Ive had a search around the forums but cant seem to find a definitive answer on this
What I’m trying to achieve is a mikrotik to mikrotik vpn or site to site to be official.
This is for a home setup, id like to be able to connect 2 home networks each with their own mikrotiks. I already have a dial in L2TP VPN for my current home network using a dynamic IP address but what i want to achieve is a permanent connection between the 2 homes so that we can share services. I run quite an extensive home network…Hyper V virtual servers, internal websites and facilities such as home automation & file sharing. Id like to be able to also use this as a way of doing off site backups to each home.
Can someone explain the best way or a guide if there is one to achieving this but with the issue of having a dynamic IP address…or if its even possible?
Put addresses at both ends of the ppp link /examp. 10.100.0.1/30 and 10.100.0.2/30 /.Route home networks over this addresses / add static route in main routing table for each home network respectively/ and make an exception in filter section on firewall for accepting the traffic between them .
I just subscribe to a free dyndns service, like no-ip.com. I have a pc thats on already 24/7 on my network run their free client that updates the public every 5 minutes, and then I can connect my vpn clients (mainly my phone and travel router) to xxxxxxx.ddns.net and my vpn works flawlessly behind a dynamic address. No scripts needed.
