MikroTik stencils for draw.io
Hi everyone,
I've been working on a library of custom vector stencils for draw.io with MikroTik hardware. The idea is simple: instead of labeling generic rectangles "RB2011" or spending time searching for device images, you just drag and drop the right device onto the canvas.
All stencils are SVG-based, so they scale cleanly at any size. Import the library file into draw.io (or diagrams.net) and you're good to go.
Currently available: CSS326-24G-2S+RM, RB2011UiAS-2HnD-IN, RB951Ui-2HnD, CCR1009-8G-1S, CCR1009-8G-1S-PC, CCR1009-8G-1S-1S+
Coming in v1.5: RB3011UiAS-RM, RB952Ui-5ac2nD (hAP ac lite), RBcAPGi-5acD2nD (cAP ac), RB962UiGS-5HacT2HnT (hAP ac), RBD52G-5HacD2HnD-TC (hAP ac²), RB2011iL-IN, RB1100
Want to see a specific device added? The best way is to draw the stencil yourself and submit a pull request. I work in Inkscape, but files from Adobe Illustrator or Visio are welcome too. If you're not sure where to start, open an issue and we'll sort it out.
GitHub: https://github.com/HugoFiermein/drawio-mikrotik
Feedback, suggestions and bug reports are all welcome. Hope it saves someone a few hours.
Good job mate!
