You can only use one sim card at a time.
So you need to change the sim cards in the software when you want to switch to other sim card.
Modem will reset during the sim change.
I have yet another little question.
Do you know if Mikrotik plans to release a faster version of the modem in the near term?
(150Mb/s LTE modem, sounds a little bit “outdated”. I think in 2018 the minimal people could expect is a 300Mbit/s LTE-A modem.
At least the price for the 150Mb/s version is in the right range, I would even say, it’s cheap for a “waterproof”, dual SIM, PoE device. But I think there is room for a faster version in the $150-170 range.)
EDIT:
Is the Mini PCIe LTE Card installed in the Mikrotik LtAP mini LTE replaceable and software compatible with any other LTE modem card? (AT command are standardized I think at least)
Is the SoC installed in the Mikrotik LtAP mini LTE powerful enough to handle it?
EDIT 2:
They even have a 600Mbps LTE-A module (M.2 format).
I have to check if those modules use a PCIe connection or an USB connection (which probably is incompatible with the Mikrotik LtAP mini).
But they are really expensive modules (when sold separately).
CAT 6 modems are still relative expensive (as you already found out), and not just a small upgrade from CAT4.
That is simple reason why today CAT4 is still the sweet spot of cellular modems.
If you want to use your own modem, buy the standard LTAP, that one has no Modem mounted. You can add
your own one inside.
Let me know which CAT6 modem you choose then and what network speeds you get (and which country/carrier)…
Well I don’t agree, for the simple reason because there is a huge difference between the theoretical performances and the real performances,.
Let’s take the Snapdragon X12, which is a CAT12 DL / CAT 13 UL (600/150Mbps; 3CA/2CA).
What is interesting in such modems?
The support of carrier aggregation.
With my Cat 4 Modem (150Mbps max, because no CA), I get only 30Mbps in practice. In other words, the ability to use carrier aggregation would allow me to double the speed, and I would still be bellow the 100Mbps limitation of the Ethernet port.
Other benefit of using recent high performance modems, is the support of QAM64 for the upload (vs QAM16), it allows a performance increase of 50% (50->75Mbps).
