I’m experiencing very poor wireless performance, especially clients uploading to the router/Internet.
If I sit with my laptop in the same room, a few feet away from the router, I get pretty good performance - 40Mbps down/12mbps up.
However, if I so much as move 10 feet away, the speeds drop to 20Mbps down/0.25Mbps up.
I’ve literally gone in and tweaked every single setting there is to tweak, and plugged in every number I can think of to the wifi config page on my router, and none of it seems to make all that much of a difference. The “best case” scenario I came up with is getting 15Mbps down/2Mbps up, from about 30 feet away. This is not related to the client I’m using either, with laptops, phones, tablets all getting similarly pathetic performance.
I’ve got an old Linksys E4200 that very much blows this Mikrotik out of the water, easily getting 60-70Mbps in both directions on both 2.4/5Ghz in identical situations with default settings.
Is the RB2011 just a lost cause when it comes to its wifi performance or is there something obvious that I’m missing?
Here’s the config:
[admin@MikroTik] /interface wireless> export
# jan/18/2015 17:25:29 by RouterOS 6.24
# software id = UWEU-1MD4
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3 antenna-gain=4 band=2ghz-b/g/n basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps bridge-mode=disabled country="united states2" disabled=no distance=indoors frequency=2462 frequency-mode=regulatory-domain ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 l2mtu=1600 mode=ap-
multicast-helper=full preamble-mode=long wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys wpa-pre-shared-key="password" wpa2-pre-shared-key="password"
