I want to get mikrotik local lan per user bandwidth volume consumption detail. Mikrotik graphing opetion just show bandwidth graph not show volume consumption. Any suggution please.
Have a look at ip accounting. There are some limitations. If you need more freedom, maybe investigate the ip traffic flow
PRTG network monitor view just mikrotik Ip trafic flow protocols not view bandwidth volume. Also i am working on ip accounting. May be get some solution. Thanks
Sent from my CPH1701 using Tapatalk
Look at my project (link in my signature) using Splunk to monitor various parameters from the Router.
One graph uses IP accounting to graph bandwidth used pr user.
There you can select all users, singel user, time period etc.
Where i download it. Also is it a free software?
All is in the link in my signature.
Sory
Where is your signature
you can see his signature on his every post
This is my signature, click the MikroTik->Splunk:
Use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Your link can"t open.
You must be blind, look in bottom of every post. The thing in the white window was just for you to see where to see the link.
But here it is:
http://forum.mikrotik.com/t/tool-using-splunk-to-analyse-mikrotik-logs-3-3-graphing-everything/121810/1
Do you see the word Splunk in color red at the bottom of the message? Link is just blow it.
Correct your words. Also see attached screen and then tell me where is your signature. Although i can get another way.
http://laxmidharnetworking.blogspot.com/2017/06/mikrotik-manually-created-queue-added.html
It seem that using a phone does not show it the same way as on a web browser.
Do you use a browser or an ohter app on the phone?
PS I can confirm that you are not blind ![]()
I can confirm that you are un professional.
