Discusion and info about new product DynaDish 5
Suggested price - $179
It looks ok.
+1 for version with SFP and DC JACK
We are waiting for it, when will be available?
Good move, the 802.3af/at POE, but the power supply is only for home users.
For a serious stabile link, I would use a 48V 1,6A power supply, no?
Interesting but expensive, should be higher gain as 23dBi is too low for suggested price, higher gain is what I am looking for as there is very dish antennas on the market with around 27dBi gain, loads at 30dBi and higher.
There is only client version? no AP?
License = L3, it can be used as CPE (client) or PTP (one end as CPE, the other in bridge mode, same as AP mode with just 1 client)
Where is the DynaDish?
Has it been delayed? My supplier said the date has been pushed back to due manufacturing issues… ;(
Mikrotik can you confirm?
Nothing?
1 month? 2 months?
From routerboard.com
PoE in Passive PoE or 802.3at (only unshielded cable)
Unshielded cable with outdoor device?
Mikrotik, why?
It was either this, or remove it from specifications altogether. This way, at least maybe somebody benefits from such option.
Something wrong with the design ?
some people like to know why it is not possible with shielding.
If we don’t use shielding al our links would-be running @ 10 mbit half duplex
Do you mean unshielded cable required only for 802.3at POE?
There’s no such restriction when using passive POE?
Yes, of course.
It works fine with Shielded cable if you don’t need 802.3af
can you tell what is wrong in the design ?
it must be something between power lines and ground
can we use 48V passive POE ?
Like I already said, you can use passive PoE with any cable, and 802.3af with unshielded cable. Provided Voltage range is correct for any PoE
what is the weight?
is it 23 od 25dBi?
what has better antenna for ptp links? qrt5ac or dynadish ac?
normis, when you expect a cheap QRT5 AC with license level 3 ?
Why this product is so expensive? in comparison with other
QRT is a very high quality 802.11ac device with a good antenna and a professional mount. It is not low end home product.
What happen when we connect shielded cable using 802.3af poe?
QRT is almost three times more expensive than SXT Lite5. If QRT is “very high quality” please made something like QRT Lite5 for distant clients.
SXT and QRT should not be compared, the SXT is also much smaller and has much smaller antenna gain. What are you saying exactly?
There is a product for every distance/price category. Choose according to your needs.
