Hi MikroTIk community,
I want to build the following network:
ISP
↓ ETH1
RB2011 #1 — edge router — with enabled internal Wi-Fi
├── ETH5 → RB2011 #2 — homelab router — with disabled internal Wi-Fi
│ CSS610 — switch
│ cAp ac — access point
└── ETH2 → wAP — outdoor access point
I prepared 2 configuration scripts,
but when I applied both of them,
I just connected the #2 MikroTik to the #1 MikroTik, and Wi-Fi on the #1 MikroTik gets shocked- it shows and disappears.
The configurations are listed below:
MikroTik #1 - Edge router
# RB2011 #1 - Edge ROUTER
# RouterOS 7.x
# Role:
# Internet-facing edge router. Terminates PPPoE on ether1 (WAN).
# Serves a single flat LAN 192.168.10.0/24 on ether2-ether10 + wlan1.
# Any spare LAN port can be used to uplink RB2011 #2 (homelab) - that
# port needs no special config here, it's just another LAN port; the
# double-NAT boundary lives entirely on RB2011 #2's side.
# BEFORE RUNNING:
# 1. Reset the router WITHOUT keeping the default (defconf) config:
# /system reset-configuration no-defaults=yes skip-backup=yes
# (or reset via the reset button / Netinstall). If you import this
# on top of the untouched defconf config, you'll get duplicate
# bridges, DHCP servers and firewall rules.
# 2. Fill in the variables below.
# 3. Upload this file (Files menu) then run:
# /import file-name=rb2011-1-edge-router.rsc
# 4. Manually check for a RouterOS package upgrade afterwards:
# /system package update check-for-updates
# (not scripted here - it needs a reboot and shouldn't run unattended
# on a box you're not standing in front of).
:local pppUser "CHANGE_ME_pppoe_user"
:local pppPass "CHANGE_ME_pppoe_pass"
:local adminPass "CHANGE_ME_admin_password"
:local wifiPass "CHANGE_ME_wifi_password"
:local country "poland"
:local lanSubnet "192.168.10.0/24"
:local lanIP "192.168.10.1/24"
:local dhcpFrom "192.168.10.10"
:local dhcpTo "192.168.10.254"
:log info "edge-router: starting configuration";
# 1. System / access hardening
/system identity set name="RB2011-EDGE"
/user set admin password=$adminPass
/system clock set time-zone-autodetect=yes
/ip service disable telnet,ftp,www,api,api-ssl
/ip service set ssh port=22
/ip service set winbox port=8291
/ip cloud set ddns-enabled=auto
# 2. Interface lists
/interface list add name=WAN comment="edge: wan"
/interface list add name=LAN comment="edge: lan"
# 3. LAN bridge - ether2 through ether10
/interface bridge add name=bridge-lan auto-mac=yes protocol-mode=rstp comment="edge: lan bridge"
:foreach i in={"ether2";"ether3";"ether4";"ether5";"ether6";"ether7";"ether8";"ether9";"ether10"} do={
/interface bridge port add bridge=bridge-lan interface=$i comment="edge: lan port"
# 4. Wireless - wlan1 as a LAN access point (WPA2/WPA3)
/interface wireless security-profiles add name=wifi-sec mode=dynamic-keys \
authentication-types=wpa2-psk wpa2-pre-shared-key=$wifiPass
:local wlanMac [/interface wireless get wlan1 mac-address]
:local ssid ("Edge-" . [:pick $wlanMac 9 11] . [:pick $wlanMac 12 14] . [:pick $wlanMac 15 17])
/interface wireless set wlan1 disabled=no mode=ap-bridge band=2ghz-b/g/n ssid=$ssid \
security-profile=wifi-sec country=$country installation=indoor wireless-protocol=802.11
/interface bridge port add bridge=bridge-lan interface=wlan1 comment="edge: lan wifi"
# 5. LAN addressing + DHCP
/ip address add address=$lanIP interface=bridge-lan comment="edge: lan"
/ip pool add name=dhcp-lan ranges=($dhcpFrom . "-" . $dhcpTo)
/ip dhcp-server add name=dhcp-lan address-pool=dhcp-lan interface=bridge-lan disabled=no
/ip dhcp-server network add address=$lanSubnet gateway=192.168.10.1 dns-server=192.168.10.1,1.1.1.1 comment="edge: lan"
/ip dns set servers=1.1.1.1,8.8.8.8 allow-remote-requests=yes
# 6. WAN - PPPoE client on ether1
/interface pppoe-client add name=pppoe-out1 interface=ether1 user=$pppUser password=$pppPass \
disabled=no add-default-route=yes use-peer-dns=yes comment="edge: wan pppoe"
/interface list member add list=WAN interface=pppoe-out1
/interface list member add list=WAN interface=ether1
/interface list member add list=LAN interface=bridge-lan
# 7. NAT
/ip firewall nat add chain=srcnat out-interface-list=WAN action=masquerade comment="edge: masquerade"
# 8. Firewall - IPv4
/ip firewall filter {
add chain=input action=accept connection-state=established,related,untracked comment="edge: accept established,related,untracked"
add chain=input action=drop connection-state=invalid comment="edge: drop invalid"
add chain=input action=accept protocol=icmp comment="edge: accept icmp"
add chain=input action=accept in-interface-list=LAN comment="edge: accept from LAN"
