Mikrotik IPTV VLAN IGMP configuration
Hi Guys,
i am struggling for 2 days how to proceed with my provider settings and Mikrotik. My ISP provided me dlink router DIR-2150 on this router i specify/enable igmpv2 and interface for IP TV (untagged) and WAN tagged with vlan 388 and it is working fine. I replaced this router with Mikrotik but nothing works for me expect internet…configured 2 Bridges 1 VLAN1 - all devices except isp tv decoder, and second bridge vlan388 and iptv doesn’t work, I tried all settings not tv doesn’t even started :frowning: Will anyone of you help me to fix that ? thanks in advance.
My current config:
# jul/02/2023 09:14:56 by RouterOS 6.49.8
# software id = **ELIDED**
# model = RB760iGS
# serial number = **ELIDED**
add name=Bridge_VLAN1
add arp=proxy-arp igmp-snooping=yes multicast-querier=yes name=Bridge_VLAN388
set [ find default-name=ether4 ] name=Dekoder_TV
set [ find default-name=ether1 ] mac-address=A8:63:7D:9C:AA:B6 name=WAN_Internet
set [ find default-name=ether3 ] name=Wifi_Router
set [ find default-name=sfp1 ] mac-address=A8:63:7D:9C:AA:B6
/interface vlan
add interface=WAN_Internet name=VLAN1 vlan-id=1
add interface=WAN_Internet name=VLAN388 vlan-id=388
set 3 default-vlan-id=388
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool2 ranges=192.168.90.2-192.168.90.254
add name=dhcp_pool3 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool4 ranges=192.168.0.2-192.168.0.254
add address-pool=dhcp disabled=no interface=Bridge_VLAN1 name=dhcp2
add address-pool=dhcp_pool4 disabled=no interface=Bridge_VLAN388 name=dhcp1
add bridge=Bridge_VLAN1 interface=ether2
add bridge=Bridge_VLAN1 interface=Wifi_Router
add bridge=Bridge_VLAN1 interface=ether5
add bridge=Bridge_VLAN388 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes \
    interface=Dekoder_TV pvid=388
add bridge=Bridge_VLAN388 disabled=yes interface=WAN_Internet pvid=388
/interface bridge vlan
add bridge=Bridge_VLAN388 tagged=Bridge_VLAN388,WAN_Internet untagged=Dekoder_TV vlan-ids=388
add bridge=Bridge_VLAN1 untagged=Wifi_Router,ether2,ether5 vlan-ids=1
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=LAN wan-interface-list=\
    WAN
add comment=defconf interface=ether5 list=LAN
add interface=ether2 list=LAN
add interface=WAN_Internet list=WAN
add address=192.168.88.1/24 interface=Bridge_VLAN1 network=192.168.88.0
add address=192.168.0.1/24 interface=Bridge_VLAN388 network=192.168.0.0
/ip dhcp-client
add disabled=no interface=WAN_Internet
add address=0.0.0.0/24 comment=defconf gateway=0.0.0.0 netmask=24
add address=192.168.0.0/24 gateway=192.168.0.1
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=\
    127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward protocol=udp
add action=accept chain=input protocol=udp
add action=accept chain=forward protocol=igmp
add action=accept chain=input protocol=igmp
add action=accept chain=forward dst-address=239.239.0.0/16
add action=accept chain=input dst-address=239.239.0.0/16
add action=accept chain=input dst-address=224.0.0.0/4
add action=accept chain=forward dst-address=224.0.0.0/4
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
    out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=VLAN388
/routing igmp-proxy
set quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=WAN_Internet upstream=yes
add interface=Bridge_VLAN388
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=MikrotikRouterSzafa
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-name=test.pcap streaming-enabled=yes streaming-server=192.168.0.136
You’ve got quite a mess here, and I’m not the best one to advise on VLANs, but since no one else seems to be responding, please accept this list of random points of advice for what good it may do:
  • I believe the core problem with your setup is that you aren’t configuring the GPON uplink (ether1) as a trunk port. It needs to carry traffic for all VLANs, with tags preserved. The router then strips tags as part of deciding which LAN leg to send incoming packets to, and it reapplies them for packets going back out to the Internet, depending on where the traffic came from.
  • Use one bridge for VLAN aggregation/disaggregation. RouterOS boxes can hardware-offload only a single bridge per switch chip, and your hEX S has but one such chip.
  • RouterOS 6 lacks hardware-offload of VLAN filtering in the hEX S. That was added in RouterOS 7.1. I presume from “GPON” that you’re talking about gigabit class speeds, which is on the borderline of what a hEX is capable of to begin with. You should upgrade if you want to get full capability from this device.
