I have successfully setup a connection largely starting from here: https://www.paranoids.at/mikrotik-routeros-6-38-ikev2-strongswan-rsa-auth-howto/
Everything is connected and the client (Centos 7 Strongswan) can connect to local (192.168.5.0/24) addresses, but I cannot connect to anything on the VPN client side (the Centos Strongswan setup) from 192.168.5.0/24 machines. I have disabled firewalls on the client and still no go. I cannot ping the host from Mikrotik over the vpn_bridge either.
Any ideas?
Mikrotik (IPSEC server):
add address=192.168.5.1/24 comment=Default interface=bridge-local network=192.168.5.0
add address=192.168.89.1/24 comment="ipsec vpn" interface=vpn-bridge network=192.168.89.0
/ip ipsec mode-config
add address=192.168.89.5 address-prefix-length=32 name=cfg-cloud static-dns=192.168.5.1,8.8.8.8,8.8.4.4 system-dns=no
/ip ipsec peer
add exchange-mode=ike2 name=peer1 passive=yes send-initial-contact=no
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 dpd-interval=1h enc-algorithm=aes-256,aes-128 hash-algorithm=sha256 lifetime=1h
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc,aes-128-cbc pfs-group=modp2048
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=ikev2-proposal pfs-group=none
/ip ipsec identity
add auth-method=digital-signature certificate=vpn.server comment="Misc Client" generate-policy=port-strict mode-config=cfg1 my-id=fqdn:vpn.server peer=peer1 \
remote-certificate=vpn.client remote-id=fqdn:vpn.client
add auth-method=digital-signature certificate=vpn.server comment="Google Cloud Server" generate-policy=port-strict mode-config=cfg-cloud my-id=fqdn:vpn.server peer=\
peer1 remote-certificate=vpn.cloud remote-id=fqdn:vpn.cloud
add address-pool=vpn name=cfg1 static-dns=192.168.5.1,8.8.8.8,8.8.4.4 system-dns=no
/ip ipsec policy
set 0 comment=vpn dst-address=192.168.89.0/24 proposal=ikev2-proposal src-address=0.0.0.0/0
add name=home ranges=192.168.5.10-192.168.5.250
add name=vpn ranges=192.168.89.10-192.168.89.50
StrongSwan ipsec.conf:
config setup
strictcrlpolicy=no
uniqueids=no
#charondebug="ike 1, knl 0, cfg 0"
charondebug="yes"
conn %default
conn tunnel
keyexchange=ikev2
ike=aes256-sha256-modp2048
esp=aes256-sha256-modp2048
ikelifetime = 24h
lifetime = 30m
dpddelay = 120s
left=%defaultroute
leftsourceip=%config
leftcert=cloud.crt
leftid=vpn.cloud
leftfirewall=no
right=home.domain.com
rightsubnet=192.168.89.0/24,192.168.5.0/24
rightid=vpn.server
modeconfig=push
auto=start
