I use it but in manual is said about plugins which can help me very much. but I could not find them in the site, how can I find them if they are.
Can anybody help me with this.
Can you elaborate a little bit more on what you’re going for? I don’t see any questions or requests in your post…
You may want to look at this thread:
http://www.butchevans.com/forum/viewthread.php?forum_id=9&thread_id=58
don’t use that program, use the Dude as a daemon instead. Also there is something called Kiwi Syslog, which also works well.
I am a fan of “syslog 2 odbc”
It is a syslog server that pushes tha data to ODBC databases.
I use SQL2005. then I can use SQL to slice and dice the data…
Yum…
I try Kiwi it’s better as I can differed logs from each MT to separate folder, and it can do many other things, its very good for logging on remote server.
Thank you.
