I’m planning to deploy BGP at my WISP.
Now I’m using MT so I’d like to know how MT works about BGP.
I didn’t found much discussions about it so I’m little bit scary.
Any experience?
thanks
Any experience?
thanks
BGP is routing OK, the config is as simple as possible, but there is a lack of features, see this short manual: http://www.mikrotik.com/docs/ros/2.8/routing/bgp.main.
Just out of intrest how do you get BGP in routeros to inject the default gateway.
Add a static route on one of your routers and issue the following command (assuming BGP is already enabled):
/routing bgp set redistribute-static=yes
