Hi everyone, I have a situation. In my setup, I have two links with internet and need choose one of those to be my cloud ip. How I make this ?
Thanks ![]()
Thanks ![]()
I’d use policy routing - create a dynamic address list:
/ip firewall address-list
add address=cloud.mikrotik.com list=mikrotik-cloud
add address=cloud2.mikrotik.com list=mikrotik-cloud
An address-list configured this way is automatically updated with dynamic entries representing all the IP numbers to which these fqdns resolve.
Then, use a mangle rule to assign a routing-mark to all packets the router itself sends towards these destinations:
/ip firewall mangle
add chain=output dst-address-list=mikrotik-cloud action=mark-routing new-routing-mark=via-wan-x
The next thing is to add a route to actually use the routing-mark assigned:
add routing-mark=via-wan-x gateway=ip.of.wan-x.gw
The above seems to be all, but nope, two more points come into play that are not obvious:
Dear,
I’m also facing problem with Cloud over dual Wan and two gateway.
Can you show me screenshot of this solution how I can resolve this
Thanks ![]()
Set up 2 dyndns like services. Set them to update the actual interface they are on.
I.e.
Ether 1 = primary.mydomain.com
Ether 2 = secondary.mydomain.com
So the netname is updated on both on a schedule.
Then use the built in ipcloud netname as your “connect to what’s hot”.
Sindy.
I’m waiting for your kind response.
Thanks ![]()
Dealing with the 2 ISPs would be:
Recursive routing.
Multiple dyndns like hosts:
Account.dyn.com
Sir, can you share your whatsapp number nmbr for help?
Thanks ![]()
Sindy, do pray tell, what is the value of this IP, in other words, how does the router find out what the IP is???>>
Second the question is :how do I choose one of the WANIPs to be my cloud IP.
I dont understand the question and thus dont understand your answer either.
The cloud IP is assigned per router, not per ISP connection.
Also, is this a load balance scenario or use one and the other is strictly for failover?
I don’t use Facebook if I can avoid it.
Knowing what the people I know think and realizing just how f–king stupid they are, has made me grind my teeth at night… And drink during the day to get some sleep.
Recursive routing has been covered here a bunch of times.
You need to set up your routes to use it.
Once done… The router will “check external hosts”. As long as those are reachable… It will use the LOWER cost IP as it’s connection. IGNORING the secondary.
This is important… There is no load balancing in “recursive routing” by default. It’s simply… “This one works… Push traffic over it.”
I dont understand the question and thus dont understand your answer either.The cloud IP is assigned per router, not per ISP connection.
All the above are various aspects of the same thing.
From the bottom
The Mikrotik cloud determines the public address of the router (or the public address of the NAT device via which the router is connected to internet) to respond with to the DNS queries about the xxxx.sn.mynetname.net by looking at the source address of the received update packets from the router. Plus it tells you in the response what that address was, so your router can compare it to the one it has sent the update request from, and print a warning if they differ.
So if you have multiple WANs, the address associated to xxxx.sn.mynetname.net may change depending on your routing configuration and state of the WAN interfaces. If you want to affect the result, you must configure specific routing for the cloud updates, to force them to be routed via the desired WAN. The way to do that is in my answer to the OP.
As for determining the IP of the gateway of that WAN, either you don’t need the router itself to determine it because it doesn’t change (it is a typical case that you have a high-speed WAN with a dynamic or private address so you use it for most of the traffic, and then you have a low-speed one with a fixed public address which you want to use for remote access), or you need a script similar to the one we have recently disussed, to copy the gateway IP to the marked route each time a DHCP assignment is received.
Is any one has solutions of Mikrotik Cloud over dual wan. (dual gateway)
Thanks ![]()
Did you not understand?
Ip cloud updates 1 interface.
Dear,
Please explain your requirements with respect to the two ISP connections.
An address-list configured this way is automatically updated with dynamic entries representing all the IP numbers to which these fqdns resolve.Then, use a mangle rule to assign a routing-mark to all packets the router itself sends towards these destinations:
/ip firewall mangle
add chain=output dst-address-list=mikrotik-cloud action=mark-routing new-routing-mark=via-wan-xThe next thing is to add a route to actually use the routing-mark assigned:
add routing-mark=via-wan-x gateway=ip.of.wan-x.gwThe above seems to be all, but nope, two more points come into play that are not obvious:
- if wan-x goes down, no active route with routing-mark=via-wan-x will remain, and the routing will fall back to the main routing table in such case. You can prevent this by adding
- either a type=blackhole default route with routing-mark=via-wan-x and distance=10
- or a routing rule:
/ip route rule
add routing-mark=via-wan-x action=lookup-only-in-table table=via-wan-x- the routing in chain output (packets originated by the router itself) is done before the packets pass through the mangle table, so the source address is chosen according to the default route currently active. If a routing-mark is assigned in the output chain of mangle, the routing is repeated but the source address of the packet doesn’t change. So you have to add a src-nat or masquerade rule to change this:
add chain=srcnat action=masquerade routing-mark=via-wan-x src-address-type=local
This worked for me, thanks.
Have been looking for a way to access my router from WAN and was stuck with my script sending me emails with updated public IP which was only provided by one out of three of my ISPs.
The trouble is finally over, with google disabling support for the insecure SMTP.
Google has introduced a per-device generated password that can be used for this. Mikrotik can send e-mails using TLS.
You can also have a look at sending notifications via Telegram - there are several related topics here.
