Mikrotik CPU usage on 100%
My Mikrotik L009UiGS-2HaxD-in shows 100% CPU usage and yet it has few hotspot users, when I check under /tools profile, it shows "Management and Console" are taking up 40% and 20% of the CPU respectively, how can I fix this without factory reset?
Having a look "under the hood" would be helpfull:
/export file=anynameyoulike
Remove serial and any other private info, post as Preformatted text by using the </> button
What kind of datarate does it show for the internet interface?
when i paste code, it says 400 Bad request
Right now its 3.4M/58M, but CPU usage rises steadily for sometime to almost 100%. then it drops to normal 18%, 22%. i have an average 65 hotspot users.
# 2025-08-15 13:13:37 by RouterOS 7.19.1
# software id = RX5B-BH4R
# model = L009UiGS-2HaxD
# serial number =
add name=bridge1-LAN
add name=bridge2-HOTSPOT
set [ find default-name=ether1 ] name=ether1-ISP
set [ find default-name=ether2 ] name=ether2-LAN
set [ find default-name=ether8 ] poe-out=forced-on poe-priority=1
/interface sstp-client
add comment=Remotemikrotik.com connect-to=server3.remotemikrotik.com \
    disabled=no name=RemoteMikrotik user=RM17444431334427
add name=WAN
add name=LAN
/interface wifi channel
add band=2ghz-n disabled=no frequency=2300-7300 name=channel1 width=20/40mhz
/interface wifi
set [ find default-name=wifi1 ] channel=channel1 configuration.country=Uganda \
    .mode=ap .ssid="Kikindu Market Hotspot" disabled=no
/interface wifi configuration
add channel.band=2ghz-n .frequency=2300-7300 .width=20/40mhz country=Uganda \
    disabled=no mode=ap name=wifi ssid="Kikindu Market Hotspot"
/ip hotspot profile
add dns-name=balance.wifi hotspot-address=10.10.10.1 html-directory=\
    "kikindu wifi" login-by=mac,cookie,http-chap,https,http-pap,mac-cookie \
    mac-auth-mode=mac-as-username-and-password name="Kikindu Market Hotspot"
add name=dhcp_pool1-LAN ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2-HOTSPOT ranges=10.10.10.2-10.10.11.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp_pool1-LAN interface=bridge1-LAN name=Server1-LAN
add address-pool=dhcp_pool2-HOTSPOT interface=bridge2-HOTSPOT lease-time=10m \
    name=Server2-HOTSPOT
/ip hotspot
add address-pool=dhcp_pool2-HOTSPOT addresses-per-mac=1 disabled=no \
    idle-timeout=1m interface=bridge2-HOTSPOT name=hotspot1 profile=\
/ip hotspot user profile
set [ find default=yes ] address-pool=dhcp_pool2-HOTSPOT
You are running without firewall? Is that directly on internet or behind an ISP NAT router?
If directly, then yes, it is not surprising.
I am behind an ISP NAT router
