeCountries
add address=142.0.72.107-142.0.143.255 comment="United States" list=
SafeCountries
add address=142.0.160.0-142.0.223.255 comment="United States" list=
SafeCountries
add address=142.0.240.0/20 comment="United States" list=SafeCountries
add address=142.4.0.0-142.4.106.255 comment="United States" list=
SafeCountries
add address=142.4.108.0-142.4.117.255 comment="United States" list=
SafeCountries
add address=142.4.120.0/24 comment="United States" list=SafeCountries
add address=142.4.126.0-142.4.193.255 comment="United States" list=
SafeCountries
add address=142.4.196.0/23 comment="United States" list=SafeCountries
add address=142.4.199.228/30 comment="United States" list=SafeCountries
add address=142.4.200.0/23 comment="United States" list=SafeCountries
add address=142.4.204.0-142.4.204.110 comment="United States" list=
SafeCountries
add address=142.4.204.112-142.4.205.46 comment="United States" list=
SafeCountries
add address=142.4.205.48-142.4.207.255 comment="United States" list=
SafeCountries
add address=142.4.224.0/19 comment="United States" list=SafeCountries
add address=142.11.0.0/16 comment="United States" list=SafeCountries
add address=142.54.0.0-142.54.19.255 comment="United States" list=
SafeCountries
add address=142.54.24.0-142.54.47.255 comment="United States" list=
SafeCountries
add address=142.54.64.0-142.54.191.255 comment="United States" list=
SafeCountries
add address=142.54.200.0/22 comment="United States" list=SafeCountries
add address=142.54.208.0-142.54.255.255 comment="United States" list=
SafeCountries
add address=142.65.0.0/16 comment="United States" list=SafeCountries
add address=142.75.251.0-142.75.253.255 comment="United States" list=
SafeCountries
add address=142.75.255.0/24 comment="United States" list=SafeCountries
add address=142.77.0.0/16 comment="United States" list=SafeCountries
add address=142.79.0.0/16 comment="United States" list=SafeCountries
add address=142.91.0.0-142.91.65.255 comment="United States" list=
SafeCountries
add address=142.91.67.0-142.91.84.255 comment="United States" list=
SafeCountries
add address=142.91.86.0-142.91.255.255 comment="United States" list=
SafeCountries
add address=142.105.0.0/16 comment="United States" list=SafeCountries
add address=142.111.0.0/16 comment="United States" list=SafeCountries
add address=142.129.0.0/16 comment="United States" list=SafeCountries
add address=142.131.178.0-142.131.255.255 comment="United States" list=
SafeCountries
add address=142.136.0.0/16 comment="United States" list=SafeCountries
add address=142.147.0.0-142.147.14.255 comment="United States" list=
SafeCountries
add address=142.147.48.0/23 comment="United States" list=SafeCountries
add address=142.147.51.0/24 comment="United States" list=SafeCountries
add address=142.147.55.0-142.147.60.255 comment="United States" list=
SafeCountries
add address=142.147.68.0-142.147.73.255 comment="United States" list=
SafeCountries
add address=142.147.75.0-142.147.77.255 comment="United States" list=
SafeCountries
add address=142.147.79.0/24 comment="United States" list=SafeCountries
add address=142.147.81.0/24 comment="United States" list=SafeCountries
add address=142.147.84.0-142.147.90.255 comment="United States" list=
SafeCountries
add address=142.147.95.0-142.147.99.255 comment="United States" list=
SafeCountries
add address=142.147.101.0/24 comment="United States" list=SafeCountries
add address=142.147.104.0-142.147.255.255 comment="United States" list=
SafeCountries
add address=142.148.128.0/17 comment="United States" list=SafeCountries
add address=142.192.0.0/16 comment="United States" list=SafeCountries
add address=142.196.0.0/15 comment="United States" list=SafeCountries
add address=142.205.60.0/24 comment="United States" list=SafeCountries
add address=142.234.0.0/16 comment="United States" list=SafeCountries
add address=142.250.0.0-142.252.255.255 comment="United States" list=
SafeCountries
add address=142.254.0.0-142.255.127.255 comment="United States" list=
SafeCountries
add address=143.0.160.0/22 comment="Costa Rica" list=SafeCountries
add address=143.1.0.0-143.28.231.255 comment="United States" list=
SafeCountries
add address=143.28.233.0-143.40.255.255 comment="United States" list=
SafeCountries
add address=143.42.0.0-143.46.255.255 comment="United States" list=
SafeCountries
add address=143.48.0.0/15 comment="United States" list=SafeCountries
add address=143.55.0.0-143.58.7.255 comment="United States" list=
SafeCountries
add address=143.58.9.0-143.64.255.255 comment="United States" list=
SafeCountries
add address=143.66.0.0-143.88.255.255 comment="United States" list=
SafeCountries
add address=143.91.0.0/16 comment="United States" list=SafeCountries
add address=143.95.0.0/16 comment="United States" list=SafeCountries
add address=143.98.0.0/16 comment="United States" list=SafeCountries
add address=143.100.0.0-143.105.255.255 comment="United States" list=
SafeCountries
add address=143.109.0.0-143.116.255.255 comment="United States" list=
SafeCountries
add address=143.120.0.0/16 comment="United States" list=SafeCountries
add address=143.122.0.0-143.124.255.255 comment="United States" list=
SafeCountries
add address=143.127.0.0/16 comment="United States" list=SafeCountries
add address=143.131.0.0-143.135.255.255 comment="United States" list=
SafeCountries
add address=143.137.148.0/22 comment="Costa Rica" list=SafeCountries
add address=143.138.0.0-143.158.255.255 comment="United States" list=
SafeCountries
add address=143.162.0.0/16 comment="United States" list=SafeCountries
add address=143.165.0.0-143.166.255.255 comment="United States" list=
SafeCountries
add address=143.168.0.0/16 comment="United States" list=SafeCountries
add address=143.170.0.0/16 comment="United States" list=SafeCountries
add address=143.172.0.0/15 comment="United States" list=SafeCountries
add address=143.175.0.0/16 comment="United States" list=SafeCountries
add address=143.181.0.0-143.187.255.255 comment="United States" list=
SafeCountries
add address=143.190.0.0-143.192.95.255 comment="United States" list=
SafeCountries
add address=143.192.128.0-143.195.255.255 comment="United States" list=
SafeCountries
add address=143.197.0.0-143.200.255.255 comment="United States" list=
SafeCountries
add address=143.202.160.0/22 comment="Costa Rica" list=SafeCountries
add address=143.203.0.0-143.204.255.255 comment="United States" list=
SafeCountries
add address=143.206.0.0/15 comment="United States" list=SafeCountries
add address=143.208.168.0/22 comment="Costa Rica" list=SafeCountries
add address=143.209.0.0/16 comment="United States" list=SafeCountries
add address=143.211.0.0-143.215.255.255 comment="United States" list=
SafeCountries
add address=143.219.0.0-143.220.255.255 comment="United States" list=
SafeCountries
add address=143.222.0.0-143.223.7.255 comment="United States" list=
SafeCountries
add address=143.223.10.0-143.223.255.255 comment="United States" list=
SafeCountries
add address=143.226.0.0-143.232.255.255 comment="United States" list=
SafeCountries
add address=143.235.0.0-143.236.255.255 comment="United States" list=
SafeCountries
add address=143.240.0.0-143.244.255.255 comment="United States" list=
SafeCountries
add address=143.246.0.0/15 comment="United States" list=SafeCountries
add address=143.249.0.0-143.251.255.255 comment="United States" list=
SafeCountries
add address=143.254.0.0/16 comment="United States" list=SafeCountries
add address=143.255.28.0/22 comment="Costa Rica" list=SafeCountries
add address=144.2.0.0/19 comment="United States" list=SafeCountries
add address=144.2.138.0/24 comment="United States" list=SafeCountries
add address=144.3.0.0/16 comment="United States" list=SafeCountries
add address=144.5.0.0/16 comment="United States" list=SafeCountries
add address=144.8.0.0/14 comment="United States" list=SafeCountries
add address=144.13.0.0-144.15.239.255 comment="United States" list=
SafeCountries
add address=144.15.241.0-144.15.255.255 comment="United States" list=
SafeCountries
add address=144.17.0.0-144.19.255.255 comment="United States" list=
SafeCountries
add address=144.22.0.0/15 comment="Costa Rica" list=SafeCountries
add address=144.25.0.0-144.26.255.255 comment="United States" list=
SafeCountries
add address=144.28.0.0/14 comment="United States" list=SafeCountries
add address=144.33.0.0-144.36.0.255 comment="United States" list=
SafeCountries
add address=144.36.2.0-144.36.4.63 comment="United States" list=SafeCountries
add address=144.36.4.68-144.36.10.191 comment="United States" list=
SafeCountries
add address=144.36.11.0-144.36.13.255 comment="United States" list=
SafeCountries
add address=144.36.15.0-144.36.23.255 comment="United States" list=
SafeCountries
add address=144.36.28.0-144.36.30.255 comment="United States" list=
SafeCountries
add address=144.36.34.0-144.36.34.191 comment="United States" list=
SafeCountries
add address=144.36.35.0-144.36.49.255 comment="United States" list=
SafeCountries
add address=144.36.56.0-144.36.60.255 comment="United States" list=
SafeCountries
add address=144.36.64.0/25 comment="United States" list=SafeCountries
add address=144.36.65.0-144.36.67.255 comment="United States" list=
SafeCountries
add address=144.36.68.128-144.36.68.139 comment="United States" list=
SafeCountries
add address=144.36.68.144-144.36.68.255 comment="United States" list=
SafeCountries
add address=144.36.74.0/23 comment="United States" list=SafeCountries
add address=144.36.79.0-144.36.89.255 comment="United States" list=
SafeCountries
add address=144.36.91.0-144.36.93.255 comment="United States" list=
SafeCountries
add address=144.36.95.0/24 comment="United States" list=SafeCountries
add address=144.36.98.0-144.36.99.127 comment="United States" list=
SafeCountries
add address=144.36.99.136-144.36.101.255 comment="United States" list=
SafeCountries
add address=144.36.102.160-144.36.102.255 comment="United States" list=
SafeCountries
add address=144.36.103.128-144.36.104.127 comment="United States" list=
SafeCountries
add address=144.36.106.0-144.36.108.255 comment="United States" list=
SafeCountries
add address=144.36.113.0/25 comment="United States" list=SafeCountries
add address=144.36.117.32-144.36.117.255 comment="United States" list=
SafeCountries
add address=144.36.122.0/23 comment="United States" list=SafeCountries
add address=144.36.126.0/23 comment="United States" list=SafeCountries
add address=144.36.143.128/25 comment="United States" list=SafeCountries
add address=144.36.154.0/24 comment="United States" list=SafeCountries
add address=144.36.163.0/26 comment="United States" list=SafeCountries
add address=144.36.164.0/22 comment="United States" list=SafeCountries
add address=144.36.172.0/24 comment="United States" list=SafeCountries
add address=144.36.173.160-144.36.175.255 comment="United States" list=
SafeCountries
add address=144.36.177.0/24 comment="United States" list=SafeCountries
add address=144.36.181.64-144.36.181.255 comment="United States" list=
SafeCountries
add address=144.36.190.0-144.36.191.127 comment="United States" list=
SafeCountries
add address=144.36.191.192-144.36.193.255 comment="United States" list=
SafeCountries
add address=144.36.197.0-144.36.199.255 comment="United States" list=
SafeCountries
add address=144.36.203.0-144.36.205.255 comment="United States" list=
SafeCountries
add address=144.36.208.0/23 comment="United States" list=SafeCountries
add address=144.36.242.0/23 comment="United States" list=SafeCountries
add address=144.37.0.0-144.40.255.255 comment="United States" list=
SafeCountries
add address=144.42.0.0/16 comment="United States" list=SafeCountries
add address=144.45.0.0-144.46.251.255 comment="United States" list=
SafeCountries
add address=144.46.253.0-144.47.255.255 comment="United States" list=
SafeCountries
add address=144.49.0.0-144.51.255.255 comment="United States" list=
SafeCountries
add address=144.58.0.0-144.62.255.255 comment="United States" list=
SafeCountries
add address=144.67.0.0-144.75.255.255 comment="United States" list=
SafeCountries
add address=144.77.0.0-144.78.255.255 comment="United States" list=
SafeCountries
add address=144.80.0.0/15 comment="United States" list=SafeCountries
add address=144.83.0.0/16 comment="United States" list=SafeCountries
add address=144.86.0.0/16 comment="United States" list=SafeCountries
add address=144.88.0.0-144.94.255.255 comment="United States" list=
SafeCountries
add address=144.95.36.0/22 comment="United States" list=SafeCountries
add address=144.95.72.0/21 comment="United States" list=SafeCountries
add address=144.96.0.0/16 comment="United States" list=SafeCountries
add address=144.99.0.0-144.109.255.255 comment="United States" list=
SafeCountries
add address=144.111.0.0-144.118.255.255 comment="United States" list=
SafeCountries
add address=144.121.0.0/16 comment="United States" list=SafeCountries
add address=144.125.0.0-144.126.255.255 comment="United States" list=
SafeCountries
add address=144.128.0.0/15 comment="United States" list=SafeCountries
add address=144.130.128.0/20 comment="United States" list=SafeCountries
add address=144.141.0.0-144.144.255.255 comment="United States" list=
SafeCountries
add address=144.146.0.0-144.163.255.255 comment="United States" list=
SafeCountries
add address=144.166.0.0-144.168.51.255 comment="United States" list=
SafeCountries
add address=144.168.56.0-144.172.127.255 comment="United States" list=
SafeCountries
add address=144.174.0.0/15 comment="United States" list=SafeCountries
add address=144.177.70.0/24 comment="United States" list=SafeCountries
add address=144.182.0.0-144.187.36.10 comment="United States" list=
SafeCountries
add address=144.187.36.12-144.192.255.255 comment="United States" list=
SafeCountries
add address=144.195.0.0-144.198.255.255 comment="United States" list=
SafeCountries
add address=144.201.0.0-144.203.255.255 comment="United States" list=
SafeCountries
add address=144.207.0.0-144.208.255.255 comment="United States" list=
SafeCountries
add address=144.210.0.0-144.211.192.255 comment="United States" list=
SafeCountries
add address=144.211.196.0-144.212.255.255 comment="United States" list=
SafeCountries
add address=144.215.0.0-144.247.255.255 comment="United States" list=
SafeCountries
add address=144.249.0.0-144.254.199.255 comment="United States" list=
SafeCountries
add address=144.254.204.0-144.254.255.255 comment="United States" list=
SafeCountries
add address=145.246.128.0/22 comment="United States" list=SafeCountries
add address=146.1.0.0/16 comment="United States" list=SafeCountries
add address=146.5.0.0-146.10.255.255 comment="United States" list=
SafeCountries
add address=146.12.0.0-146.18.255.255 comment="United States" list=
SafeCountries
add address=146.20.0.0/16 comment="United States" list=SafeCountries
add address=146.22.0.0-146.23.177.255 comment="United States" list=
SafeCountries
add address=146.23.179.0-146.23.195.255 comment="United States" list=
SafeCountries
add address=146.23.197.0-146.23.211.255 comment="United States" list=
SafeCountries
add address=146.23.213.0-146.23.241.255 comment="United States" list=
SafeCountries
add address=146.23.243.0-146.47.255.255 comment="United States" list=
SafeCountries
add address=146.49.0.0/16 comment="United States" list=SafeCountries
add address=146.53.0.0-146.55.255.255 comment="United States" list=
SafeCountries
add address=146.57.0.0/16 comment="United States" list=SafeCountries
add address=146.61.0.0/16 comment="United States" list=SafeCountries
add address=146.63.0.0/16 comment="United States" list=SafeCountries
add address=146.65.0.0/16 comment="United States" list=SafeCountries
add address=146.68.0.0/15 comment="United States" list=SafeCountries
add address=146.71.0.0/16 comment="United States" list=SafeCountries
add address=146.73.0.0-146.74.255.255 comment="United States" list=
SafeCountries
add address=146.76.0.0/16 comment="United States" list=SafeCountries
add address=146.78.0.0/15 comment="United States" list=SafeCountries
add address=146.82.0.0/20 comment="United States" list=SafeCountries
add address=146.82.17.0-146.82.20.255 comment="United States" list=
SafeCountries
add address=146.82.23.0-146.82.32.255 comment="United States" list=
SafeCountries
add address=146.82.33.234 comment="United States" list=SafeCountries
add address=146.82.34.0-146.82.67.255 comment="United States" list=
SafeCountries
add address=146.82.69.0-146.82.155.255 comment="United States" list=
SafeCountries
add address=146.82.157.0-146.82.228.63 comment="United States" list=
SafeCountries
add address=146.82.228.96-146.82.235.255 comment="United States" list=
SafeCountries
add address=146.82.237.0-146.82.255.255 comment="United States" list=
SafeCountries
add address=146.84.0.0-146.86.255.255 comment="United States" list=
SafeCountries
add address=146.88.0.0/20 comment="United States" list=SafeCountries
add address=146.88.29.0-146.88.31.255 comment="United States" list=
SafeCountries
add address=146.88.96.0/19 comment="United States" list=SafeCountries
add address=146.88.136.0-146.88.145.255 comment="United States" list=
SafeCountries
add address=146.88.148.0/22 comment="United States" list=SafeCountries
add address=146.88.176.0-146.88.195.255 comment="United States" list=
SafeCountries
add address=146.88.208.0-146.89.255.255 comment="United States" list=
SafeCountries
add address=146.91.0.0-146.96.255.255 comment="United States" list=
SafeCountries
add address=146.98.0.0/16 comment="United States" list=SafeCountries
add address=146.111.0.0/16 comment="United States" list=SafeCountries
add address=146.113.0.0-146.115.255.255 comment="United States" list=
SafeCountries
add address=146.121.0.0-146.122.202.255 comment="United States" list=
SafeCountries
add address=146.122.204.0-146.123.255.255 comment="United States" list=
SafeCountries
add address=146.125.0.0-146.130.255.255 comment="United States" list=
SafeCountries
add address=146.132.0.0/16 comment="United States" list=SafeCountries
add address=146.135.0.0/16 comment="United States" list=SafeCountries
add address=146.137.0.0-146.139.255.255 comment="United States" list=
SafeCountries
add address=146.142.0.0-146.148.71.255 comment="United States" list=
SafeCountries
add address=146.148.73.0-146.154.255.255 comment="United States" list=
SafeCountries
add address=146.156.0.0/15 comment="United States" list=SafeCountries
add address=146.163.0.0/16 comment="United States" list=SafeCountries
add address=146.165.0.0-146.168.255.255 comment="United States" list=
SafeCountries
add address=146.170.0.0/16 comment="United States" list=SafeCountries
add address=146.174.0.0/16 comment="United States" list=SafeCountries
add address=146.180.0.0/15 comment="United States" list=SafeCountries
add address=146.183.0.0-146.184.255.255 comment="United States" list=
SafeCountries
add address=146.185.204.0/25 comment="United States" list=SafeCountries
add address=146.186.0.0/15 comment="United States" list=SafeCountries
add address=146.189.0.0-146.190.255.255 comment="United States" list=
SafeCountries
add address=146.196.100.0/22 comment="United States" list=SafeCountries
add address=146.197.0.0/16 comment="United States" list=SafeCountries
add address=146.199.44.139 comment="United States" list=SafeCountries
add address=146.200.0.0/24 comment="United States" list=SafeCountries
add address=146.200.11.0/24 comment="United States" list=SafeCountries
add address=146.200.22.0/23 comment="United States" list=SafeCountries
add address=146.200.27.0-146.200.29.255 comment="United States" list=
SafeCountries
add address=146.200.35.0/24 comment="United States" list=SafeCountries
add address=146.200.40.0-146.200.45.255 comment="United States" list=
SafeCountries
add address=146.200.46.128-146.200.51.255 comment="United States" list=
SafeCountries
add address=146.200.53.0-146.200.60.255 comment="United States" list=
SafeCountries
add address=146.200.64.0-146.200.64.146 comment="United States" list=
SafeCountries
add address=146.200.64.148-146.200.64.255 comment="United States" list=
SafeCountries
add address=146.200.68.0/23 comment="United States" list=SafeCountries
add address=146.200.73.0-146.200.76.255 comment="United States" list=
SafeCountries
add address=146.200.78.0-146.200.80.255 comment="United States" list=
SafeCountries
add address=146.200.86.0-146.200.91.255 comment="United States" list=
SafeCountries
add address=146.200.93.0/24 comment="United States" list=SafeCountries
add address=146.200.97.0-146.200.99.255 comment="United States" list=
SafeCountries
add address=146.200.101.0-146.200.102.255 comment="United States" list=
SafeCountries
add address=146.200.104.0/21 comment="United States" list=SafeCountries
add address=146.200.113.128/25 comment="United States" list=SafeCountries
add address=146.200.121.0/24 comment="United States" list=SafeCountries
add address=146.200.124.0/22 comment="United States" list=SafeCountries
add address=146.200.131.0-146.200.132.255 comment="United States" list=
SafeCountries
add address=146.200.134.0/23 comment="United States" list=SafeCountries
add address=146.200.137.0-146.200.139.255 comment="United States" list=
SafeCountries
add address=146.200.141.0-146.200.146.255 comment="United States" list=
SafeCountries
add address=146.200.151.0/24 comment="United States" list=SafeCountries
add address=146.200.154.0/24 comment="United States" list=SafeCountries
add address=146.200.156.0/23 comment="United States" list=SafeCountries
add address=146.200.159.0/24 comment="United States" list=SafeCountries
add address=146.200.161.0-146.200.162.255 comment="United States" list=
SafeCountries
add address=146.200.165.0/24 comment="United States" list=SafeCountries
add address=146.200.170.0/23 comment="United States" list=SafeCountries
add address=146.200.173.0-146.200.175.255 comment="United States" list=
SafeCountries
add address=146.200.177.0/24 comment="United States" list=SafeCountries
add address=146.200.180.0/24 comment="United States" list=SafeCountries
add address=146.200.182.0-146.200.185.255 comment="United States" list=
SafeCountries
add address=146.200.187.0-146.200.200.255 comment="United States" list=
SafeCountries
add address=146.200.202.0/24 comment="United States" list=SafeCountries
add address=146.200.204.0/24 comment="United States" list=SafeCountries
add address=146.200.209.0-146.200.215.255 comment="United States" list=
SafeCountries
add address=146.200.218.0/23 comment="United States" list=SafeCountries
add address=146.200.222.0/24 comment="United States" list=SafeCountries
add address=146.200.224.0/24 comment="United States" list=SafeCountries
add address=146.200.226.0/23 comment="United States" list=SafeCountries
add address=146.200.229.0-146.200.230.255 comment="United States" list=
SafeCountries
add address=146.200.233.0/24 comment="United States" list=SafeCountries
add address=146.200.235.0-146.200.237.255 comment="United States" list=
SafeCountries
add address=146.200.248.0/23 comment="United States" list=SafeCountries
add address=146.200.251.0/24 comment="United States" list=SafeCountries
add address=146.200.253.0-146.209.255.255 comment="United States" list=
SafeCountries
add address=146.214.0.0/15 comment="United States" list=SafeCountries
add address=146.217.0.0-146.218.255.255 comment="United States" list=
SafeCountries
add address=146.222.0.0/15 comment="United States" list=SafeCountries
add address=146.225.0.0/16 comment="United States" list=SafeCountries
add address=146.229.0.0/16 comment="United States" list=SafeCountries
add address=146.233.0.0/16 comment="United States" list=SafeCountries
add address=146.235.0.0-146.246.255.255 comment="United States" list=
SafeCountries
add address=146.250.0.0/16 comment="United States" list=SafeCountries
add address=146.252.0.0/16 comment="United States" list=SafeCountries
add address=146.255.120.0-146.255.122.255 comment="United States" list=
SafeCountries
add address=147.0.0.0-147.1.7.255 comment="United States" list=SafeCountries
add address=147.1.9.0-147.1.10.255 comment="United States" list=SafeCountries
add address=147.1.12.0-147.1.27.255 comment="United States" list=
SafeCountries
add address=147.1.29.0-147.1.37.255 comment="United States" list=
SafeCountries
add address=147.1.39.0-147.1.79.255 comment="United States" list=
SafeCountries
add address=147.1.81.0-147.5.255.255 comment="United States" list=
SafeCountries
add address=147.9.0.0/16 comment="United States" list=SafeCountries
add address=147.11.0.0/16 comment="United States" list=SafeCountries
add address=147.15.0.0-147.26.255.255 comment="United States" list=
SafeCountries
add address=147.28.0.0/16 comment="United States" list=SafeCountries
add address=147.31.0.0/16 comment="United States" list=SafeCountries
add address=147.34.0.0-147.40.255.255 comment="United States" list=
SafeCountries
add address=147.42.0.0/16 comment="United States" list=SafeCountries
add address=147.48.0.0/15 comment="United States" list=SafeCountries
add address=147.51.0.0/16 comment="United States" list=SafeCountries
add address=147.53.0.0/16 comment="United States" list=SafeCountries
add address=147.55.0.0-147.59.255.255 comment="United States" list=
SafeCountries
add address=147.61.0.0-147.64.255.255 comment="United States" list=
SafeCountries
add address=147.70.0.0-147.74.255.255 comment="United States" list=
SafeCountries
add address=147.75.128.0/20 comment="United States" list=SafeCountries
add address=147.75.160.0-147.75.203.255 comment="United States" list=
SafeCountries
add address=147.75.206.0/23 comment="United States" list=SafeCountries
add address=147.79.0.0-147.82.255.255 comment="United States" list=
SafeCountries
add address=147.85.0.0/16 comment="United States" list=SafeCountries
add address=147.90.0.0/16 comment="United States" list=SafeCountries
add address=147.92.0.0/16 comment="United States" list=SafeCountries
add address=147.97.0.0/16 comment="United States" list=SafeCountries
add address=147.101.0.0/16 comment="United States" list=SafeCountries
add address=147.103.0.0-147.108.15.255 comment="United States" list=
SafeCountries
add address=147.108.18.0-147.108.31.255 comment="United States" list=
SafeCountries
add address=147.108.40.0-147.108.55.255 comment="United States" list=
SafeCountries
add address=147.108.64.0/23 comment="United States" list=SafeCountries
add address=147.108.68.0-147.108.75.255 comment="United States" list=
SafeCountries
add address=147.108.78.0-147.108.199.255 comment="United States" list=
SafeCountries
add address=147.108.208.0-147.108.255.255 comment="United States" list=
SafeCountries
add address=147.113.0.0/16 comment="United States" list=SafeCountries
add address=147.115.0.0-147.118.255.255 comment="United States" list=
SafeCountries
add address=147.120.0.0/15 comment="United States" list=SafeCountries
add address=147.124.0.0/16 comment="United States" list=SafeCountries
add address=147.126.0.0/16 comment="United States" list=SafeCountries
add address=147.128.0.0/14 comment="United States" list=SafeCountries
add address=147.133.0.0-147.141.255.255 comment="United States" list=
SafeCountries
add address=147.144.0.0-147.146.255.255 comment="United States" list=
SafeCountries
add address=147.153.0.0-147.155.255.255 comment="United States" list=
SafeCountries
add address=147.159.0.0-147.160.255.255 comment="United States" list=
SafeCountries
add address=147.164.0.0-147.166.255.255 comment="United States" list=
SafeCountries
add address=147.168.0.0-147.170.255.255 comment="United States" list=
SafeCountries
add address=147.174.0.0/16 comment="United States" list=SafeCountries
add address=147.177.0.0-147.179.255.255 comment="United States" list=
SafeCountries
add address=147.182.0.0-147.182.200.255 comment="United States" list=
SafeCountries
add address=147.182.202.0-147.183.255.255 comment="United States" list=
