MikroTik RB2011UiAS-RM LCD touch screen
Hi all
Im new to Mikrotik and router OS, i wanted to try this out for my home lab
I cant seem to find way to enable the LCD screen on the router
it lights up when you reboots and thats it
When i try the /lcd submenu it give a bad command error on terminal
I tired the web interface and the winbox didn’t find any reference to the LCD screen config
Update:
I installed the LCD pakage
What LCD model do I need to select on the LCD settings
My google searches didn’t turn up anything
Any help would be greatly appreciated
If packages are installed and you are running default configuration there should be multiple entries on the LCD to choose from and also some interface usage slideshow.
If your display only lights-up when booting I wonder if it is broken.
Are you seeing some text when booting, “like booting from nand”?
