MikroTik Wireless Wire nRAY not pre config
I bought a pair of MikroTik Wireless Wire nRAY not knowing I could get them pre-config and would like to execute whatever is needed to have them more readily available to plug and play due to lack of knowledge.
Could you please reformulate your post according to: Getting the most out of this forum
These ones?:
https://mikrotik.com/product/wireless_wire_nray
In theory they should be pre-coupled in factory.
Anyway the base configuration should be simple enough, essentially one should be set as AP and the other one as Station (please read as Client).
What you should do is to:
  1. get your hands on a copy of Winbox (preferrably 3.x), see:
    Why you should use Winbox
  2. follow the instructions here:
    Forum rules - #5 by gigabyte091
    and post the current configurations of both devices.
