Mikrotik CCR2004-12S+2XS with GPON
Good morning,
I have a MikroTik CCR2004-12S+2XS and am experiencing connection issues with my provider. I have a 2.5 Gbps GPON PPPoE connection via OpenFiber. My MikroTik is connected to the ONT through the SFP+1 port using a MikroTik S+RJ10 module, which negotiates at 2.5 Gbps. I have disabled auto-negotiation on the module and forced it to 10 Gbps; "FastTrack" is also enabled. However, speed tests do not exceed 950 Mbps. For these tests, I am using a 25 Gbps server located outside of the created bridge.
Below, you will find my MikroTik configuration. Could someone please help me resolve this issue?
# 2026-11-11 12:37:47 by RouterOS 7.25.1
# medel = CCR2004-1G-12S+2XS
/ip neighbor discovery-settings set discover-interface-list=!dynamic
/ip cloud set back-to-home-vpn=enabled ddns-enabled=yes
/ip dhcp-server network add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.254
/ip firewall address-list add address=192.168.1.0/24 list=LAN-OK
/ip pool add name=LAN-DHCP ranges=192.168.1.1-192.168.1.121
/ip ssh set host-key-type=rsa known-hosts-validation=no
/ip service set www-ssl disabled=no
/interface bridge add name=LAN
/interface ethernet set \[ find default-name=sfp-sfpplus1 \] advertise=2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT rx-flow-control=on tx-flow-control=on
/interface ethernet set \[ find default-name=sfp-sfpplus6 \] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-full,1G-baseT-half,1G-baseT-full,1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR
/interface ethernet set \[ find default-name=sfp-sfpplus7 \] auto-negotiation=no speed=10G-baseT
/interface ethernet set \[ find default-name=sfp-sfpplus10 \] auto-negotiation=no speed=10G-baseSR-LR
/interface ethernet set \[ find default-name=sfp-sfpplus12 \] auto-negotiation=no speed=1G-baseT-full
/interface ethernet set \[ find default-name=sfp28-1 \] auto-negotiation=no fec-mode=fec74 rx-flow-control=on speed=25G-baseSR-LR tx-flow-control=on
/interface pppoe-client add add-default-route=yes disabled=no interface=sfp-sfpplus1 keepalive-timeout=disabled name=OPENFIBER-OUT use-peer-dns=yes user=openfiber
/interface wireguard add comment=back-to-home-vpn listen-port=40063 mtu=1420 name=back-to-home-vpn
/interface wireguard add listen-port=46880 mtu=1420 name=wireguard-1
/interface vlan add disabled=yes interface=sfp-sfpplus1 name=OPENFIBER vlan-id=100
/interface wireguard peers add allowed-address=10.0.10.3/32 interface=wireguard-1 name=peer1 public-
/interface wireguard peers add allowed-address=10.0.10.4/32 interface=wireguard-1 name=peer2 public-
/ip address add address=192.168.1.254/24 interface=LAN network=192.168.1.0
/ip address add address=10.0.10.1/24 interface=wireguard-1 network=10.0.10.0
/ip address add address=192.168.10.254/24 comment=server interface=sfp28-1 network=192.168.10.0
/ip dhcp-client add comment=WAN interface=sfp-sfpplus1 name=sfp-sfpplus1
/ip dhcp-server add address-pool=LAN-DHCP interface=LAN lease-time=1d name=DHCP-SERVER
/ip dns set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall filter add action=fasttrack-connection chain=forward connection-state=established,related
/ip firewall filter add action=accept chain=input connection-state=established,related,untracked
/ip firewall filter add action=accept chain=input src-address-list=LAN-OK
/ip firewall filter add action=accept chain=forward comment="Plex alt port" connection-nat-state=dstnat dst-port=32400 in-interface=OPENFIBER-OUT protocol=tcp
/ip firewall filter add action=accept chain=input dst-port=46880 protocol=udp
/ip firewall filter add action=accept chain=input dst-port=1194 protocol=tcp
/ip firewall filter add action=accept chain=forward dst-port=8123 protocol=tcp
/ip firewall filter add action=accept chain=forward dst-port=80,443,8555,8666,8000 protocol=tcp
/ip firewall filter add action=accept chain=forward connection-nat-state=dstnat dst-port=32400 protocol=tcp
