paste this on both, and check what is no/off
/system/device-mode print
CSS610 switch and the cAp ac are "inside" the homelab network, or must be directly linked to edge?
edge.rsc (8.2 KB)
homelab.rsc (8.0 KB)
Open the edge.rsc and set the right VLAN number, pppoe username and password
For apply correctly the config, after the file copy on root, use on edge:
/system reset-configuration keep-users=yes skip-backup=no no-defaults=yes run-after-reset=edge.rsc
and obviously on homelab
/system reset-configuration keep-users=yes skip-backup=no no-defaults=yes run-after-reset=homelab.rsc
I dont see the point for two routers.
Nor why superior intellects above, have missed this LOL
Simply have one router with a bridge and two vlans.
One for the home network and one for the lab.
Perfectly safe, much easier.
Yes, CSS610 and cAp ac are inside the homelab network.
Not really, if you're going to experiment, it's better not to piss off your wife...
Jaja, sounds like you are recounting past faux pas, when adjusting your network ![]()
Results:
MikroTik #1 - Edge
[admin@RB2011-Edge] > /system/device-mode print
mode: advanced
allowed-versions: 7.13+,6.49.8+
flagged: no
flagging-enabled: yes
scheduler: yes
socks: yes
fetch: yes
pptp: yes
l2tp: yes
bandwidth-test: yes
traffic-gen: no
sniffer: yes
ipsec: yes
romon: yes
proxy: yes
hotspot: yes
smb: yes
email: yes
zerotier: yes
container: no
install-any-version: no
partitions: no
routerboard: no
attempt-count: 0
MikroTik #2 - HomeLab
[admin@RB2011-HOMELAB] > /system/device-mode print
mode: advanced
flagged: no
scheduler: yes
socks: yes
fetch: yes
pptp: yes
l2tp: yes
bandwidth-test: yes
traffic-gen: no
sniffer: yes
ipsec: yes
romon: yes
proxy: yes
hotspot: yes
smb: yes
email: yes
zerotier: yes
container: no
partitions: no
routerboard: no
attempt-count: 0
Thank you for creation this files.
I have a question to this file:
edge.rsc
Why to routes are added this destination addresses? ; )
add blackhole distance=1 dst-address=10.0.0.0/8
add blackhole distance=1 dst-address=169.254.0.0/16
add blackhole distance=1 dst-address=172.16.0.0/12
add blackhole distance=1 dst-address=192.168.0.0/16
add blackhole distance=1 dst-address=224.0.0.0/4
add blackhole distance=1 dst-address=240.0.0.0/5
add blackhole distance=1 dst-address=248.0.0.0/6
add blackhole distance=1 dst-address=252.0.0.0/7
add blackhole distance=1 dst-address=254.0.0.0/8
Are all IPs not available on Internet, and if your internal network do not use that numbers, must be blackholed, not forwarded to your ISP.
The presence of any route for 192.168.1.0/24, for example, do not need the removal of the bigger 0.0/16
execution of this command probably broke during execution because MikroTik does not show any Wi-Fi network.
When I run the command: /import edge.rsc
I received the message:
[admin@MikroTik] > /import edge.rsc
Script Error: expected end of command (line 18 column 5)
command: /ip dhcp-server add does not have the next parameter: add-dns-entries
I will try to update my ROS to the latest long-term stable version.
RouterOS 7.24.2 is expected... not older/any version...
For be precise, routeros and wireless package only.
Not any other packages or wifi* packages that are for other models
A weird situation happened,
when I update:
- VLAN ID
- PPPoE authorization
- Wi-Fi SSID and password
- Device Identity
in *.rsc file, after importing internet access works on the RB2011, but router clients don't.
but when I import the plain version of the edge.rsc file and update the listed fields on the device, internet access works on the RB2011 and clients.
In summary, the edge router works; I will check the ** homelab ** device next week.
Probably text editor used ruin the file.
Apply the right settings after the use of the .rsc solve this case.
Sure two devices are better than one......... Like two wives, or perhaps wife and girlfriend, you should really stick to learning how to do this on one device LOL.
I used the Kate editor on Fedora, but probably something went wrong, as you said.
Yes - I did it this way - it works and is doing its job ; )
Sure two devices are better than one - Like two wives or wife and girlfriend
In my opinion, the truth is old like the world - it depends,
for example: on what is needed or what is expected
you should [...] learn how to do this on one device
of course - I could have gone for a shortcut solution and used one device - but it is not my purpose,
I could have configured my network with the devices shown in the schema in the first post, but I will lost possibility the way to connect any wired devices.
Try to prepare configurations directly on routers using Winbox and then export script and try to import it but it needs a little effort as that script is not exported in a way that all needed configuration's elements are exported in a proper order.
When you confirm that this script imports well, then comment it and use as a reference one.
It would be HI generated version, not AI one.
