OK - Like WTF? I did your Step #2 Try disable “Use Network APN”… And I can now get out… Explain this to me… I am super Happy it is working - but at the same time - very confused… pda.bell.ca works on 3 other LTE devices… I am SURE we tried internet as the default APN as well - and without success… Anyway - What ever the reason - THANK YOU!! Super happy it is working… We have a similar issue with the MikroTik Audience - I will give it a try… Woo Hoo! Many Thanks… ( I just wish I could understand the reason!)
Hi restended… Sorry for the confusion, I did indeed follow your advice on your 2nd Post & Post #9… See my replies below… your advice had APN=no, so yes - I guess it would have worked - but it did not work with the previous release that the Chateau was running… Now that I am at the very latest release - it seemed to have worked… My apologies! Lots of factors working with a device that doesn’t have a stable release I guess… I really appreciate all the assistance… Could not have figured it out without the assist…
My reply 2nd Post:
Thanks much for the post… Yes, the APN was set via the QuickSet when we were doing the testing. If you didn’t see it in the rsc file its probably one of the iterations where we had just reset the unit to factory. The SIM we used in other LTE devices without issue… We have always been trying the configuration as close to default as possible just to eliminate any issues made in the config… ie. Plug in the SIM and set the APN and it should work… We just managed to get a MikroTik Audience LTE 6 going with the BELL SIM and the same APN… I ran the commands provided on the Chateau-12 with no success to get out to the Internet - However, yes, we are able to do NSLOOKUP...
My reply Post #9:
Sorry! In Toronto at the ERU Warehouse… was away form the laptop. OK - Done but with no change - can still NSLookup though! Just can’t get out to surf… Have included latest RSC File…
