They are both the same, diference is that one can be mounted in rack and second can’t and it’s smaller. For 200 users I think minimum is RB3011UiAS it’s not much more expensive and it’s ARM 2 cores, 1GB RAM…but in this case better someone more experience will say something.
I agree that the RB3011 is the better choice, but when the budget is really a problem the RB750Gr3 is better than teh RB2011UiAS models.
(but check for the CORRECT model with Gr3)
RB750Gr3 Is much better than RB2011
But it has license level 4
and just 5Gig Ethernet
Ok maybe he has to be more careful in selecting a router then.
I never use this “usermanager” and “hotspot” stuff so for me the only license level difference is between level 3 (for wifi devices that are only usable point-to-point)
and higher levels (that can do anything I want). 4,5 or 6 does not matter to me.
Maybe for him it is important, also because “usermanager” is not available on all devices.
Not Just UserMan (which does not supported yet)
there is so many different between license 4-5-6
PPPoE,PPTP,L2TP,OpenVPN tunnels counts
Hotspot Active users
do you use PPPoE ,PPTP,L2TP ,… ?