SafeCountries
add address=147.185.0.0/16 comment="United States" list=SafeCountries
add address=147.187.0.0/16 comment="United States" list=SafeCountries
add address=147.190.0.0-147.192.255.255 comment="United States" list=
SafeCountries
add address=147.195.0.0/16 comment="United States" list=SafeCountries
add address=147.198.0.0/15 comment="United States" list=SafeCountries
add address=147.202.0.0-147.203.119.255 comment="United States" list=
SafeCountries
add address=147.203.121.0-147.203.255.255 comment="United States" list=
SafeCountries
add address=147.205.0.0-147.208.255.255 comment="United States" list=
SafeCountries
add address=147.216.0.0/14 comment="United States" list=SafeCountries
add address=147.221.0.0-147.227.255.255 comment="United States" list=
SafeCountries
add address=147.238.0.0-147.242.255.255 comment="United States" list=
SafeCountries
add address=147.243.128.0/19 comment="United States" list=SafeCountries
add address=147.244.0.0-147.249.255.255 comment="United States" list=
SafeCountries
add address=147.253.0.0-147.255.255.255 comment="United States" list=
SafeCountries
add address=148.1.0.0/16 comment="United States" list=SafeCountries
add address=148.4.0.0/15 comment="United States" list=SafeCountries
add address=148.7.0.0-148.53.255.255 comment="United States" list=
SafeCountries
add address=148.55.0.0/16 comment="United States" list=SafeCountries
add address=148.57.0.0-148.59.255.255 comment="United States" list=
SafeCountries
add address=148.61.0.0-148.66.63.255 comment="United States" list=
SafeCountries
add address=148.66.128.0/17 comment="United States" list=SafeCountries
add address=148.69.0.0-148.78.255.255 comment="United States" list=
SafeCountries
add address=148.80.0.0/16 comment="United States" list=SafeCountries
add address=148.84.0.0/14 comment="United States" list=SafeCountries
add address=148.89.0.0-148.100.255.255 comment="United States" list=
SafeCountries
add address=148.104.0.0-148.106.81.24 comment="United States" list=
SafeCountries
add address=148.106.81.26-148.106.151.255 comment="United States" list=
SafeCountries
add address=148.106.153.60 comment="United States" list=SafeCountries
add address=148.106.160.0-148.107.4.255 comment="United States" list=
SafeCountries
add address=148.107.6.0-148.107.11.255 comment="United States" list=
SafeCountries
add address=148.107.13.0-148.109.255.255 comment="United States" list=
SafeCountries
add address=148.111.0.0-148.116.255.255 comment="United States" list=
SafeCountries
add address=148.124.0.0-148.134.255.255 comment="United States" list=
SafeCountries
add address=148.137.0.0/16 comment="United States" list=SafeCountries
add address=148.139.0.0/16 comment="United States" list=SafeCountries
add address=148.141.0.0-148.142.255.255 comment="United States" list=
SafeCountries
add address=148.144.0.0/16 comment="United States" list=SafeCountries
add address=148.146.0.0/15 comment="United States" list=SafeCountries
add address=148.149.0.0-148.150.255.255 comment="United States" list=
SafeCountries
add address=148.152.0.0/13 comment="United States" list=SafeCountries
add address=148.162.0.0-148.163.179.255 comment="United States" list=
SafeCountries
add address=148.163.184.0-148.168.255.255 comment="United States" list=
SafeCountries
add address=148.170.0.0-148.175.255.255 comment="United States" list=
SafeCountries
add address=148.177.0.0-148.177.88.255 comment="United States" list=
SafeCountries
add address=148.177.90.0-148.177.127.255 comment="United States" list=
SafeCountries
add address=148.177.130.0-148.177.194.255 comment="United States" list=
SafeCountries
add address=148.177.196.0-148.177.216.255 comment="United States" list=
SafeCountries
add address=148.177.218.0-148.177.241.255 comment="United States" list=
SafeCountries
add address=148.177.243.0-148.180.255.255 comment="United States" list=
SafeCountries
add address=148.183.0.0-148.184.255.255 comment="United States" list=
SafeCountries
add address=148.186.0.0/16 comment="United States" list=SafeCountries
add address=148.188.0.0-148.188.1.59 comment="United States" list=
SafeCountries
add address=148.188.1.61-148.188.8.255 comment="United States" list=
SafeCountries
add address=148.188.10.0-148.188.17.55 comment="United States" list=
SafeCountries
add address=148.188.17.57-148.188.247.255 comment="United States" list=
SafeCountries
add address=148.188.249.0-148.194.255.255 comment="United States" list=
SafeCountries
add address=148.199.0.0/16 comment="United States" list=SafeCountries
add address=148.254.0.0/16 comment="United States" list=SafeCountries
add address=149.1.0.0-149.2.255.255 comment="United States" list=
SafeCountries
add address=149.4.0.0-149.5.0.127 comment="United States" list=SafeCountries
add address=149.5.0.160-149.5.21.127 comment="United States" list=
SafeCountries
add address=149.5.21.160-149.5.31.255 comment="United States" list=
SafeCountries
add address=149.5.33.0-149.5.34.255 comment="United States" list=
SafeCountries
add address=149.5.39.0/24 comment="United States" list=SafeCountries
add address=149.5.44.0-149.5.46.255 comment="United States" list=
SafeCountries
add address=149.5.48.0-149.5.64.255 comment="United States" list=
SafeCountries
add address=149.5.66.0-149.5.69.127 comment="United States" list=
SafeCountries
add address=149.5.69.192-149.5.88.255 comment="United States" list=
SafeCountries
add address=149.5.90.0-149.5.109.255 comment="United States" list=
SafeCountries
add address=149.5.114.0-149.5.129.255 comment="United States" list=
SafeCountries
add address=149.5.131.0-149.5.147.255 comment="United States" list=
SafeCountries
add address=149.5.148.1-149.5.176.15 comment="United States" list=
SafeCountries
add address=149.5.176.24-149.5.186.255 comment="United States" list=
SafeCountries
add address=149.5.188.0-149.5.218.7 comment="United States" list=
SafeCountries
add address=149.5.218.16-149.5.226.255 comment="United States" list=
SafeCountries
add address=149.5.227.128/25 comment="United States" list=SafeCountries
add address=149.5.229.0-149.5.247.255 comment="United States" list=
SafeCountries
add address=149.6.0.0/23 comment="United States" list=SafeCountries
add address=149.6.3.0/24 comment="United States" list=SafeCountries
add address=149.6.5.0-149.6.8.255 comment="United States" list=SafeCountries
add address=149.6.10.0-149.6.12.63 comment="United States" list=SafeCountries
add address=149.6.12.72-149.6.15.255 comment="United States" list=
SafeCountries
add address=149.6.18.0-149.6.44.255 comment="United States" list=
SafeCountries
add address=149.6.46.0-149.6.52.16 comment="United States" list=SafeCountries
add address=149.6.52.19-149.6.54.191 comment="United States" list=
SafeCountries
add address=149.6.54.200-149.6.56.255 comment="United States" list=
SafeCountries
add address=149.6.58.0-149.6.90.15 comment="United States" list=SafeCountries
add address=149.6.90.20-149.6.106.15 comment="United States" list=
SafeCountries
add address=149.6.106.24-149.6.110.55 comment="United States" list=
SafeCountries
add address=149.6.110.64-149.6.113.255 comment="United States" list=
SafeCountries
add address=149.6.115.0-149.6.115.39 comment="United States" list=
SafeCountries
add address=149.6.115.48-149.6.123.153 comment="United States" list=
SafeCountries
add address=149.6.123.155-149.6.129.255 comment="United States" list=
SafeCountries
add address=149.6.131.0-149.6.145.255 comment="United States" list=
SafeCountries
add address=149.6.147.0-149.6.150.37 comment="United States" list=
SafeCountries
add address=149.6.150.39-149.6.153.223 comment="United States" list=
SafeCountries
add address=149.6.153.232-149.6.154.223 comment="United States" list=
SafeCountries
add address=149.6.154.232-149.6.160.255 comment="United States" list=
SafeCountries
add address=149.6.162.0/23 comment="United States" list=SafeCountries
add address=149.6.165.0/24 comment="United States" list=SafeCountries
add address=149.6.168.0-149.6.184.255 comment="United States" list=
SafeCountries
add address=149.6.186.0/24 comment="United States" list=SafeCountries
add address=149.6.188.0/22 comment="United States" list=SafeCountries
add address=149.6.196.0-149.6.198.255 comment="United States" list=
SafeCountries
add address=149.6.201.0-149.7.31.255 comment="United States" list=
SafeCountries
add address=149.7.33.0-149.7.43.255 comment="United States" list=
SafeCountries
add address=149.7.46.0/24 comment="United States" list=SafeCountries
add address=149.7.50.0/24 comment="United States" list=SafeCountries
add address=149.7.52.0-149.7.57.223 comment="United States" list=
SafeCountries
add address=149.7.58.0-149.7.97.255 comment="United States" list=
SafeCountries
add address=149.7.99.0-149.7.103.255 comment="United States" list=
SafeCountries
add address=149.7.105.0-149.7.111.255 comment="United States" list=
SafeCountries
add address=149.7.113.0-149.7.194.255 comment="United States" list=
SafeCountries
add address=149.7.196.0-149.7.211.255 comment="United States" list=
SafeCountries
add address=149.7.213.0-149.7.216.207 comment="United States" list=
SafeCountries
add address=149.7.216.240/28 comment="United States" list=SafeCountries
add address=149.7.224.0-149.8.247.255 comment="United States" list=
SafeCountries
add address=149.8.249.0-149.8.251.255 comment="United States" list=
SafeCountries
add address=149.8.253.0-149.11.26.13 comment="United States" list=
SafeCountries
add address=149.11.26.15-149.11.35.255 comment="United States" list=
SafeCountries
add address=149.11.37.0-149.11.44.255 comment="United States" list=
SafeCountries
add address=149.11.46.0-149.11.65.31 comment="United States" list=
SafeCountries
add address=149.11.65.36-149.11.99.255 comment="United States" list=
SafeCountries
add address=149.11.101.0/24 comment="United States" list=SafeCountries
add address=149.11.103.0-149.11.107.255 comment="United States" list=
SafeCountries
add address=149.11.109.0-149.11.110.139 comment="United States" list=
SafeCountries
add address=149.11.110.248-149.11.113.255 comment="United States" list=
SafeCountries
add address=149.11.115.0-149.11.127.255 comment="United States" list=
SafeCountries
add address=149.11.129.0/24 comment="United States" list=SafeCountries
add address=149.11.131.0-149.11.141.255 comment="United States" list=
SafeCountries
add address=149.11.145.0-149.11.159.255 comment="United States" list=
SafeCountries
add address=149.11.162.0-149.11.166.103 comment="United States" list=
SafeCountries
add address=149.11.166.108-149.11.170.87 comment="United States" list=
SafeCountries
add address=149.11.170.96-149.11.255.255 comment="United States" list=
SafeCountries
add address=149.12.16.0/23 comment="United States" list=SafeCountries
add address=149.12.20.0-149.12.32.127 comment="United States" list=
SafeCountries
add address=149.12.32.144-149.12.67.255 comment="United States" list=
SafeCountries
add address=149.12.69.0-149.12.95.255 comment="United States" list=
SafeCountries
add address=149.12.97.0-149.12.180.31 comment="United States" list=
SafeCountries
add address=149.12.180.64-149.12.183.255 comment="United States" list=
SafeCountries
add address=149.12.188.0-149.12.215.255 comment="United States" list=
SafeCountries
add address=149.12.220.0-149.12.222.133 comment="United States" list=
SafeCountries
add address=149.12.222.135-149.13.23.255 comment="United States" list=
SafeCountries
add address=149.13.28.0-149.13.34.255 comment="United States" list=
SafeCountries
add address=149.13.36.0-149.13.36.95 comment="United States" list=
SafeCountries
add address=149.13.36.104-149.13.96.31 comment="United States" list=
SafeCountries
add address=149.13.96.40-149.13.98.255 comment="United States" list=
SafeCountries
add address=149.13.100.0-149.13.111.255 comment="United States" list=
SafeCountries
add address=149.13.113.0-149.13.116.255 comment="United States" list=
SafeCountries
add address=149.13.118.0/23 comment="United States" list=SafeCountries
add address=149.13.128.0-149.13.145.255 comment="United States" list=
SafeCountries
add address=149.13.147.0/24 comment="United States" list=SafeCountries
add address=149.13.152.0-149.13.241.255 comment="United States" list=
SafeCountries
add address=149.13.250.0-149.14.3.255 comment="United States" list=
SafeCountries
add address=149.14.5.0-149.14.20.255 comment="United States" list=
SafeCountries
add address=149.14.22.0-149.14.65.255 comment="United States" list=
SafeCountries
add address=149.14.67.0-149.14.80.47 comment="United States" list=
SafeCountries
add address=149.14.80.56-149.17.255.255 comment="United States" list=
SafeCountries
add address=149.18.192.0-149.24.153.255 comment="United States" list=
SafeCountries
add address=149.24.155.0-149.26.255.255 comment="United States" list=
SafeCountries
add address=149.28.0.0-149.33.255.255 comment="United States" list=
SafeCountries
add address=149.34.16.0/20 comment="United States" list=SafeCountries
add address=149.34.48.0/21 comment="United States" list=SafeCountries
add address=149.34.64.0-149.48.255.255 comment="United States" list=
SafeCountries
add address=149.51.0.0-149.53.255.255 comment="United States" list=
SafeCountries
add address=149.55.0.0-149.58.255.255 comment="United States" list=
SafeCountries
add address=149.60.0.0/15 comment="United States" list=SafeCountries
add address=149.63.0.0-149.66.195.255 comment="United States" list=
SafeCountries
add address=149.66.197.0-149.71.56.255 comment="United States" list=
SafeCountries
add address=149.71.60.0/22 comment="United States" list=SafeCountries
add address=149.71.112.0/20 comment="United States" list=SafeCountries
add address=149.71.160.0/24 comment="United States" list=SafeCountries
add address=149.71.163.0-149.78.6.114 comment="United States" list=
SafeCountries
add address=149.78.6.116-149.78.10.118 comment="United States" list=
SafeCountries
add address=149.78.10.120-149.78.11.255 comment="United States" list=
SafeCountries
add address=149.78.13.0-149.78.14.255 comment="United States" list=
SafeCountries
add address=149.78.16.0-149.78.20.255 comment="United States" list=
SafeCountries
add address=149.78.23.0/24 comment="United States" list=SafeCountries
add address=149.78.27.0/24 comment="United States" list=SafeCountries
add address=149.78.29.0-149.78.34.255 comment="United States" list=
SafeCountries
add address=149.78.37.0/24 comment="United States" list=SafeCountries
add address=149.78.39.0/24 comment="United States" list=SafeCountries
add address=149.78.41.0-149.78.44.255 comment="United States" list=
SafeCountries
add address=149.78.47.0/24 comment="United States" list=SafeCountries
add address=149.78.49.0-149.78.67.255 comment="United States" list=
SafeCountries
add address=149.78.69.0/24 comment="United States" list=SafeCountries
add address=149.78.71.0-149.78.74.255 comment="United States" list=
SafeCountries
add address=149.78.76.0-149.78.78.255 comment="United States" list=
SafeCountries
add address=149.78.80.0-149.78.94.237 comment="United States" list=
SafeCountries
add address=149.78.94.239-149.78.95.255 comment="United States" list=
SafeCountries
add address=149.78.98.0-149.78.103.255 comment="United States" list=
SafeCountries
add address=149.78.106.0/24 comment="United States" list=SafeCountries
add address=149.78.108.0-149.78.111.24 comment="United States" list=
SafeCountries
add address=149.78.111.26-149.78.115.255 comment="United States" list=
SafeCountries
add address=149.78.117.0-149.78.127.255 comment="United States" list=
SafeCountries
add address=149.79.0.0-149.86.63.255 comment="United States" list=
SafeCountries
add address=149.86.72.0-149.86.95.255 comment="United States" list=
SafeCountries
add address=149.86.104.0-149.86.109.255 comment="United States" list=
SafeCountries
add address=149.86.128.0/19 comment="United States" list=SafeCountries
add address=149.86.168.0-149.86.183.255 comment="United States" list=
SafeCountries
add address=149.86.192.0-149.86.239.255 comment="United States" list=
SafeCountries
add address=149.86.244.0/22 comment="United States" list=SafeCountries
add address=149.87.0.0/16 comment="United States" list=SafeCountries
add address=149.89.0.0-149.91.79.255 comment="United States" list=
SafeCountries
add address=149.91.84.0/22 comment="United States" list=SafeCountries
add address=149.91.92.0/22 comment="United States" list=SafeCountries
add address=149.91.136.0-149.98.255.255 comment="United States" list=
SafeCountries
add address=149.100.1.0-149.100.4.255 comment="United States" list=
SafeCountries
add address=149.100.6.0/23 comment="United States" list=SafeCountries
add address=149.100.9.0-149.100.160.255 comment="United States" list=
SafeCountries
add address=149.100.162.0-149.100.167.255 comment="United States" list=
SafeCountries
add address=149.100.176.0-149.101.255.255 comment="United States" list=
SafeCountries
add address=149.103.0.0-149.111.175.255 comment="United States" list=
SafeCountries
add address=149.111.177.0-149.125.255.255 comment="United States" list=
SafeCountries
add address=149.126.73.38 comment="United States" list=SafeCountries
add address=149.127.0.0-149.128.255.255 comment="United States" list=
SafeCountries
add address=149.130.0.0/15 comment="United States" list=SafeCountries
add address=149.134.173.0/24 comment="United States" list=SafeCountries
add address=149.136.0.0-149.138.255.255 comment="United States" list=
SafeCountries
add address=149.141.0.0-149.143.255.255 comment="United States" list=
SafeCountries
add address=149.145.0.0/16 comment="United States" list=SafeCountries
add address=149.149.0.0-149.152.255.255 comment="United States" list=
SafeCountries
add address=149.154.0.0/18 comment="United States" list=SafeCountries
add address=149.154.158.0/24 comment="United States" list=SafeCountries
add address=149.158.0.0-149.166.255.255 comment="United States" list=
SafeCountries
add address=149.168.0.0/15 comment="United States" list=SafeCountries
add address=149.173.0.0-149.175.255.255 comment="United States" list=
SafeCountries
add address=149.198.0.0/15 comment="United States" list=SafeCountries
add address=149.234.252.0/22 comment="United States" list=SafeCountries
add address=149.252.0.0/15 comment="United States" list=SafeCountries
add address=149.255.32.0/25 comment="United States" list=SafeCountries
add address=149.255.32.192-149.255.33.79 comment="United States" list=
SafeCountries
add address=149.255.33.96/28 comment="United States" list=SafeCountries
add address=149.255.33.120/29 comment="United States" list=SafeCountries
add address=149.255.33.136-149.255.33.207 comment="United States" list=
SafeCountries
add address=149.255.33.240-149.255.34.159 comment="United States" list=
SafeCountries
add address=149.255.35.0/24 comment="United States" list=SafeCountries
add address=149.255.36.64-149.255.36.255 comment="United States" list=
SafeCountries
add address=150.102.0.0-150.104.255.255 comment="United States" list=
SafeCountries
add address=150.108.0.0-150.114.255.255 comment="United States" list=
SafeCountries
add address=150.118.0.0-150.120.255.255 comment="United States" list=
SafeCountries
add address=150.123.0.0-150.127.224.255 comment="United States" list=
SafeCountries
add address=150.127.226.0-150.127.255.255 comment="United States" list=
SafeCountries
add address=150.130.0.0/15 comment="United States" list=SafeCountries
add address=150.133.0.0-150.137.255.255 comment="United States" list=
SafeCountries
add address=150.141.0.0-150.144.255.255 comment="United States" list=
SafeCountries
add address=150.147.0.0-150.149.255.255 comment="United States" list=
SafeCountries
add address=150.152.0.0-150.157.255.255 comment="United States" list=
SafeCountries
add address=150.159.0.0-150.160.255.255 comment="United States" list=
SafeCountries
add address=150.166.0.0-150.172.255.255 comment="United States" list=
SafeCountries
add address=150.174.0.0/16 comment="United States" list=SafeCountries
add address=150.176.0.0/15 comment="United States" list=SafeCountries
add address=150.179.0.0-150.182.255.255 comment="United States" list=
SafeCountries
add address=150.184.0.0/16 comment="United States" list=SafeCountries
add address=150.190.0.0/16 comment="United States" list=SafeCountries
add address=150.192.0.0-150.196.255.255 comment="United States" list=
SafeCountries
add address=150.198.0.0-150.202.255.255 comment="United States" list=
SafeCountries
add address=150.208.0.0-150.212.255.255 comment="United States" list=
SafeCountries
add address=150.215.0.0-150.216.255.255 comment="United States" list=
SafeCountries
add address=150.218.0.0-150.222.255.255 comment="United States" list=
SafeCountries
add address=150.224.0.0-150.226.255.255 comment="United States" list=
SafeCountries
add address=150.228.0.0/16 comment="United States" list=SafeCountries
add address=150.231.0.0-150.235.255.255 comment="United States" list=
SafeCountries
add address=150.238.0.0-150.240.255.255 comment="United States" list=
SafeCountries
add address=150.242.220.0/22 comment="United States" list=SafeCountries
add address=150.243.0.0/16 comment="United States" list=SafeCountries
add address=150.245.0.0-150.250.255.255 comment="United States" list=
SafeCountries
add address=150.252.0.0/15 comment="United States" list=SafeCountries
add address=151.101.0.0-151.104.255.255 comment="United States" list=
SafeCountries
add address=151.106.0.0-151.114.255.255 comment="United States" list=
SafeCountries
add address=151.116.0.0/14 comment="United States" list=SafeCountries
add address=151.121.0.0-151.126.255.255 comment="United States" list=
SafeCountries
add address=151.128.0.0/16 comment="United States" list=SafeCountries
add address=151.131.0.0-151.132.255.255 comment="United States" list=
SafeCountries
add address=151.134.0.0/16 comment="United States" list=SafeCountries
add address=151.137.0.0-151.155.255.255 comment="United States" list=
SafeCountries
add address=151.159.0.0-151.169.255.255 comment="United States" list=
SafeCountries
add address=151.171.0.0/16 comment="United States" list=SafeCountries
add address=151.173.0.0-151.174.255.255 comment="United States" list=
SafeCountries
add address=151.179.0.0/16 comment="United States" list=SafeCountries
add address=151.181.0.0/16 comment="United States" list=SafeCountries
add address=151.185.0.0-151.186.255.255 comment="United States" list=
SafeCountries
add address=151.188.0.0/16 comment="United States" list=SafeCountries
add address=151.190.0.0-151.193.119.255 comment="United States" list=
SafeCountries
add address=151.193.121.0-151.210.255.255 comment="United States" list=
SafeCountries
add address=151.213.0.0-151.215.255.255 comment="United States" list=
SafeCountries
add address=151.236.16.0/24 comment="United States" list=SafeCountries
add address=151.236.22.0/24 comment="United States" list=SafeCountries
add address=151.237.176.0/24 comment="United States" list=SafeCountries
add address=151.248.24.30 comment="United States" list=SafeCountries
add address=152.1.0.0-152.51.255.255 comment="United States" list=
SafeCountries
add address=152.53.0.0-152.62.44.55 comment="United States" list=
SafeCountries
add address=152.62.44.60-152.62.108.255 comment="United States" list=
SafeCountries
add address=152.62.109.62 comment="United States" list=SafeCountries
add address=152.62.110.0-152.65.255.255 comment="United States" list=
SafeCountries
add address=152.67.0.0-152.70.255.255 comment="United States" list=
SafeCountries
add address=152.72.0.0-152.72.129.255 comment="United States" list=
SafeCountries
add address=152.72.131.0-152.72.255.255 comment="United States" list=
SafeCountries
add address=152.75.0.0/16 comment="United States" list=SafeCountries
add address=152.79.0.0-152.80.255.255 comment="United States" list=
SafeCountries
add address=152.82.0.0/16 comment="United States" list=SafeCountries
add address=152.85.0.0-152.87.255.255 comment="United States" list=
SafeCountries
add address=152.97.0.0/16 comment="United States" list=SafeCountries
add address=152.100.0.0/16 comment="United States" list=SafeCountries
add address=152.113.0.0/16 comment="United States" list=SafeCountries
add address=152.116.0.0/15 comment="United States" list=SafeCountries
add address=152.119.0.0-152.130.7.195 comment="United States" list=
SafeCountries
add address=152.130.7.197-152.133.255.255 comment="United States" list=
SafeCountries
add address=152.135.0.0-152.138.255.255 comment="United States" list=
SafeCountries
add address=152.140.0.0-152.142.255.255 comment="United States" list=
SafeCountries
add address=152.144.0.0-152.146.255.255 comment="United States" list=
SafeCountries
add address=152.148.0.0/16 comment="United States" list=SafeCountries
add address=152.151.0.0/16 comment="United States" list=SafeCountries
add address=152.154.0.0/15 comment="United States" list=SafeCountries
add address=152.157.0.0-152.160.85.255 comment="United States" list=
SafeCountries
add address=152.160.87.0-152.165.255.255 comment="United States" list=
SafeCountries
add address=152.176.0.0-152.199.255.255 comment="United States" list=
SafeCountries
add address=152.208.0.0-152.225.255.255 comment="United States" list=
SafeCountries
add address=152.227.0.0-152.229.255.255 comment="United States" list=
SafeCountries
add address=152.231.128.0/17 comment="Costa Rica" list=SafeCountries
add address=153.2.0.0/16 comment="United States" list=SafeCountries
add address=153.4.0.0/16 comment="United States" list=SafeCountries
add address=153.6.0.0-153.14.255.255 comment="United States" list=
SafeCountries
add address=153.16.0.0/16 comment="United States" list=SafeCountries
add address=153.18.0.0/16 comment="United States" list=SafeCountries
add address=153.21.0.0-153.33.255.255 comment="United States" list=
SafeCountries
add address=153.38.0.0-153.40.255.255 comment="United States" list=
SafeCountries
add address=153.42.0.0/15 comment="United States" list=SafeCountries
add address=153.47.1.0-153.48.255.255 comment="United States" list=
SafeCountries
add address=153.50.0.0-153.87.255.255 comment="United States" list=
SafeCountries
add address=153.89.0.0-153.91.255.255 comment="United States" list=
SafeCountries
add address=153.92.32.0/21 comment="United States" list=SafeCountries
add address=153.92.181.0/24 comment="United States" list=SafeCountries
add address=153.92.188.0/22 comment="United States" list=SafeCountries
add address=153.102.0.0-153.106.255.255 comment="United States" list=
SafeCountries
add address=153.112.223.0/24 comment="United States" list=SafeCountries
add address=153.113.0.0-153.117.255.255 comment="United States" list=
SafeCountries
add address=153.143.46.0-153.143.63.255 comment="United States" list=
SafeCountries
add address=153.254.158.0/24 comment="United States" list=SafeCountries
add address=153.254.164.0/23 comment="United States" list=SafeCountries
add address=154.1.0.0-154.4.255.255 comment="United States" list=
SafeCountries
add address=154.6.0.0/15 comment="United States" list=SafeCountries
add address=154.9.0.0/16 comment="United States" list=SafeCountries
add address=154.12.0.0/15 comment="United States" list=SafeCountries
add address=154.16.1.0/24 comment="United States" list=SafeCountries
add address=154.16.5.0/24 comment="United States" list=SafeCountries
add address=154.16.7.0/24 comment="United States" list=SafeCountries
add address=154.16.9.0/24 comment="United States" list=SafeCountries
add address=154.16.11.0/24 comment="United States" list=SafeCountries
add address=154.16.13.0/24 comment="United States" list=SafeCountries
add address=154.16.15.0/24 comment="United States" list=SafeCountries
add address=154.16.19.0/24 comment="United States" list=SafeCountries
add address=154.16.21.0/24 comment="United States" list=SafeCountries
