I’ve purchased a new R52HN mini pci card for my Linux router to have 5 Ghz 802.11n capability at my home network.
Previously I had a AR5413 chipset based miniPci card which provides 802.11g at 2.4 Ghz.
My router has Ubuntu 12.04 OS on it and the wireless regulatory domain is set to EU (Europe)
So, I believe at channel 36 , I should be able to go up to 20 dBm with no issues.
And the R52HN seems to support it.
But when I run hostapd with following configuration, I get limited to 17 dBm power output.
The antenna is connected to J4 on the R52HN
I get very poor wireless reception at home.
Even with channel bonding, all I get is max 81Mbs on my Windows PC client.
What is wrong that I’m doing ?
country_code=EU
ieee80211d=1
ht_capab=[HT40-][HT40+]
channel=36
bridge=br0
driver=nl80211
hw_mode=a
interface=wlan1
rsn_pairwise=CCMP TKIP
ssid=xeonw5
wpa=3
wpa_key_mgmt=WPA-PSK
wpa_pairwise=CCMP TKIP
wpa_psk_file=/etc/hostapd/hostapd2.wpa_psk
ieee80211n=1
wmm_enabled=1
Btw, I’m willing to change regulatory domain to anything that would supply more power and solve my wifi reception issues.
iw reg set EU command output on dmesg:
[ 983.151076] cfg80211: Regulatory domain changed to country: EU
[ 983.151093] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 983.151119] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 983.151144] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 983.151168] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 983.151194] cfg80211: (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm)
root@router:~# iw reg get
country EU:
(2402 - 2482 @ 40), (N/A, 20)
(5170 - 5250 @ 40), (N/A, 20)
(5250 - 5330 @ 40), (N/A, 20), DFS
(5490 - 5710 @ 40), (N/A, 27), DFS
hostapd command output:
root@router:~# /usr/sbin/hostapd -dd -B -P /var/run/hostapd3.pid /etc/hostapd/hostapd2.conf
Configuration file: /etc/hostapd/hostapd2.conf
nl80211: Interface wlan1 is in bridge br0
nl80211: Add own interface ifindex 4
nl80211: Add own interface ifindex 5
Failed to create interface mon.wlan1: -23 (Too many open files in system)
Try to remove and re-create mon.wlan1
nl80211: Remove interface ifindex=11
nl80211: New interface mon.wlan1 created: ifindex=12
nl80211: Add own interface ifindex 12
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
nl80211: Added 802.11b mode based on 802.11g information
Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=17 dBm
Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=17 dBm
Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=17 dBm
Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=17 dBm
Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm
RATE[0] rate=60 flags=0x1
RATE[1] rate=90 flags=0x0
RATE[2] rate=120 flags=0x1
RATE[3] rate=180 flags=0x0
RATE[4] rate=240 flags=0x1
RATE[5] rate=360 flags=0x0
RATE[6] rate=480 flags=0x0
RATE[7] rate=540 flags=0x0
Scan for neighboring BSSes prior to enabling 40 MHz channel
Scan requested (ret=0) - scan timeout 10 seconds
Interface initialization will be completed in a callback
root@router:~#
Btw, I am not sure if this is the correct place to post this issue. Please let me know where I should post if I’m doing wrong.
Thanks.
