I have issue with my Mikrotik’s it looks like theare are bloking access to Office365 account in my company or block access to proxy.
My Mikrotik is configured to work in Bridge mode on all ports, so it should work like normal swich in L2.
I tested 2 device RB760iGS (6.42.10) and RouterBOARD 750 r2 (6.42.10) and both have the same problem , Microsoft Outlook can not connect to Exchange - in status bar.
In my comopany wy use proxy server to access internet. I’m able to access to internet (web mail https://outlook.office365.com/mail/inbox etc.) form my PC and ping Lan IP and websites from Mikrotik.
I setup router with and without defaul Configuration, add extra firewall rules with no result.
Please help me resolve this problem and check my config maybe I missed something :
That’s almost craziest firewall filter ruleset I’ve seen so far. And without any effect for that matter.
Anyway, if you want RB to act as ethernet switch, start off from an empty config, create a bridge and add all ethernet ports to it. No other bridge settings, no IP address, nothing.
At this point RB is a switch. If you can’t access office365, then it’s not RB blocking it, it’s something else.
After many tries I start setup like you said “creazy rules” because I have no idea whay Mikrotik act so strange. Any others switches dont have so kind of problem I tested HP/Aruba Cisco TP link Netgar etc.
When I connect to Mikrotik, Microsoft Outlook stops on Loading Profile and I need to disconnect Network Cable, to open application and after reconect Cable Outlook is “Trying to connect”
Does anyone have any ideas how to resolve this problem?
“I have issue with my Mikrotik’s it looks like theare are bloking access to Office365 account in my company or block access to proxy.”
Trying to bypass corporate security ???
If other switches work, then at least use the MKT as switch. All interfaces bridged is OK. But don’t do /interface bridge settings set use-ip-firewall=yes
In a corporate network under my supervision your switches would have stopped all your network access immediately !
If no DHCP server is set up on a Mikrotik acting as a mere bridge (i.e. also use-ip-firewall=no), and there are no bridge filter/nat rules, there is no reason why Office 365 should be affected selectively. So it looks like either a more generic problem which you have only noticed when connecting to O365. With such a simple configuration (transparent bridge), the only reason I can imagine is some L2 MTU one. So as @erlinden suggests, as the first step I’d updgrade to a current long-term RouterOS (which is 6.46.7 as of writing this), reset the configuration to default after the upgrade, and then disable the DHCP server on the bridge. Ignore ether1 for the moment, use any of the remaining etherX interfaces as the uplink and to connect your laptop, and try whether the access to the O365 works. If yes, you can go step by step towards your desired configuration, checking that the login to O365 is still possible after each step.
Finally, good news, I find root cause of the problem
Today I did a little investigation and it turned out that the problem does not affect all computers.
The virtual network card added by VirtualBox (6.0.4-128413) turned out to be problematic, I do not know how yet, but there is some dependence here with Mikrotik.
After disabling this Network Adapter, Outlook starts up and connect to Exchange
So it had nothing to do with Mikrotik, you do know that you hurts its feelings…
MT may sue for slander!!
Thank god MT detected the anomaly and card fault, albeit not directly.
In any case, keep your OS current is the one thing you should get out of this thread!!!
