HI guys,
Is it possible to plug a USB keyboard into the USB port of a RB and interact with the router in any way? I’ve plugged in a keyboard and I’ve seen that it detects it correctly as a keyboard so driver’s shouldn’t be a problem. I’ve tried using the port, screen and serial terminal interfaces without success.
I’m wondering if it would be possible to add a USB button that when pressed triggers a specific script for example? The keyboard is just a testing stepping stone.
