Mikrotik CCR 1036 802.3ad Bond with Cisco3560 over etherchannel LACP
Hello to all
I have a CCR1036-12G-4S and a WS-C3560X-48PF-S.
I created a LACP between these two with config blow, but instead of speed getting quadrupled, it got very slow (300 Mbps).
I need help.
Mikrotik:
/interface bonding
add arp=enabled arp-interval=100ms arp-ip-targets="" arp-timeout=auto comment=\
    "etherchannel between cisco and router" disabled=no \
    down-delay=0ms !forced-mac-address lacp-rate=30secs link-monitoring=mii \
    mii-interval=100ms min-links=0 mode=802.3ad mtu=1500 name=bonding-SW1 \
    primary=none slaves=ether1,ether2,ether3,ether4 transmit-hash-policy=\
    layer-2-and-3 up-delay=0ms
Cisco:
port-channel load-balance src-dst-ip
interface Port-channel1
 switchport trunk allowed vlan 1,16,20,50,100,120,130,140-142,150,151,160,170
 switchport trunk allowed vlan add 180
 switchport trunk encapsulation dot1q
 switchport mode trunk
 interface GigabitEthernet0/1
 channel-protocol lacp
 channel-group 1 mode active
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
on the cisco I would say that it is sufficient to indicate the trunk and the vlan ids only in the port channel and not in the individual ports