  • Your diagram and your prose are mutually inconsistent. You say IPTV is untagged and regular internet traffic is VLAN 388, but then you show the IPTV decoder on the VLAN 388 leg and the PC on VLAN 1. Which is it? I’m betting that the diagram is correct, but you tell us; don’t make us second-guess you.
  • Although I said “one bridge” above, there’s an exception for gateway type routers: you generally want the uplink to be outside the main bridge, and it is often convenient to put that single port into its own separate bridge. This causes everything going out that port to run through the CPU, not be hardware-offloaded, but that’s what a router does anyway, so it causes no net harm. The single bridge principle applies to the LAN side, allowing your hEX to switch that traffic without CPU intervention.
  • IGMPv2, really? I thought everyone moved on to IGMPv3 a decade and more ago. It’s important because some OSes (macOS and the BSDs) obey the spec and degrade to IGMPv2 when they see the first v2 packet even if they start out on v3, in the name of compatibility. Windows doesn’t care, and I don’t remember what Linux does. (Your IPTV decoder is almost certainly running Linux.) This may amount to quibbling in your case, but be sure you get this right in case it matters.
  • Why is your DHCP server issuing addresses on five different subnets, but two VLANs? Simplify this. I suggest using 192.168.1.0/24 for VLAN 1 and 192.168.88.0/24 for VLAN 388. This shows the common scheme of reusing the VLAN IDs in the third octet of the IP to make reading IPs easier. Since your ISP-assigned 388 ID doesn’t fit, you can use either 38 or 88, based solely on your preference. If you had control of the VLAN IDs, you’d pick values in the 0-255 range to simplify this, but your ISP has made that decision for you, so…
  • Why are you sending IPTV traffic (VLAN 388) to the WiFi? I don’t care how badass your WiFi is, traditional IPTV — meaning multicast MPEG-TS over raw UDP or RTP — is all but doomed when run over WiFi unless you go way out of your way to fix the problems in the defaults. If you have to do video over WiFi, at least use unicast TCP protocols such as HLS, RTMP, and WebRTC which were designed to paper over its weaknesses, as used by most of the OTT services. (NetFlix, Prime Video, YouTube…)
I’m tired of typing. Fixing that list of problems should keep you busy for a while. :slight_smile:
You should read: http://forum.mikrotik.com/t/vlan-tutorial-understanding-menu-interface-bridge-vlan/164722/1
Hi Guys,
first of all thanks for yours reply really appreciate. I play again a bit with Mikrotik hex S but still not very lucky :frowning: upgraded device, removed unused pools but this vlan stuff makes me crazy… lets assume. We have only two VLANs on LAN side, VLAN 100 - all LAN devices (PC’s, WiFi access point, printer - interface=Wifi_Router ) i need DHCP for that, and VLAN 388 - only IPTV (ether4) decoder and need other DHCP range, interface facing WAN configured as trunk with tagged only VLAN388 - regarding this point i am a bit confused if this port should be added under same bridge with PVID 1 ? Or as you suggested create new bridge with only this port ? Regarding DHCP how to accomplish that ? i need to create vlan interface for each vlan id and assign it to bridge ? or physical port ? Thanks in advance for any advise.
[admin@MikroTik] > interface export
# 1970-01-02 01:50:01 by RouterOS 7.10.1
# software id = P08D-5xxx
# model = RB760iGS
# serial number = HDH08Sxxxx
add admin-mac=48:A9:8A:15:34:B7 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=A8:63:7D:9C:AA:B6 name=\
    WAN_Internet
add bridge=bridge comment=defconf ingress-filtering=no interface=Wifi_Router \
    pvid=100
add bridge=bridge comment=defconf interface=ether4 pvid=388
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge tagged=WAN_Internet untagged=ether4 vlan-ids=388
add bridge=bridge untagged=Wifi_Router vlan-ids=100
add comment=defconf interface=WAN_Internet list=WAN
fixed all issues on LAN side… :slight_smile: hosts works, get ips and internet works fine… only problem is with TV not sure how to add vlan 388 to tag on WAN and how to enable IGMP working as it was on my dlink router.
