Hi there, thanks for the guide! Would like to ask for some assistance however, as am struggling to set this up over the weekend while following several guides.
I’ve managed to successfully establish a handshake between my android phone and the Tik, but there’s no internet access and the log shows a barrage of the following message when enabling wireguard on my phone:
Buffer: memory Topics: Firewall, info WG: input: in:pppoe-outFEED out:(unknown 0), src-mac (phone mac), proto UDP, > (sensitive, phone public IP) > → > (sensitive, Tik public IP)> , len 124
The “no-internet-access” issue resolves if I configure the android client Allowed Addresses to my LAN subnet instead of 0.0.0.0/0, but I’m still getting the log barrage and I’m not certain that the traffic is properly routed through my pihole.
My network setup is as follows: ISP<-> ISP modem (bridge mode) ↔ Mikrotik router (PPPoE) ↔ LAN (Pihole DNS server)
# sep/26/2021 10:46:55 by RouterOS 7.1rc4
# software id = W9WG-AU8M
# model = 960PGS
# serial number = (sensitive)
add arp=proxy-arp comment="LAN Bridge" name=bridge
set [ find default-name=ether1 ] comment="WAN Primary - Modem" speed=\
100Mbps
set [ find default-name=ether2 ] advertise=1000M-half,1000M-full comment=\
" - Minion" poe-out=off speed=100Mbps
set [ find default-name=ether3 ] comment=" - Unraid" poe-out=off speed=\
100Mbps
set [ find default-name=ether4 ] comment=" - SHIELD" poe-out=off speed=\
100Mbps
set [ find default-name=ether5 ] comment=" - Camera" poe-out=forced-on speed=\
100Mbps
set [ find default-name=sfp1 ] advertise=1000M-half,1000M-full comment=\
" - Switch"
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=ether2 name=vlan4000-ether2 vlan-id=4000
add interface=ether3 name=vlan4000-ether3 vlan-id=4000
add interface=ether5 name=vlan4000-ether5 vlan-id=4000
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-outFEED \
user=(sensitive)
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
add name=dhcp ranges=192.168.88.3-192.168.88.254
add name=dhcp_pool2 ranges=10.10.102.2-10.10.102.254
add name=dhcp_pool3 ranges=10.10.105.2-10.10.105.254
add name=dhcp_pool4 ranges=10.10.113.2-10.10.113.254
add name=dhcp_pool5 ranges=10.10.117.2-10.10.117.254
add name=dhcp_pool6 ranges=10.10.119.2-10.10.119.254
add address-pool=dhcp interface=bridge lease-time=10m10s name=dhcp1
/queue simple
add name=Minion_QOS packet-marks=Minion_Packets priority=1/1 target=ether2
/queue tree
add limit-at=5M max-limit=7M name="Jelly Out" packet-mark=jellyfinout parent=\
global
/queue type
add kind=sfq name=sfq-default sfq-perturb=10
/queue simple
add max-limit=10M/100M name=sfq-default queue=sfq-default/sfq-default target=\
192.168.88.0/24 total-queue=sfq-default
/queue tree
add limit-at=10M max-limit=10M name="Minion Out" packet-mark=Minionout \
parent=global priority=1 queue=sfq-default
/routing bgp template
set default as=65530 disabled=no name=default output.network=bgp-networks
/routing ospf instance
add in-filter-chain=ospf-in name=default-v2 out-filter-chain=ospf-out
/routing ospf area
add instance=default-v2 name=backbone-v2
/routing table
add fib name=""
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp,rest-api"
add name=sniffer policy="ssh,read,!local,!telnet,!ftp,!reboot,!write,!policy,!\
test,!winbox,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp,!r\
est-api"
add bridge=bridge ingress-filtering=no interface=ether2
add bridge=bridge ingress-filtering=no interface=ether3
add bridge=bridge ingress-filtering=no interface=ether4
add bridge=bridge ingress-filtering=no interface=ether5
add bridge=bridge ingress-filtering=no interface=sfp1
/ip settings
set rp-filter=strict
/ipv6 settings
set disable-ipv6=yes
add interface=ether1 list=WAN
add interface=bridge list=LAN
add interface=pppoe-outFEED list=WAN
/interface wireguard peers
add allowed-address=10.0.0.1/32 interface=wireguard1 persistent-keepalive=25s \
public-key="[i](sensitive)[/i]"
add address=192.168.88.1/24 comment="LAN Primary" interface=bridge network=\
192.168.88.0
add address=192.168.42.1/24 comment="IoT vlan (eth1,2,5)" interface=\
vlan4000-ether3 network=192.168.42.0
add address=192.168.42.1/24 interface=vlan4000-ether5 network=192.168.42.0
add address=192.168.42.1/24 interface=vlan4000-ether2 network=192.168.42.0
add address=10.0.0.1/24 interface=wireguard1 network=10.0.0.0
add address=192.168.1.2/24 comment="Modem Gateway" interface=ether1 network=\
192.168.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-server lease
add address=192.168.88.253 client-id=1:cc:2d:e0:aa:7:6e comment=WiFi \
mac-address=[i](sensitive) [/i]server=dhcp1
add address=192.168.88.252 client-id=1:cc:2d:e0:aa:7:70 comment=WiFi \
add address=192.168.88.98 client-id=1:b8:27:eb:cd:dc:1d comment=PiHole \
add address=192.168.88.57 client-id=1:0:4:4b:bd:d:5d comment="Nvidia Shield" \
