Mikrotik to PureVPN
Hi everyone,
Hope I will be not too much off topic…
Did anyone successfully connected from the router to PureVPN using L2TP/IPsec or OVPN?
They provide steps for PPTP but I don’t want to use this protocol and I am struggling with setting up the two mentioned above.
Could anyone who successfully did it, help me, please?
Thanks!!
I think they do have guides for IPsec:
https://support.purevpn.com/how-to-setup-purevpn-l2tp-manually-on-mac
and the RouterOS manual should give you some ideas where to apply this in RouterOS:
http://wiki.mikrotik.com/wiki/Manual:IP/IPsec
Hi normis,
Thanks for your repsonse!
These guides were the first thing I followed trying to set it up - but keep failing with “NO-PROPOSAL-CHOSEN”…
Just wanted to ensure - as there are guides how to setup on OSX and WIN, is there any reason why it should not work on Mikrotik? - is there some difference in the client making it possibly impossible or when it works from win, it will simply work from mikrotik as well and all I need is just to carefully config?
Thanks!
It means that the phase2 settings do not match between the peers. You will need to adjust them on the MikroTik to match what PureVPN has set on their side of things. Since their guide is showing Windows and Mac, chances are they are using the default built in ones that Windows uses.
auth-algorithms=sha1
enc-algorithms=3des
pfs-group=modp1024
http://wiki.mikrotik.com/wiki/L2TP_%2B_IPSEC_between_Mikrotik_router_and_a_PC#Windows_PC
Hi, Here is the step by step guide of PureVPN, Follow these steps:
Go to “System Preferences”
Click “Network”
Click the “+” icon on the bottom left
A new box will pop-up, Click the “Interface box” and a drop down menu will appear
Click “VPN” from the drop down menu
Click “VPN Type” and select L2TP over IPSec
Name the service PureVPN L2TP, now click Create
In the new window, type the Server address box your desired server name (server addresses are available PureVPN’s support)
Fill in your username in “Account Name” box
Tick the “Show VPN status in menu bar” option
Next, click the “Authentication Settings” button
Fill in your PureVPN account password in “Password” box and 12345678 in “Shared Secret ” box, then click OK
Now click “Advanced ” on the bottom right
Tick “Send all traffic over VPN connection” , then click ok
Finally, click “Apply” to complete setup
Now click “Connect”
You should now be connected to PureVPN
Guide Source: https://www.bestvpnprovider.com/purevpn-review/
Do you know you sent me the steps for Windows, right? :slight_smile:
