Mikrotik Dynamic IP to Sonicwall VPN
I have been fighting with setting up an aggressive mode VPN between a RB750r2 (dynamic IP) and a Sonicwall TZ500 (static IP) firewall and after spending 2 hours on the phone with Sonicwall Support yesterday, I would like to ask some help from this community.
I seem to be having two different problems:
  1. Mikrotik to Sonicwall is unable to setup an aggressive mode VPN connection, however the Sonicwall to Mikrotik can.
  2. When the Mikrotik is setup as a static IP (on test bench), the VPN connects, but no data is transferred from either end.
I am fairly sure that some of the problems stem from the firewall, however even with no rules set apart from VPN Masquerade, there is still no VPN traffic.
Sonicwall WAN Network: 111.167.211.41/32
Sonicwall LAN Network: 192.168.6.0/24
Mikrotik WAN Network: 222.53.243.169/28 (will be a dynamic ip later, am using this as testing as it will bring the VPN up)
Mikrotik LAN Network: 192.168.88.0/28
Current Config:
Mikrotik:
[admin@MikroTik] > /ip ipsec peer print
Flags: X - disabled, D - dynamic
 0    ;;; Unsafe configuration, suggestion to use certificates
      address=111.167.211.41/32 local-address=:: passive=no port=500
      auth-method=pre-shared-key secret="secret" generate-policy=no
      policy-template-group=default exchange-mode=aggressive
      send-initial-contact=yes nat-traversal=no my-id=fqdn:test.com.au
      proposal-check=obey hash-algorithm=sha1 enc-algorithm=3des
      dh-group=modp1024 lifetime=8h lifebytes=0 dpd-interval=disable-dpd
      dpd-maximum-failures=5
[admin@MikroTik] > /ip ipsec policy  print
Flags: T - template, X - disabled, D - dynamic, I - inactive, * - default
 0 TX* group=default src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all
       proposal=default template=yes
 1     src-address=192.168.88.0/28 src-port=any dst-address=192.168.6.0/24
       dst-port=any protocol=all action=encrypt level=require
       ipsec-protocols=esp tunnel=yes sa-src-address=0.0.0.0
       sa-dst-address=111.167.211.41 proposal=default priority=0
[admin@MikroTik] > /ip ipsec proposal  print
Flags: X - disabled, * - default
 0  * name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=8h pfs-group=none
[admin@MikroTik] > /ip firewall filter print
 0    ;;; IPSec VPN traffic destined for this router
      chain=input action=accept src-address=192.168.6.0/24 dst-address=192.168.88.0/28 log=no log-prefix=""
 1    ;;; IPSec VPN traffic destined to this subnet
      chain=forward action=accept src-address=192.168.6.0/24 dst-address=192.168.88.0/28 log=no log-prefix=""
 2    chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
 3    chain=input action=accept protocol=udp dst-port=500 log=no log-prefix=""
 4    chain=input action=accept protocol=udp dst-port=4500 log=no log-prefix=""
 5    ;;; Add Syn Flood IP to the list
      chain=input action=add-src-to-address-list tcp-flags=syn connection-limit=30,32 protocol=tcp address-list=Syn_Flooder address-list-timeout=30m log=no log-prefix=""
 6    ;;; Drop to syn flood list
      chain=input action=drop src-address-list=Syn_Flooder log=no log-prefix=""
 7    ;;; Port Scanner Detect
      chain=input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1 address-list=Port_Scanner address-list-timeout=1w log=no log-prefix=""
 8    ;;; Drop to port scan list
      chain=input action=drop src-address-list=Port_Scanner log=no log-prefix=""
 9    ;;; Jump for icmp input flow
      chain=input action=jump jump-target=ICMP protocol=icmp log=no log-prefix=""
10    ;;; Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT ADDRESS LIST
      chain=input action=drop protocol=tcp src-address-list=!support dst-port=8291 log=no log-prefix=""
11    ;;; Jump for icmp forward flow
      chain=forward action=jump jump-target=ICMP protocol=icmp log=no
      log-prefix=""
12    ;;; Drop to bogon list
      chain=forward action=drop dst-address-list=bogons log=no log-prefix=""
13    ;;; Avoid spammers action
      chain=forward action=drop protocol=tcp src-address-list=spammers
