when i open winbox and connect in host the mikrotik show me “wrong username or password” i don’t changed the password or username, restart but don’t have success.
sorry my english
Cristiano
sorry my english
Cristiano
Was it old RouterOS version? If so its likely been hacked. Good news is, being old version you can use the same hack to re-gain access - but once its been compromised you should take config export, make sure no bad config is in there, and do a fresh net-install.
this issue keeps happening to me when my winbox version is to old for the used RouterOS version - just try to update winbox before you do anything else.
@mikrotik:
please add a more usable error message because even though it happened to me a couple of times I am regularly confused for some time before I figure it out again.
BR
Alex
WinBox v3.18 doesn’t connect to RB with empty password out-of-the box.
Just login via WebFig / SSH / telnet and set a password (may even be empty).
WinBox login w/o password seems to works fine..
i can’t confirm this - i am pretty sure I did exactly that last week
BR
Alex
You are correct ![]()
