I have two crs328-24p-4s+rm running 7.5 I enabled mlag over a bonded peer link, I am only using L2 features no l3 features on the switch and no acl. Once I enabled mlag I lost access to the switch via ip address but can still connect via winbox either wired or wirelessly. All traffic is passing and mlag is working, there are two other switches in play but all traffic is flowing. Can’t think of what could have changed at the address level to suddenly loss access.
[admin@core233] > export
# dec/11/2022 14:38:05 by RouterOS 7.5
# software id = MDNX-ZUMT
# model = CRS328-24P-4S+
# serial number = D41D0B26F339
add admin-mac=C4:AD:34:F6:8E:37 auto-mac=no comment=defconf dhcp-snooping=yes igmp-snooping=yes name=bridge vlan-filtering=yes
set [ find default-name=ether15 ] name=Bedroom
set [ find default-name=ether16 ] name=KitchenAP
set [ find default-name=ether9 ] name=backyad
set [ find default-name=ether10 ] name=basement
set [ find default-name=sfp-sfpplus3 ] l2mtu=9000 mtu=9000 name=core96_sfp6
set [ find default-name=sfp-sfpplus2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full,2500M-full,5000M-full l2mtu=9000 mtu=9000 name=core98_sfp4
set [ find default-name=sfp-sfpplus1 ] l2mtu=9000 mtu=9000 name=core234-sfp2
set [ find default-name=sfp-sfpplus4 ] l2mtu=9000 mtu=9000 name=core234-sfp4
set [ find default-name=ether7 ] name=dead poe-out=off
set [ find default-name=ether13 ] poe-out=off
set [ find default-name=ether24 ] poe-out=off
set [ find default-name=ether3 ] name=ethport poe-out=off
set [ find default-name=ether14 ] name=frontdoor
set [ find default-name=ether5 ] name=garage
set [ find default-name=ether12 ] name=hall
set [ find default-name=ether4 ] name=left
set [ find default-name=ether8 ] name=leftf
set [ find default-name=ether18 ] name=plate
set [ find default-name=ether19 ] name=plate2
set [ find default-name=ether20 ] name=pool
set [ find default-name=ether17 ] name=rear
set [ find default-name=ether6 ] name=right
set [ find default-name=ether2 ] name=rightF
set [ find default-name=ether11 ] name=roof poe-out=off
/interface vlan
add interface=bridge name=MHQ vlan-id=103
/interface bonding
add mode=802.3ad mtu=9000 name=234-b slaves=core234-sfp2,core234-sfp4
add mlag-id=10 mode=802.3ad name=fw01-bond slaves=ether21
add mlag-id=20 mode=802.3ad name=fw02-bond slaves=ether22
add name=WAN
add name=LAN
add name=cam
/interface lte apn
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/system logging action
set 3 remote=172.16.1.54 remote-port=7004
/interface bridge mlag
set bridge=bridge peer-port=234-b
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=ether1 pvid=103
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=rightF pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=ethport pvid=106
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=left pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=garage pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=right pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=dead
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=leftf pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=backyad pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=basement trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=roof
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=hall trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=ether13 pvid=103
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=frontdoor pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=Bedroom trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=KitchenAP trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=rear pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=plate pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=plate2 pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=pool pvid=222
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no interface=ether23 pvid=100
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=ether24 trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=core98_sfp4 trusted=yes
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=core96_sfp6 trusted=yes
add bridge=bridge interface=234-b pvid=99 trusted=yes
add bridge=bridge frame-types=admit-only-vlan-tagged hw=no interface=fw01-bond
add bridge=bridge frame-types=admit-only-vlan-tagged hw=no interface=fw02-bond
set discover-interface-list=all lldp-med-net-policy-vlan=1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=core98_sfp4,core234-sfp4,core234-sfp2,core96_sfp6,234-b untagged=rightF,left,garage,right,leftf,backyad,pool,frontdoor,rear,plate vlan-ids=222
add bridge=bridge tagged=core98_sfp4,core234-sfp2,core234-sfp4,core96_sfp6,234-b,fw01-bond untagged=ethport vlan-ids=106
add bridge=bridge tagged=core98_sfp4,core234-sfp2,core234-sfp4,core96_sfp6,234-b vlan-ids=105
add bridge=bridge tagged=basement,core98_sfp4,hall,core234-sfp2,core96_sfp6,KitchenAP,Bedroom,core234-sfp4,234-b vlan-ids=104
add bridge=bridge tagged=basement,core98_sfp4,hall,core234-sfp2,core96_sfp6,KitchenAP,Bedroom,core234-sfp4,234-b vlan-ids=102
add bridge=bridge tagged=basement,core98_sfp4,hall,core234-sfp2,core96_sfp6,KitchenAP,Bedroom,core234-sfp4,234-b vlan-ids=101
add bridge=bridge tagged=core98_sfp4,core96_sfp6,core234-sfp2,core234-sfp4,234-b vlan-ids=100
add bridge=bridge tagged=basement,core98_sfp4,hall,core234-sfp2,KitchenAP,core96_sfp6,Bedroom,core234-sfp4,bridge,234-b untagged=ether13,ether1 vlan-ids=103
add bridge=bridge tagged=core96_sfp6,core234-sfp2,core234-sfp4,234-b untagged=core98_sfp4 vlan-ids=420
add interface=ether1 list=WAN
add interface=rightF list=LAN
add interface=ethport list=LAN
add interface=left list=LAN
add interface=garage list=LAN
add interface=right list=LAN
add interface=dead list=LAN
add interface=leftf list=LAN
add interface=backyad list=LAN
add interface=basement list=LAN
add interface=roof list=LAN
add interface=hall list=LAN
add interface=ether13 list=LAN
add interface=frontdoor list=LAN
add interface=Bedroom list=LAN
add interface=KitchenAP list=LAN
add interface=rear list=LAN
add interface=plate list=LAN
add interface=plate2 list=LAN
add interface=pool list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether23 list=LAN
add interface=ether24 list=LAN
add interface=core234-sfp2 list=LAN
add interface=core98_sfp4 list=LAN
add interface=core96_sfp6 list=LAN
add interface=core234-sfp4 list=LAN
add interface=backyad list=cam
add interface=ether13 list=cam
add interface=rear list=cam
add interface=right list=cam
add interface=rightF list=cam
add interface=left list=cam
add interface=leftf list=cam
add interface=garage list=cam
add interface=frontdoor list=cam
add interface=plate list=cam
add interface=plate2 list=cam
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.103.233/24 interface=MHQ network=192.168.103.0
/ip dhcp-client
add dhcp-options=clientid,clientid_duid,hostname interface=bridge
set servers=172.16.1.154
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.103.1
/snmp
set contact=netadmin enabled=yes location=MHQ trap-target=192.168.105.248
/system clock
set time-zone-name=America/Chicago
/system identity
set name=core233
/system logging
set 0 action=remote
set 1 action=remote
set 2 action=remote
set 3 action=remote
add action=remote topics=interface
add action=remote topics=bridge
/system ntp client
set enabled=yes
/system ntp client servers
add address=172.16.1.4
/system package update
set channel=testing
/system routerboard settings
set boot-os=router-os boot-protocol=dhcp
/system swos
set allow-from-ports=p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p13,p14,p15,p16,p17,p18,p19,p20,p21,p22,p23,p24,p25,p26,p27,p28 identity=core233 static-ip-address=192.168.103.233
/tool sniffer
set file-name=temp2.pkt filter-interface=bridge
[admin@core233] >