add address=154.16.23.0/24 comment="United States" list=SafeCountries
add address=154.16.25.0/24 comment="United States" list=SafeCountries
add address=154.16.27.0/24 comment="United States" list=SafeCountries
add address=154.16.29.0/24 comment="United States" list=SafeCountries
add address=154.16.31.0/24 comment="United States" list=SafeCountries
add address=154.16.33.0/24 comment="United States" list=SafeCountries
add address=154.16.35.0/24 comment="United States" list=SafeCountries
add address=154.16.37.0/24 comment="United States" list=SafeCountries
add address=154.16.39.0/24 comment="United States" list=SafeCountries
add address=154.16.41.0/24 comment="United States" list=SafeCountries
add address=154.16.43.0/24 comment="United States" list=SafeCountries
add address=154.16.45.0/24 comment="United States" list=SafeCountries
add address=154.16.47.0/24 comment="United States" list=SafeCountries
add address=154.16.49.0/24 comment="United States" list=SafeCountries
add address=154.16.51.0/24 comment="United States" list=SafeCountries
add address=154.16.53.0/24 comment="United States" list=SafeCountries
add address=154.16.55.0/24 comment="United States" list=SafeCountries
add address=154.16.57.0/24 comment="United States" list=SafeCountries
add address=154.16.59.0/24 comment="United States" list=SafeCountries
add address=154.16.61.0/24 comment="United States" list=SafeCountries
add address=154.16.65.0/24 comment="United States" list=SafeCountries
add address=154.16.67.0/24 comment="United States" list=SafeCountries
add address=154.16.69.0/24 comment="United States" list=SafeCountries
add address=154.16.71.0/24 comment="United States" list=SafeCountries
add address=154.16.73.0/24 comment="United States" list=SafeCountries
add address=154.16.75.0/24 comment="United States" list=SafeCountries
add address=154.16.77.0/24 comment="United States" list=SafeCountries
add address=154.16.79.0/24 comment="United States" list=SafeCountries
add address=154.16.81.0/24 comment="United States" list=SafeCountries
add address=154.16.83.0/24 comment="United States" list=SafeCountries
add address=154.16.85.0/24 comment="United States" list=SafeCountries
add address=154.16.87.0/24 comment="United States" list=SafeCountries
add address=154.16.89.0/24 comment="United States" list=SafeCountries
add address=154.16.91.0/24 comment="United States" list=SafeCountries
add address=154.16.97.0-154.16.106.255 comment="United States" list=
SafeCountries
add address=154.16.108.0/22 comment="United States" list=SafeCountries
add address=154.16.120.0-154.16.138.255 comment="United States" list=
SafeCountries
add address=154.16.140.0-154.16.157.255 comment="United States" list=
SafeCountries
add address=154.16.159.0-154.16.164.255 comment="United States" list=
SafeCountries
add address=154.16.166.0-154.19.255.255 comment="United States" list=
SafeCountries
add address=154.21.0.0-154.25.3.8 comment="United States" list=SafeCountries
add address=154.25.3.11-154.25.3.36 comment="United States" list=
SafeCountries
add address=154.25.3.39-154.31.255.255 comment="United States" list=
SafeCountries
add address=154.35.0.0-154.41.1.255 comment="United States" list=
SafeCountries
add address=154.41.4.0-154.42.143.255 comment="United States" list=
SafeCountries
add address=154.42.168.0-154.43.3.255 comment="United States" list=
SafeCountries
add address=154.43.8.0-154.43.135.255 comment="United States" list=
SafeCountries
add address=154.43.144.0-154.43.223.255 comment="United States" list=
SafeCountries
add address=154.43.224.32-154.44.139.255 comment="United States" list=
SafeCountries
add address=154.44.144.0-154.44.175.255 comment="United States" list=
SafeCountries
add address=154.44.178.0-154.44.185.255 comment="United States" list=
SafeCountries
add address=154.44.188.0-154.44.255.255 comment="United States" list=
SafeCountries
add address=154.45.0.16-154.45.1.255 comment="United States" list=
SafeCountries
add address=154.45.4.0-154.45.40.63 comment="United States" list=
SafeCountries
add address=154.45.40.80-154.45.211.255 comment="United States" list=
SafeCountries
add address=154.45.213.0-154.46.34.255 comment="United States" list=
SafeCountries
add address=154.46.36.0/22 comment="United States" list=SafeCountries
add address=154.46.42.0/23 comment="United States" list=SafeCountries
add address=154.46.48.0-154.46.107.255 comment="United States" list=
SafeCountries
add address=154.46.109.0-154.46.111.255 comment="United States" list=
SafeCountries
add address=154.46.116.0-154.46.203.255 comment="United States" list=
SafeCountries
add address=154.46.206.0-154.47.66.255 comment="United States" list=
SafeCountries
add address=154.47.69.0-154.47.71.255 comment="United States" list=
SafeCountries
add address=154.47.73.0-154.47.127.255 comment="United States" list=
SafeCountries
add address=154.47.129.0-154.47.131.255 comment="United States" list=
SafeCountries
add address=154.47.133.0-154.47.135.255 comment="United States" list=
SafeCountries
add address=154.47.140.0-154.47.223.255 comment="United States" list=
SafeCountries
add address=154.47.225.0/24 comment="United States" list=SafeCountries
add address=154.47.227.0-154.48.127.255 comment="United States" list=
SafeCountries
add address=154.48.129.0/24 comment="United States" list=SafeCountries
add address=154.48.152.0/23 comment="United States" list=SafeCountries
add address=154.48.155.0/24 comment="United States" list=SafeCountries
add address=154.48.178.0-154.49.193.255 comment="United States" list=
SafeCountries
add address=154.49.195.0/24 comment="United States" list=SafeCountries
add address=154.49.202.0-154.49.209.255 comment="United States" list=
SafeCountries
add address=154.49.211.0-154.50.0.63 comment="United States" list=
SafeCountries
add address=154.50.1.0-154.50.191.255 comment="United States" list=
SafeCountries
add address=154.50.193.0-154.50.195.255 comment="United States" list=
SafeCountries
add address=154.50.197.0-154.50.197.175 comment="United States" list=
SafeCountries
add address=154.50.197.192-154.50.199.255 comment="United States" list=
SafeCountries
add address=154.50.202.0/24 comment="United States" list=SafeCountries
add address=154.50.206.0-154.50.209.255 comment="United States" list=
SafeCountries
add address=154.50.212.0-154.51.129.255 comment="United States" list=
SafeCountries
add address=154.51.131.0/24 comment="United States" list=SafeCountries
add address=154.51.134.0/23 comment="United States" list=SafeCountries
add address=154.51.136.64-154.51.149.15 comment="United States" list=
SafeCountries
add address=154.51.149.32-154.52.114.202 comment="United States" list=
SafeCountries
add address=154.52.114.204-154.52.127.255 comment="United States" list=
SafeCountries
add address=154.52.130.0-154.53.0.255 comment="United States" list=
SafeCountries
add address=154.53.2.0-154.53.127.255 comment="United States" list=
SafeCountries
add address=154.53.129.0-154.54.39.197 comment="United States" list=
SafeCountries
add address=154.54.39.199-154.54.75.9 comment="United States" list=
SafeCountries
add address=154.54.75.11-154.56.1.255 comment="United States" list=
SafeCountries
add address=154.56.3.0-154.56.127.255 comment="United States" list=
SafeCountries
add address=154.56.130.0/24 comment="United States" list=SafeCountries
add address=154.56.133.0-154.56.135.255 comment="United States" list=
SafeCountries
add address=154.56.148.0-154.56.198.255 comment="United States" list=
SafeCountries
add address=154.56.208.0-154.57.3.255 comment="United States" list=
SafeCountries
add address=154.57.8.0-154.57.63.255 comment="United States" list=
SafeCountries
add address=154.57.80.0-154.57.195.24 comment="United States" list=
SafeCountries
add address=154.57.195.26-154.57.204.79 comment="United States" list=
SafeCountries
add address=154.57.204.81-154.57.215.113 comment="United States" list=
SafeCountries
add address=154.57.215.115-154.57.223.255 comment="United States" list=
SafeCountries
add address=154.58.4.0/22 comment="United States" list=SafeCountries
add address=154.58.16.0-154.58.47.255 comment="United States" list=
SafeCountries
add address=154.58.128.0-154.58.195.255 comment="United States" list=
SafeCountries
add address=154.58.204.0/22 comment="United States" list=SafeCountries
add address=154.58.224.0-154.59.95.255 comment="United States" list=
SafeCountries
add address=154.59.114.0-154.59.135.255 comment="United States" list=
SafeCountries
add address=154.59.144.0/21 comment="United States" list=SafeCountries
add address=154.59.160.0-154.59.255.255 comment="United States" list=
SafeCountries
add address=154.60.32.0/19 comment="United States" list=SafeCountries
add address=154.60.65.0-154.60.225.255 comment="United States" list=
SafeCountries
add address=154.60.228.0-154.61.95.255 comment="United States" list=
SafeCountries
add address=154.61.100.0-154.64.159.255 comment="United States" list=
SafeCountries
add address=154.64.176.0-154.64.208.255 comment="United States" list=
SafeCountries
add address=154.64.211.0-154.64.212.255 comment="United States" list=
SafeCountries
add address=154.64.217.0-154.64.255.255 comment="United States" list=
SafeCountries
add address=154.87.0.0/16 comment="United States" list=SafeCountries
add address=154.127.48.0/24 comment="United States" list=SafeCountries
add address=154.127.52.0/22 comment="United States" list=SafeCountries
add address=154.127.57.0/24 comment="United States" list=SafeCountries
add address=155.1.0.0-155.2.255.255 comment="United States" list=
SafeCountries
add address=155.5.0.0-155.9.255.255 comment="United States" list=
SafeCountries
add address=155.13.0.0-155.14.255.255 comment="United States" list=
SafeCountries
add address=155.16.0.0/12 comment="United States" list=SafeCountries
add address=155.33.0.0-155.35.0.255 comment="United States" list=
SafeCountries
add address=155.35.2.0-155.35.33.255 comment="United States" list=
SafeCountries
add address=155.35.36.0-155.35.45.255 comment="United States" list=
SafeCountries
add address=155.35.48.0-155.35.231.255 comment="United States" list=
SafeCountries
add address=155.35.233.0-155.35.247.255 comment="United States" list=
SafeCountries
add address=155.35.249.0-155.44.255.255 comment="United States" list=
SafeCountries
add address=155.46.0.0-155.53.255.255 comment="United States" list=
SafeCountries
add address=155.57.0.0-155.57.154.255 comment="United States" list=
SafeCountries
add address=155.57.156.0/22 comment="United States" list=SafeCountries
add address=155.57.161.0-155.58.255.255 comment="United States" list=
SafeCountries
add address=155.61.0.0-155.63.199.255 comment="United States" list=
SafeCountries
add address=155.63.202.0-155.63.205.255 comment="United States" list=
SafeCountries
add address=155.63.207.0-155.65.255.255 comment="United States" list=
SafeCountries
add address=155.67.0.0-155.68.255.255 comment="United States" list=
SafeCountries
add address=155.70.0.0/16 comment="United States" list=SafeCountries
add address=155.72.0.0/16 comment="United States" list=SafeCountries
add address=155.74.0.0-155.88.255.255 comment="United States" list=
SafeCountries
add address=155.90.0.0-155.91.64.9 comment="United States" list=SafeCountries
add address=155.91.64.12-155.91.135.255 comment="United States" list=
SafeCountries
add address=155.91.137.0-155.92.255.255 comment="United States" list=
SafeCountries
add address=155.94.0.0-155.94.69.255 comment="United States" list=
SafeCountries
add address=155.94.71.0-155.104.255.255 comment="United States" list=
SafeCountries
add address=155.106.0.0-155.126.7.255 comment="United States" list=
SafeCountries
add address=155.126.9.0-155.130.255.255 comment="United States" list=
SafeCountries
add address=155.133.196.0/22 comment="United States" list=SafeCountries
add address=155.134.0.0/15 comment="United States" list=SafeCountries
add address=155.138.0.0/15 comment="United States" list=SafeCountries
add address=155.141.0.0-155.142.255.255 comment="United States" list=
SafeCountries
add address=155.146.0.0-155.157.255.255 comment="United States" list=
SafeCountries
add address=155.161.0.0-155.184.255.255 comment="United States" list=
SafeCountries
add address=155.186.0.0/16 comment="United States" list=SafeCountries
add address=155.188.0.0/14 comment="United States" list=SafeCountries
add address=155.193.0.0/16 comment="United States" list=SafeCountries
add address=155.195.0.0/16 comment="United States" list=SafeCountries
add address=155.197.0.0/16 comment="United States" list=SafeCountries
add address=155.199.0.0-155.201.255.255 comment="United States" list=
SafeCountries
add address=155.203.0.0/16 comment="United States" list=SafeCountries
add address=155.206.0.0/16 comment="United States" list=SafeCountries
add address=155.208.0.0-155.208.253.255 comment="United States" list=
SafeCountries
add address=155.208.255.0/24 comment="United States" list=SafeCountries
add address=155.212.0.0-155.222.255.255 comment="United States" list=
SafeCountries
add address=155.224.0.0-155.226.255.255 comment="United States" list=
SafeCountries
add address=155.229.0.0/16 comment="United States" list=SafeCountries
add address=155.241.0.0-155.244.255.255 comment="United States" list=
SafeCountries
add address=155.246.0.0-155.248.190.255 comment="United States" list=
SafeCountries
add address=155.248.192.0/18 comment="United States" list=SafeCountries
add address=155.252.0.0/16 comment="United States" list=SafeCountries
add address=155.254.0.0/23 comment="United States" list=SafeCountries
add address=155.254.4.0-155.254.35.255 comment="United States" list=
SafeCountries
add address=155.254.37.0-155.254.39.255 comment="United States" list=
SafeCountries
add address=155.254.48.0/20 comment="United States" list=SafeCountries
add address=155.254.105.0/24 comment="United States" list=SafeCountries
add address=155.254.108.0/24 comment="United States" list=SafeCountries
add address=155.254.110.0/24 comment="United States" list=SafeCountries
add address=155.254.112.0/24 comment="United States" list=SafeCountries
add address=155.254.114.0/24 comment="United States" list=SafeCountries
add address=155.254.116.0/24 comment="United States" list=SafeCountries
add address=155.254.118.0/23 comment="United States" list=SafeCountries
add address=155.254.122.0/24 comment="United States" list=SafeCountries
add address=155.254.124.0/24 comment="United States" list=SafeCountries
add address=155.254.127.0-155.254.135.255 comment="United States" list=
SafeCountries
add address=155.254.160.0/19 comment="United States" list=SafeCountries
add address=155.254.244.0/24 comment="United States" list=SafeCountries
add address=155.254.250.0/24 comment="United States" list=SafeCountries
add address=156.0.0.0/13 comment="United States" list=SafeCountries
add address=156.9.0.0/16 comment="United States" list=SafeCountries
add address=156.12.0.0/16 comment="United States" list=SafeCountries
add address=156.15.0.0/16 comment="United States" list=SafeCountries
add address=156.19.0.0-156.21.255.255 comment="United States" list=
SafeCountries
add address=156.23.0.0-156.24.255.255 comment="United States" list=
SafeCountries
add address=156.26.0.0/15 comment="United States" list=SafeCountries
add address=156.29.0.0-156.30.255.255 comment="United States" list=
SafeCountries
add address=156.32.0.0/15 comment="United States" list=SafeCountries
add address=156.36.0.0-156.37.252.255 comment="United States" list=
SafeCountries
add address=156.37.254.0/23 comment="United States" list=SafeCountries
add address=156.39.0.0-156.42.255.255 comment="United States" list=
SafeCountries
add address=156.45.0.0-156.47.255.255 comment="United States" list=
SafeCountries
add address=156.53.0.0/16 comment="United States" list=SafeCountries
add address=156.55.0.0-156.56.255.255 comment="United States" list=
SafeCountries
add address=156.60.0.0/16 comment="United States" list=SafeCountries
add address=156.63.0.0-156.67.3.255 comment="United States" list=
SafeCountries
add address=156.68.0.0/16 comment="United States" list=SafeCountries
add address=156.70.0.0-156.71.148.255 comment="United States" list=
SafeCountries
add address=156.71.150.0-156.82.255.255 comment="United States" list=
SafeCountries
add address=156.84.0.0-156.96.255.255 comment="United States" list=
SafeCountries
add address=156.98.0.0-156.105.255.255 comment="United States" list=
SafeCountries
add address=156.107.0.0-156.107.32.255 comment="United States" list=
SafeCountries
add address=156.107.34.0-156.107.44.1 comment="United States" list=
SafeCountries
add address=156.107.44.3-156.107.44.5 comment="United States" list=
SafeCountries
add address=156.107.44.7-156.107.44.9 comment="United States" list=
SafeCountries
add address=156.107.44.11-156.107.44.33 comment="United States" list=
SafeCountries
add address=156.107.44.35-156.107.44.37 comment="United States" list=
SafeCountries
add address=156.107.44.39-156.107.44.41 comment="United States" list=
SafeCountries
add address=156.107.44.43-156.107.44.65 comment="United States" list=
SafeCountries
add address=156.107.44.67-156.107.44.69 comment="United States" list=
SafeCountries
add address=156.107.44.71-156.107.44.73 comment="United States" list=
SafeCountries
add address=156.107.44.75-156.107.81.255 comment="United States" list=
SafeCountries
add address=156.107.82.32-156.107.82.55 comment="United States" list=
SafeCountries
add address=156.107.82.72-156.107.135.255 comment="United States" list=
SafeCountries
add address=156.107.138.0-156.107.138.9 comment="United States" list=
SafeCountries
add address=156.107.138.11-156.107.155.255 comment="United States" list=
SafeCountries
add address=156.107.158.0-156.107.172.1 comment="United States" list=
SafeCountries
add address=156.107.172.3-156.107.172.5 comment="United States" list=
SafeCountries
add address=156.107.172.7-156.107.172.9 comment="United States" list=
SafeCountries
add address=156.107.172.11-156.107.172.33 comment="United States" list=
SafeCountries
add address=156.107.172.35-156.107.172.37 comment="United States" list=
SafeCountries
add address=156.107.172.39-156.107.172.41 comment="United States" list=
SafeCountries
add address=156.107.172.43-156.107.172.69 comment="United States" list=
SafeCountries
add address=156.107.172.71-156.107.172.73 comment="United States" list=
SafeCountries
add address=156.107.172.75-156.109.10.16 comment="United States" list=
SafeCountries
add address=156.109.10.18-156.109.17.255 comment="United States" list=
SafeCountries
add address=156.109.19.0-156.113.255.255 comment="United States" list=
SafeCountries
add address=156.117.0.0/16 comment="United States" list=SafeCountries
add address=156.119.0.0-156.132.255.255 comment="United States" list=
SafeCountries
add address=156.134.0.0/16 comment="United States" list=SafeCountries
add address=156.136.0.0-156.146.255.255 comment="United States" list=
SafeCountries
add address=156.151.0.0-156.155.255.255 comment="United States" list=
SafeCountries
add address=157.21.0.0-157.22.255.255 comment="United States" list=
SafeCountries
add address=157.30.0.0/15 comment="United States" list=SafeCountries
add address=157.52.32.0-157.54.255.255 comment="United States" list=
SafeCountries
add address=157.55.16.0-157.55.39.255 comment="United States" list=
SafeCountries
add address=157.55.48.0-157.55.127.255 comment="United States" list=
SafeCountries
add address=157.55.128.32-157.55.204.127 comment="United States" list=
SafeCountries
add address=157.55.205.0-157.55.223.255 comment="United States" list=
SafeCountries
add address=157.55.240.0-157.56.99.255 comment="United States" list=
SafeCountries
add address=157.56.100.32-157.56.111.255 comment="United States" list=
SafeCountries
add address=157.56.128.0-157.56.156.255 comment="United States" list=
SafeCountries
add address=157.56.159.0-157.56.191.255 comment="United States" list=
SafeCountries
add address=157.56.200.0-157.56.247.255 comment="United States" list=
SafeCountries
add address=157.57.0.0-157.60.163.255 comment="United States" list=
SafeCountries
add address=157.60.165.0-157.60.169.255 comment="United States" list=
SafeCountries
add address=157.60.171.0-157.60.175.255 comment="United States" list=
SafeCountries
add address=157.60.176.128-157.60.183.255 comment="United States" list=
SafeCountries
add address=157.60.186.0-157.60.255.255 comment="United States" list=
SafeCountries
add address=157.62.0.0/16 comment="United States" list=SafeCountries
add address=157.87.0.0/16 comment="United States" list=SafeCountries
add address=157.89.0.0-157.91.255.255 comment="United States" list=
SafeCountries
add address=157.93.0.0/16 comment="United States" list=SafeCountries
add address=157.95.0.0/16 comment="United States" list=SafeCountries
add address=157.98.0.0/16 comment="United States" list=SafeCountries
add address=157.120.192.0/19 comment="United States" list=SafeCountries
add address=157.121.0.0/16 comment="United States" list=SafeCountries
add address=157.123.0.0/16 comment="United States" list=SafeCountries
add address=157.126.0.0/15 comment="United States" list=SafeCountries
add address=157.130.0.0-157.133.47.255 comment="United States" list=
SafeCountries
add address=157.133.56.0-157.135.255.255 comment="United States" list=
SafeCountries
add address=157.137.0.0/16 comment="United States" list=SafeCountries
add address=157.139.0.0/16 comment="United States" list=SafeCountries
add address=157.141.0.0-157.143.255.255 comment="United States" list=
SafeCountries
add address=157.145.0.0-157.147.255.255 comment="United States" list=
SafeCountries
add address=157.149.0.0-157.154.255.255 comment="United States" list=
SafeCountries
add address=157.160.0.0/16 comment="United States" list=SafeCountries
add address=157.165.0.0-157.166.215.255 comment="United States" list=
SafeCountries
add address=157.166.217.0-157.166.255.255 comment="United States" list=
SafeCountries
add address=157.170.0.0/16 comment="United States" list=SafeCountries
add address=157.174.0.0-157.176.255.255 comment="United States" list=
SafeCountries
add address=157.178.0.0/16 comment="United States" list=SafeCountries
add address=157.182.0.0-157.185.255.255 comment="United States" list=
SafeCountries
add address=157.187.0.0-157.189.255.255 comment="United States" list=
SafeCountries
add address=157.191.0.0-157.191.26.9 comment="United States" list=
SafeCountries
add address=157.191.26.11-157.191.26.69 comment="United States" list=
SafeCountries
add address=157.191.26.71-157.191.26.73 comment="United States" list=
SafeCountries
add address=157.191.26.75-157.191.26.77 comment="United States" list=
SafeCountries
add address=157.191.26.79-157.191.26.133 comment="United States" list=
SafeCountries
add address=157.191.26.135-157.191.26.137 comment="United States" list=
SafeCountries
add address=157.191.26.139-157.191.27.9 comment="United States" list=
SafeCountries
add address=157.191.27.11-157.191.27.69 comment="United States" list=
SafeCountries
add address=157.191.27.71-157.191.27.73 comment="United States" list=
SafeCountries
add address=157.191.27.75-157.191.27.77 comment="United States" list=
SafeCountries
add address=157.191.27.79-157.191.27.133 comment="United States" list=
SafeCountries
add address=157.191.27.135-157.191.27.137 comment="United States" list=
SafeCountries
add address=157.191.27.139-157.191.44.9 comment="United States" list=
SafeCountries
add address=157.191.44.11-157.191.44.69 comment="United States" list=
SafeCountries
add address=157.191.44.71-157.191.44.73 comment="United States" list=
SafeCountries
add address=157.191.44.75-157.191.44.77 comment="United States" list=
SafeCountries
add address=157.191.44.79-157.191.44.133 comment="United States" list=
SafeCountries
add address=157.191.44.135-157.191.44.137 comment="United States" list=
SafeCountries
add address=157.191.44.139-157.191.45.9 comment="United States" list=
SafeCountries
add address=157.191.45.11-157.191.45.69 comment="United States" list=
SafeCountries
add address=157.191.45.71-157.191.45.73 comment="United States" list=
SafeCountries
add address=157.191.45.75-157.191.45.77 comment="United States" list=
SafeCountries
add address=157.191.45.79-157.191.45.133 comment="United States" list=
SafeCountries
add address=157.191.45.135-157.191.45.137 comment="United States" list=
SafeCountries
add address=157.191.45.139-157.191.81.9 comment="United States" list=
SafeCountries
add address=157.191.81.11-157.191.81.69 comment="United States" list=
SafeCountries
add address=157.191.81.71-157.191.81.73 comment="United States" list=
SafeCountries
add address=157.191.81.75-157.191.81.77 comment="United States" list=
SafeCountries
add address=157.191.81.79-157.191.81.133 comment="United States" list=
SafeCountries
add address=157.191.81.135-157.191.81.137 comment="United States" list=
SafeCountries
add address=157.191.81.139-157.191.97.9 comment="United States" list=
SafeCountries
add address=157.191.97.11-157.191.97.69 comment="United States" list=
SafeCountries
add address=157.191.97.71-157.191.97.73 comment="United States" list=
SafeCountries
add address=157.191.97.75-157.191.97.77 comment="United States" list=
SafeCountries
add address=157.191.97.79-157.191.97.133 comment="United States" list=
SafeCountries
add address=157.191.97.135-157.191.97.137 comment="United States" list=
SafeCountries
add address=157.191.97.139-157.191.255.255 comment="United States" list=
SafeCountries
add address=157.194.0.0-157.196.255.255 comment="United States" list=
SafeCountries
add address=157.198.0.0/15 comment="United States" list=SafeCountries
add address=157.201.0.0-157.202.255.255 comment="United States" list=
SafeCountries
add address=157.204.0.0/16 comment="United States" list=SafeCountries
add address=157.206.0.0-157.207.64.255 comment="United States" list=
SafeCountries
add address=157.207.66.0-157.208.127.255 comment="United States" list=
SafeCountries
add address=157.208.129.0-157.210.255.255 comment="United States" list=
SafeCountries
add address=157.212.0.0-157.226.255.255 comment="United States" list=
SafeCountries
add address=157.229.0.0-157.234.215.255 comment="United States" list=
SafeCountries
add address=157.234.217.0-157.235.255.255 comment="United States" list=
SafeCountries
add address=157.238.0.0-157.242.255.255 comment="United States" list=
SafeCountries
add address=157.245.0.0-157.246.255.255 comment="United States" list=
SafeCountries
add address=157.248.0.0/16 comment="United States" list=SafeCountries
add address=157.250.0.0/18 comment="United States" list=SafeCountries
add address=157.251.0.0-157.252.255.255 comment="United States" list=
SafeCountries
add address=157.254.0.0/16 comment="United States" list=SafeCountries
add address=158.0.0.0-158.34.239.255 comment="United States" list=
SafeCountries
add address=158.34.241.0-158.35.255.255 comment="United States" list=
SafeCountries
add address=158.48.0.0/16 comment="United States" list=SafeCountries
add address=158.50.64.0/20 comment="United States" list=SafeCountries
add address=158.52.0.0/15 comment="United States" list=SafeCountries
add address=158.55.0.0-158.57.255.255 comment="United States" list=
SafeCountries
add address=158.59.0.0-158.63.255.255 comment="United States" list=
SafeCountries
add address=158.65.0.0/16 comment="United States" list=SafeCountries
add address=158.68.0.0-158.69.3.255 comment="United States" list=
SafeCountries
add address=158.69.6.0-158.69.9.255 comment="United States" list=
SafeCountries
add address=158.69.10.128-158.69.13.255 comment="United States" list=
SafeCountries
add address=158.69.14.128-158.69.15.255 comment="United States" list=
SafeCountries
add address=158.69.16.80/28 comment="United States" list=SafeCountries
add address=158.69.17.0-158.69.159.255 comment="United States" list=
