Mikrotik-Rate-Limit Attribute
I have the Mikrotik-Rate-Limit attribute set in radius and my mikrotik log displays the following:
radius,debug,packet MT-Rate-Limit = 0x00000000
The format I used in my radius server is:
128k/256k
Am I missing something?
Thanks,
ROS Version? Mikrotik’s Dictionary up to date on the Radius server?
ROS version 3.18
The Mikrotik-Rate-Limit attribute is in the radius server attribute list.
I would say try on 3.17 first and see whether it works there.
If it works on 3.17 and not on 3.18, then we have a possible bug perhaps.
Tried on an older version and same results.
try
128000/256000
Yea try that. However I have been trying to use the User-manager Bursts. That however does not work. It will only set a new Tx/RX setting IF the connection is reset? Is this correct or is it a bug. It would be really nice if I could us the RX/TX limiting rather than a simple queue on the CPE side. Sorry if I hijacked But thought this would be a good place for it. Thanks -Jordan
Still the same result.
Try using Rate-Limit (64000/64000), instead of Mikrotik-Rate-Limit. Don’t ask me why, but I see in my old configurations that I used the former, and not the later… I know mine worked…
Mine works ok. I use freeradius, and it is returning ‘Mikrotik-Rate-Limit’ in the format xxxK/yyyK. I logged in with this attribute on my username, and no message in MT box log. By your log entry, the radius server sent back ‘MT-Rate-Limit’, not ‘Mikrotik-Rate-Limit’.
This is entered in the radius radreply or radgroupreply table, correct?
ADD: This is in the format rx/tx from the hotspot point-of-view. So rx bandwidth is upload from the client, and tx is download to the client. As an example, 128K/512K will give a client 128K upload, and 512K download.
I thought it was odd that it displays MT-Rate-Limit and not Mikrotik-Rate-Limit
Im sure that has something to do with my issue.
Using RadiusNT enterprise here.
Can you run debug on your radius server and post exactly what its sending out?
Mikrotik-Rate-Limit is set to 128k/25k in radius user config.
Looks like a radius server issue-
Output from radius server:
radrecv: Request from host 10.0.0.1 (testnetworkPrivate) code=Auth Request(1),
id=14, length=175
User-Service = Framed-User
Framed-Protocol = PPP
NAS-Port = 15
NAS-Port-Type = Ethernet
User-Name = “dan”
Caller-Id = “00:1D:72:17:18:F1”
NAS-Port-Id = “bridge1”
MS-CHAP-Challenge = <size:16 Data:CHAP>
MS-CHAP2-Response = <size:50 Data:CHAP id:1 flags:0>
NAS-Identifier = “MikroTik”
NAS-Identifier = 10.0.0.1
Sending Ack of id 14 to 10.0.0.1 (testnetworkPrivate)
Mikrotik-Rate-Limit = 0
Framed-Address = 10.0.0.2
Class = “IEAS08811\005174592\003101”
MPPE-Send-Key = “\256&\332\012\246\016\277\337HA\242\n\002\237\261”
MPPE-Recv-Key = “\262\352l!\234\275\2441*\220\244W\023\350u”
MS-CHAP2-Success = “\001S=09A7B26EAE961244671CD7F5DCA7E58B01493BDE”
Resp Time: 10 Auth: 43/114/2 → 157 Acct: 0/0/83 → 0
yah it does seem a radius server issue. i use freeradius and my output debugs are a bit different looking but I think I agree with you that
is not exactly right.
you seem to have the command right though. one of mine that is working is
Mikrotik-Rate-Limit = 512k/512k 1M/1M 256K/256K 30/30 7
in the radiusd config, sorry i can’t help with your specific radius server
Something else I noticed:
In my radius database, in the attribute entry config for the user there are two areas to enter the “data” or the “value” for that attribute.
Data meaning a STRING
Value meaning an interger
The “0” is the “value” being sent.
Radius send:
Mikrotik recieve:
If I set the “VALUE” to the integer 2, output follows:
Radius send:
Mikrotik-Rate-Limit = 2
Mikrotik recieve
MT-Rate-Limit = 0x00000002
It should “I assume” be sending the “STRING” or “DATA” value, which I have set to “128k/256k”
clearly you should try putting the entire command in value
According to the Mikrotik dictionary that came with freeRadius, this value is a string, not a number. I am not familiar with the database that your radius uses, so I don’t know how much help I can be on the rest.
Got It!
When I defined the attribute, there is a value called “AttributeType”
0 = string
1 = 32 bit integer
I had this set to “1” which was looking at the “value” field when I setup the attribute for the user.
Changing this to “0” fixed it.
The correct “string” 128k/256k is now being recieved by mikrotik.
Thanks all for your help!
Now I know how to run my radius server in debug mode, very helpfull…
