mikrotik password expires
For a few weeks the RouterOS of a CCR2116 has been left without a password since the password expires leaving the device without a password.
I have tried to solve the problem by changing passwords and others but it continues to expire automatically after a couple of weeks, sometimes it happens in just days
Please tell us exactly what you are seeing. As far as I can tell from poking in WinBox and reading the help pages, passwords don’t expire unless you explicitly expire them.
Note with the above said, when a router is factory reset, the first login with admin / will show that the password is expired and require changing it. Did that on an old RB750r2 last night…
The last time we used a completely different password from the previous ones, so it is not that someone entered and there changed the password. It has simply expired and to enter it you only need the login username and blank password
When entering, it appears that the password has expired and I must enter a new password where the old one is not required because if I enter it, it tells me that it is not valid and I must leave it blank and only enter the new one
Were you able to find a solution? I have a CCR1009 that, lately, from time to time, goes into a reboot loop and requires Netinstall to get back up and running. But after being in operation for a few days, the access passwords are eliminated, exactly as you describe.
If I understand you correctly you are saying that after a while the password has been reset to blank? so no password is required to log in? (which will cause the popup box to reset the password)
You then set a password, but again after a while it resets itself to blank?