SafeCountries
add address=158.69.161.0-158.69.199.200 comment="United States" list=
SafeCountries
add address=158.69.199.202-158.74.255.255 comment="United States" list=
SafeCountries
add address=158.76.0.0-158.85.63.255 comment="United States" list=
SafeCountries
add address=158.85.128.0-158.88.255.255 comment="United States" list=
SafeCountries
add address=158.91.0.0/16 comment="United States" list=SafeCountries
add address=158.93.0.0/16 comment="United States" list=SafeCountries
add address=158.95.0.0-158.96.255.255 comment="United States" list=
SafeCountries
add address=158.98.0.0/16 comment="United States" list=SafeCountries
add address=158.100.0.0/15 comment="United States" list=SafeCountries
add address=158.103.0.0-158.104.255.255 comment="United States" list=
SafeCountries
add address=158.106.0.0/18 comment="United States" list=SafeCountries
add address=158.106.128.0-158.107.255.255 comment="United States" list=
SafeCountries
add address=158.111.0.0/16 comment="United States" list=SafeCountries
add address=158.113.0.0-158.116.224.0 comment="United States" list=
SafeCountries
add address=158.116.224.2-158.118.255.255 comment="United States" list=
SafeCountries
add address=158.120.0.0/14 comment="United States" list=SafeCountries
add address=158.130.0.0/16 comment="United States" list=SafeCountries
add address=158.134.0.0-158.140.255.255 comment="United States" list=
SafeCountries
add address=158.142.0.0/16 comment="United States" list=SafeCountries
add address=158.145.0.0-158.147.255.255 comment="United States" list=
SafeCountries
add address=158.151.0.0/16 comment="United States" list=SafeCountries
add address=158.153.0.0-158.155.255.255 comment="United States" list=
SafeCountries
add address=158.157.0.0-158.159.255.255 comment="United States" list=
SafeCountries
add address=158.164.0.0/15 comment="United States" list=SafeCountries
add address=158.171.0.0/16 comment="United States" list=SafeCountries
add address=158.181.58.96-158.181.59.31 comment="United States" list=
SafeCountries
add address=158.181.59.128-158.181.63.255 comment="United States" list=
SafeCountries
add address=158.183.0.0-158.189.255.255 comment="United States" list=
SafeCountries
add address=158.219.0.0/16 comment="United States" list=SafeCountries
add address=158.221.0.0-158.222.39.255 comment="United States" list=
SafeCountries
add address=158.222.42.0-158.222.103.255 comment="United States" list=
SafeCountries
add address=158.222.112.0-158.222.255.255 comment="United States" list=
SafeCountries
add address=158.224.0.0/16 comment="United States" list=SafeCountries
add address=158.228.0.0-158.228.161.255 comment="United States" list=
SafeCountries
add address=158.228.163.0-158.228.244.255 comment="United States" list=
SafeCountries
add address=158.228.246.0-158.229.255.255 comment="United States" list=
SafeCountries
add address=158.235.0.0-158.247.255.255 comment="United States" list=
SafeCountries
add address=158.252.0.0-158.254.255.255 comment="United States" list=
SafeCountries
add address=158.255.209.112 comment="United States" list=SafeCountries
add address=158.255.209.113 comment="Costa Rica" list=SafeCountries
add address=158.255.213.0/24 comment="United States" list=SafeCountries
add address=159.1.0.0-159.5.255.255 comment="United States" list=
SafeCountries
add address=159.9.0.0-159.11.255.255 comment="United States" list=
SafeCountries
add address=159.14.0.0/16 comment="United States" list=SafeCountries
add address=159.17.0.0/16 comment="United States" list=SafeCountries
add address=159.19.0.0/16 comment="United States" list=SafeCountries
add address=159.21.0.0/18 comment="United States" list=SafeCountries
add address=159.21.68.0-159.21.130.255 comment="United States" list=
SafeCountries
add address=159.21.132.0-159.21.141.255 comment="United States" list=
SafeCountries
add address=159.21.148.0-159.21.255.255 comment="United States" list=
SafeCountries
add address=159.24.0.0/16 comment="United States" list=SafeCountries
add address=159.26.0.0-159.28.255.255 comment="United States" list=
SafeCountries
add address=159.35.0.0-159.37.255.255 comment="United States" list=
SafeCountries
add address=159.39.0.0-159.45.255.255 comment="United States" list=
SafeCountries
add address=159.47.0.0-159.49.255.255 comment="United States" list=
SafeCountries
add address=159.53.0.0-159.54.255.255 comment="United States" list=
SafeCountries
add address=159.56.0.0/15 comment="United States" list=SafeCountries
add address=159.59.0.0/16 comment="United States" list=SafeCountries
add address=159.61.0.0-159.63.20.247 comment="United States" list=
SafeCountries
add address=159.63.20.252-159.63.21.85 comment="United States" list=
SafeCountries
add address=159.63.21.87-159.63.49.171 comment="United States" list=
SafeCountries
add address=159.63.49.176-159.63.167.255 comment="United States" list=
SafeCountries
add address=159.63.172.0-159.71.255.255 comment="United States" list=
SafeCountries
add address=159.74.0.0-159.79.255.255 comment="United States" list=
SafeCountries
add address=159.82.0.0/15 comment="United States" list=SafeCountries
add address=159.85.0.0/16 comment="United States" list=SafeCountries
add address=159.87.0.0-159.88.255.255 comment="United States" list=
SafeCountries
add address=159.91.0.0/16 comment="United States" list=SafeCountries
add address=159.94.0.0/16 comment="United States" list=SafeCountries
add address=159.96.0.0/14 comment="United States" list=SafeCountries
add address=159.100.176.0-159.100.181.6 comment="United States" list=
SafeCountries
add address=159.100.181.8-159.100.239.255 comment="United States" list=
SafeCountries
add address=159.101.208.0/21 comment="United States" list=SafeCountries
add address=159.102.0.0/16 comment="United States" list=SafeCountries
add address=159.104.0.0-159.106.255.255 comment="United States" list=
SafeCountries
add address=159.108.0.0/16 comment="United States" list=SafeCountries
add address=159.110.0.0/16 comment="United States" list=SafeCountries
add address=159.112.0.0/15 comment="United States" list=SafeCountries
add address=159.115.0.0-159.116.255.255 comment="United States" list=
SafeCountries
add address=159.118.0.0-159.122.5.223 comment="United States" list=
SafeCountries
add address=159.122.6.0-159.122.15.127 comment="United States" list=
SafeCountries
add address=159.122.15.136-159.122.22.159 comment="United States" list=
SafeCountries
add address=159.122.22.168-159.122.28.159 comment="United States" list=
SafeCountries
add address=159.122.28.192-159.122.63.255 comment="United States" list=
SafeCountries
add address=159.122.128.0-159.122.129.201 comment="United States" list=
SafeCountries
add address=159.122.129.203 comment="United States" list=SafeCountries
add address=159.122.129.205-159.122.130.255 comment="United States" list=
SafeCountries
add address=159.122.132.0-159.122.133.191 comment="United States" list=
SafeCountries
add address=159.122.134.0-159.122.217.127 comment="United States" list=
SafeCountries
add address=159.122.217.160-159.122.224.15 comment="United States" list=
SafeCountries
add address=159.122.224.32-159.127.255.255 comment="United States" list=
SafeCountries
add address=159.129.0.0/16 comment="United States" list=SafeCountries
add address=159.131.0.0-159.133.255.255 comment="United States" list=
SafeCountries
add address=159.135.0.0-159.143.255.255 comment="United States" list=
SafeCountries
add address=159.145.0.0/16 comment="United States" list=SafeCountries
add address=159.150.0.0/16 comment="United States" list=SafeCountries
add address=159.153.0.0-159.153.119.255 comment="United States" list=
SafeCountries
add address=159.153.124.0-159.153.135.255 comment="United States" list=
SafeCountries
add address=159.153.137.0/24 comment="United States" list=SafeCountries
add address=159.153.139.0-159.153.147.255 comment="United States" list=
SafeCountries
add address=159.153.151.0-159.153.156.59 comment="United States" list=
SafeCountries
add address=159.153.156.61-159.153.171.255 comment="United States" list=
SafeCountries
add address=159.153.176.0/22 comment="United States" list=SafeCountries
add address=159.153.182.0/23 comment="United States" list=SafeCountries
add address=159.153.188.0-159.153.210.255 comment="United States" list=
SafeCountries
add address=159.153.212.0/22 comment="United States" list=SafeCountries
add address=159.153.219.0-159.153.255.255 comment="United States" list=
SafeCountries
add address=159.155.0.0/16 comment="United States" list=SafeCountries
add address=159.157.0.0-159.158.255.255 comment="United States" list=
SafeCountries
add address=159.161.0.0/16 comment="United States" list=SafeCountries
add address=159.163.0.0-159.166.255.255 comment="United States" list=
SafeCountries
add address=159.169.0.0/16 comment="United States" list=SafeCountries
add address=159.172.0.0/21 comment="United States" list=SafeCountries
add address=159.172.9.0-159.172.51.255 comment="United States" list=
SafeCountries
add address=159.172.53.0-159.172.63.255 comment="United States" list=
SafeCountries
add address=159.172.65.0-159.172.103.255 comment="United States" list=
SafeCountries
add address=159.172.112.0-159.172.139.255 comment="United States" list=
SafeCountries
add address=159.172.141.0/24 comment="United States" list=SafeCountries
add address=159.172.145.0-159.172.171.255 comment="United States" list=
SafeCountries
add address=159.172.173.0-159.172.203.255 comment="United States" list=
SafeCountries
add address=159.172.206.0-159.172.240.255 comment="United States" list=
SafeCountries
add address=159.172.243.0-159.172.255.255 comment="United States" list=
SafeCountries
add address=159.174.0.0/16 comment="United States" list=SafeCountries
add address=159.176.0.0/16 comment="United States" list=SafeCountries
add address=159.178.0.0/16 comment="United States" list=SafeCountries
add address=159.180.128.0/19 comment="United States" list=SafeCountries
add address=159.180.192.0/19 comment="United States" list=SafeCountries
add address=159.181.0.0-159.182.40.255 comment="United States" list=
SafeCountries
add address=159.182.43.0-159.182.71.255 comment="United States" list=
SafeCountries
add address=159.182.80.0-159.182.119.255 comment="United States" list=
SafeCountries
add address=159.182.128.0-159.189.255.255 comment="United States" list=
SafeCountries
add address=159.191.0.0/16 comment="United States" list=SafeCountries
add address=159.198.0.0/15 comment="United States" list=SafeCountries
add address=159.201.0.0-159.202.255.255 comment="United States" list=
SafeCountries
add address=159.203.64.0-159.204.255.255 comment="United States" list=
SafeCountries
add address=159.209.0.0/16 comment="United States" list=SafeCountries
add address=159.212.0.0/16 comment="United States" list=SafeCountries
add address=159.214.0.0-159.215.129.255 comment="United States" list=
SafeCountries
add address=159.215.131.0-159.215.247.255 comment="United States" list=
SafeCountries
add address=159.218.0.0/16 comment="United States" list=SafeCountries
add address=159.220.0.0-159.220.51.255 comment="United States" list=
SafeCountries
add address=159.220.53.0-159.220.73.255 comment="United States" list=
SafeCountries
add address=159.220.77.0-159.221.183.255 comment="United States" list=
SafeCountries
add address=159.221.185.0-159.221.243.255 comment="United States" list=
SafeCountries
add address=159.221.245.0-159.223.255.255 comment="United States" list=
SafeCountries
add address=159.225.0.0/16 comment="United States" list=SafeCountries
add address=159.227.0.0/16 comment="United States" list=SafeCountries
add address=159.229.0.0-159.230.255.255 comment="United States" list=
SafeCountries
add address=159.233.0.0-159.235.255.255 comment="United States" list=
SafeCountries
add address=159.238.0.0/16 comment="United States" list=SafeCountries
add address=159.240.0.0/16 comment="United States" list=SafeCountries
add address=159.242.0.0/15 comment="United States" list=SafeCountries
add address=159.245.32.0/20 comment="United States" list=SafeCountries
add address=159.245.64.0/22 comment="United States" list=SafeCountries
add address=159.246.0.0/15 comment="United States" list=SafeCountries
add address=159.249.0.0-159.252.255.255 comment="United States" list=
SafeCountries
add address=160.0.0.0/14 comment="United States" list=SafeCountries
add address=160.7.0.0/16 comment="United States" list=SafeCountries
add address=160.10.0.0/16 comment="United States" list=SafeCountries
add address=160.31.0.0-160.37.255.255 comment="United States" list=
SafeCountries
add address=160.39.0.0/16 comment="United States" list=SafeCountries
add address=160.41.0.0-160.43.255.255 comment="United States" list=
SafeCountries
add address=160.65.0.0/16 comment="United States" list=SafeCountries
add address=160.69.0.0/16 comment="United States" list=SafeCountries
add address=160.73.0.0/16 comment="United States" list=SafeCountries
add address=160.76.0.0/16 comment="United States" list=SafeCountries
add address=160.79.0.0/20 comment="United States" list=SafeCountries
add address=160.79.18.0-160.79.37.255 comment="United States" list=
SafeCountries
add address=160.79.39.0-160.79.53.255 comment="United States" list=
SafeCountries
add address=160.79.56.0-160.79.108.255 comment="United States" list=
SafeCountries
add address=160.79.110.0-160.79.133.255 comment="United States" list=
SafeCountries
add address=160.79.136.0-160.79.141.255 comment="United States" list=
SafeCountries
add address=160.79.144.0-160.79.213.255 comment="United States" list=
SafeCountries
add address=160.79.216.0-160.79.239.255 comment="United States" list=
SafeCountries
add address=160.79.242.0/24 comment="United States" list=SafeCountries
add address=160.79.246.0-160.79.255.255 comment="United States" list=
SafeCountries
add address=160.81.0.0-160.83.29.255 comment="United States" list=
SafeCountries
add address=160.83.31.0-160.83.33.255 comment="United States" list=
SafeCountries
add address=160.83.37.0-160.83.41.255 comment="United States" list=
SafeCountries
add address=160.83.43.0-160.83.95.255 comment="United States" list=
SafeCountries
add address=160.83.98.0-160.83.159.255 comment="United States" list=
SafeCountries
add address=160.83.161.0-160.84.255.255 comment="United States" list=
SafeCountries
add address=160.86.0.0-160.91.255.255 comment="United States" list=
SafeCountries
add address=160.93.0.0-160.95.255.255 comment="United States" list=
SafeCountries
add address=160.101.0.0-160.102.255.255 comment="United States" list=
SafeCountries
add address=160.107.0.0-160.112.255.255 comment="United States" list=
SafeCountries
add address=160.125.0.0-160.151.255.255 comment="United States" list=
SafeCountries
add address=160.153.0.0/16 comment="United States" list=SafeCountries
add address=160.202.64.0/18 comment="United States" list=SafeCountries
add address=160.202.136.0/24 comment="United States" list=SafeCountries
add address=160.202.166.0/23 comment="United States" list=SafeCountries
add address=160.205.0.0/16 comment="United States" list=SafeCountries
add address=160.206.136.0/21 comment="United States" list=SafeCountries
add address=160.206.148.0-160.206.153.255 comment="United States" list=
SafeCountries
add address=160.207.0.0-160.209.255.255 comment="United States" list=
SafeCountries
add address=160.212.0.0/16 comment="United States" list=SafeCountries
add address=160.227.0.0/16 comment="United States" list=SafeCountries
add address=160.229.0.0-160.232.255.255 comment="United States" list=
SafeCountries
add address=160.253.0.0-160.254.255.255 comment="United States" list=
SafeCountries
add address=161.0.3.0/28 comment="Costa Rica" list=SafeCountries
add address=161.0.16.176/29 comment="United States" list=SafeCountries
add address=161.1.0.0/16 comment="United States" list=SafeCountries
add address=161.6.0.0/15 comment="United States" list=SafeCountries
add address=161.8.128.0-161.8.253.255 comment="United States" list=
SafeCountries
add address=161.11.0.0/16 comment="United States" list=SafeCountries
add address=161.13.0.0-161.16.255.255 comment="United States" list=
SafeCountries
add address=161.21.0.0/16 comment="United States" list=SafeCountries
add address=161.26.0.0/16 comment="United States" list=SafeCountries
add address=161.28.0.0/16 comment="United States" list=SafeCountries
add address=161.30.28.0/23 comment="United States" list=SafeCountries
add address=161.30.114.0/24 comment="United States" list=SafeCountries
add address=161.31.0.0-161.36.255.255 comment="United States" list=
SafeCountries
add address=161.38.0.0-161.40.255.255 comment="United States" list=
SafeCountries
add address=161.44.0.0/14 comment="United States" list=SafeCountries
add address=161.49.0.0/16 comment="United States" list=SafeCountries
add address=161.51.0.0-161.51.42.255 comment="United States" list=
SafeCountries
add address=161.51.44.0-161.51.255.255 comment="United States" list=
SafeCountries
add address=161.55.0.0/16 comment="United States" list=SafeCountries
add address=161.57.0.0-161.58.255.255 comment="United States" list=
SafeCountries
add address=161.60.0.0/15 comment="United States" list=SafeCountries
add address=161.63.0.0/16 comment="United States" list=SafeCountries
add address=161.68.0.0-161.68.30.255 comment="United States" list=
SafeCountries
add address=161.68.32.0-161.69.134.255 comment="United States" list=
SafeCountries
add address=161.69.136.0-161.69.147.255 comment="United States" list=
SafeCountries
add address=161.69.152.0-161.69.219.255 comment="United States" list=
SafeCountries
add address=161.69.224.0-161.70.255.255 comment="United States" list=
SafeCountries
add address=161.77.0.0/16 comment="United States" list=SafeCountries
add address=161.80.0.0-161.82.255.255 comment="United States" list=
SafeCountries
add address=161.84.224.0/19 comment="United States" list=SafeCountries
add address=161.88.240.0/20 comment="United States" list=SafeCountries
add address=161.97.0.0-161.103.255.255 comment="United States" list=
SafeCountries
add address=161.107.0.0-161.109.255.255 comment="United States" list=
SafeCountries
add address=161.113.0.0-161.114.125.255 comment="United States" list=
SafeCountries
add address=161.114.127.0-161.115.255.255 comment="United States" list=
SafeCountries
add address=161.119.0.0-161.121.255.255 comment="United States" list=
SafeCountries
add address=161.123.193.0/24 comment="United States" list=SafeCountries
add address=161.123.195.0/24 comment="United States" list=SafeCountries
add address=161.123.197.0/24 comment="United States" list=SafeCountries
add address=161.123.199.0/24 comment="United States" list=SafeCountries
add address=161.123.201.0/24 comment="United States" list=SafeCountries
add address=161.123.203.0/24 comment="United States" list=SafeCountries
add address=161.123.205.0/24 comment="United States" list=SafeCountries
add address=161.123.207.0/24 comment="United States" list=SafeCountries
add address=161.123.209.0/24 comment="United States" list=SafeCountries
add address=161.123.215.0/24 comment="United States" list=SafeCountries
add address=161.123.217.0/24 comment="United States" list=SafeCountries
add address=161.124.0.0/15 comment="United States" list=SafeCountries
add address=161.127.0.0-161.130.255.255 comment="United States" list=
SafeCountries
add address=161.133.0.0-161.137.255.255 comment="United States" list=
SafeCountries
add address=161.144.0.0/15 comment="United States" list=SafeCountries
add address=161.149.0.0-161.151.255.255 comment="United States" list=
SafeCountries
add address=161.153.0.0-161.157.255.255 comment="United States" list=
SafeCountries
add address=161.159.0.0-161.162.64.255 comment="United States" list=
SafeCountries
add address=161.162.66.0-161.183.255.255 comment="United States" list=
SafeCountries
add address=161.185.0.0-161.186.255.255 comment="United States" list=
SafeCountries
add address=161.188.0.0/15 comment="United States" list=SafeCountries
add address=161.191.0.0-161.195.255.255 comment="United States" list=
SafeCountries
add address=161.197.0.0-161.199.255.255 comment="United States" list=
SafeCountries
add address=161.201.0.0-161.202.2.239 comment="United States" list=
SafeCountries
add address=161.202.3.0-161.202.3.79 comment="United States" list=
SafeCountries
add address=161.202.3.96-161.202.12.7 comment="United States" list=
SafeCountries
add address=161.202.12.9-161.202.63.255 comment="United States" list=
SafeCountries
add address=161.202.128.0-161.202.132.156 comment="United States" list=
SafeCountries
add address=161.202.132.158-161.202.144.201 comment="United States" list=
SafeCountries
add address=161.202.144.203-161.202.144.248 comment="United States" list=
SafeCountries
add address=161.202.144.250-161.206.255.255 comment="United States" list=
SafeCountries
add address=161.208.0.0/14 comment="United States" list=SafeCountries
add address=161.213.0.0-161.215.255.255 comment="United States" list=
SafeCountries
add address=161.217.0.0-161.228.255.255 comment="United States" list=
SafeCountries
add address=161.230.0.0-161.233.255.255 comment="United States" list=
SafeCountries
add address=161.235.0.0-161.237.255.255 comment="United States" list=
SafeCountries
add address=161.239.0.0-161.245.255.255 comment="United States" list=
SafeCountries
add address=161.247.0.0-161.251.255.255 comment="United States" list=
SafeCountries
add address=161.253.0.0-161.254.255.255 comment="United States" list=
SafeCountries
add address=162.1.0.0-162.10.255.255 comment="United States" list=
SafeCountries
add address=162.12.0.0/16 comment="United States" list=SafeCountries
add address=162.14.0.0-162.18.142.255 comment="United States" list=
SafeCountries
add address=162.18.144.0-162.20.255.255 comment="United States" list=
SafeCountries
add address=162.22.0.0/16 comment="United States" list=SafeCountries
add address=162.24.0.0/16 comment="United States" list=SafeCountries
add address=162.27.0.0-162.37.255.255 comment="United States" list=
SafeCountries
add address=162.39.0.0-162.44.223.255 comment="United States" list=
SafeCountries
add address=162.44.225.0-162.52.255.255 comment="United States" list=
SafeCountries
add address=162.54.0.0/15 comment="United States" list=SafeCountries
add address=162.57.0.0-162.69.255.255 comment="United States" list=
SafeCountries
add address=162.71.0.0-162.72.255.255 comment="United States" list=
SafeCountries
add address=162.74.0.0-162.84.255.255 comment="United States" list=
SafeCountries
add address=162.87.0.0-162.90.98.255 comment="United States" list=
SafeCountries
add address=162.90.100.0-162.97.8.255 comment="United States" list=
SafeCountries
add address=162.97.10.0-162.97.148.75 comment="United States" list=
SafeCountries
add address=162.97.148.80-162.97.148.117 comment="United States" list=
SafeCountries
add address=162.97.148.119-162.97.148.141 comment="United States" list=
SafeCountries
add address=162.97.148.143-162.104.255.255 comment="United States" list=
SafeCountries
add address=162.107.0.0-162.111.255.255 comment="United States" list=
SafeCountries
add address=162.113.0.0-162.116.125.255 comment="United States" list=
SafeCountries
add address=162.116.127.0-162.121.255.255 comment="United States" list=
SafeCountries
add address=162.123.0.0-162.138.255.255 comment="United States" list=
SafeCountries
add address=162.140.0.0-162.144.255.255 comment="United States" list=
SafeCountries
add address=162.148.0.0-162.155.255.255 comment="United States" list=
SafeCountries
add address=162.158.0.0/24 comment="United States" list=SafeCountries
add address=162.158.4.0/24 comment="United States" list=SafeCountries
add address=162.158.8.0/24 comment="United States" list=SafeCountries
add address=162.158.12.0/24 comment="United States" list=SafeCountries
add address=162.158.16.0/24 comment="United States" list=SafeCountries
add address=162.158.20.0/24 comment="United States" list=SafeCountries
add address=162.158.28.0/24 comment="United States" list=SafeCountries
add address=162.158.32.0-162.158.34.255 comment="United States" list=
SafeCountries
add address=162.158.36.0/24 comment="United States" list=SafeCountries
add address=162.158.40.0/24 comment="United States" list=SafeCountries
add address=162.158.52.0/24 comment="United States" list=SafeCountries
add address=162.158.56.0-162.158.79.255 comment="United States" list=
SafeCountries
add address=162.158.96.0/24 comment="United States" list=SafeCountries
add address=162.158.100.0/24 comment="United States" list=SafeCountries
add address=162.158.104.0/22 comment="United States" list=SafeCountries
add address=162.158.110.0/23 comment="United States" list=SafeCountries
add address=162.158.120.0-162.158.124.255 comment="United States" list=
SafeCountries
add address=162.158.127.0-162.158.132.255 comment="United States" list=
SafeCountries
add address=162.158.140.0-162.158.144.255 comment="United States" list=
SafeCountries
add address=162.158.148.0/24 comment="United States" list=SafeCountries
add address=162.158.152.0/21 comment="United States" list=SafeCountries
add address=162.158.161.0-162.158.162.255 comment="United States" list=
SafeCountries
add address=162.158.168.0-162.158.191.255 comment="United States" list=
SafeCountries
add address=162.158.193.0-162.158.195.255 comment="United States" list=
SafeCountries
add address=162.158.200.0-162.158.239.255 comment="United States" list=
SafeCountries
add address=162.158.244.0/22 comment="United States" list=SafeCountries
add address=162.158.252.0-162.208.11.255 comment="United States" list=
SafeCountries
add address=162.208.16.0-162.208.35.255 comment="United States" list=
SafeCountries
add address=162.208.40.0-162.208.59.255 comment="United States" list=
SafeCountries
add address=162.208.64.0/20 comment="United States" list=SafeCountries
add address=162.208.84.0/22 comment="United States" list=SafeCountries
add address=162.208.92.0-162.208.99.255 comment="United States" list=
SafeCountries
add address=162.208.104.0-162.208.127.255 comment="United States" list=
SafeCountries
add address=162.209.0.0-162.209.239.255 comment="United States" list=
SafeCountries
add address=162.210.0.0/21 comment="United States" list=SafeCountries
add address=162.210.12.0-162.210.31.255 comment="United States" list=
SafeCountries
add address=162.210.36.0/22 comment="United States" list=SafeCountries
add address=162.210.44.0-162.210.55.255 comment="United States" list=
SafeCountries
add address=162.210.60.0-162.210.67.255 comment="United States" list=
SafeCountries
add address=162.210.72.0-162.210.155.255 comment="United States" list=
SafeCountries
add address=162.210.168.0-162.210.179.255 comment="United States" list=
SafeCountries
add address=162.210.184.0-162.210.223.255 comment="United States" list=
SafeCountries
add address=162.210.228.0-162.211.95.255 comment="United States" list=
SafeCountries
add address=162.211.104.0/21 comment="United States" list=SafeCountries
add address=162.211.120.0-162.211.135.255 comment="United States" list=
SafeCountries
add address=162.211.140.0-162.211.177.255 comment="United States" list=
SafeCountries
add address=162.211.180.0/22 comment="United States" list=SafeCountries
add address=162.211.188.0/22 comment="United States" list=SafeCountries
add address=162.211.200.0/21 comment="United States" list=SafeCountries
add address=162.211.216.0-162.211.227.255 comment="United States" list=
SafeCountries
add address=162.211.240.0/21 comment="United States" list=SafeCountries
add address=162.211.252.0-162.212.7.255 comment="United States" list=
SafeCountries
add address=162.212.16.0/22 comment="United States" list=SafeCountries
add address=162.212.24.0-162.212.63.255 comment="United States" list=
SafeCountries
add address=162.212.72.0-162.212.99.255 comment="United States" list=
SafeCountries