# 2023-07-04 13:37:58 by RouterOS 7.10.1
# software id = P08D-54EP
# model = RB760iGS
# serial number = xxxxxxx
add igmp-snooping=yes multicast-querier=yes name=BR1 protocol-mode=none \
    vlan-filtering=yes
set [ find default-name=ether1 ] mac-address=xxxxxxxxxx name=WAN_LINK
set [ find default-name=ether2 ] name=WiFi_Router
/interface vlan
add interface=BR1 name=BLUE_VLAN vlan-id=10
add interface=BR1 name=MGMT_VLAN vlan-id=99
add interface=BR1 name=TV_VLAN vlan-id=388
add interface=BR1 name=WiFi_VLAN vlan-id=100
add name=WAN
add name=VLAN
add name=BASE
/ip hotspot profile
add name=BLUE_POOL ranges=10.0.10.2-10.0.10.254
add name=TV_POOL ranges=10.0.20.2-10.0.20.254
add name=MGMT_POOL ranges=192.168.100.10-192.168.100.254
add name=WiFI_POOL ranges=10.0.100.2-10.0.100.254
add address-pool=BLUE_POOL interface=BLUE_VLAN name=BLUE_DHCP
add address-pool=TV_POOL interface=TV_VLAN name=TV_DHCP
add address-pool=MGMT_POOL interface=MGMT_VLAN name=MGMT_DHCP
add address-pool=WiFI_POOL interface=WiFi_VLAN name=Wifi_DHCP
/port
set 0 name=serial0
add bridge=BR1 comment=defconf frame-types=\
    admit-only-untagged-and-priority-tagged interface=WiFi_Router pvid=100
    admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
    admit-only-untagged-and-priority-tagged interface=Dekoder_TV pvid=388
    admit-only-untagged-and-priority-tagged interface=ether5 pvid=99
add bridge=BR1 tagged=BR1 vlan-ids=10
add bridge=BR1 tagged=BR1,WAN_LINK vlan-ids=388
add bridge=BR1 tagged=BR1 vlan-ids=99
add bridge=BR1 tagged=BR1 vlan-ids=100
add interface=WAN_LINK list=WAN
add interface=MGMT_VLAN list=VLAN
add interface=BLUE_VLAN list=VLAN
add interface=TV_VLAN list=VLAN
add interface=MGMT_VLAN list=BASE
add interface=WiFi_VLAN list=VLAN
add address=192.168.100.1/24 interface=MGMT_VLAN network=192.168.100.0
add address=x.x.x.x interface=WAN_LINK network=x.x.x.x
add address=10.0.10.1/24 interface=BLUE_VLAN network=10.0.10.0
add address=10.0.20.1/24 interface=TV_VLAN network=10.0.20.0
add address=10.0.100.1/24 interface=WiFi_VLAN network=10.0.100.0
/ip dhcp-client
add comment=defconf interface=*7
add address=10.0.10.0/24 dns-server=192.168.100.1 gateway=10.0.10.1
add address=10.0.20.0/24 dns-server=192.168.100.1 gateway=10.0.20.1
add address=10.0.100.0/24 dns-server=192.168.100.1 gateway=10.0.100.1
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1
set allow-remote-requests=yes servers=9.9.9.9
add action=accept chain=input comment="Allow Estab & Related" connection-state=\
    established,related
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" \
    in-interface=MGMT_VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment="Default masquerade" \
add distance=1 gateway=x.x.x.x
/system clock
/system note
set show-at-login=no
Lack of ideas right now, anyone will be able and help me to correct my config ? right now tv works perfect but… no internet on my vlans :frowning:
Below my config. VLAN388 tagged on ISP link. Added WAN int to bridge.
 [admin@MikroTik] > /export
# 2023-07-04 22:54:12 by RouterOS 7.10.1
# model = RB760iGS
add igmp-snooping=yes name=BR1 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] mac-address=x.x.x.x. name=WAN_LINK
set [ find default-name=ether5 ] poe-out=off
/interface vlan
add name=WAN
add name=VLAN
add name=BASE
/ip hotspot profile
/port
set 0 name=serial0
add bridge=BR1 comment=BR1 frame-types=admit-only-untagged-and-priority-tagged \
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=\
    ether3 pvid=10
add bridge=BR1 comment=BR2 fast-leave=yes interface=Dekoder_TV pvid=388
    ether5 pvid=99
add bridge=BR1 interface=WAN_LINK pvid=388
add bridge=BR1 tagged=BR1,WAN_LINK untagged=Dekoder_TV vlan-ids=388
/ip dhcp-client
    established,related
# in/out-interface matcher not possible when interface (WAN_LINK) is slave - use m
 ster instead (BR1)
add action=accept chain=input in-interface=WAN_LINK protocol=igmp
/routing igmp-proxy
set quick-leave=yes
add alternative-subnets=0.0.0.0/0 disabled=yes interface=WAN_LINK upstream=yes
add disabled=yes interface=TV_VLAN
add disabled=yes interface=Dekoder_TV
/system clock
/system note
[admin@MikroTik] >
Anyone will be able to help ?
