Mikrotik Syslog
Dear All,
I have 4-5 Core routers(Mikrotik) and created log with syslog on remote syslog server. Presently all the routers logs written in single file on remote server. How can i create different log file for different Mikrotik router on remote syslog server.
Direct_logic
This should be done on the syslog server.
Thanks for reply,
But how can i do this on syslog server(Linux).
It differs from syslog to syslog. I use Kiwi syslog, but it runs on windows server machine. I can help you with this one.
http://www.rsyslog.com/ check it…
syslog-ng could handle that as well.
In case you still need some ideas about logging and syslog-ng specifically, you might get some ideas in my blog post about my own setup here: Replace MAC Addresses With Labels Using Syslog-NG.
Zap.