add address=162.212.104.0/21 comment="United States" list=SafeCountries
add address=162.212.116.0-162.212.133.255 comment="United States" list=
SafeCountries
add address=162.212.135.0-162.212.159.255 comment="United States" list=
SafeCountries
add address=162.212.168.0-162.212.199.255 comment="United States" list=
SafeCountries
add address=162.212.212.0-162.212.231.255 comment="United States" list=
SafeCountries
add address=162.212.240.0-162.213.7.255 comment="United States" list=
SafeCountries
add address=162.213.12.0-162.213.103.255 comment="United States" list=
SafeCountries
add address=162.213.112.0-162.213.135.255 comment="United States" list=
SafeCountries
add address=162.213.140.0-162.213.155.255 comment="United States" list=
SafeCountries
add address=162.213.160.0/21 comment="United States" list=SafeCountries
add address=162.213.172.0-162.213.208.255 comment="United States" list=
SafeCountries
add address=162.213.209.64-162.216.83.255 comment="United States" list=
SafeCountries
add address=162.216.88.0-162.216.159.255 comment="United States" list=
SafeCountries
add address=162.216.168.0/21 comment="United States" list=SafeCountries
add address=162.216.180.0/22 comment="United States" list=SafeCountries
add address=162.216.192.0-162.217.23.255 comment="United States" list=
SafeCountries
add address=162.217.32.0-162.217.231.255 comment="United States" list=
SafeCountries
add address=162.217.244.0-162.218.23.255 comment="United States" list=
SafeCountries
add address=162.218.28.0/22 comment="United States" list=SafeCountries
add address=162.218.40.0-162.218.123.255 comment="United States" list=
SafeCountries
add address=162.218.128.0-162.218.175.255 comment="United States" list=
SafeCountries
add address=162.218.180.0-162.218.255.255 comment="United States" list=
SafeCountries
add address=162.219.16.0-162.219.47.255 comment="United States" list=
SafeCountries
add address=162.219.56.0-162.219.67.255 comment="United States" list=
SafeCountries
add address=162.219.72.0-162.219.159.255 comment="United States" list=
SafeCountries
add address=162.219.164.0-162.219.175.255 comment="United States" list=
SafeCountries
add address=162.219.180.0/22 comment="United States" list=SafeCountries
add address=162.219.192.0-162.219.231.255 comment="United States" list=
SafeCountries
add address=162.219.240.0-162.220.35.255 comment="United States" list=
SafeCountries
add address=162.220.40.0-162.220.95.255 comment="United States" list=
SafeCountries
add address=162.220.104.0-162.220.135.255 comment="United States" list=
SafeCountries
add address=162.220.144.0-162.220.175.255 comment="United States" list=
SafeCountries
add address=162.220.180.0-162.220.187.255 comment="United States" list=
SafeCountries
add address=162.220.192.0-162.220.203.255 comment="United States" list=
SafeCountries
add address=162.220.208.0-162.220.245.255 comment="United States" list=
SafeCountries
add address=162.220.247.0/24 comment="United States" list=SafeCountries
add address=162.220.252.0-162.221.11.255 comment="United States" list=
SafeCountries
add address=162.221.16.0-162.221.119.255 comment="United States" list=
SafeCountries
add address=162.221.128.0-162.221.199.255 comment="United States" list=
SafeCountries
add address=162.221.208.0/22 comment="United States" list=SafeCountries
add address=162.221.216.0-162.221.247.255 comment="United States" list=
SafeCountries
add address=162.222.0.0-162.222.55.255 comment="United States" list=
SafeCountries
add address=162.222.64.0/20 comment="United States" list=SafeCountries
add address=162.222.88.0-162.222.107.255 comment="United States" list=
SafeCountries
add address=162.222.112.0/21 comment="United States" list=SafeCountries
add address=162.222.128.0/21 comment="United States" list=SafeCountries
add address=162.222.140.0/22 comment="United States" list=SafeCountries
add address=162.222.148.0-162.222.155.255 comment="United States" list=
SafeCountries
add address=162.222.166.0-162.222.223.255 comment="United States" list=
SafeCountries
add address=162.222.225.0-162.222.255.255 comment="United States" list=
SafeCountries
add address=162.223.8.0-162.223.43.255 comment="United States" list=
SafeCountries
add address=162.223.52.0-162.223.99.255 comment="United States" list=
SafeCountries
add address=162.223.104.0-162.223.223.255 comment="United States" list=
SafeCountries
add address=162.223.232.0-162.243.189.255 comment="United States" list=
SafeCountries
add address=162.243.191.0-162.244.15.255 comment="United States" list=
SafeCountries
add address=162.244.32.0-162.244.43.255 comment="United States" list=
SafeCountries
add address=162.244.48.0-162.244.87.255 comment="United States" list=
SafeCountries
add address=162.244.92.0-162.244.119.255 comment="United States" list=
SafeCountries
add address=162.244.124.0-162.244.167.255 comment="United States" list=
SafeCountries
add address=162.244.172.0-162.244.207.255 comment="United States" list=
SafeCountries
add address=162.244.212.0-162.244.227.255 comment="United States" list=
SafeCountries
add address=162.244.232.0-162.244.247.255 comment="United States" list=
SafeCountries
add address=162.244.252.0-162.245.55.255 comment="United States" list=
SafeCountries
add address=162.245.60.0-162.245.75.255 comment="United States" list=
SafeCountries
add address=162.245.80.0-162.245.143.255 comment="United States" list=
SafeCountries
add address=162.245.148.0/22 comment="United States" list=SafeCountries
add address=162.245.156.0-162.245.207.255 comment="United States" list=
SafeCountries
add address=162.245.216.0-162.245.239.255 comment="United States" list=
SafeCountries
add address=162.246.4.0/22 comment="United States" list=SafeCountries
add address=162.246.16.0-162.246.51.255 comment="United States" list=
SafeCountries
add address=162.246.56.0-162.246.103.255 comment="United States" list=
SafeCountries
add address=162.246.112.0/20 comment="United States" list=SafeCountries
add address=162.246.132.0-162.246.155.255 comment="United States" list=
SafeCountries
add address=162.246.160.0-162.246.171.255 comment="United States" list=
SafeCountries
add address=162.246.176.0/21 comment="United States" list=SafeCountries
add address=162.246.185.0-162.247.11.255 comment="United States" list=
SafeCountries
add address=162.247.32.0/22 comment="United States" list=SafeCountries
add address=162.247.41.0/24 comment="United States" list=SafeCountries
add address=162.247.44.0-162.247.46.255 comment="United States" list=
SafeCountries
add address=162.247.48.0-162.247.91.255 comment="United States" list=
SafeCountries
add address=162.247.104.0/21 comment="United States" list=SafeCountries
add address=162.247.128.0-162.247.167.255 comment="United States" list=
SafeCountries
add address=162.247.172.0-162.247.218.255 comment="United States" list=
SafeCountries
add address=162.247.232.0-162.248.7.255 comment="United States" list=
SafeCountries
add address=162.248.12.0-162.248.31.255 comment="United States" list=
SafeCountries
add address=162.248.40.0/22 comment="United States" list=SafeCountries
add address=162.248.48.0-162.248.119.255 comment="United States" list=
SafeCountries
add address=162.248.128.0-162.248.139.255 comment="United States" list=
SafeCountries
add address=162.248.144.0/21 comment="United States" list=SafeCountries
add address=162.248.172.0/22 comment="United States" list=SafeCountries
add address=162.248.184.0-162.248.219.255 comment="United States" list=
SafeCountries
add address=162.248.222.0-162.249.7.255 comment="United States" list=
SafeCountries
add address=162.249.12.0-162.249.39.255 comment="United States" list=
SafeCountries
add address=162.249.44.0-162.249.87.255 comment="United States" list=
SafeCountries
add address=162.249.96.0/19 comment="United States" list=SafeCountries
add address=162.249.136.0-162.249.159.255 comment="United States" list=
SafeCountries
add address=162.249.164.0-162.249.235.255 comment="United States" list=
SafeCountries
add address=162.249.240.0-162.250.11.255 comment="United States" list=
SafeCountries
add address=162.250.16.0-162.250.43.255 comment="United States" list=
SafeCountries
add address=162.250.48.0-162.250.145.255 comment="United States" list=
SafeCountries
add address=162.250.146.64-162.250.146.255 comment="United States" list=
SafeCountries
add address=162.250.148.0-162.250.167.255 comment="United States" list=
SafeCountries
add address=162.250.176.0-162.250.187.255 comment="United States" list=
SafeCountries
add address=162.250.200.0-162.250.219.255 comment="United States" list=
SafeCountries
add address=162.250.224.0-162.251.15.255 comment="United States" list=
SafeCountries
add address=162.251.24.0-162.251.59.255 comment="United States" list=
SafeCountries
add address=162.251.64.0/21 comment="United States" list=SafeCountries
add address=162.251.88.0-162.251.191.255 comment="United States" list=
SafeCountries
add address=162.251.200.0-162.252.43.255 comment="United States" list=
SafeCountries
add address=162.252.48.0-162.252.58.255 comment="United States" list=
SafeCountries
add address=162.252.60.0-162.252.91.255 comment="United States" list=
SafeCountries
add address=162.252.96.0/20 comment="United States" list=SafeCountries
add address=162.252.120.0-162.252.131.255 comment="United States" list=
SafeCountries
add address=162.252.136.0-162.252.183.255 comment="United States" list=
SafeCountries
add address=162.252.192.0-162.252.215.255 comment="United States" list=
SafeCountries
add address=162.252.224.0/20 comment="United States" list=SafeCountries
add address=162.252.244.0-162.252.251.255 comment="United States" list=
SafeCountries
add address=162.253.0.0/21 comment="United States" list=SafeCountries
add address=162.253.12.0-162.253.51.255 comment="United States" list=
SafeCountries
add address=162.253.56.0-162.253.99.255 comment="United States" list=
SafeCountries
add address=162.253.104.0-162.253.127.255 comment="United States" list=
SafeCountries
add address=162.253.132.0/22 comment="United States" list=SafeCountries
add address=162.253.144.0-162.253.167.255 comment="United States" list=
SafeCountries
add address=162.253.172.0-162.253.207.255 comment="United States" list=
SafeCountries
add address=162.253.216.0-162.253.247.255 comment="United States" list=
SafeCountries
add address=162.254.0.0-162.254.39.255 comment="United States" list=
SafeCountries
add address=162.254.44.0-162.254.85.255 comment="United States" list=
SafeCountries
add address=162.254.86.16-162.254.131.255 comment="United States" list=
SafeCountries
add address=162.254.136.0-162.254.171.255 comment="United States" list=
SafeCountries
add address=162.254.176.0-162.254.195.255 comment="United States" list=
SafeCountries
add address=162.254.199.0-162.255.51.255 comment="United States" list=
SafeCountries
add address=162.255.56.0-162.255.111.255 comment="United States" list=
SafeCountries
add address=162.255.116.0-162.255.143.255 comment="United States" list=
SafeCountries
add address=162.255.152.0-162.255.175.255 comment="United States" list=
SafeCountries
add address=162.255.180.0-162.255.203.255 comment="United States" list=
SafeCountries
add address=162.255.224.0/22 comment="United States" list=SafeCountries
add address=162.255.232.0-162.255.247.255 comment="United States" list=
SafeCountries
add address=163.2.0.0/16 comment="United States" list=SafeCountries
add address=163.4.0.0/16 comment="United States" list=SafeCountries
add address=163.6.0.0/16 comment="United States" list=SafeCountries
add address=163.11.0.0-163.12.255.255 comment="United States" list=
SafeCountries
add address=163.33.0.0/16 comment="United States" list=SafeCountries
add address=163.35.0.0-163.41.255.255 comment="United States" list=
SafeCountries
add address=163.44.96.0/19 comment="United States" list=SafeCountries
add address=163.47.60.0/22 comment="United States" list=SafeCountries
add address=163.47.179.0/24 comment="United States" list=SafeCountries
add address=163.118.0.0/16 comment="United States" list=SafeCountries
add address=163.120.0.0/16 comment="United States" list=SafeCountries
add address=163.124.0.0/16 comment="United States" list=SafeCountries
add address=163.126.0.0/16 comment="United States" list=SafeCountries
add address=163.129.0.0/16 comment="United States" list=SafeCountries
add address=163.150.0.0/15 comment="United States" list=SafeCountries
add address=163.153.0.0-163.154.255.255 comment="United States" list=
SafeCountries
add address=163.176.0.0/16 comment="United States" list=SafeCountries
add address=163.178.0.0/16 comment="Costa Rica" list=SafeCountries
add address=163.181.0.0-163.188.255.255 comment="United States" list=
SafeCountries
add address=163.190.0.0-163.194.255.255 comment="United States" list=
SafeCountries
add address=163.205.0.0-163.207.255.255 comment="United States" list=
SafeCountries
add address=163.228.0.0/16 comment="United States" list=SafeCountries
add address=163.230.0.0/15 comment="United States" list=SafeCountries
add address=163.234.0.0-163.238.255.255 comment="United States" list=
SafeCountries
add address=163.240.0.0-163.244.61.255 comment="United States" list=
SafeCountries
add address=163.244.64.0-163.244.245.255 comment="United States" list=
SafeCountries
add address=163.244.247.0-163.246.255.255 comment="United States" list=
SafeCountries
add address=163.248.0.0/15 comment="United States" list=SafeCountries
add address=163.251.0.0-163.254.255.255 comment="United States" list=
SafeCountries
add address=164.3.220.0/24 comment="United States" list=SafeCountries
add address=164.40.166.0/24 comment="United States" list=SafeCountries
add address=164.44.0.0/15 comment="United States" list=SafeCountries
add address=164.47.0.0/16 comment="United States" list=SafeCountries
add address=164.49.0.0-164.52.255.255 comment="United States" list=
SafeCountries
add address=164.54.0.0-164.58.255.255 comment="United States" list=
SafeCountries
add address=164.62.0.0-164.68.255.255 comment="United States" list=
SafeCountries
add address=164.72.0.0/16 comment="United States" list=SafeCountries
add address=164.74.0.0/16 comment="United States" list=SafeCountries
add address=164.76.0.0/16 comment="United States" list=SafeCountries
add address=164.79.0.0/16 comment="United States" list=SafeCountries
add address=164.82.0.0-164.84.255.255 comment="United States" list=
SafeCountries
add address=164.86.0.0/15 comment="United States" list=SafeCountries
add address=164.89.0.0-164.90.127.255 comment="United States" list=
SafeCountries
add address=164.90.129.0-164.95.255.255 comment="United States" list=
SafeCountries
add address=164.99.0.0/16 comment="United States" list=SafeCountries
add address=164.101.0.0/16 comment="United States" list=SafeCountries
add address=164.103.0.0-164.107.255.255 comment="United States" list=
SafeCountries
add address=164.109.0.0-164.111.255.255 comment="United States" list=
SafeCountries
add address=164.113.0.0-164.114.255.255 comment="United States" list=
SafeCountries
add address=164.116.0.0-164.123.255.255 comment="United States" list=
SafeCountries
add address=164.143.248.0/22 comment="United States" list=SafeCountries
add address=164.144.0.0-164.144.123.0 comment="United States" list=
SafeCountries
add address=164.144.123.2-164.145.255.255 comment="United States" list=
SafeCountries
add address=164.152.0.0-164.154.255.255 comment="United States" list=
SafeCountries
add address=164.156.0.0/14 comment="United States" list=SafeCountries
add address=164.165.0.0/16 comment="United States" list=SafeCountries
add address=164.167.0.0-164.176.255.255 comment="United States" list=
SafeCountries
add address=164.179.0.0-164.214.255.255 comment="United States" list=
SafeCountries
add address=164.215.110.0/24 comment="United States" list=SafeCountries
add address=164.216.0.0-164.255.255.255 comment="United States" list=
SafeCountries
add address=165.1.0.0-165.2.255.255 comment="United States" list=
SafeCountries
add address=165.6.0.0/15 comment="United States" list=SafeCountries
add address=165.13.0.0/16 comment="United States" list=SafeCountries
add address=165.19.0.0-165.20.255.255 comment="United States" list=
SafeCountries
add address=165.22.0.0/16 comment="United States" list=SafeCountries
add address=165.24.0.0/16 comment="United States" list=SafeCountries
add address=165.26.0.0-165.26.216.63 comment="United States" list=
SafeCountries
add address=165.26.216.128-165.30.255.255 comment="United States" list=
SafeCountries
add address=165.32.0.0-165.41.255.255 comment="United States" list=
SafeCountries
add address=165.44.0.0-165.48.255.255 comment="United States" list=
SafeCountries
add address=165.64.0.0-165.68.255.255 comment="United States" list=
SafeCountries
add address=165.70.0.0/15 comment="United States" list=SafeCountries
add address=165.74.0.0/15 comment="United States" list=SafeCountries
add address=165.77.0.0-165.83.255.255 comment="United States" list=
SafeCountries
add address=165.84.208.0/20 comment="United States" list=SafeCountries
add address=165.84.225.0-165.84.227.255 comment="United States" list=
SafeCountries
add address=165.84.229.0-165.84.230.255 comment="United States" list=
SafeCountries
add address=165.85.0.0/16 comment="United States" list=SafeCountries
add address=165.87.0.0-165.89.255.255 comment="United States" list=
SafeCountries
add address=165.91.0.0-165.92.255.255 comment="United States" list=
SafeCountries
add address=165.94.0.0/15 comment="United States" list=SafeCountries
add address=165.97.0.0/16 comment="United States" list=SafeCountries
add address=165.103.0.0-165.107.255.255 comment="United States" list=
SafeCountries
add address=165.109.0.0-165.113.255.255 comment="United States" list=
SafeCountries
add address=165.116.0.0/15 comment="United States" list=SafeCountries
add address=165.119.0.0/16 comment="United States" list=SafeCountries
add address=165.121.0.0-165.125.177.255 comment="United States" list=
SafeCountries
add address=165.125.179.0-165.125.180.255 comment="United States" list=
SafeCountries
add address=165.125.182.0-165.129.11.14 comment="United States" list=
SafeCountries
add address=165.129.11.16-165.131.255.255 comment="United States" list=
SafeCountries
add address=165.134.0.0-165.140.255.255 comment="United States" list=
SafeCountries
add address=165.150.0.0-165.153.255.255 comment="United States" list=
SafeCountries
add address=165.155.0.0-165.164.255.255 comment="United States" list=
SafeCountries
add address=165.166.0.0-165.168.255.255 comment="United States" list=
SafeCountries
add address=165.170.0.0-165.177.255.255 comment="United States" list=
SafeCountries
add address=165.179.0.0/16 comment="United States" list=SafeCountries
add address=165.180.148.101 comment="United States" list=SafeCountries
add address=165.181.0.0/16 comment="United States" list=SafeCountries
add address=165.184.0.0/16 comment="United States" list=SafeCountries
add address=165.188.0.0-165.190.255.255 comment="United States" list=
SafeCountries
add address=165.192.0.0-165.193.143.255 comment="United States" list=
SafeCountries
add address=165.193.145.0-165.193.147.255 comment="United States" list=
SafeCountries
add address=165.193.150.0/24 comment="United States" list=SafeCountries
add address=165.193.152.0/22 comment="United States" list=SafeCountries
add address=165.193.159.0/24 comment="United States" list=SafeCountries
add address=165.193.162.0/23 comment="United States" list=SafeCountries
add address=165.193.168.0/23 comment="United States" list=SafeCountries
add address=165.193.172.0/24 comment="United States" list=SafeCountries
add address=165.193.174.0/24 comment="United States" list=SafeCountries
add address=165.193.176.0-165.193.178.255 comment="United States" list=
SafeCountries
add address=165.193.180.0-165.193.255.255 comment="United States" list=
SafeCountries
add address=165.195.0.0-165.197.215.255 comment="United States" list=
SafeCountries
add address=165.197.224.0-165.201.255.255 comment="United States" list=
SafeCountries
add address=165.203.0.0-165.204.54.255 comment="United States" list=
SafeCountries
add address=165.204.56.0-165.204.71.255 comment="United States" list=
SafeCountries
add address=165.204.73.0-165.204.77.255 comment="United States" list=
SafeCountries
add address=165.204.79.0/24 comment="United States" list=SafeCountries
add address=165.204.84.0-165.204.255.255 comment="United States" list=
SafeCountries
add address=165.206.0.0-165.208.255.255 comment="United States" list=
SafeCountries
add address=165.212.0.0/16 comment="United States" list=SafeCountries
add address=165.214.0.0-165.215.163.255 comment="United States" list=
SafeCountries
add address=165.215.168.0-165.219.255.255 comment="United States" list=
SafeCountries
add address=165.221.0.0/16 comment="United States" list=SafeCountries
add address=165.223.0.0-165.225.35.255 comment="United States" list=
SafeCountries
add address=165.225.36.71 comment="United States" list=SafeCountries
add address=165.225.38.0-165.225.63.255 comment="United States" list=
SafeCountries
add address=165.225.65.0/24 comment="United States" list=SafeCountries
add address=165.225.67.0/24 comment="United States" list=SafeCountries
add address=165.225.69.0/24 comment="United States" list=SafeCountries
add address=165.225.75.0/24 comment="United States" list=SafeCountries
add address=165.225.84.0-165.225.95.255 comment="United States" list=
SafeCountries
add address=165.225.99.0/24 comment="United States" list=SafeCountries
add address=165.225.103.0/24 comment="United States" list=SafeCountries
add address=165.225.106.0-165.227.255.255 comment="United States" list=
SafeCountries
add address=165.230.0.0/16 comment="United States" list=SafeCountries
add address=165.231.48.0/20 comment="United States" list=SafeCountries
add address=165.231.192.0/19 comment="United States" list=SafeCountries
add address=165.232.0.0/16 comment="United States" list=SafeCountries
add address=165.234.0.0-165.239.255.255 comment="United States" list=
SafeCountries
add address=165.245.0.0/16 comment="United States" list=SafeCountries
add address=165.247.0.0-165.254.254.255 comment="United States" list=
SafeCountries
add address=166.0.0.0-166.11.255.255 comment="United States" list=
SafeCountries
add address=166.16.0.0-166.47.255.255 comment="United States" list=
SafeCountries
add address=166.49.0.0/17 comment="United States" list=SafeCountries
add address=166.50.0.0-166.62.127.255 comment="United States" list=
SafeCountries
add address=166.63.0.0-166.63.211.255 comment="United States" list=
SafeCountries
add address=166.63.213.0-166.63.255.255 comment="United States" list=
SafeCountries
add address=166.66.0.0-166.74.255.255 comment="United States" list=
SafeCountries
add address=166.76.0.0-166.78.255.255 comment="United States" list=
SafeCountries
add address=166.80.0.0/16 comment="United States" list=SafeCountries
add address=166.82.0.0/16 comment="United States" list=SafeCountries
add address=166.84.0.0/16 comment="United States" list=SafeCountries
add address=166.86.0.0/16 comment="United States" list=SafeCountries
add address=166.88.0.0-166.99.255.255 comment="United States" list=
SafeCountries
add address=166.101.0.0-166.102.255.255 comment="United States" list=
SafeCountries
add address=166.105.0.0/16 comment="United States" list=SafeCountries
add address=166.107.0.0-166.109.255.255 comment="United States" list=
SafeCountries
add address=166.112.0.0/15 comment="United States" list=SafeCountries
add address=166.115.0.0-166.117.255.255 comment="United States" list=
SafeCountries
add address=166.122.0.0-166.124.255.255 comment="United States" list=
SafeCountries
add address=166.126.0.0-166.179.226.255 comment="United States" list=
SafeCountries
add address=166.179.228.0-166.179.230.255 comment="United States" list=
SafeCountries
add address=166.179.232.0-166.210.224.255 comment="United States" list=
SafeCountries
add address=166.210.226.0-166.255.255.255 comment="United States" list=
SafeCountries
add address=167.1.0.0-167.9.5.10 comment="United States" list=SafeCountries
add address=167.9.5.12-167.10.255.255 comment="United States" list=
SafeCountries
add address=167.12.0.0-167.16.255.255 comment="United States" list=
SafeCountries
add address=167.18.0.0-167.27.255.255 comment="United States" list=
SafeCountries
add address=167.29.0.0/16 comment="United States" list=SafeCountries
add address=167.31.0.0/16 comment="United States" list=SafeCountries
add address=167.64.0.0-167.73.255.255 comment="United States" list=
SafeCountries
add address=167.75.0.0-167.80.255.255 comment="United States" list=
SafeCountries
add address=167.82.0.0-167.83.8.255 comment="United States" list=
SafeCountries
add address=167.83.10.0-167.83.97.255 comment="United States" list=
SafeCountries
add address=167.83.100.0-167.83.144.255 comment="United States" list=
SafeCountries
add address=167.83.146.0-167.88.15.255 comment="United States" list=
SafeCountries
add address=167.88.48.0-167.88.96.255 comment="United States" list=
SafeCountries
add address=167.88.112.0/20 comment="United States" list=SafeCountries
add address=167.88.144.0-167.88.175.255 comment="United States" list=
SafeCountries
add address=167.88.192.0-167.91.255.255 comment="United States" list=
SafeCountries
add address=167.93.0.0-167.102.255.255 comment="United States" list=
SafeCountries
add address=167.104.0.0/14 comment="United States" list=SafeCountries
add address=167.109.0.0-167.110.255.255 comment="United States" list=
SafeCountries
add address=167.112.0.0/15 comment="United States" list=SafeCountries
add address=167.114.11.34 comment="United States" list=SafeCountries
add address=167.114.32.0/24 comment="United States" list=SafeCountries
add address=167.114.38.180/30 comment="United States" list=SafeCountries
add address=167.114.60.40/29 comment="United States" list=SafeCountries
add address=167.114.64.93 comment="United States" list=SafeCountries
add address=167.114.81.64/28 comment="United States" list=SafeCountries
add address=167.114.85.44/30 comment="United States" list=SafeCountries
add address=167.114.99.213 comment="United States" list=SafeCountries
add address=167.114.100.48 comment="United States" list=SafeCountries
add address=167.114.100.116 comment="United States" list=SafeCountries
add address=167.114.123.48 comment="United States" list=SafeCountries
add address=167.114.143.32/28 comment="United States" list=SafeCountries
add address=167.114.165.184/29 comment="United States" list=SafeCountries
add address=167.114.197.0/28 comment="United States" list=SafeCountries
add address=167.114.214.48/29 comment="United States" list=SafeCountries
add address=167.115.0.0/16 comment="United States" list=SafeCountries
add address=167.117.0.0-167.122.255.255 comment="United States" list=
SafeCountries
add address=167.124.0.0/16 comment="United States" list=SafeCountries
add address=167.126.0.0-167.128.255.255 comment="United States" list=
SafeCountries
add address=167.131.0.0-167.133.255.255 comment="United States" list=
SafeCountries
add address=167.135.0.0-167.138.255.255 comment="United States" list=
SafeCountries
add address=167.140.0.0-167.146.255.255 comment="United States" list=
SafeCountries
add address=167.148.0.0/16 comment="United States" list=SafeCountries
add address=167.150.0.0-167.156.255.255 comment="United States" list=
SafeCountries
add address=167.158.0.0-167.160.39.255 comment="United States" list=
SafeCountries
add address=167.160.44.0/22 comment="United States" list=SafeCountries
add address=167.160.64.0-167.161.255.255 comment="United States" list=
SafeCountries
add address=167.163.0.0-167.167.255.255 comment="United States" list=
SafeCountries
add address=167.170.0.0/15 comment="United States" list=SafeCountries
