I have been working with Mikrotik routers for over 15 years and have the problem that I cannot connect the Opnsense to a Mikrotik.
The Mikrotik router has a SIM card and no fixed IP. I have set up WG on the Opnsense and it also works with the WG client on the PC and mobile phone. Has anyone managed to do this with an MK router as the counterpart?
In peer config, set persistent keepalive to something like 20s and check if it works. Your Opnsense seems to be configured as responder and doesn’t initiate connection on it’s own.
It’s not clear for me, you posted a config where interface should have 10.90.200.4/32. Now you tell us it’s 10.55.55.254/24.
For the route, you should set gateway IP to the address of the peer, so if Opnsense peer is 10.55.55.253 - this is your gateway. Also you can consider using smaller networks for ptp links.
You can also check ping of the other side of tunnel first, before setuping routing
