We have a Mikrotik virtual CHR hosted on AWS working as the VPN gateway between our office and AWS cloud(using SSTP tunnel), which works perfect.
Recently one of our partner needs to build an IPsec tunnel to us, and we’d like to use this CHR as the peer on our side. However, the IPsec tunnel does not established.
Our AWS CHR is pretty simple with only one interface(both private and public IP assigned by AWS).
Does anyone have experience configure IPsec in AWS CHR before? Any comment will be appreciated.
AWS Doesn’t normally pass a true public to the guest VM so you need to make sure that you have NAT Traversal enabled for IPSEC. What are the settings you are using? Can you share your config?
I literally finished setting this up myself this morning.
Absolutely as above. You get a private LAN which is 1:1 NAT with a real public IP. You need NAT traversal and the key for me was IPSEC-ESP being open in the firewall.
My CHR at home connects no problem as well as parents RB750 but I had to do a registry “hack” in W10 to get it to connect.
The easiest way around that is to set Amazon AWS to forward “ALL” traffic onto the CHR istance rather than allowing specific ports and then control the firewall from the CHR. I did the registry hack on my laptop so it works from behind a NAT, my CHR at home works fine (+cool routing rules), my phone works on LTE but not on WiFi (must be a NAT-T setting not built into Android).
I have NAT-T enable, and how can make sure I open the IPSEC-ESP in the firewall?
I just edit the security group on the CHR instance make sure the port 500, 4500 are opened to the peer. Do I need to do something in the CHR firewall rules?
Here is a good tutorial on how to open ports in AWS. And I do not agree that you should just open all ports. Unless you are an ISP or Hosting Data Center that has other security appliances deployed, You should only allow the ports that you need and deny the rest. AWS Has great security appliances that protect your VMs, use them.
Why poke holes in a firewall you have little control over when you can forward all traffic to a firewall you have full control over? The option is easily accessible through MikroTik. If AWS don’t give you option for it, make your life easier by putting a decent firewall on your CHR and pass everything through.
I am not sure if I am doing what you said, currently I have following routes on my AWS VPC:
0.0.0.0/0 target to the Internet gateway
All internal static routes target to the CHR interface
Can I know why use Mikrotik CHR instead of AWS VPN service? Some feature that AWS VPN does not support?
Cause I am trying to connect Mkrotik in my DC to AWS VPN and is facing issues getting it setup properly. My lack of skill with mikrotik is getting the better of me. And the project is due yesterday. Imagine the pressure I am facing getting it working.