add address=167.173.0.0-167.174.255.255 comment="United States" list=
SafeCountries
add address=167.176.0.0-167.178.255.255 comment="United States" list=
SafeCountries
add address=167.180.0.0-167.188.255.255 comment="United States" list=
SafeCountries
add address=167.190.0.0-167.191.252.255 comment="United States" list=
SafeCountries
add address=167.191.254.0-167.202.191.255 comment="United States" list=
SafeCountries
add address=167.202.224.0/19 comment="United States" list=SafeCountries
add address=167.204.0.0/16 comment="United States" list=SafeCountries
add address=167.206.0.0-167.216.140.255 comment="United States" list=
SafeCountries
add address=167.216.142.0-167.216.146.159 comment="United States" list=
SafeCountries
add address=167.216.146.192-167.216.148.127 comment="United States" list=
SafeCountries
add address=167.216.148.160-167.219.47.255 comment="United States" list=
SafeCountries
add address=167.219.49.0-167.219.59.255 comment="United States" list=
SafeCountries
add address=167.219.61.0-167.220.191.255 comment="United States" list=
SafeCountries
add address=167.220.202.0-167.220.223.255 comment="United States" list=
SafeCountries
add address=167.221.0.0-167.226.255.255 comment="United States" list=
SafeCountries
add address=167.228.0.0-167.232.232.255 comment="United States" list=
SafeCountries
add address=167.232.234.0-167.232.239.255 comment="United States" list=
SafeCountries
add address=167.232.241.0-167.236.63.255 comment="United States" list=
SafeCountries
add address=167.236.128.0-167.236.247.255 comment="United States" list=
SafeCountries
add address=167.236.249.0-167.246.62.255 comment="United States" list=
SafeCountries
add address=167.246.64.0-167.247.14.255 comment="United States" list=
SafeCountries
add address=167.247.16.0-167.247.79.255 comment="United States" list=
SafeCountries
add address=167.247.88.0-167.247.219.9 comment="United States" list=
SafeCountries
add address=167.247.219.11-167.248.255.255 comment="United States" list=
SafeCountries
add address=167.250.192.0/22 comment="Costa Rica" list=SafeCountries
add address=167.251.0.0/16 comment="United States" list=SafeCountries
add address=167.253.0.0-167.255.255.255 comment="United States" list=
SafeCountries
add address=168.1.128.0-168.61.55.255 comment="United States" list=
SafeCountries
add address=168.61.64.0/20 comment="United States" list=SafeCountries
add address=168.61.84.142 comment="United States" list=SafeCountries
add address=168.61.128.0-168.62.32.191 comment="United States" list=
SafeCountries
add address=168.62.33.0-168.62.34.255 comment="United States" list=
SafeCountries
add address=168.62.36.0-168.62.255.255 comment="United States" list=
SafeCountries
add address=168.63.88.0/23 comment="United States" list=SafeCountries
add address=168.63.91.64-168.63.91.255 comment="United States" list=
SafeCountries
add address=168.64.0.0-168.65.65.229 comment="United States" list=
SafeCountries
add address=168.65.65.231-168.69.255.255 comment="United States" list=
SafeCountries
add address=168.71.0.0-168.75.255.255 comment="United States" list=
SafeCountries
add address=168.82.0.0/16 comment="United States" list=SafeCountries
add address=168.84.0.0-168.87.3.32 comment="United States" list=SafeCountries
add address=168.87.3.34-168.87.70.255 comment="United States" list=
SafeCountries
add address=168.87.72.0-168.88.255.255 comment="United States" list=
SafeCountries
add address=168.91.0.0-168.94.255.255 comment="United States" list=
SafeCountries
add address=168.97.0.0-168.100.255.255 comment="United States" list=
SafeCountries
add address=168.102.0.0-168.105.255.255 comment="United States" list=
SafeCountries
add address=168.107.0.0-168.114.255.255 comment="United States" list=
SafeCountries
add address=168.116.0.0/14 comment="United States" list=SafeCountries
add address=168.122.0.0/16 comment="United States" list=SafeCountries
add address=168.124.0.0/15 comment="United States" list=SafeCountries
add address=168.127.0.0-168.128.7.255 comment="United States" list=
SafeCountries
add address=168.128.16.0/20 comment="United States" list=SafeCountries
add address=168.129.0.0/16 comment="United States" list=SafeCountries
add address=168.133.0.0/16 comment="United States" list=SafeCountries
add address=168.135.0.0-168.138.255.255 comment="United States" list=
SafeCountries
add address=168.141.0.0/16 comment="United States" list=SafeCountries
add address=168.143.0.0/16 comment="United States" list=SafeCountries
add address=168.145.0.0-168.151.255.255 comment="United States" list=
SafeCountries
add address=168.153.107.0-168.153.108.255 comment="United States" list=
SafeCountries
add address=168.156.0.0-168.159.143.255 comment="United States" list=
SafeCountries
add address=168.159.145.0-168.159.159.255 comment="United States" list=
SafeCountries
add address=168.159.161.0-168.159.191.255 comment="United States" list=
SafeCountries
add address=168.159.193.0-168.159.255.255 comment="United States" list=
SafeCountries
add address=168.161.0.0-168.161.96.255 comment="United States" list=
SafeCountries
add address=168.161.98.0-168.161.199.255 comment="United States" list=
SafeCountries
add address=168.161.201.0/24 comment="United States" list=SafeCountries
add address=168.161.203.0-168.162.255.255 comment="United States" list=
SafeCountries
add address=168.166.0.0/16 comment="United States" list=SafeCountries
add address=168.168.0.0-168.168.32.255 comment="United States" list=
SafeCountries
add address=168.168.34.0-168.168.42.255 comment="United States" list=
SafeCountries
add address=168.168.44.0-168.171.255.255 comment="United States" list=
SafeCountries
add address=168.173.0.0-168.175.255.255 comment="United States" list=
SafeCountries
add address=168.177.0.0-168.180.255.255 comment="United States" list=
SafeCountries
add address=168.181.160.0/22 comment="Costa Rica" list=SafeCountries
add address=168.182.0.0-168.183.83.255 comment="United States" list=
SafeCountries
add address=168.183.85.0-168.185.255.255 comment="United States" list=
SafeCountries
add address=168.187.11.0/24 comment="United States" list=SafeCountries
add address=168.187.103.0/24 comment="United States" list=SafeCountries
add address=168.187.111.0/24 comment="United States" list=SafeCountries
add address=168.189.0.0-168.193.255.255 comment="United States" list=
SafeCountries
add address=168.199.0.0-168.201.255.255 comment="United States" list=
SafeCountries
add address=168.203.0.0-168.204.255.255 comment="United States" list=
SafeCountries
add address=168.205.64.0/22 comment="Costa Rica" list=SafeCountries
add address=168.207.0.0-168.208.5.255 comment="United States" list=
SafeCountries
add address=168.208.7.0-168.208.255.255 comment="United States" list=
SafeCountries
add address=168.212.0.0-168.216.255.255 comment="United States" list=
SafeCountries
add address=168.218.0.0/16 comment="United States" list=SafeCountries
add address=168.220.0.0-168.224.159.255 comment="United States" list=
SafeCountries
add address=168.224.161.0-168.225.255.255 comment="United States" list=
SafeCountries
add address=168.229.0.0-168.230.239.255 comment="United States" list=
SafeCountries
add address=168.230.241.0-168.230.255.255 comment="United States" list=
SafeCountries
add address=168.232.28.0/22 comment="Costa Rica" list=SafeCountries
add address=168.233.0.0/16 comment="United States" list=SafeCountries
add address=168.235.0.0-168.235.76.197 comment="United States" list=
SafeCountries
add address=168.235.76.199-168.235.143.255 comment="United States" list=
SafeCountries
add address=168.235.160.0-168.235.223.255 comment="United States" list=
SafeCountries
add address=168.235.240.0-168.242.255.255 comment="United States" list=
SafeCountries
add address=168.244.0.0/14 comment="United States" list=SafeCountries
add address=168.250.0.0/15 comment="United States" list=SafeCountries
add address=168.254.0.0/16 comment="United States" list=SafeCountries
add address=169.2.0.0-169.31.255.255 comment="United States" list=
SafeCountries
add address=169.38.0.0-169.38.70.255 comment="United States" list=
SafeCountries
add address=169.38.71.8-169.38.255.255 comment="United States" list=
SafeCountries
add address=169.40.0.0/16 comment="United States" list=SafeCountries
add address=169.44.0.0/16 comment="United States" list=SafeCountries
add address=169.45.66.221 comment="United States" list=SafeCountries
add address=169.45.115.196 comment="United States" list=SafeCountries
add address=169.50.0.0-169.50.66.207 comment="United States" list=
SafeCountries
add address=169.50.66.209-169.50.67.240 comment="United States" list=
SafeCountries
add address=169.50.67.242-169.51.255.255 comment="United States" list=
SafeCountries
add address=169.53.0.0-169.53.166.191 comment="United States" list=
SafeCountries
add address=169.53.166.208-169.53.188.255 comment="United States" list=
SafeCountries
add address=169.53.190.0-169.53.227.31 comment="United States" list=
SafeCountries
add address=169.53.227.64-169.53.253.191 comment="United States" list=
SafeCountries
add address=169.53.253.208-169.54.63.255 comment="United States" list=
SafeCountries
add address=169.54.128.0-169.54.164.63 comment="United States" list=
SafeCountries
add address=169.54.164.80-169.54.197.111 comment="United States" list=
SafeCountries
add address=169.54.197.128-169.54.211.63 comment="United States" list=
SafeCountries
add address=169.54.211.96-169.54.214.31 comment="United States" list=
SafeCountries
add address=169.54.214.48-169.54.226.127 comment="United States" list=
SafeCountries
add address=169.54.226.144-169.54.227.175 comment="United States" list=
SafeCountries
add address=169.54.227.192-169.55.31.191 comment="United States" list=
SafeCountries
add address=169.55.31.208-169.55.33.95 comment="United States" list=
SafeCountries
add address=169.55.33.112-169.55.39.79 comment="United States" list=
SafeCountries
add address=169.55.39.96-169.56.255.255 comment="United States" list=
SafeCountries
add address=169.64.0.0-169.128.255.255 comment="United States" list=
SafeCountries
add address=169.130.0.0-169.139.255.255 comment="United States" list=
SafeCountries
add address=169.141.0.0-169.143.243.255 comment="United States" list=
SafeCountries
add address=169.143.248.0-169.145.41.255 comment="United States" list=
SafeCountries
add address=169.145.43.0-169.145.196.255 comment="United States" list=
SafeCountries
add address=169.145.198.0-169.148.255.255 comment="United States" list=
SafeCountries
add address=169.150.0.0-169.157.255.255 comment="United States" list=
SafeCountries
add address=169.160.0.0-169.196.71.255 comment="United States" list=
SafeCountries
add address=169.196.80.0-169.196.195.255 comment="United States" list=
SafeCountries
add address=169.196.200.0-169.197.63.255 comment="United States" list=
SafeCountries
add address=169.198.0.0-169.200.255.255 comment="United States" list=
SafeCountries
add address=169.203.0.0-169.207.255.255 comment="United States" list=
SafeCountries
add address=169.224.0.0-169.238.255.255 comment="United States" list=
SafeCountries
add address=169.240.0.0-169.253.255.255 comment="United States" list=
SafeCountries
add address=170.0.0.0-170.17.255.255 comment="United States" list=
SafeCountries
add address=170.19.0.0-170.24.255.255 comment="United States" list=
SafeCountries
add address=170.26.0.0-170.32.255.255 comment="United States" list=
SafeCountries
add address=170.34.0.0-170.37.203.255 comment="United States" list=
SafeCountries
add address=170.37.205.0-170.37.255.255 comment="United States" list=
SafeCountries
add address=170.40.0.0-170.50.255.255 comment="United States" list=
SafeCountries
add address=170.52.0.0-170.54.159.255 comment="United States" list=
SafeCountries
add address=170.54.161.0-170.59.255.255 comment="United States" list=
SafeCountries
add address=170.61.0.0-170.61.235.255 comment="United States" list=
SafeCountries
add address=170.61.240.0-170.65.203.255 comment="United States" list=
SafeCountries
add address=170.65.205.0/24 comment="United States" list=SafeCountries
add address=170.65.207.0-170.65.255.255 comment="United States" list=
SafeCountries
add address=170.67.0.0-170.69.255.255 comment="United States" list=
SafeCountries
add address=170.71.0.0-170.75.159.255 comment="United States" list=
SafeCountries
add address=170.75.176.0-170.77.255.255 comment="United States" list=
SafeCountries
add address=170.85.0.0-170.86.14.255 comment="United States" list=
SafeCountries
add address=170.86.16.0-170.104.255.255 comment="United States" list=
SafeCountries
add address=170.106.0.0-170.136.114.255 comment="United States" list=
SafeCountries
add address=170.136.116.0-170.146.149.255 comment="United States" list=
SafeCountries
add address=170.146.151.0-170.148.95.255 comment="United States" list=
SafeCountries
add address=170.148.97.0-170.148.98.255 comment="United States" list=
SafeCountries
add address=170.148.100.0-170.148.143.255 comment="United States" list=
SafeCountries
add address=170.148.145.0-170.148.197.255 comment="United States" list=
SafeCountries
add address=170.148.199.0-170.148.214.255 comment="United States" list=
SafeCountries
add address=170.148.216.0-170.149.255.255 comment="United States" list=
SafeCountries
add address=170.151.0.0-170.154.255.255 comment="United States" list=
SafeCountries
add address=170.156.0.0/16 comment="United States" list=SafeCountries
add address=170.158.0.0-170.162.32.255 comment="United States" list=
SafeCountries
add address=170.162.34.0-170.168.255.255 comment="United States" list=
SafeCountries
add address=170.170.0.0-170.174.255.255 comment="United States" list=
SafeCountries
add address=170.176.0.0-170.178.255.255 comment="United States" list=
SafeCountries
add address=170.180.0.0-170.194.15.255 comment="United States" list=
SafeCountries
add address=170.194.17.0-170.194.31.255 comment="United States" list=
SafeCountries
add address=170.194.33.0-170.205.63.255 comment="United States" list=
SafeCountries
add address=170.205.192.0-170.209.255.255 comment="United States" list=
SafeCountries
add address=170.211.0.0-170.235.255.255 comment="United States" list=
SafeCountries
add address=170.240.0.0/14 comment="United States" list=SafeCountries
add address=170.248.4.0/24 comment="United States" list=SafeCountries
add address=170.248.8.0-170.248.10.255 comment="United States" list=
SafeCountries
add address=170.248.14.0/23 comment="United States" list=SafeCountries
add address=170.248.20.0-170.248.40.255 comment="United States" list=
SafeCountries
add address=170.248.44.0/23 comment="United States" list=SafeCountries
add address=170.248.48.0-170.248.77.255 comment="United States" list=
SafeCountries
add address=170.248.79.0/24 comment="United States" list=SafeCountries
add address=170.248.82.0/23 comment="United States" list=SafeCountries
add address=170.248.88.0-170.248.119.255 comment="United States" list=
SafeCountries
add address=170.248.126.0-170.248.136.255 comment="United States" list=
SafeCountries
add address=170.248.140.0/23 comment="United States" list=SafeCountries
add address=170.248.143.0-170.248.144.255 comment="United States" list=
SafeCountries
add address=170.248.148.0-170.248.152.255 comment="United States" list=
SafeCountries
add address=170.248.172.0-170.248.189.255 comment="United States" list=
SafeCountries
add address=170.248.192.0/20 comment="United States" list=SafeCountries
add address=170.248.210.0-170.248.225.255 comment="United States" list=
SafeCountries
add address=170.248.227.0-170.250.255.255 comment="United States" list=
SafeCountries
add address=170.251.12.0-170.251.19.255 comment="United States" list=
SafeCountries
add address=170.251.22.0/24 comment="United States" list=SafeCountries
add address=170.251.24.0-170.251.35.255 comment="United States" list=
SafeCountries
add address=170.251.50.0-170.251.59.255 comment="United States" list=
SafeCountries
add address=170.251.63.128/25 comment="United States" list=SafeCountries
add address=170.251.69.0-170.251.75.255 comment="United States" list=
SafeCountries
add address=170.251.86.0-170.251.89.255 comment="United States" list=
SafeCountries
add address=170.251.98.0/23 comment="Costa Rica" list=SafeCountries
add address=170.251.102.0/24 comment="United States" list=SafeCountries
add address=170.251.106.0/24 comment="United States" list=SafeCountries
add address=170.251.132.0-170.251.136.255 comment="United States" list=
SafeCountries
add address=170.251.138.0/24 comment="United States" list=SafeCountries
add address=170.251.140.0/23 comment="United States" list=SafeCountries
add address=170.251.144.0/23 comment="United States" list=SafeCountries
add address=170.251.148.0/24 comment="United States" list=SafeCountries
add address=170.251.152.0/23 comment="United States" list=SafeCountries
add address=170.251.158.0/23 comment="United States" list=SafeCountries
add address=170.251.162.0/23 comment="United States" list=SafeCountries
add address=170.251.164.128/26 comment="United States" list=SafeCountries
add address=170.251.166.0/23 comment="United States" list=SafeCountries
add address=170.251.172.0/23 comment="United States" list=SafeCountries
add address=170.251.178.32-170.251.178.95 comment="United States" list=
SafeCountries
add address=170.251.178.128-170.251.179.255 comment="United States" list=
SafeCountries
add address=170.251.182.0/23 comment="United States" list=SafeCountries
add address=170.251.192.0-170.252.31.255 comment="United States" list=
SafeCountries
add address=170.252.37.0/25 comment="United States" list=SafeCountries
add address=170.252.40.0-170.252.63.255 comment="United States" list=
SafeCountries
add address=170.252.102.0-170.252.105.255 comment="United States" list=
SafeCountries
add address=170.252.108.0/23 comment="United States" list=SafeCountries
add address=170.252.114.0/23 comment="United States" list=SafeCountries
add address=170.252.192.0-170.253.255.255 comment="United States" list=
SafeCountries
add address=171.64.0.0-171.75.255.255 comment="United States" list=
SafeCountries
add address=171.128.0.0-171.159.47.255 comment="United States" list=
SafeCountries
add address=171.159.49.0-171.161.47.255 comment="United States" list=
SafeCountries
add address=171.161.50.0-171.191.255.255 comment="United States" list=
SafeCountries
add address=171.192.1.0-171.206.255.255 comment="United States" list=
SafeCountries
add address=172.0.0.0-172.15.10.255 comment="United States" list=
SafeCountries
add address=172.15.11.188 comment="United States" list=SafeCountries
add address=172.15.11.233 comment="United States" list=SafeCountries
add address=172.15.12.0-172.15.255.255 comment="United States" list=
SafeCountries
add address=172.32.0.0-172.81.175.255 comment="United States" list=
SafeCountries
add address=172.81.184.0-172.82.4.255 comment="United States" list=
SafeCountries
add address=172.82.6.0-172.82.14.255 comment="United States" list=
SafeCountries
add address=172.82.16.0-172.82.255.255 comment="United States" list=
SafeCountries
add address=172.85.0.0-172.85.79.255 comment="United States" list=
SafeCountries
add address=172.85.88.0-172.85.119.255 comment="United States" list=
SafeCountries
add address=172.85.128.0-172.86.183.255 comment="United States" list=
SafeCountries
add address=172.86.224.0/20 comment="United States" list=SafeCountries
add address=172.86.248.0-172.87.79.255 comment="United States" list=
SafeCountries
add address=172.87.96.0-172.93.79.255 comment="United States" list=
SafeCountries
add address=172.93.96.0-172.93.123.255 comment="United States" list=
SafeCountries
add address=172.93.128.0/17 comment="United States" list=SafeCountries
add address=172.94.36.0-172.94.46.255 comment="United States" list=
SafeCountries
add address=172.94.48.0/23 comment="United States" list=SafeCountries
add address=172.94.58.0-172.94.63.255 comment="United States" list=
SafeCountries
add address=172.94.67.0-172.94.81.255 comment="United States" list=
SafeCountries
add address=172.94.90.0-172.94.93.255 comment="United States" list=
SafeCountries
add address=172.94.95.0-172.94.115.255 comment="United States" list=
SafeCountries
add address=172.94.117.0-172.96.39.255 comment="United States" list=
SafeCountries
add address=172.96.48.0-172.96.191.255 comment="United States" list=
SafeCountries
add address=172.97.0.0/21 comment="United States" list=SafeCountries
add address=172.97.16.0-172.97.47.255 comment="United States" list=
SafeCountries
add address=172.97.56.0/22 comment="United States" list=SafeCountries
add address=172.97.64.0-172.97.119.255 comment="United States" list=
SafeCountries
add address=172.97.124.0/22 comment="United States" list=SafeCountries
add address=172.98.0.0-172.98.66.255 comment="United States" list=
SafeCountries
add address=172.98.68.0-172.98.143.255 comment="United States" list=
SafeCountries
add address=172.98.161.0-172.98.162.255 comment="United States" list=
SafeCountries
add address=172.98.164.0-172.98.168.255 comment="United States" list=
SafeCountries
add address=172.98.170.0-172.98.178.255 comment="United States" list=
SafeCountries
add address=172.98.180.0/23 comment="United States" list=SafeCountries
add address=172.98.184.0-172.99.7.255 comment="United States" list=
SafeCountries
add address=172.99.12.0-172.99.19.255 comment="United States" list=
SafeCountries
add address=172.99.32.0-172.102.15.255 comment="United States" list=
SafeCountries
add address=172.102.32.0-172.102.213.255 comment="United States" list=
SafeCountries
add address=172.102.215.0-172.102.217.255 comment="United States" list=
SafeCountries
add address=172.102.219.0-172.102.223.255 comment="United States" list=
SafeCountries
add address=172.102.232.0-172.103.47.255 comment="United States" list=
SafeCountries
add address=172.103.64.0/18 comment="United States" list=SafeCountries
add address=172.104.0.0-172.110.63.255 comment="United States" list=
SafeCountries
add address=172.110.80.0-172.111.127.255 comment="United States" list=
SafeCountries
add address=172.111.134.0/24 comment="United States" list=SafeCountries
add address=172.111.139.0/24 comment="United States" list=SafeCountries
add address=172.111.150.0/23 comment="United States" list=SafeCountries
add address=172.111.158.0/23 comment="United States" list=SafeCountries
add address=172.111.171.0-172.111.173.255 comment="United States" list=
SafeCountries
add address=172.111.175.0/24 comment="United States" list=SafeCountries
add address=172.111.180.0-172.111.184.255 comment="United States" list=
SafeCountries
add address=172.111.190.0/23 comment="United States" list=SafeCountries
add address=172.111.194.0-172.121.255.255 comment="United States" list=
SafeCountries
add address=172.124.0.0-172.140.255.255 comment="United States" list=
SafeCountries
add address=172.144.0.0-172.146.204.255 comment="United States" list=
SafeCountries
add address=172.146.206.0-172.151.255.255 comment="United States" list=
SafeCountries
add address=172.153.0.0-172.157.255.255 comment="United States" list=
SafeCountries
add address=172.160.0.0-172.162.13.187 comment="United States" list=
SafeCountries
add address=172.162.13.189-172.164.0.224 comment="United States" list=
SafeCountries
add address=172.164.0.226-172.172.255.255 comment="United States" list=
SafeCountries
add address=172.175.0.0/16 comment="United States" list=SafeCountries
add address=172.190.0.0/15 comment="United States" list=SafeCountries
add address=172.217.0.0/16 comment="United States" list=SafeCountries
add address=172.220.0.0-172.245.11.167 comment="United States" list=
SafeCountries
add address=172.245.11.176-172.255.59.255 comment="United States" list=
SafeCountries
add address=172.255.64.0-172.255.255.255 comment="United States" list=
SafeCountries
add address=173.0.16.0-173.0.70.255 comment="United States" list=
SafeCountries
add address=173.0.72.0-173.0.191.255 comment="United States" list=
SafeCountries
add address=173.0.224.0-173.31.255.255 comment="United States" list=
SafeCountries
add address=173.36.0.0-173.38.208.255 comment="United States" list=
SafeCountries
add address=173.38.210.0-173.38.219.255 comment="United States" list=
SafeCountries
add address=173.38.221.0-173.39.120.255 comment="United States" list=
SafeCountries
add address=173.39.122.0-173.44.12.255 comment="United States" list=
SafeCountries
add address=173.44.14.0-173.44.18.255 comment="United States" list=
SafeCountries
add address=173.44.20.0/22 comment="United States" list=SafeCountries
add address=173.44.25.0-173.44.26.255 comment="United States" list=
SafeCountries
add address=173.44.28.0-173.44.177.255 comment="United States" list=
SafeCountries
add address=173.44.180.0-173.44.233.255 comment="United States" list=
SafeCountries
add address=173.44.235.0-173.44.248.239 comment="United States" list=
SafeCountries
add address=173.44.248.248-173.45.31.255 comment="United States" list=
SafeCountries
add address=173.45.33.0-173.45.152.255 comment="United States" list=
SafeCountries
add address=173.45.154.0-173.45.255.255 comment="United States" list=
SafeCountries
add address=173.46.32.0-173.175.255.255 comment="United States" list=
SafeCountries
add address=173.184.0.0-173.192.251.255 comment="United States" list=
SafeCountries
add address=173.192.253.0/24 comment="United States" list=SafeCountries
add address=173.192.255.0-173.194.90.255 comment="United States" list=
SafeCountries
add address=173.194.93.0-173.194.95.255 comment="United States" list=
SafeCountries
add address=173.194.97.0/24 comment="United States" list=SafeCountries
add address=173.194.99.0-173.195.47.255 comment="United States" list=
SafeCountries
add address=173.195.64.0-173.199.63.255 comment="United States" list=
SafeCountries
add address=173.199.66.0/24 comment="United States" list=SafeCountries
add address=173.199.84.0-173.199.104.255 comment="United States" list=
SafeCountries
add address=173.199.106.0/24 comment="United States" list=SafeCountries
add address=173.199.112.12-173.199.112.31 comment="United States" list=
SafeCountries
add address=173.199.112.48/28 comment="United States" list=SafeCountries
add address=173.199.112.88-173.199.112.159 comment="United States" list=
SafeCountries
add address=173.199.112.176-173.199.112.223 comment="United States" list=
SafeCountries
add address=173.199.112.240-173.199.113.31 comment="United States" list=
SafeCountries
add address=173.199.113.64-173.199.113.223 comment="United States" list=
SafeCountries
add address=173.199.114.0-173.203.128.69 comment="United States" list=
SafeCountries
add address=173.203.128.71-173.205.5.47 comment="United States" list=
SafeCountries
add address=173.205.5.64-173.205.255.255 comment="United States" list=
SafeCountries
add address=173.207.0.0-173.209.31.255 comment="United States" list=
SafeCountries
add address=173.209.46.208/29 comment="United States" list=SafeCountries
add address=173.209.49.224/29 comment="United States" list=SafeCountries
add address=173.209.53.56/29 comment="United States" list=SafeCountries
add address=173.209.64.0-173.209.111.255 comment="United States" list=
SafeCountries
add address=173.209.160.0-173.210.127.255 comment="United States" list=
SafeCountries
add address=173.211.0.0/17 comment="United States" list=SafeCountries
add address=173.211.192.0-173.212.63.255 comment="United States" list=
SafeCountries
add address=173.212.192.0-173.212.229.255 comment="United States" list=
SafeCountries
add address=173.212.231.0-173.214.127.255 comment="United States" list=
SafeCountries
add address=173.214.144.0-173.215.127.255 comment="United States" list=
SafeCountries
add address=173.216.0.0-173.222.95.255 comment="United States" list=
SafeCountries
add address=173.222.100.0-173.222.107.255 comment="United States" list=
SafeCountries
add address=173.222.110.0-173.222.127.255 comment="United States" list=