add chain=input action=drop in-interface-list=WAN comment="edge: drop everything else from WAN"
add chain=forward action=accept connection-state=established,related,untracked comment="edge: accept established,related,untracked"
add chain=forward action=drop connection-state=invalid comment="edge: drop invalid"
add chain=forward action=fasttrack-connection connection-state=established,related comment="edge: fasttrack"
add chain=forward action=drop connection-nat-state=!dstnat in-interface-list=WAN comment="edge: drop wan traffic that isn't dstnat'd"
# 9. Firewall - IPv6
/ipv6 firewall filter {
add chain=input action=accept protocol=icmpv6 comment="edge: accept icmpv6"
add chain=forward action=drop in-interface-list=WAN comment="edge: drop forward from WAN"
# 10. Misc hardening
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
/ip neighbor discovery-settings set discover-interface-list=LAN
:log info ("edge-router: configuration complete - SSID: " . $ssid);
MikroTik #2 - HomeLab router:
# RB2011 #2 - HomeLab ROUTER
# RouterOS 7.x
# Role:
# Sits behind RB2011 #1 (edge). ether1 is WAN and gets a DHCP lease
# from RB2011 #1's LAN (192.168.10.0/24) - this is the double-NAT
# boundary. Serves a fully isolated homelab LAN 192.168.20.0/24 on
# ether2-ether10 (+ wlan1, disabled by default).
# Isolation: the firewall drops everything inbound from WAN (i.e. from
# RB2011 #1's LAN) that isn't a reply to homelab-initiated traffic, so
# the main LAN cannot reach into the homelab unless you punch a hole
# (dstnat / port forward) for it.
# BEFORE RUNNING:
# 3. Physically plug ether1 into any LAN port on RB2011 #1.
# 4. Upload this file (Files menu) then run:
# /import file-name=rb2011-2-homelab-router.rsc
:local lanSubnet "192.168.20.0/24"
:local lanIP "192.168.20.1/24"
:local dhcpFrom "192.168.20.10"
:local dhcpTo "192.168.20.254"
:log info "homelab-router: starting configuration";
/system identity set name="RB2011-HomeLab"
/interface list add name=WAN comment="homelab: uplink to edge router"
/interface list add name=LAN comment="homelab: isolated lan"
/interface bridge add name=bridge-lan auto-mac=yes protocol-mode=rstp comment="homelab: lan bridge"
/interface bridge port add bridge=bridge-lan interface=$i comment="homelab: lan port"
# 4. Wireless - wlan1, disabled by default (flip disabled=no if you want it)
:local ssid ("Homelab-" . [:pick $wlanMac 9 11] . [:pick $wlanMac 12 14] . [:pick $wlanMac 15 17])
/interface wireless set wlan1 disabled=yes mode=ap-bridge band=2ghz-b/g/n ssid=$ssid \
/interface bridge port add bridge=bridge-lan interface=wlan1 comment="homelab: lan wifi (disabled by default)"
/ip address add address=$lanIP interface=bridge-lan comment="homelab: lan"
/ip dhcp-server network add address=$lanSubnet gateway=192.168.20.1 dns-server=192.168.20.1,1.1.1.1 comment="homelab: lan"
# 6. WAN - DHCP client on ether1 (uplinked into RB2011 #1's LAN)
/ip dhcp-client add interface=ether1 disabled=no add-default-route=yes use-peer-dns=no comment="homelab: wan dhcp from edge router"
# 7. NAT - second NAT layer, this is the double-NAT isolation boundary
/ip firewall nat add chain=srcnat out-interface-list=WAN action=masquerade comment="homelab: masquerade"
add chain=input action=accept connection-state=established,related,untracked comment="homelab: accept established,related,untracked"
add chain=input action=drop connection-state=invalid comment="homelab: drop invalid"
add chain=input action=accept protocol=icmp comment="homelab: accept icmp"
add chain=input action=accept in-interface-list=LAN comment="homelab: accept from LAN"
add chain=input action=drop in-interface-list=WAN comment="homelab: drop everything else from WAN (incl. edge LAN)"
add chain=forward action=accept connection-state=established,related,untracked comment="homelab: accept established,related,untracked"
add chain=forward action=drop connection-state=invalid comment="homelab: drop invalid"
add chain=forward action=fasttrack-connection connection-state=established,related comment="homelab: fasttrack"
add chain=forward action=drop connection-nat-state=!dstnat in-interface-list=WAN comment="homelab: block edge LAN from initiating into homelab"
add chain=input action=accept protocol=icmpv6 comment="homelab: accept icmpv6"
add chain=input action=drop in-interface-list=WAN comment="homelab: drop everything else from WAN"
add chain=forward action=drop in-interface-list=WAN comment="homelab: drop forward from WAN"
:log info ("homelab-router: configuration complete - SSID: " . $ssid . " (wifi disabled by default)");
If you have any questions or advice, please do not hesitate to contact me.
Have a nice day!
Regards,
Mateusz