mac-address=[i](sensitive)[/i] server=dhcp1
add address=192.168.88.88 client-id=1:b8:ac:6f:90:e0:f8 comment=Unraid \
add address=192.168.88.8 client-id=1:b4:2e:99:3b:14:e5 comment=Minion \
add address=192.168.88.125 comment=HomeAssistant mac-address=\
(sensitive) server=dhcp1
add address=192.168.88.128 client-id=1:74:4d:28:75:6e:30 comment=Switch \
add address=192.168.88.38 client-id=1:94:53:30:3b:99:9c comment=LaserPrinter \
add address=192.168.88.10 client-id=1:52:54:0:52:63:75 comment=macOS \
add address=192.168.88.20 comment="3D Printer" mac-address=[i](sensitive) [/i]\
server=dhcp1
add address=192.168.88.95 client-id=1:2c:44:fd:c1:2e:c8 comment=\
"Color Printer" mac-address=[i](sensitive)[/i] server=dhcp1
add address=192.168.88.19 client-id=1:b8:ac:6f:90:e1:0 comment=R710 \
add address=192.168.88.4 client-id=1:ca:37:29:9:d8:a7 comment="Phone" \
add address=192.168.88.11 client-id=1:30:a9:de:c3:52:bc comment=TV \
add address=192.168.88.3 comment="Nintendo Switch" mac-address=\
add address=192.168.88.9 client-id=1:8:ed:ed:5d:c6:8e comment=\
"Dahua (camera)" mac-address=[i](sensitive) [/i]server=dhcp1
add address=192.168.88.22 client-id=1:52:54:0:3a:7b:82 mac-address=\
[i] (sensitive) [/i]server=dhcp1
add address=192.168.88.141 client-id=1:50:1e:2d:3f:50:ba comment=Anthem \
add address=192.168.88.0/24 dns-server=192.168.88.98 gateway=192.168.88.1 \
netmask=24
set allow-remote-requests=yes cache-max-ttl=1m servers=192.168.88.98
/ip firewall address-list
add address=192.168.88.2-192.168.88.254 list=allowed-to-router
add action=fasttrack-connection chain=forward connection-state=\
established,related hw-offload=yes
add action=accept chain=input comment="Accept WireGuard" dst-port=13231 \
in-interface-list=WAN log=yes log-prefix=WG: protocol=udp
add action=accept chain=forward comment="Accept WireGuard" connection-state=\
established,new disabled=yes dst-port=13231 in-interface=pppoe-outFEED \
"Accept established,related,untracked" connection-state=\
add action=accept chain=forward comment="Accept LAN >>> WAN" disabled=yes \
out-interface=ether1 src-address=192.168.88.0/24
add action=drop chain=forward comment="drop all from WAN not DSTNATed" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid
add action=drop chain=input in-interface-list=!LAN
add action=drop chain=input comment="Drop Blacklisted Hosts through Router" \
in-interface=ether1 src-address-list=BlackList
add action=drop chain=forward comment="Drop Blacklisted Hosts through Router" \
add action=accept chain=input comment="Accept to Router" src-address-list=\
allowed_to_router
add action=accept chain=input comment="Accept ICMP" protocol=icmp
add action=accept chain=input connection-state=established disabled=yes
add action=accept chain=input comment="accept local loopback (for CAPsMAN)" \
dst-address=127.0.0.1
/ip firewall mangle
add action=mark-packet chain=forward comment=jellyfin_rx_mark \
new-packet-mark=jellyfinout passthrough=yes src-address=192.168.88.88
add action=mark-packet chain=forward comment=Minion_rx_mark new-packet-mark=\
Minionout passthrough=yes src-address=192.168.88.8
add action=masquerade chain=srcnat comment="LAN - NAT (towards modem)" \
add action=masquerade chain=srcnat comment="LAN - NAT (towards web)" \
out-interface=pppoe-outFEED
add action=dst-nat chain=dstnat comment=\
"Pihole - run any upd traffic (except Pihole) through Pihole" \
dst-address=!192.168.88.98 dst-port=53 protocol=udp src-address=\
!192.168.88.98 to-addresses=192.168.88.98
"Pihole - run any tcp traffic (except Pihole) through Pihole" \
dst-address=192.168.88.98 dst-port=53 protocol=tcp src-address=\
add action=masquerade chain=srcnat comment=Pihole dst-address=192.168.88.98 \
dst-port=53 protocol=udp src-address=192.168.88.0/24
dst-port=53 protocol=tcp src-address=192.168.88.0/24
add action=dst-nat chain=dstnat comment="TCP inbound to port 443 >> 192.168.88.88:1444
dst-port=443 in-interface=pppoe-outFEED protocol=tcp to-addresses=\
192.168.88.88 to-ports=1444
add action=dst-nat chain=dstnat comment="UDP inbound to port 443 >> 192.168.88.88:1444
dst-port=443 in-interface=pppoe-outFEED protocol=udp to-addresses=\
add action=dst-nat chain=dstnat disabled=yes dst-port=13231 in-interface=pppoe-outFEED protocol=udp \
src-port="" to-addresses=192.168.88.1 to-ports=13231
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-outFEED \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes port=2121
set www disabled=yes port=8081
set ssh disabled=yes
set www-ssl disabled=no tls-version=only-1.2
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote strong-crypto=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=bridge type=internal
/system clock
set time-zone-name=Europe/Athens
/system identity
set name="hex PoE"
/system package update
set channel=development
x.rsc (10.5 KB)
