Hello
I have a hAP ax2 router from today and I am a bit disappointed. I have a UPC 750/200 Mbit link and on the UPC router I get speeds of about 500 Mbit / s over Wi-Fi 5. I connected the ax2 router to it and configured it for Wi-Fi 6. On the iPhone 13 speedtest I only have about 250 Mbit / s.
I also tested some time ago on ASUS XD6 and I had about 700 Mbit / s after Wi-Fi 6.
Is something wrongly positioned?
Please help.
Configuration in attachment.
# oct/19/2022 22:06:59 by RouterOS 7.6
# software id = NAHX-XSTS
# model = C52iG-5HaxD2HaxD
# serial number = <CENSORED>
add admin-mac=18:FD:74:BB:9E:5D auto-mac=no name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.country=Poland .mode=ap .ssid=\
MT5 disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.country=Poland .mode=ap .ssid=MT \
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add interface=bridge list=LAN
add interface=ether1 list=WAN
192.168.88.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
/tool mac-server mac-winbox
When I start doing speedtest, the tx rate drops to 600/600, not 1201 Mbps.
I’m about 3-4 meters from router.
In the same room.
