/ip vrf print where name=vrf3
0 name="vrf3" interfaces=none
/ip route print where routing-table=vrf3
0 As 0.0.0.0/0 gateway=pppoe-out1 routing-table=vrf3
I can successfully ping Google from VRF3 on R1.
R2:
/ip vrf print where name=vrf1
0 name="vrf1" interfaces=none
/ip route print where routing-table=vrf1
0 As 0.0.0.0/0 gateway=b.vl99 routing-table=vrf1 distance=1
However, I cannot ping Google from VRF1 on R2.
I'm trying to understand what I'm missing and why it works on R1 but not on R2.
Please continue posting a few more partial snippets of the output of random print commands.
Given enough posts we will before or later get the idea of what could be provided as a single /export of the whole configuration of both devices (which is what is needed).
You can see that the management interfaces between R1 and R2 are in the main routing table. All I'm doing is creating a VRF with interfaces=none and adding vlan99@main.
The hold point works from interface where the public ip-add is, but it doesn't work from local ip-add
If you want to redistribute the default route to a neighbouring device using the same AS number, you need to configure gateway=interface-name@main in the VRF. If you use gateway=IP-address, the default route will not be redistributed.
I'm happy to provide the exports from all routers if needed. However, my priority is to resolve the issue described above first.
Point taken.
When (if) I will ever get to know what
VPNv4 is, and I will need to redistribute a router with the same AS, this will surely come useful, thanks.
