Mlag / crs518-16xs-2xq-rm
Hello, I am configuring MLAGU on CRS518-16XS-2XQ-RM devices. And I came across a problem where I don’t know much, because the information is varied. How to configure the bridge correctly? I couldn’t find this mentioned anywhere in the official documentation. If I left the default configuration I would use the same MAC in the admin-mac field that the bridge has set, but apparently both devices are supposed to have the same MAC set in “admin-mac”. Has anyone solved a similar problem ?
Configuration:
add name=bridge-cluster protocol-mode=rstp priority=0x1000 vlan-filtering=yes
set bridge-cluster auto-mac=no admin-mac=[/interface get bridge-cluster mac-address]
or
/interface bridge set bridge-cluster auto-mac=no admin-mac=02:AA:BB:CCD:02
/interface bonding
add lacp-rate=1sec mode=802.3ad name=bond-peer slaves=qsfp28-1-1,qsfp28-2-1 transmit-hash-policy=layer-2-and-3
add lacp-rate=1sec mlag-id=100 mode=802.3ad name=bond-firewall slaves=sfp28-14,sfp28-15
add bridge=bridge-cluster interface=bond-peer pvid=99
add bridge=bridge-cluster edge=yes frame-types=admit-all interface=bond-firewall
add bridge=bridge-cluster edge=yes interface=ether1
/interface bridge vlan
add bridge=bridge-cluster tagged=bond-peer,bond-firewall vlan-ids=10
add bridge=bridge-cluster untagged=bond-peer vlan-ids=99
add bridge=bridge-cluster tagged=bond-peer untagged=ether1 vlan-ids=1
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
SW01
/interface bridge mlag # priority=0 = master, priority=50 = secondary
set bridge=bridge-cluster peer-port=bond-peer priority=0
/system identity
set name=SW01
SW02
set bridge=bridge-cluster peer-port=bond-peer priority=50
/system identity
set name=SW02
None of mine have the same admin MAC. Where does it say that?
Once the MLAG is up, they’ll use the MAC address of the primary switch automatically.
On the bridge, see my configuration. What is the correct MAC to use ?
or
I just copied and pasted the MAC that showed up as the automatic one and made it the admin MAC.
