Hello and thank you for the time you are investing in my problem,
I am very new to mikrotik routers. My problem is that I am using a mikrotik router as a repeater but I have no internet. I suspect the problem may come from DNS or DHCP but i am not able to diagnose it in mikrotik.
- Main Ruter is Tenda with IP. 192.168.0.1
- Mikrotik has IP 192.168.88.1
- I have successfully created the repeater in mikrotik and I can connect to the ap bridge (also I have done the authentication to the Tenda with new security profile and it is connected)
- I try to ping 192.168.0.1 though Winbox but I get response timeout
- below you can see /export result
[admin@MikroTik] > /export
jan/02/1970 00:56:10 by RouterOS 6.43.1
software id = Y1FT-IENC
model = 951Ui-2HnD
serial number = 5581041B136C
add admin-mac=4C:5E:0C:CC:BF:3D auto-mac=no fast-forward=no mtu=1500 name=bridge-local
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether1-gateway
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether2-master-local
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether3-slave-local
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether4-slave-local
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether5-slave-local
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name="AP tuneli"
supplicant-identity="" wpa-pre-shared-key=tetuneli111 wpa2-pre-shared-key=tetuneli111
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=shpia
supplicant-identity="" wpa-pre-shared-key=arens1234 wpa2-pre-shared-key=arens1234
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no frequency=2442 mode=
station-pseudobridge security-profile="AP tuneli" ssid="Diginet- TE TUNELI"
add disabled=no mac-address=4E:5E:0C:CC:BF:41 master-interface=wlan1 name=wlan3 security-profile=shpia ssid=wifi
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether3-slave-local
add bridge=bridge-local interface=ether4-slave-local
add bridge=bridge-local interface=ether5-slave-local
add bridge=bridge-local interface=wlan3
set discover-interface-list=discover
add interface=ether2-master-local list=discover
add interface=ether3-slave-local list=discover
add interface=ether4-slave-local list=discover
add interface=ether5-slave-local list=discover
add interface=wlan1 list=discover
add interface=bridge-local list=discover
add interface=ether2-master-local list=mactel
add interface=ether3-slave-local list=mactel
add interface=ether2-master-local list=mac-winbox
add interface=ether4-slave-local list=mactel
add interface=ether3-slave-local list=mac-winbox
add interface=ether5-slave-local list=mactel
add interface=ether4-slave-local list=mac-winbox
add interface=wlan1 list=mactel
add interface=ether5-slave-local list=mac-winbox
add interface=bridge-local list=mactel
add interface=wlan1 list=mac-winbox
add interface=bridge-local list=mac-winbox
add address=192.168.88.1/24 comment="default configuration" interface=ether2-master-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
add dhcp-options=hostname,clientid disabled=no interface=bridge-local
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established
add action=accept chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add action=accept chain=forward comment="default configuration" connection-state=established
add action=accept chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/system clock
set time-zone-autodetect=no
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