I would expect a single bridge. Can you please supply all the information how of the ISP? Where should you use VLAN’s? Only IPTV, or is it for Internet?
The WAN interface with Internet should be NAT-ted, the WAN internface with IPTV should be added to the bridge (tagged if it is on a VLAN or untagged to seperate it from the rest of the network).
Please read this great tutorial:
thanks for your reply, tagged vlan 388 on ISP link plus untagged vlan 1 (by means of trunk ?), ISP provides static ip and need to have NAT. If i add WAN interface to bridge IPTV works but internet doesn’t if i disable it internet works on all hosts but no IPTV. Based on this tutorial i fixed internet, dhcp, natting fw etc. but still iptv doesn’t work as WAN link is not on bridge… when i added it iptv starts working as i said but internet dropped from LAN.
Finally got fixed it.
I have the seam issue would you please how to fix it please
thanks
Configure 2 Bridges and all vlan interface, assign access interfaces to lets say BR1 and one vlan facing ISP, under physicall interface towards ISP in my case unerd eth1. Under BR1 ports you must add all access ports but physicall ones i means eth2,3, etc. for example all as untagged. Next BR2 ports you must add physicall interface of end host (it wont be tagged, tv decoder etc.) and interface vlan configured previously towards ISP. Last step under bridge vlans add access vlan nr and under tagged use BR1 and BR1 as bridge, under isp/tv vlan add BR2 as bridge and BR2 as tagged. Turn on vlan filtering under each bridge. In my case i also enabled igmp snooping under BR2 and it starter working. Regarding ip/dhcp you myst add networks and vlan interface. You can paste screens will try to help you.
What is the use of the second bridge if a single bridge with vlan filtering is sufficient?
In second bridge you bind trunk (vlan under eth1/isp connection port) and yours access port towards tv decoder.
This might (but obviously doesn’t) work but is very inefficient … with one word: wrong. Use single bridge with properly configured VLANs.
Great :slight_smile: i asked guys and no one was able to help me on my exact config, right now you are writing this is wrong… hm… okay so maybe you will be so kind and based on my config correct it and provide me what is wrong :slight_smile: ?
@erlinden posted a link in post #8 above. The thread gives enough insights on how to do it properly.
If you try to implement single bridge concept and run into problems, I’ll be more than happy to help you overcome hurdles. But I’m not going to try fixing your config which goes against “good practices” and I’m not going to spoon-feed you with a completely new configuration. I’m not saying it can’t be done the way you started (I strongly believe it can be), but I’m not willing to. And I guess many of experienced forum members feel similarly.
Below prepared config based on yours tips. This is what you was thinking about ? I have one thing which is not working i mean tv dhcp and not sure how to sort this out (tv works now, without internal ip assigned).
# 2023-07-09 22:06:54 by RouterOS 7.10.1
# model = RB760iGS
add igmp-snooping=yes name=BR2 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether3 ] name=Poddasze
set [ find default-name=ether1 ] mac-address=xxxxxxxx name=WAN_LINK
/interface vlan
add interface=WAN_LINK name=TV_VLAN-in vlan-id=388
add name=WAN
add name=VLAN
add name=BASE
add include=all name=TV
/ip hotspot profile
/port
set 0 name=serial0
add bridge=BR1 comment="BR1 - internet" frame-types=\
    admit-only-untagged-and-priority-tagged interface=Poddasze pvid=10
add bridge=BR1 comment="BR1 - internet" disabled=yes frame-types=\
add bridge=BR1 comment="BR1 - TV" frame-types=\
    admit-only-untagged-and-priority-tagged interface=TV_VLAN-in pvid=388
add bridge=BR1 tagged=BR1 vlan-ids=388
add interface=TV_VLAN-in list=TV
add address=xxxxxx interface=WAN_LINK network=xxxxxxx
add address=10.0.20.1/24 disabled=yes interface=*11 network=10.0.20.0
/ip dhcp-client
add address-pool=TV_POOL disabled=yes interface=*11 name=TV_DHCP
    established,related
/ip firewall service-port
set ftp disabled=yes
add distance=1 gateway=xxxxxx
add interface=TV_VLAN-in upstream=yes
add interface=BR2
/system clock
/system note
[admin@MikroTik] >
You haven’t got a dhcp-server with address-pool=TV_POOL on interface=Dekoder_TV.
DHCP server won’t work on slave interface.
