Hi All,
Does anyone know, why my KNOT after upgraded to version 7.2 the LTE Interface is missing? anyone face similar problem with me?
Thank You.
Hi All,
Thank You.
As i can see you have 7.1.5.. but the router shows firmware 7.2
So at some point you did upgraded the ROS and firmware to 7.2, then for some reason your downgraded to 7.1.5 and you left the firmware version as it was…
I am missing details on why you downgraded, because the LTE was missing ?
Personally lately i had an issue when upgraded the firmware to 7.2.1, the LTE was missing as well, but a reboot fixed it..
Yeah… I did downgraded from 7.2 to 7.1.5 with assumption it will restore the interface but it didn’t.
3x time rebooted but no result.
OK, I’ll shoot with 7.2.1
Upgraded to 7.2.1 with 3x rebooted, no luck, my LTE still undetected, should I downgrade to version 6 again?
I would first give netinstall a try…
https://help.mikrotik.com/docs/display/ROS/Netinstall
OK, Will do
Netinstall doesn’t resolved my problem.
LTE Interface still unavailable.
I’m stuck!
Downgrade to V6…
Is the interface back ?
You can always contact MikroTIK support… https://mikrotik.com/support
Unfortunately no ahahahahaha dead end, I’ve sent the ticket to mikrotik support, let see what they need from me, I hope it’s only software issue.
I received the update from MikroTik support, that KNOT is using BG77 modem, here the cap the link he share it’s not right, you should check https://help.mikrotik.com/docs/display/ROS/LTE and https://help.mikrotik.com/docs/display/UM/BG77+modem+AT+commands
Case closed.
Then the lte interface was never there, it dit not dissapear after the update…