      dst-port=25,587 log=no log-prefix=""
14    ;;; Accept DNS - UDP
      chain=input action=accept protocol=udp port=53 log=no log-prefix=""
15    ;;; Accept DNS - TCP
      chain=input action=accept protocol=tcp port=53 log=no log-prefix=""
16    ;;; Accept to established connections
      chain=input action=accept connection-state=established log=no
      log-prefix=""
17    ;;; Accept to related connections
      chain=input action=accept connection-state=related log=no log-prefix=""
18    ;;; Full access to SUPPORT address list
      chain=input action=accept src-address-list=support log=no log-prefix=""
19    ;;; Drop anything else! # DO NOT ENABLE THIS RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED
      chain=input action=drop log=no log-prefix=""
20    ;;; Echo reply
      chain=ICMP action=accept protocol=icmp icmp-options=0:0 log=no log-prefix=""
21    ;;; Time Exceeded
      chain=ICMP action=accept protocol=icmp icmp-options=11:0 log=no log-prefix=""
22    ;;; Destination unreachable
      chain=ICMP action=accept protocol=icmp icmp-options=3:0-1 log=no log-prefix=""
23    ;;; PMTUD
      chain=ICMP action=accept protocol=icmp icmp-options=3:4 log=no log-prefix=""
24    ;;; Drop to the other ICMPs - Disable to allow ping through tunnel chain=ICMP action=drop protocol=icmp log=no log-prefix=""
25    ;;; Jump for icmp output chain=output action=jump jump-target=ICMP protocol=icmp log=no log-prefix=""
[admin@MikroTik] /ip firewall> nat print
 0    chain=srcnat action=accept src-address=192.168.88.0/28 dst-address=192.168.6.0/24
 1    chain=srcnat action=masquerade
[admin@MikroTik] /ip firewall> address-list  print
 #   LIST              ADDRESS                               TIMEOUT
 0   support           192.168.88.0/28
 1   ;;; Self-Identification [RFC 3330]
     bogons            0.0.0.0/8
 2 X ;;; Private[RFC 1918] - CLASS A # Check if you need this subnet before en...
     bogons            10.0.0.0/8
 3   ;;; Loopback [RFC 3330]
     bogons            127.0.0.0/8
 4   ;;; Link Local [RFC 3330]
     bogons            169.254.0.0/16
 5 X ;;; Private[RFC 1918] - CLASS B # Check if you need this subnet before en...
     bogons            172.16.0.0/12
 6 X ;;; Private[RFC 1918] - CLASS C # Check if you need this subnet before en...
     bogons            192.168.0.0/16
 7   ;;; Reserved - IANA - TestNet1
     bogons            192.0.2.0/24
 8   ;;; 6to4 Relay Anycast [RFC 3068]
     bogons            192.88.99.0/24
 9   ;;; NIDB Testing
     bogons            198.18.0.0/15
10   ;;; Reserved - IANA - TestNet2
     bogons            198.51.100.0/24
11   ;;; Reserved - IANA - TestNet3
     bogons            203.0.113.0/24
12 X ;;; MC, Class D, IANA # Check if you need this subnet before enable it
     bogons            224.0.0.0/4
13   support           192.168.6.0/24
When the Mikrotik is set as the initiator, I get the following:
[admin@MikroTik] > /ip ipsec remote-peers print
 0 local-address=222.53.246.169 remote-address=111.167.211.41 state=established side=initiator established=6s
This shows in the Sonicwall that Aggressive mode 1 is complete, and mode 2 does not start.
When the Sonicwall is set as the initiator, I get the following:
 0 local-address=222.53.246.169 remote-address=111.167.211.41 state=established side=responder established=12s
And that shows in the Sonicwall that both mode 1 and 2 are complete, however still no traffic is sent over the link.
I can never see any bytes or packets being sent using the NAT rule, so not sure if that has something to do with it.
Sonicwall Config below:
I am having this same issue, we are trying to setup Mikrotik as OOB devices using a 4g card with a dynamic IP, connecting to a Sonicwall NSA 4600.
If you find a fix please let me know, I will do the same
We found using AES for encryption had better results.
what’s in the logs of the MikroTik and the SonicWALL?
Configuring a syslog server for logging the SonicWALL’s messages and the MikroTik’s messages would be helpful to correlate the findings.
Regards,
Ape