SafeCountries
add address=173.222.133.0-173.222.161.255 comment="United States" list=
SafeCountries
add address=173.222.164.0-173.222.199.255 comment="United States" list=
SafeCountries
add address=173.222.204.0/22 comment="United States" list=SafeCountries
add address=173.222.212.0-173.223.9.255 comment="United States" list=
SafeCountries
add address=173.223.12.0-173.223.21.255 comment="United States" list=
SafeCountries
add address=173.223.24.0/22 comment="United States" list=SafeCountries
add address=173.223.32.0-173.223.105.255 comment="United States" list=
SafeCountries
add address=173.223.108.0-173.223.127.255 comment="United States" list=
SafeCountries
add address=173.223.130.0/24 comment="United States" list=SafeCountries
add address=173.223.132.0-173.223.155.255 comment="United States" list=
SafeCountries
add address=173.223.160.0/20 comment="United States" list=SafeCountries
add address=173.223.192.0-173.224.115.33 comment="United States" list=
SafeCountries
add address=173.224.115.35-173.224.126.134 comment="United States" list=
SafeCountries
add address=173.224.126.136-173.224.126.166 comment="United States" list=
SafeCountries
add address=173.224.126.169-173.224.127.142 comment="United States" list=
SafeCountries
add address=173.224.127.144-173.224.127.255 comment="United States" list=
SafeCountries
add address=173.224.144.0-173.224.223.255 comment="United States" list=
SafeCountries
add address=173.225.0.0-173.225.207.255 comment="United States" list=
SafeCountries
add address=173.225.224.0/20 comment="United States" list=SafeCountries
add address=173.226.0.0-173.228.191.255 comment="United States" list=
SafeCountries
add address=173.229.0.0-173.230.159.255 comment="United States" list=
SafeCountries
add address=173.230.192.0-173.230.240.207 comment="United States" list=
SafeCountries
add address=173.230.240.216-173.231.0.255 comment="United States" list=
SafeCountries
add address=173.231.2.0-173.231.95.255 comment="United States" list=
SafeCountries
add address=173.231.128.0-173.231.193.255 comment="United States" list=
SafeCountries
add address=173.231.195.0/24 comment="United States" list=SafeCountries
add address=173.231.200.0/24 comment="United States" list=SafeCountries
add address=173.231.202.0-173.231.214.255 comment="United States" list=
SafeCountries
add address=173.231.216.0/22 comment="United States" list=SafeCountries
add address=173.231.222.0/24 comment="United States" list=SafeCountries
add address=173.231.224.0/24 comment="United States" list=SafeCountries
add address=173.231.226.0/23 comment="United States" list=SafeCountries
add address=173.231.229.0/24 comment="United States" list=SafeCountries
add address=173.231.231.0-173.231.232.255 comment="United States" list=
SafeCountries
add address=173.231.234.0-173.231.247.255 comment="United States" list=
SafeCountries
add address=173.231.250.0-173.232.51.255 comment="United States" list=
SafeCountries
add address=173.232.53.0-173.232.144.255 comment="United States" list=
SafeCountries
add address=173.232.147.0-173.232.149.95 comment="United States" list=
SafeCountries
add address=173.232.149.104-173.232.161.255 comment="United States" list=
SafeCountries
add address=173.232.163.0-173.232.174.255 comment="United States" list=
SafeCountries
add address=173.232.176.0/21 comment="United States" list=SafeCountries
add address=173.232.185.0-173.232.186.255 comment="United States" list=
SafeCountries
add address=173.232.188.0-173.232.199.255 comment="United States" list=
SafeCountries
add address=173.232.201.0-173.232.207.255 comment="United States" list=
SafeCountries
add address=173.232.209.0-173.232.225.255 comment="United States" list=
SafeCountries
add address=173.232.227.0-173.234.188.255 comment="United States" list=
SafeCountries
add address=173.234.190.0-173.237.95.255 comment="United States" list=
SafeCountries
add address=173.237.128.0-173.237.207.255 comment="United States" list=
SafeCountries
add address=173.237.224.0/20 comment="United States" list=SafeCountries
add address=173.239.0.0/17 comment="United States" list=SafeCountries
add address=173.239.192.0-173.239.206.255 comment="United States" list=
SafeCountries
add address=173.239.208.0-173.239.255.255 comment="United States" list=
SafeCountries
add address=173.240.1.0-173.240.2.255 comment="United States" list=
SafeCountries
add address=173.240.4.0-173.240.175.255 comment="United States" list=
SafeCountries
add address=173.240.192.0-173.241.31.255 comment="United States" list=
SafeCountries
add address=173.241.48.0-173.241.95.255 comment="United States" list=
SafeCountries
add address=173.241.112.0-173.241.131.255 comment="United States" list=
SafeCountries
add address=173.241.133.0-173.241.134.255 comment="United States" list=
SafeCountries
add address=173.241.135.0/24 comment="Costa Rica" list=SafeCountries
add address=173.241.144.0-173.241.240.232 comment="United States" list=
SafeCountries
add address=173.241.240.234-173.242.207.255 comment="United States" list=
SafeCountries
add address=173.242.224.0-173.243.31.255 comment="United States" list=
SafeCountries
add address=173.243.48.0-173.243.79.255 comment="United States" list=
SafeCountries
add address=173.243.91.0-173.243.92.255 comment="United States" list=
SafeCountries
add address=173.243.96.0-173.243.191.255 comment="United States" list=
SafeCountries
add address=173.243.208.0-173.244.54.255 comment="United States" list=
SafeCountries
add address=173.244.56.0-173.244.79.255 comment="United States" list=
SafeCountries
add address=173.244.87.0/24 comment="United States" list=SafeCountries
add address=173.244.92.0/23 comment="United States" list=SafeCountries
add address=173.244.96.0/20 comment="United States" list=SafeCountries
add address=173.244.128.0-173.245.48.255 comment="United States" list=
SafeCountries
add address=173.245.50.0-173.245.52.255 comment="United States" list=
SafeCountries
add address=173.245.54.0-173.245.86.15 comment="United States" list=
SafeCountries
add address=173.245.86.24-173.245.208.255 comment="United States" list=
SafeCountries
add address=173.245.210.0-173.245.216.255 comment="United States" list=
SafeCountries
add address=173.245.218.0-173.245.255.255 comment="United States" list=
SafeCountries
add address=173.246.32.0/19 comment="United States" list=SafeCountries
add address=173.246.94.0/24 comment="United States" list=SafeCountries
add address=173.246.96.0/19 comment="United States" list=SafeCountries
add address=173.246.160.0-173.247.31.255 comment="United States" list=
SafeCountries
add address=173.247.64.0/18 comment="United States" list=SafeCountries
add address=173.247.160.0-173.247.207.255 comment="United States" list=
SafeCountries
add address=173.247.224.0-173.248.191.255 comment="United States" list=
SafeCountries
add address=173.249.0.0-173.249.152.255 comment="United States" list=
SafeCountries
add address=173.249.157.0-173.249.199.255 comment="United States" list=
SafeCountries
add address=173.249.204.0-173.249.206.255 comment="United States" list=
SafeCountries
add address=173.249.224.0/19 comment="United States" list=SafeCountries
add address=173.250.128.0-173.251.255.255 comment="United States" list=
SafeCountries
add address=173.252.64.0-173.252.143.255 comment="United States" list=
SafeCountries
add address=173.252.145.0-173.252.184.7 comment="United States" list=
SafeCountries
add address=173.252.184.16-173.252.184.63 comment="United States" list=
SafeCountries
add address=173.252.184.72-173.252.187.47 comment="United States" list=
SafeCountries
add address=173.252.187.64-173.252.187.175 comment="United States" list=
SafeCountries
add address=173.252.187.224-173.252.190.127 comment="United States" list=
SafeCountries
add address=173.252.190.160-173.252.191.119 comment="United States" list=
SafeCountries
add address=173.252.191.128/27 comment="United States" list=SafeCountries
add address=173.252.191.192-173.253.63.255 comment="United States" list=
SafeCountries
add address=173.253.112.0-173.253.114.87 comment="United States" list=
SafeCountries
add address=173.253.114.96-173.253.125.7 comment="United States" list=
SafeCountries
add address=173.253.125.16-173.255.15.255 comment="United States" list=
SafeCountries
add address=173.255.32.0/19 comment="United States" list=SafeCountries
add address=173.255.80.0-173.255.135.139 comment="United States" list=
SafeCountries
add address=173.255.135.148-173.255.136.163 comment="United States" list=
SafeCountries
add address=173.255.136.168-173.255.143.255 comment="United States" list=
SafeCountries
add address=173.255.160.0-173.255.255.255 comment="United States" list=
SafeCountries
add address=174.8.0.0-174.34.190.255 comment="United States" list=
SafeCountries
add address=174.34.192.0-174.35.3.255 comment="United States" list=
SafeCountries
add address=174.35.6.0-174.35.45.255 comment="United States" list=
SafeCountries
add address=174.35.47.0-174.35.49.255 comment="United States" list=
SafeCountries
add address=174.35.51.0-174.35.61.255 comment="United States" list=
SafeCountries
add address=174.35.65.0/24 comment="United States" list=SafeCountries
add address=174.35.68.0/24 comment="United States" list=SafeCountries
add address=174.35.70.0/24 comment="United States" list=SafeCountries
add address=174.35.72.0-174.35.81.255 comment="United States" list=
SafeCountries
add address=174.35.83.0-174.35.86.255 comment="United States" list=
SafeCountries
add address=174.35.89.0/24 comment="United States" list=SafeCountries
add address=174.35.91.0/24 comment="United States" list=SafeCountries
add address=174.35.95.0-174.35.127.255 comment="United States" list=
SafeCountries
add address=174.36.0.0-174.87.255.255 comment="United States" list=
SafeCountries
add address=174.96.0.0/12 comment="United States" list=SafeCountries
add address=174.120.0.0-174.122.45.255 comment="United States" list=
SafeCountries
add address=174.122.48.0-174.127.87.255 comment="United States" list=
SafeCountries
add address=174.127.89.0-174.133.115.255 comment="United States" list=
SafeCountries
add address=174.133.120.0-174.136.105.191 comment="United States" list=
SafeCountries
add address=174.136.105.200-174.136.111.255 comment="United States" list=
SafeCountries
add address=174.136.128.0-174.136.201.255 comment="United States" list=
SafeCountries
add address=174.136.203.0-174.136.208.255 comment="United States" list=
SafeCountries
add address=174.136.210.0-174.136.219.255 comment="United States" list=
SafeCountries
add address=174.136.221.0-174.136.225.255 comment="United States" list=
SafeCountries
add address=174.136.227.0-174.137.47.255 comment="United States" list=
SafeCountries
add address=174.137.64.0-174.137.184.255 comment="United States" list=
SafeCountries
add address=174.137.187.0-174.137.191.255 comment="United States" list=
SafeCountries
add address=174.138.0.0/17 comment="United States" list=SafeCountries
add address=174.138.160.0/19 comment="United States" list=SafeCountries
add address=174.138.224.0-174.140.175.255 comment="United States" list=
SafeCountries
add address=174.140.192.0-174.141.255.255 comment="United States" list=
SafeCountries
add address=174.143.0.0-174.143.101.111 comment="United States" list=
SafeCountries
add address=174.143.101.128-174.255.255.255 comment="United States" list=
SafeCountries
add address=175.100.165.0/24 comment="United States" list=SafeCountries
add address=176.32.96.0/21 comment="United States" list=SafeCountries
add address=176.32.112.0-176.32.123.255 comment="United States" list=
SafeCountries
add address=176.32.125.0/25 comment="United States" list=SafeCountries
add address=176.61.140.0/22 comment="United States" list=SafeCountries
add address=176.67.80.0-176.67.84.247 comment="United States" list=
SafeCountries
add address=176.67.84.249-176.67.86.183 comment="United States" list=
SafeCountries
add address=176.67.86.188-176.67.87.255 comment="United States" list=
SafeCountries
add address=176.120.16.0/21 comment="United States" list=SafeCountries
add address=176.241.117.0-176.241.119.255 comment="United States" list=
SafeCountries
add address=177.234.139.0/28 comment="United States" list=SafeCountries
add address=178.17.233.0-178.17.237.255 comment="United States" list=
SafeCountries
add address=178.18.16.0/22 comment="United States" list=SafeCountries
add address=178.18.26.0-178.18.29.255 comment="United States" list=
SafeCountries
add address=178.57.66.128/25 comment="United States" list=SafeCountries
add address=178.76.140.0/23 comment="United States" list=SafeCountries
add address=178.76.147.0/24 comment="United States" list=SafeCountries
add address=178.76.149.0/24 comment="United States" list=SafeCountries
add address=178.76.152.0/23 comment="United States" list=SafeCountries
add address=178.76.158.0/24 comment="United States" list=SafeCountries
add address=178.76.160.0/23 comment="United States" list=SafeCountries
add address=178.76.165.0-178.76.166.255 comment="United States" list=
SafeCountries
add address=178.76.177.0-178.76.178.255 comment="United States" list=
SafeCountries
add address=178.76.180.0/24 comment="United States" list=SafeCountries
add address=178.76.184.0/23 comment="United States" list=SafeCountries
add address=178.170.139.0/24 comment="United States" list=SafeCountries
add address=178.255.86.0/29 comment="United States" list=SafeCountries
add address=178.255.86.12-178.255.86.255 comment="United States" list=
SafeCountries
add address=179.0.20.0/22 comment="Costa Rica" list=SafeCountries
add address=179.0.33.0/24 comment="Costa Rica" list=SafeCountries
add address=179.0.35.0-179.0.38.255 comment="Costa Rica" list=SafeCountries
add address=179.0.45.0-179.0.46.255 comment="Costa Rica" list=SafeCountries
add address=179.0.51.0/24 comment="Costa Rica" list=SafeCountries
add address=179.0.54.0-179.0.56.255 comment="Costa Rica" list=SafeCountries
add address=179.0.61.0-179.0.62.255 comment="Costa Rica" list=SafeCountries
add address=179.0.160.0/19 comment="Costa Rica" list=SafeCountries
add address=179.0.202.0/24 comment="Costa Rica" list=SafeCountries
add address=179.0.208.0/20 comment="Costa Rica" list=SafeCountries
add address=179.43.0.0/18 comment="Costa Rica" list=SafeCountries
add address=179.48.64.0-179.48.73.255 comment="Costa Rica" list=SafeCountries
add address=179.48.76.0-179.48.78.255 comment="Costa Rica" list=SafeCountries
add address=179.48.80.0/24 comment="Costa Rica" list=SafeCountries
add address=179.48.82.0-179.48.84.255 comment="Costa Rica" list=SafeCountries
add address=179.48.86.0-179.48.90.255 comment="Costa Rica" list=SafeCountries
add address=179.48.93.0-179.48.95.255 comment="Costa Rica" list=SafeCountries
add address=179.48.114.0/24 comment="Costa Rica" list=SafeCountries
add address=179.48.160.0/23 comment="Costa Rica" list=SafeCountries
add address=179.48.165.0-179.48.168.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.170.0-179.48.175.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.177.0-179.48.179.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.181.0-179.48.184.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.187.0-179.48.188.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.190.0/24 comment="Costa Rica" list=SafeCountries
add address=179.48.209.0-179.48.210.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.212.0/23 comment="Costa Rica" list=SafeCountries
add address=179.48.215.0-179.48.217.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.219.0/24 comment="Costa Rica" list=SafeCountries
add address=179.48.221.0-179.48.223.255 comment="Costa Rica" list=
SafeCountries
add address=179.48.248.0/22 comment="Costa Rica" list=SafeCountries
add address=179.50.128.0/17 comment="Costa Rica" list=SafeCountries
add address=179.51.128.0-179.51.141.255 comment="Costa Rica" list=
SafeCountries
add address=179.51.143.0-179.51.164.255 comment="Costa Rica" list=
SafeCountries
add address=179.51.166.0/24 comment="Costa Rica" list=SafeCountries
add address=179.51.168.0/23 comment="Costa Rica" list=SafeCountries
add address=179.51.171.0-179.51.190.255 comment="Costa Rica" list=
SafeCountries
add address=179.51.194.0-179.51.196.255 comment="Costa Rica" list=
SafeCountries
add address=179.51.198.0-179.51.204.255 comment="Costa Rica" list=
SafeCountries
add address=179.51.206.0-179.51.208.255 comment="Costa Rica" list=
SafeCountries
add address=179.51.210.0-179.51.212.255 comment="Costa Rica" list=
SafeCountries
add address=179.51.216.0/21 comment="Costa Rica" list=SafeCountries
add address=179.60.160.0/21 comment="Costa Rica" list=SafeCountries
add address=179.60.192.0/22 comment="United States" list=SafeCountries
add address=179.61.129.0/24 comment="United States" list=SafeCountries
add address=179.61.131.0/24 comment="United States" list=SafeCountries
add address=179.61.132.128-179.61.133.255 comment="United States" list=
SafeCountries
add address=179.61.135.0/24 comment="United States" list=SafeCountries
add address=179.61.136.128-179.61.137.255 comment="United States" list=
SafeCountries
add address=179.61.139.0/24 comment="United States" list=SafeCountries
add address=179.61.140.128-179.61.141.255 comment="United States" list=
SafeCountries
add address=179.61.143.0/24 comment="United States" list=SafeCountries
add address=179.61.144.128/25 comment="United States" list=SafeCountries
add address=179.61.148.128/25 comment="United States" list=SafeCountries
add address=179.61.149.128/25 comment="United States" list=SafeCountries
add address=179.61.152.128/25 comment="United States" list=SafeCountries
add address=179.61.155.128/25 comment="United States" list=SafeCountries
add address=179.61.156.128/25 comment="United States" list=SafeCountries
add address=179.61.160.128/25 comment="United States" list=SafeCountries
add address=179.61.161.16/28 comment="United States" list=SafeCountries
add address=179.61.161.128/25 comment="United States" list=SafeCountries
add address=179.61.164.128/25 comment="United States" list=SafeCountries
add address=179.61.167.128/25 comment="United States" list=SafeCountries
add address=179.61.168.128/25 comment="United States" list=SafeCountries
add address=179.61.172.128/25 comment="United States" list=SafeCountries
add address=179.61.173.128/25 comment="United States" list=SafeCountries
add address=179.61.176.128/25 comment="United States" list=SafeCountries
add address=179.61.179.128/25 comment="United States" list=SafeCountries
add address=179.61.180.128/25 comment="United States" list=SafeCountries
add address=179.61.184.128/25 comment="United States" list=SafeCountries
add address=179.61.185.128/25 comment="United States" list=SafeCountries
add address=179.61.188.128/25 comment="United States" list=SafeCountries
add address=179.61.190.128/25 comment="United States" list=SafeCountries
add address=179.61.191.128/25 comment="United States" list=SafeCountries
add address=179.61.194.0/25 comment="United States" list=SafeCountries
add address=179.61.195.0-179.61.197.255 comment="United States" list=
SafeCountries
add address=179.61.199.0/24 comment="United States" list=SafeCountries
add address=179.61.202.0/24 comment="United States" list=SafeCountries
add address=179.61.204.0/24 comment="United States" list=SafeCountries
add address=179.61.205.16/28 comment="United States" list=SafeCountries
add address=179.61.208.0/24 comment="United States" list=SafeCountries
add address=179.61.210.0/24 comment="United States" list=SafeCountries
add address=179.61.216.0/22 comment="United States" list=SafeCountries
add address=179.61.223.0/24 comment="United States" list=SafeCountries
add address=179.61.228.0/22 comment="United States" list=SafeCountries
add address=179.61.233.0-179.61.240.255 comment="United States" list=
SafeCountries
add address=179.61.242.0/24 comment="United States" list=SafeCountries
add address=179.61.245.0/24 comment="United States" list=SafeCountries
add address=179.61.248.0/24 comment="United States" list=SafeCountries
add address=179.63.0.0-179.63.68.255 comment="Costa Rica" list=SafeCountries
add address=179.63.71.0-179.63.74.255 comment="Costa Rica" list=SafeCountries
add address=179.63.77.0-179.63.79.255 comment="Costa Rica" list=SafeCountries
add address=179.63.81.0-179.63.84.255 comment="Costa Rica" list=SafeCountries
add address=179.63.86.0/23 comment="Costa Rica" list=SafeCountries
add address=179.63.89.0-179.63.90.255 comment="Costa Rica" list=SafeCountries
add address=179.63.93.0-179.63.94.255 comment="Costa Rica" list=SafeCountries
add address=179.63.96.0-179.63.112.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.115.0-179.63.117.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.119.0/24 comment="Costa Rica" list=SafeCountries
add address=179.63.123.0-179.63.127.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.133.0-179.63.134.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.136.0/23 comment="Costa Rica" list=SafeCountries
add address=179.63.140.0/23 comment="Costa Rica" list=SafeCountries
add address=179.63.144.0/24 comment="Costa Rica" list=SafeCountries
add address=179.63.147.0-179.63.150.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.152.0/22 comment="Costa Rica" list=SafeCountries
add address=179.63.157.0-179.63.158.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.160.0/22 comment="Costa Rica" list=SafeCountries
add address=179.63.165.0-179.63.167.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.170.0/24 comment="Costa Rica" list=SafeCountries
add address=179.63.172.0/24 comment="Costa Rica" list=SafeCountries
add address=179.63.174.0-179.63.178.255 comment="Costa Rica" list=
SafeCountries
add address=179.63.180.0/24 comment="Costa Rica" list=SafeCountries
add address=179.63.182.0-179.63.191.255 comment="Costa Rica" list=
SafeCountries
add address=180.87.185.216/30 comment="United States" list=SafeCountries
add address=180.94.73.0/24 comment="United States" list=SafeCountries
add address=180.94.79.0-180.94.80.255 comment="United States" list=
SafeCountries
add address=180.94.82.0/24 comment="United States" list=SafeCountries
add address=180.94.85.0-180.94.86.255 comment="United States" list=
SafeCountries
add address=180.94.90.0/25 comment="United States" list=SafeCountries
add address=180.94.90.192-180.94.91.255 comment="United States" list=
SafeCountries
add address=180.131.212.0/23 comment="United States" list=SafeCountries
add address=180.131.223.0/24 comment="United States" list=SafeCountries
add address=180.131.225.0-180.131.226.255 comment="United States" list=
SafeCountries
add address=180.131.228.0/23 comment="United States" list=SafeCountries
add address=180.131.232.0/22 comment="United States" list=SafeCountries
add address=180.131.240.0/24 comment="United States" list=SafeCountries
add address=180.131.245.0/24 comment="United States" list=SafeCountries
add address=180.131.249.0/24 comment="United States" list=SafeCountries
add address=180.222.138.0/24 comment="United States" list=SafeCountries
add address=180.240.179.0/24 comment="United States" list=SafeCountries
add address=181.41.32.0/19 comment="United States" list=SafeCountries
add address=181.41.128.0/23 comment="United States" list=SafeCountries
add address=181.41.131.0/24 comment="United States" list=SafeCountries
add address=181.41.136.0/22 comment="United States" list=SafeCountries
add address=181.41.160.0/19 comment="United States" list=SafeCountries
add address=181.41.195.0/24 comment="United States" list=SafeCountries
add address=181.41.199.0-181.41.200.255 comment="United States" list=
SafeCountries
add address=181.41.202.0/24 comment="United States" list=SafeCountries
add address=181.41.204.0/24 comment="United States" list=SafeCountries
add address=181.41.206.0-181.41.208.255 comment="United States" list=
SafeCountries
add address=181.41.209.138/31 comment="United States" list=SafeCountries
add address=181.41.209.160/30 comment="United States" list=SafeCountries
add address=181.41.213.0/24 comment="United States" list=SafeCountries
add address=181.41.215.0-181.41.216.255 comment="United States" list=
SafeCountries
add address=181.41.218.0/24 comment="United States" list=SafeCountries
add address=181.79.129.0/24 comment="United States" list=SafeCountries
add address=181.119.112.0/24 comment="United States" list=SafeCountries
add address=181.119.115.0-181.119.127.255 comment="United States" list=
SafeCountries
add address=181.174.168.0/22 comment="Costa Rica" list=SafeCountries
add address=181.174.208.0-181.174.220.255 comment="Costa Rica" list=
SafeCountries
add address=181.174.223.0-181.174.255.255 comment="Costa Rica" list=
SafeCountries
add address=181.177.89.48/29 comment="United States" list=SafeCountries
add address=181.177.113.24/29 comment="Costa Rica" list=SafeCountries
add address=181.177.113.168/29 comment="Costa Rica" list=SafeCountries
add address=181.177.115.64/28 comment="United States" list=SafeCountries
add address=181.177.117.64/29 comment="United States" list=SafeCountries
add address=181.177.126.72/29 comment="Costa Rica" list=SafeCountries
add address=181.189.0.0-181.189.61.255 comment="Costa Rica" list=
SafeCountries
add address=181.189.63.0-181.189.127.255 comment="Costa Rica" list=
SafeCountries
add address=181.191.244.0/22 comment="United States" list=SafeCountries
add address=181.193.0.0-181.193.146.255 comment="Costa Rica" list=
SafeCountries
add address=181.193.148.0-181.195.255.255 comment="Costa Rica" list=
SafeCountries
add address=181.214.1.0/24 comment="United States" list=SafeCountries
add address=181.214.2.16/28 comment="United States" list=SafeCountries
add address=181.214.3.0/24 comment="United States" list=SafeCountries
add address=181.214.5.0/24 comment="United States" list=SafeCountries
add address=181.214.7.0/24 comment="United States" list=SafeCountries
add address=181.214.9.0/24 comment="United States" list=SafeCountries
add address=181.214.11.0/24 comment="United States" list=SafeCountries
add address=181.214.13.0/24 comment="United States" list=SafeCountries
add address=181.214.15.0/24 comment="United States" list=SafeCountries
add address=181.214.17.0/24 comment="United States" list=SafeCountries
add address=181.214.19.0/24 comment="United States" list=SafeCountries
add address=181.214.21.0/24 comment="United States" list=SafeCountries
add address=181.214.23.0/24 comment="United States" list=SafeCountries
add address=181.214.25.0/24 comment="United States" list=SafeCountries
add address=181.214.27.0/24 comment="United States" list=SafeCountries
add address=181.214.29.0/24 comment="United States" list=SafeCountries
add address=181.214.31.0/24 comment="United States" list=SafeCountries
add address=181.214.32.128/25 comment="United States" list=SafeCountries
add address=181.214.37.0/24 comment="United States" list=SafeCountries
add address=181.214.38.128-181.214.39.255 comment="United States" list=
SafeCountries
add address=181.214.41.0/24 comment="United States" list=SafeCountries
add address=181.214.43.0/24 comment="United States" list=SafeCountries
add address=181.214.44.64-181.214.45.255 comment="United States" list=
SafeCountries
add address=181.214.47.0/24 comment="United States" list=SafeCountries
add address=181.214.49.0/24 comment="United States" list=SafeCountries
add address=181.214.52.0/24 comment="United States" list=SafeCountries
add address=181.214.56.0-181.214.203.255 comment="United States" list=
SafeCountries
add address=181.214.206.0-181.214.211.255 comment="United States" list=
SafeCountries
add address=181.214.214.0-181.214.255.255 comment="United States" list=
SafeCountries
add address=181.215.1.0/24 comment="United States" list=SafeCountries
add address=181.215.5.0/24 comment="United States" list=SafeCountries
add address=181.215.7.0/24 comment="United States" list=SafeCountries
