Two switches with a single peer link (I will be using LACP once I've gotten the basics figured out).
Two Linux clients with LACP where eth2 goes to switch 1 and eth3 goes to switch 2.
If I do a ping series from client 2 to client 1, and on client 1 take eth3 down:
The pings no longer reach between clients.
I can see the packets reach switch 1 peer link, but not the bond.
Switch 2 still shows client 1 MAC to be on the bond interface instead of the peer link.
Switch 2 shows the client 1 bond as: key=15 flags="ATGS--F-"
If I instead take down the port on switch 2 side instead of on the client:
Pings continue working
Switch 2 shows client 1 MAC to be on the peer link interface.
Switch 2 shows the client bond as: key=0 flags="ATGSCD--" partner-sys-id=AA:C1:AB:5C:7F:5B partner-sys-priority=65535 partner-key=15 partner-flags="ATGSCD--"
In both cases client 1 LACP status shows LACP for eth3 as down, so that side seems to be working fine.
But the switch seems to not really fail over correctly on the MLAG when the state is "ATGS--F-" which should indicate failed. Instead it only seems to react to "key=0" (or something else that I don't know where to look for).
My question is: Is this intentional, an issue/limitation with CHR in containerlab, a configuration issue, or a bug?
I'll continue digging, but before spending lots of time digging deeper I would just want to know if this is expected or not. I'm hoping it's not by design, because I see a lot of cases where MLAG is much worse than regular LACP since it seems to then require a physical link failure and everything else will just fail traffic.
After reading MLAG Support On CHR? it seems like it may well be a limitation when using CHR. Although my setup does work partially at least, so better than what's discussed in that thread.
That's too bad though, because with MLAG being so historically finicky and buggy it would have been great to test and compare using a virtual lab. This would kind of "force" me to get a set of test switches I think.
I hadn't seen that thread - but it doesn't look promising for the CHR approach. At a glance the configurations look reasonable. The syntax I use is a little different (I'm running RouterOS 7), but appears to be expressing the same things, notably:
Since CHR MLAG support was added in 7.22 I'll try to downgrade to that version.
But can anyone confirm if they have gotten MLAG to work with edge LACP where a link fails in a way that is not seen as complete link loss on the switch side (but the client actually fails the LACP over to just one link)?
Same in v7.22.3. Failing on the server side with LACP status: A port=ether2 key=15 flags="ATGS--F-"
Which is clearly failed, traffic does not switch to pass over the MLAG. But, setting interface disabled on the switch gives LACP status: port=ether2 key=0 flags="ATGS--F-"
Traffic does start to flow over the MLAG.
On my end I've only tested on switch to switch LACP connections. So there may be something specific to the Linux bonding configuration that it doesn't like.
