From my exp sha1 is generally 50% slower than md5, so I don’t really know why it capped at 2Mbps. I have other x86 based router and sha1/3des is 50% slower than md5/des. Also I will later test it on RB450G and post results.
i have that same problem, but with beta 4
we are looking into the problem thank you all for reporting it.
Any fix for this when should we expect the next release? Having trouble monitoring traffic in realtime without torch
I have same issue as Inox, pleas see my screenshot, i post topic aprox 2 weeks but no reply ![]()
we have fixed this in RC2
i can confirm that rc2 torch is working!! on x86
gustkiller, where You get rc2
it is a pre-release i received to test the HP Smartarray SCSI/SAS driver. Then I downgraded to rc1 because some problems with ospf.
Did you report about ospf bug? Because i’m intrested to use RC2 with ospf …
sure!!
Just checked all my x86 RouterOS machines, and Torch works in all cases, in all machines running v5x…
IMHO, sometimes no tx traffic is telling you something other than Torch not working. If you are getting hit hard by intruders, it would possibly show a lot of rx for many IPs, but those IPs are properly not responding to the bogus or intruder attempts. Just a thought…
just wait
Sorry for flame … ![]()
But Just gimme something new to test … ![]()
I also have the same issue as InoX and I would love to get my hands on the fix ![]()
One thing that bothers me too is that the ports & protocols aren’t listed by default any more like they used to in v3 & v4.
