Hi guys !
Im having a problem when i try to delete some connection from the tracking list.
For example :
[admin@MK_Office] > ip firewall connection remove [find src-address~"192.168.1.169"]
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
[admin@MK_Office] > ip firewall connection remove [/ip firewall connection find src-address~"192.168.1.169"]
[admin@MK_Office] /ip firewall connection> print where src-address~"192.168.1.169" ;
Flags: E - expected, S - seen-reply, A - assured, C - confirmed, D - dying, F - fasttrack, s - srcnat, d - dstnat
# PROTOCOL SRC-ADDRESS DST-ADDRESS TCP-STATE TIMEOUT ORIG-RATE REPL-RATE ORIG-PACKETS REPL-PACKETS ORIG-BYTES REPL-BYTES
0 SAC s udp 192.168.1.169:5062 XXXXXXXXXXX:XXXX 2m59s 2.8kbps 3.7kbps 10 421 10 654 3 818 121 4 976 249
1 SAC s udp 192.168.1.169:53011 XXXXXXXXXXX:XXXX 2m50s 0bps 0bps 69 69 37 153 33 961
2 SAC s udp 192.168.1.169:5060 XXXXXXXXXXX:XXXX 2m42s 0bps 0bps 20 586 20 567 9 407 915 14 495 709
[admin@MK_Office] > system resource print
uptime: 6w1h46m59s
version: 6.30.2
build-time: Jul/22/2015 11:17:58
free-memory: 1470.6MiB
total-memory: 1518.7MiB
cpu: e500v2
cpu-count: 2
cpu-frequency: 1066MHz
cpu-load: 0%
free-hdd-space: 83.7MiB
total-hdd-space: 128.0MiB
architecture-name: powerpc
board-name: RB1100AHx2
platform: MikroTik
[admin@MK_Office] > system routerboard print
routerboard: yes
model: 1100AHx2
serial-number: XXXXXXXXXXXX
current-firmware: 3.24
upgrade-firmware: 3.24
Im was looking at the forum for an answer, but i saw that this problem have been found in 2008 … It could be?
Here is this post, who has the same issue.
Thanks a lot !
Regards,
