I am network engineer and search for wifi router for home. Microrotik have two types of routers: MIPS based or ARM based. What is difference? What is better?
Actually we also have PPC, SMIPS, MIPS-LE and TILE. There is no better. Just different architectures.
And MMIPS… ![]()
Router size is better determined by the WAN bandwidth you want to “move” first, and what kind of filtering, queueing, etc you’ll want to apply.
Do you need a router with wireless capabilities? Will you go with a seperate router and AP?
I thought that this is same on all routers with same RouterOS level ( RouterOS: Level 4).
pukkita> Do you need a router with wireless capabilities?
Yes /n or /ac, 2.4 and 5 GHz.
pukkita> Will you go with a separate router and AP?
No, but it is possible, if this this option is cheaper.
Go by ARM, hap ac 2 for example.
https://mikrotik.com/product/hap_ac2#fndtn-testresults
This option is two times cheaper than hap ac. What’s worse with it?
The biggest difference is lack of SFP port and 2 wireless chains instead of 3. But this is of little importance, since nearly all WiFi devices are 2 chain anyway.
These are not MIPS ISA versions, but Mikrotik configurations.
And is there any MIPS CPU that is not bi-endian besides R8000 ?
