Mikrotik Rb750 DHCP SERVER PROBLEM
Hi all,
I have Mikrotik RB750, what i want to do is to set up the router from the bignning.
  1. set the address in Ip->Address to WAN port 192.168.1.0/24
  2. ether2 → set as master port
    3)ether3 → slave
    4)ether4-> slave
    5)ether5 → slave
  3. Ip-> pool → 192.168.2.0/24
  4. Ip-> dhcp server → set the pool and ether2-master
    :sunglasses: Ip->dhcp server → tab networks → address 192.168.1.0/24 → gateway 192.168.1.1 → DNS 192.168.1.1
PROBLEM:
DHCP server get red and no computer gets IP!! :frowning:
Please guys help me…
http://forum.mikrotik.com/t/getting-the-most-out-of-this-forum/40983/1
Hi all,
I solve my problem yesterday. Thanks for the tips rextended.
In interface i was putting the wrong interface. The correct interface is ether2-master.
Thanks!
how did you solved the issue ? Can write some clues ?
Best Regards
Interface must have ip address in the range handled by the DHCP server
Exactly!!! That was part my mistake…
Hi all,
thanks i forgot to put the address on the interface. This solved me the first issue that i face it.
The second issue that still “colored red the secondary DHCP configuration” was because i forgot to remove the virtual interface from the bridge that already was part from primary DHCP configuration.
Anyway all you help was for me the success of my configuration .
Best Regards to all !