add address=181.215.8.128-181.215.9.255 comment="United States" list=
SafeCountries
add address=181.215.11.0/24 comment="United States" list=SafeCountries
add address=181.215.13.0/24 comment="United States" list=SafeCountries
add address=181.215.15.0/24 comment="United States" list=SafeCountries
add address=181.215.17.0/24 comment="United States" list=SafeCountries
add address=181.215.19.0/24 comment="United States" list=SafeCountries
add address=181.215.21.0/24 comment="United States" list=SafeCountries
add address=181.215.23.0/24 comment="United States" list=SafeCountries
add address=181.215.25.0/24 comment="United States" list=SafeCountries
add address=181.215.27.0/24 comment="United States" list=SafeCountries
add address=181.215.29.0/24 comment="United States" list=SafeCountries
add address=181.215.31.0/24 comment="United States" list=SafeCountries
add address=181.215.33.0/24 comment="United States" list=SafeCountries
add address=181.215.35.0/24 comment="United States" list=SafeCountries
add address=181.215.37.0/24 comment="United States" list=SafeCountries
add address=181.215.39.0/24 comment="United States" list=SafeCountries
add address=181.215.41.0/24 comment="United States" list=SafeCountries
add address=181.215.43.0/24 comment="United States" list=SafeCountries
add address=181.215.45.0/24 comment="United States" list=SafeCountries
add address=181.215.47.0/24 comment="United States" list=SafeCountries
add address=181.215.49.0-181.215.132.255 comment="United States" list=
SafeCountries
add address=181.215.133.128/25 comment="United States" list=SafeCountries
add address=181.215.134.128/25 comment="United States" list=SafeCountries
add address=181.215.135.128/25 comment="United States" list=SafeCountries
add address=181.215.136.128/25 comment="United States" list=SafeCountries
add address=181.215.137.128/25 comment="United States" list=SafeCountries
add address=181.215.138.128-181.215.139.255 comment="United States" list=
SafeCountries
add address=181.215.140.128/25 comment="United States" list=SafeCountries
add address=181.215.141.88/29 comment="Costa Rica" list=SafeCountries
add address=181.215.141.128/25 comment="United States" list=SafeCountries
add address=181.215.142.128-181.215.143.255 comment="United States" list=
SafeCountries
add address=181.215.144.128-181.215.145.255 comment="United States" list=
SafeCountries
add address=181.215.146.128-181.215.147.255 comment="United States" list=
SafeCountries
add address=181.215.148.128-181.215.151.255 comment="United States" list=
SafeCountries
add address=181.215.152.128-181.215.153.255 comment="United States" list=
SafeCountries
add address=181.215.154.32-181.215.196.255 comment="United States" list=
SafeCountries
add address=181.215.198.0-181.215.255.255 comment="United States" list=
SafeCountries
add address=181.224.0.0/18 comment="Costa Rica" list=SafeCountries
add address=181.224.65.0/24 comment="Costa Rica" list=SafeCountries
add address=181.224.72.0/24 comment="Costa Rica" list=SafeCountries
add address=181.224.77.0-181.224.80.255 comment="Costa Rica" list=
SafeCountries
add address=181.224.82.0-181.224.90.255 comment="Costa Rica" list=
SafeCountries
add address=181.224.92.0/22 comment="Costa Rica" list=SafeCountries
add address=181.224.128.0-181.224.130.255 comment="United States" list=
SafeCountries
add address=181.224.132.0-181.224.134.255 comment="United States" list=
SafeCountries
add address=181.224.136.0-181.224.151.255 comment="United States" list=
SafeCountries
add address=181.224.192.0/21 comment="Costa Rica" list=SafeCountries
add address=181.224.216.0/21 comment="Costa Rica" list=SafeCountries
add address=181.232.128.0-181.233.66.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.68.0-181.233.72.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.74.0/24 comment="Costa Rica" list=SafeCountries
add address=181.233.76.0/24 comment="Costa Rica" list=SafeCountries
add address=181.233.78.0-181.233.87.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.89.0-181.233.91.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.93.0-181.233.97.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.99.0-181.233.100.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.103.0-181.233.108.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.110.0/24 comment="Costa Rica" list=SafeCountries
add address=181.233.112.0-181.233.117.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.119.0-181.233.147.255 comment="Costa Rica" list=
SafeCountries
add address=181.233.152.0-181.233.191.255 comment="Costa Rica" list=
SafeCountries
add address=182.54.238.0/24 comment="United States" list=SafeCountries
add address=184.0.0.0-184.21.255.255 comment="United States" list=
SafeCountries
add address=184.22.96.0/20 comment="United States" list=SafeCountries
add address=184.22.224.0-184.24.95.255 comment="United States" list=
SafeCountries
add address=184.24.98.0/24 comment="United States" list=SafeCountries
add address=184.24.112.0-184.24.191.255 comment="United States" list=
SafeCountries
add address=184.24.208.0-184.25.31.255 comment="United States" list=
SafeCountries
add address=184.25.48.0-184.25.106.255 comment="United States" list=
SafeCountries
add address=184.25.108.0-184.25.157.255 comment="United States" list=
SafeCountries
add address=184.25.160.0-184.25.215.255 comment="United States" list=
SafeCountries
add address=184.25.220.0-184.26.159.255 comment="United States" list=
SafeCountries
add address=184.26.161.0-184.26.164.255 comment="United States" list=
SafeCountries
add address=184.26.166.0-184.27.31.255 comment="United States" list=
SafeCountries
add address=184.27.36.0-184.27.135.255 comment="United States" list=
SafeCountries
add address=184.27.140.0-184.27.194.255 comment="United States" list=
SafeCountries
add address=184.27.196.0-184.27.205.255 comment="United States" list=
SafeCountries
add address=184.27.208.0/23 comment="United States" list=SafeCountries
add address=184.27.212.0-184.28.53.255 comment="United States" list=
SafeCountries
add address=184.28.58.0/23 comment="United States" list=SafeCountries
add address=184.28.62.0-184.28.73.255 comment="United States" list=
SafeCountries
add address=184.28.78.0/23 comment="United States" list=SafeCountries
add address=184.28.82.0/24 comment="United States" list=SafeCountries
add address=184.28.84.0-184.28.91.255 comment="United States" list=
SafeCountries
add address=184.28.94.0-184.28.97.255 comment="United States" list=
SafeCountries
add address=184.28.100.0/24 comment="United States" list=SafeCountries
add address=184.28.107.0-184.28.147.255 comment="United States" list=
SafeCountries
add address=184.28.152.0-184.28.179.255 comment="United States" list=
SafeCountries
add address=184.28.182.0-184.29.63.255 comment="United States" list=
SafeCountries
add address=184.29.68.0-184.30.95.255 comment="United States" list=
SafeCountries
add address=184.30.112.0-184.30.207.255 comment="United States" list=
SafeCountries
add address=184.30.224.0-184.31.79.255 comment="United States" list=
SafeCountries
add address=184.31.96.0-184.50.29.255 comment="United States" list=
SafeCountries
add address=184.50.32.0-184.50.94.255 comment="United States" list=
SafeCountries
add address=184.50.96.0-184.50.159.255 comment="United States" list=
SafeCountries
add address=184.50.176.0-184.51.145.255 comment="United States" list=
SafeCountries
add address=184.51.147.0/24 comment="United States" list=SafeCountries
add address=184.51.150.0-184.51.153.255 comment="United States" list=
SafeCountries
add address=184.51.154.128-184.51.201.255 comment="United States" list=
SafeCountries
add address=184.51.203.0-184.51.253.255 comment="United States" list=
SafeCountries
add address=184.52.0.0-184.63.255.255 comment="United States" list=
SafeCountries
add address=184.72.0.0-184.75.127.255 comment="United States" list=
SafeCountries
add address=184.75.144.0-184.75.207.255 comment="United States" list=
SafeCountries
add address=184.75.224.0-184.81.255.255 comment="United States" list=
SafeCountries
add address=184.83.0.0-184.84.181.255 comment="United States" list=
SafeCountries
add address=184.84.183.0-184.84.211.255 comment="United States" list=
SafeCountries
add address=184.84.216.0-184.84.220.255 comment="United States" list=
SafeCountries
add address=184.84.222.0-184.84.233.255 comment="United States" list=
SafeCountries
add address=184.84.236.0/23 comment="United States" list=SafeCountries
add address=184.84.239.0-184.84.255.255 comment="United States" list=
SafeCountries
add address=184.85.16.0-184.85.143.255 comment="United States" list=
SafeCountries
add address=184.85.160.0/20 comment="United States" list=SafeCountries
add address=184.85.192.0-184.85.222.255 comment="United States" list=
SafeCountries
add address=184.85.224.0-184.85.241.255 comment="United States" list=
SafeCountries
add address=184.85.244.0/22 comment="United States" list=SafeCountries
add address=184.85.249.0-184.85.250.255 comment="United States" list=
SafeCountries
add address=184.85.252.0/22 comment="United States" list=SafeCountries
add address=184.86.16.0-184.86.47.255 comment="United States" list=
SafeCountries
add address=184.86.64.0/20 comment="United States" list=SafeCountries
add address=184.86.84.0/22 comment="United States" list=SafeCountries
add address=184.86.92.0-184.86.99.255 comment="United States" list=
SafeCountries
add address=184.86.102.0-184.86.107.255 comment="United States" list=
SafeCountries
add address=184.86.112.0-184.86.175.255 comment="United States" list=
SafeCountries
add address=184.86.192.0/20 comment="United States" list=SafeCountries
add address=184.86.210.0-184.86.222.255 comment="United States" list=
SafeCountries
add address=184.86.232.0/22 comment="United States" list=SafeCountries
add address=184.86.240.0-184.87.175.255 comment="United States" list=
SafeCountries
add address=184.87.194.0-184.87.215.255 comment="United States" list=
SafeCountries
add address=184.87.224.0-184.93.255.255 comment="United States" list=
SafeCountries
add address=184.94.128.0-184.94.175.255 comment="United States" list=
SafeCountries
add address=184.94.192.0/18 comment="United States" list=SafeCountries
add address=184.95.16.0-184.95.191.255 comment="United States" list=
SafeCountries
add address=184.96.0.0-184.105.70.255 comment="United States" list=
SafeCountries
add address=184.105.72.0-184.105.77.255 comment="United States" list=
SafeCountries
add address=184.105.79.0-184.105.80.24 comment="United States" list=
SafeCountries
add address=184.105.80.26-184.105.80.93 comment="United States" list=
SafeCountries
add address=184.105.80.95-184.105.80.152 comment="United States" list=
SafeCountries
add address=184.105.80.154-184.105.81.52 comment="United States" list=
SafeCountries
add address=184.105.81.54-184.105.179.255 comment="United States" list=
SafeCountries
add address=184.105.181.0-184.105.213.233 comment="United States" list=
SafeCountries
add address=184.105.213.235-184.105.222.133 comment="United States" list=
SafeCountries
add address=184.105.222.135-184.106.255.255 comment="United States" list=
SafeCountries
add address=184.107.225.56/29 comment="United States" list=SafeCountries
add address=184.108.0.0-184.143.255.255 comment="United States" list=
SafeCountries
add address=184.152.0.0-184.154.170.15 comment="United States" list=
SafeCountries
add address=184.154.170.24-184.159.255.255 comment="United States" list=
SafeCountries
add address=184.164.0.0-184.169.47.255 comment="United States" list=
SafeCountries
add address=184.169.64.0/24 comment="United States" list=SafeCountries
add address=184.169.70.0-184.169.77.255 comment="United States" list=
SafeCountries
add address=184.169.96.0-184.169.255.255 comment="United States" list=
SafeCountries
add address=184.170.64.0/18 comment="United States" list=SafeCountries
add address=184.170.144.0-184.171.191.255 comment="United States" list=
SafeCountries
add address=184.171.224.0-184.173.255.255 comment="United States" list=
SafeCountries
add address=184.174.16.0-184.174.255.255 comment="United States" list=
SafeCountries
add address=184.175.64.0-184.175.70.255 comment="United States" list=
SafeCountries
add address=184.175.75.0/24 comment="United States" list=SafeCountries
add address=184.175.77.0-184.175.104.255 comment="United States" list=
SafeCountries
add address=184.175.106.0-184.175.119.255 comment="United States" list=
SafeCountries
add address=184.175.121.0-184.255.255.255 comment="United States" list=
SafeCountries
add address=185.9.168.0/22 comment="United States" list=SafeCountries
add address=185.9.236.0-185.9.243.255 comment="United States" list=
SafeCountries
add address=185.11.124.0/22 comment="United States" list=SafeCountries
add address=186.26.115.0/24 comment="Costa Rica" list=SafeCountries
add address=201.191.152.0/24 comment="Costa Rica" list=SafeCountries
add address=201.0.0.0/8 comment="Costa Rica" list=SafeCountries
add address=200.0.0.0/8 comment="Costa Rica" list=SafeCountries
add address=removed list=ERC_GatewayIPs
add address=removed comment="UBNT Office" list=SafeCountries
add address=166.182.86.41 comment="US Cellular" list=SafeCountries
add address=removed comment="UBNT whitelist" list=
SafeCountries
add address=removed list="Marshall Office"
add address=10.10.10.0/29 list="Marshall Office"
add address=removed comment="Allow removed VPN public IP" list=
"removed VPN"
add address=10.0.0.0/8 list=rfc1918
add address=172.16.0.0/12 list=rfc1918
add address=192.168.0.0/16 list=rfc1918
set enabled=yes
add action=accept chain=input src-address=removed
"Explicitly allows removed on the firewall" dst-address=removed
add action=add-src-to-address-list address-list=ssh_blacklist
address-list-timeout=4w2d chain=input connection-state=new dst-port=22
log=yes protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3
address-list-timeout=1m chain=input connection-state=new dst-port=22
protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2
protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1
protocol=tcp
add action=accept chain=input comment="input allow established"
connection-state=established
add action=accept chain=input comment="input allow related" connection-state=
related
add action=accept chain=input comment="Accept from Marshall Office Router"
src-address-list="Marshall Office"
add action=accept chain=forward comment="allow traffic to UCRM server"
dst-address=removed
add action=accept chain=input comment="input allow from admin-ips"
src-address-list=admin-ips
add action=accept chain=input comment="Accept ERC Upstream IPs"
src-address-list=ERC_GatewayIPs
add action=accept chain=forward comment="Allow removed Remote office"
dst-address=68.153.109.160
add action=accept chain=input comment="Allow ICMP (Ping)" protocol=icmp
add action=accept chain=forward comment=xbox dst-port=88 protocol=udp
add action=accept chain=forward comment=xbox dst-port=3074 protocol=udp
add action=accept chain=forward comment=xbox dst-port=3074 protocol=tcp
add action=accept chain=forward comment=xbox dst-port=53 protocol=tcp
add action=accept chain=forward comment=xbox dst-port=80 protocol=tcp
add action=accept chain=forward comment=xbox dst-port=3544 protocol=udp
add action=accept chain=forward comment=xbox dst-port=4500 protocol=udp
"Allow Already Stablished Connections" connection-state=established
add action=accept chain=forward comment="Allow Related Connections"
connection-state=related
add action=add-src-to-address-list address-list=Torrenters
address-list-timeout=none-dynamic chain=forward packet-mark=Torrent
add action=add-src-to-address-list address-list=Bittorrent_users
address-list-timeout=none-dynamic chain=forward comment=Bittorrent_users
layer7-protocol=Bittorrent
add action=drop chain=forward comment="Drops Identified P2P" disabled=yes
packet-mark=Torrent
add action=add-dst-to-address-list address-list=ftp_blacklist
address-list-timeout=3h chain=output content="530 Login incorrect"
protocol=tcp
add action=accept chain=output content="530 Login incorrect" dst-limit=
1/1m,9,dst-address/1m protocol=tcp
add action=accept chain=input comment="Allows SSH from Known Hosts" dst-port=
22 log=yes protocol=tcp src-address-list=InetSSH
add action=accept chain=input comment="Allows L2TP VPN" dst-port=1194
protocol=tcp
add action=accept chain=input dst-port=4500 protocol=udp src-address-list=
SafeCountries
add action=accept chain=input dst-port=1701 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp src-address-list=
SafeCountries
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input protocol=ipsec-ah
"Cisco VPN - ( ports 500, 4500, 10000 )" dst-port=10000 protocol=udp
add action=accept chain=input comment="Allows PPTP Connections" dst-port=1723
protocol=tcp
add action=accept chain=input protocol=gre
"Allows DNS Request from Internal Network" dst-port=53 in-interface=
!ether7-WAN protocol=udp
"Only Allow Connections From Internal Network" in-interface=!ether7-WAN
add action=accept chain=forward comment="Teleport TCP" dst-port=8051
protocol=tcp src-port=8051
add action=accept chain=forward comment="teleport UDP" dst-port=8051
protocol=udp src-port=8051
add action=drop chain=forward comment="Drop Invalid Connections"
connection-state=invalid disabled=yes protocol=tcp
add action=drop chain=forward comment="Block "bogon" IP addresses"
src-address=0.0.0.0/8
add action=drop chain=forward dst-address=0.0.0.0/8
add action=drop chain=forward src-address=127.0.0.0/8
add action=drop chain=forward dst-address=127.0.0.0/8
add action=drop chain=forward src-address=224.0.0.0/3
add action=drop chain=forward dst-address=224.0.0.0/3
add action=jump chain=forward comment="Make jumps to new chains" jump-target=
tcp protocol=tcp
add action=jump chain=forward jump-target=icmp protocol=icmp
add action=jump chain=forward jump-target=udp protocol=udp
add action=drop chain=tcp comment="Deny TFTP" dst-port=69 protocol=tcp
add action=drop chain=tcp comment="Deny RPC Portmapper" dst-port=111
protocol=tcp
add action=drop chain=tcp comment="Deny RPC Portmapper" dst-port=135
protocol=tcp
add action=drop chain=tcp comment="Deny NBT" dst-port=137-139 protocol=tcp
add action=drop chain=tcp comment="Deny CIFS" dst-port=445 protocol=tcp
add action=drop chain=tcp comment="Deny NFS" dst-port=2049 protocol=tcp
add action=drop chain=tcp comment="Deny NetBus" dst-port=12345-12346
protocol=tcp
add action=drop chain=tcp comment="Deny NetBus" dst-port=20034 protocol=tcp
add action=drop chain=tcp comment="Deny BackOriffice" dst-port=3133 protocol=
tcp
add action=drop chain=tcp comment="Drop DHCP" dst-port=67-68 protocol=tcp
add action=accept chain=udp comment="Accepts DNS Forwards" dst-port=53
packet-size=512-4096 protocol=udp
add action=drop chain=udp comment="Deny TFTP" dst-port=69 protocol=udp
add action=drop chain=udp comment="Deny RPC Portmapper" dst-port=111
protocol=udp
add action=drop chain=udp comment="Deny RPC Portmapper" dst-port=135
protocol=udp
add action=drop chain=udp comment="Deny NBT" dst-port=137-139 protocol=udp
add action=drop chain=udp comment="Deny NFS" dst-port=2049 protocol=udp
add action=drop chain=udp comment="Deny BackOriffice" dst-port=3133 protocol=
udp
add action=accept chain=icmp comment="Echo Reply" icmp-options=0:0 protocol=
icmp
add action=accept chain=icmp comment="Net Unreachable" icmp-options=3:0
protocol=icmp
add action=accept chain=icmp comment="Host Unreacheable" icmp-options=3:1
protocol=icmp
"Host Unreachable Fragmentation Required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="Allow Source Quench" icmp-options=4:0
protocol=icmp
add action=accept chain=icmp comment="Allow Echo Request" icmp-options=8:0
protocol=icmp
add action=accept chain=icmp comment="Allow Time Exceed" icmp-options=11:0
protocol=icmp
add action=accept chain=icmp comment="Allow Parameter Bad" icmp-options=12:0
protocol=icmp
add action=drop chain=icmp comment="Deny All Other Types" disabled=yes
add action=drop chain=input comment="Drop Invalid Connections"
add action=drop chain=input comment="Drop FTP Brute Forcers" dst-port=21
protocol=tcp src-address-list=ftp_blacklist
add action=drop chain=input comment="Drop SSH Brute Forcers" dst-port=22
protocol=tcp src-address-list=ssh_blacklist
add action=drop chain=input comment="Drop Everything Else"
/ip firewall mangle
add action=mark-connection chain=prerouting comment=removed (dst)" dst-address=
removed new-connection-mark=removed passthrough=yes
add action=mark-connection chain=prerouting comment="removed (src)"
new-connection-mark=removed passthrough=yes src-address=
removed
add action=mark-packet chain=prerouting comment=WEMT connection-mark=WEMT
new-packet-mark=WEMT passthrough=no
add action=mark-connection chain=prerouting comment=SpeedTest disabled=yes
new-connection-mark=SpeedTest passthrough=yes
add action=mark-packet chain=prerouting comment=SpeedTest connection-mark=
SpeedTest disabled=yes new-packet-mark=SpeedTest passthrough=no
add action=mark-connection chain=forward comment=Torrent disabled=yes
log-prefix="Torrent P2P" new-connection-mark=Torrent p2p=all-p2p
passthrough=yes
add action=mark-packet chain=forward comment=Torrent connection-mark=Torrent
disabled=yes new-packet-mark=Torrent passthrough=no
add action=mark-connection chain=forward comment="Torrent Web Pages"
disabled=yes layer7-protocol=torrent-wwws log-prefix="Torrent WWW"
new-connection-mark="Torrent WWW" passthrough=yes protocol=tcp
add action=mark-packet chain=forward comment="Torrent Web Pages"
connection-mark="Torrent WWW" disabled=yes new-packet-mark=Torrent
passthrough=no
add action=mark-connection chain=forward comment="Torrent DNS" disabled=yes
dst-port=53 layer7-protocol=torrent-dns new-connection-mark="Torrent DNS"
passthrough=yes protocol=udp
add action=mark-packet chain=forward comment="Torrent DNS" connection-mark=
"Torrent DNS" disabled=yes new-packet-mark=Torrent passthrough=no
add action=mark-connection chain=prerouting comment=DNS connection-state=new
disabled=yes new-connection-mark=DNS passthrough=yes port=53 protocol=udp
add action=mark-packet chain=prerouting comment=DNS connection-mark=DNS
disabled=yes new-packet-mark=DNS passthrough=no
add action=mark-connection chain=postrouting comment=DNS connection-state=new
add action=mark-packet chain=postrouting comment=DNS connection-mark=DNS
add action=mark-connection chain=prerouting comment=VOIP disabled=yes
new-connection-mark=VOIP passthrough=yes port=5060,5061,10000-20000
protocol=udp
add action=mark-packet chain=prerouting comment=VOIP connection-mark=VOIP
disabled=yes new-packet-mark=VOIP passthrough=no
add action=mark-connection chain=prerouting comment=UDP connection-state=new
disabled=yes new-connection-mark=UDP passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment=UDP connection-mark=UDP
disabled=yes new-packet-mark=UDP passthrough=no
add action=mark-connection chain=prerouting comment=ICMP connection-state=new
disabled=yes new-connection-mark=ICMP passthrough=yes protocol=icmp
add action=mark-packet chain=prerouting comment=ICMP connection-mark=ICMP
disabled=yes new-packet-mark=ICMP passthrough=no
add action=mark-connection chain=postrouting comment=ICMP connection-state=
new disabled=yes new-connection-mark=ICMP passthrough=yes protocol=icmp
add action=mark-packet chain=postrouting comment=ICMP connection-mark=ICMP
add action=mark-packet chain=postrouting comment=ACK disabled=yes
new-packet-mark=ACK packet-size=0-123 passthrough=no protocol=tcp
tcp-flags=ack
add action=mark-packet chain=prerouting comment=ACK disabled=yes
tcp-flags=ack
add action=mark-connection chain=prerouting comment="HTTP BIG"
connection-bytes=100000000-0 connection-rate=200k-100M disabled=yes
new-connection-mark=HTTP_BIG passthrough=yes port=80,443 protocol=tcp
add action=mark-packet chain=prerouting comment="HTTP BIG" connection-mark=
HTTP_BIG disabled=yes new-packet-mark=HTTP_BIG passthrough=no
add action=mark-connection chain=prerouting comment=HTTP connection-mark=
!HTTP_BIG connection-state=new disabled=yes new-connection-mark=HTTP
add action=mark-packet chain=prerouting comment=HTTP connection-mark=HTTP
disabled=yes new-packet-mark=HTTP passthrough=no
add action=mark-connection chain=prerouting new-connection-mark=removed
passthrough=yes src-address=removed
add action=mark-connection chain=prerouting dst-address=removed
add action=mark-packet chain=prerouting connection-mark=removed
new-packet-mark=removed passthrough=no
add action=passthrough chain=prerouting comment=OTHER connection-mark=no-mark
add action=accept chain=srcnat src-address=10.10.10.0/29
add action=src-nat chain=srcnat comment="Local to Internet NAT"
out-interface=ether7-WAN src-address-list=rfc1918 to-addresses=
removed
add action=masquerade chain=srcnat comment="masq vpn network" src-address=
10.222.222.0/24
there is the firewall yes I know its a mess fixing it is a work in progress
sindy
August 5, 2019, 11:09am
11
OK. So you ask RouterOS to generate the settings for L2TP for you using the default profile , proposal , and template in the default policy group by setting use-ipsec=required in /interface l2tp-server server , but at the same time you have created a peer and identity on your own, so there may be a collision. I would recommend to remove the manually added peer and identity, set the encryption and authentication algorithms you need for your client devices in the default profile , disable and re-enable the /interface l2tp-server server and see whether it becomes better. /ip ipsec peer print and /ip ipsec identity print should show you a peer and identity with a D in the second column, informing you that these items were dynamically created.
If your clients use Windows 10, it may be even more colourful as mine stopped even attempting L2TP/IPsec connection after one of the recent updates. So /tool sniffer quick port=500 is the first thing to run if the changes above don’t help, to check that some connection attempts from clients do arrive.
OK, so I removed what you said
But when I re-enabled the L2TP server the log is showing failed to bind to ::[500] bad file descriptor
and VPN is still now working
thanks for the help by the way
sindy
August 5, 2019, 11:37am
13
The failed to bind message is a cosmetic issue as you have disabled IPv6, it’s not the reason why it doesn’t work. Set /system logging print add topics=ipsec,!packet and see whether the log shows anything when the client tries to connect.
when client tries to connect I get ipsec error “IP” peer sent packet for dead phase2
that is the only error in the log I see for a client trying to connect
also that set commnad dose not seem to work
but I already have ipsec debug enabled for the logs
sindy
August 5, 2019, 11:46am
16
Have you added the log topic I have suggested? Because if you did, you have to see tons of ipsec,info messages. How exactly did you set the debug?
emils
August 5, 2019, 11:52am
17
I would guess the policy generation fails since it does not match the policy template:
/ppp profile
add change-tcp-mss=yes local-address=10.222.22.1 name=\
"L2TP Remote Connection" remote-address="VPN Pool" use-encryption=\
required
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=10.222.22.1/32
So Do I delete the IPsec policies??
what do I need to do to fix it?
I’m a neewbie when it comes to mikrotik sorry
the other issue is I’m out of the country and the firewall is blocking the country I’m in
so each time I need to test I have to contact somone in the states to test the VPN
if somone understands the country access list (I did not Make it)
if you can please give me a terminal command to allow my WAN to VPN you will be a hero
sindy
August 5, 2019, 12:13pm
20
Just remove the src-address-list from the rules permitting access to UDP ports 500 and 4500