/ip firewall filter add action=accept chain=input comment=Torrent dst-port=50413 protocol=udp
/ip firewall filter add action=accept chain=input comment=Torrent dst-port=50413 protocol=tcp
/ip firewall filter add action=accept chain=input comment="BTH clients" in-interface=back-to-home-vpn
/ip firewall filter add action=accept chain=input comment="WG clients" in-interface=wireguard-1
/ip firewall filter add action=drop chain=input dst-port=53 protocol=udp src-address-list=!LAN-OK
/ip firewall filter add action=add-src-to-address-list address-list=BAN address-list-timeout=none-dynamic chain=input
/ip firewall filter add action=drop chain=input in-interface=!LAN log=yes log-prefix="\[BAN IP\]"
/ip firewall filter add action=accept chain=forward dst-address-list=LAN-OK src-address-list=LAN-OK
/ip firewall filter add action=accept chain=forward connection-state=established,related
/ip firewall filter add action=drop chain=forward connection-state=invalid log=yes log-prefix="\[INVALID\]"
/ip firewall filter add action=accept chain=forward in-interface=LAN log=yes log-prefix="\[LAN\_!LAN\]" src-address=192.168.1.0/24
/ip firewall mangle add action=change-mss chain=forward dst-port=6 new-mss=clamp-to-pmtu out-interface=OPENFIBER-OUT protocol=tcp tcp-flags=syn
/ip firewall mangle add action=change-mss chain=forward comment="Fix PPPoE MSS Out" new-mss=clamp-to-pmtu out-interface=OPENFIBER-OUT protocol=tcp tcp-flags=syn
/ip firewall nat add action=masquerade chain=srcnat out-interface=OPENFIBER-OUT
/ip firewall nat add action=dst-nat chain=dstnat dst-port=443 in-interface=OPENFIBER-OUT port="" protocol=tcp to-addresses=192.168.1.66 to-ports=443
/ip firewall nat add action=dst-nat chain=dstnat dst-port=50413 in-interface=OPENFIBER-OUT protocol=tcp to-addresses=192.168.1.24 to-ports=50413
/ip firewall nat add action=dst-nat chain=dstnat dst-port=50413 in-interface=OPENFIBER-OUT protocol=udp to-addresses=192.168.1.24 to-ports=50413
/ip firewall nat add action=dst-nat chain=dstnat dst-port=40063 in-interface=OPENFIBER-OUT protocol=udp to-addresses=192.168.1.254 to-ports=40063
/ip firewall nat add action=dst-nat chain=dstnat dst-port=8123 in-interface=OPENFIBER-OUT protocol=tcp to-addresses=192.168.1.51 to-ports=8123
/ip firewall nat add action=dst-nat chain=dstnat dst-port=32400 in-interface=OPENFIBER-OUT protocol=tcp to-addresses=192.168.10.24 to-ports=32400
/ip firewall nat add action=dst-nat chain=dstnat dst-port=32401 in-interface=OPENFIBER-OUT protocol=tcp to-addresses=192.168.10.24 to-ports=32400
/system clock set time-zone-name=Europe/Rome
/system health settings set fan-min-speed-percent=10%
/system identity set name=CCR2004
/system routerboard settings set auto-upgrade=yes
/interface bridge port add bridge=LAN interface=sfp-sfpplus4
/interface bridge port add bridge=LAN interface=sfp-sfpplus3
/interface bridge port add bridge=LAN interface=sfp-sfpplus2
/interface bridge port add bridge=LAN interface=sfp-sfpplus5
/interface bridge port add bridge=LAN interface=sfp-sfpplus6
/interface bridge port add bridge=LAN interface=sfp-sfpplus7
/interface bridge port add bridge=LAN interface=sfp-sfpplus8
/interface bridge port add bridge=LAN interface=sfp-sfpplus9
/interface bridge port add bridge=LAN interface=sfp-sfpplus10
/interface bridge port add bridge=LAN interface=sfp-sfpplus11
/interface bridge port add bridge=LAN interface=sfp-sfpplus12
/interface bridge port add bridge=LAN interface=sfp28-2
/interface bridge port add bridge=LAN interface=ether1
< fixed code quotes for readability >
I can not fully comment on the functional part but I do know that when using S+RJ10 you should NOT touch autonegotation nor speed setting for that module. It will adapt itself based on the advertised speed from the other side.
Having said that, please also check your cable from SFP to ONT to be sure that's not the one limiting you to 1Gbps.
