I'm troubleshooting an unusual forwarding behaviour in a MikroTik MLAG setup and would appreciate some help understanding what might cause it.
Topology
- Two MikroTik CRS309-1G-8S+ switches (
spinesw01,spinesw02), RouterOS 7.25. - The switches form an MLAG pair using
po1000as the inter-chassis link (ICC). - Both firewalls (
fw01,fw02) are connected to both spines using LACP. - Each firewall has its own LACP bond (
bond1), with one physical link to each spine. - On the spines:
po1: LACP to fw01,mlag-id=1po2: LACP to fw02,mlag-id=2po3: LACP to the leaf switch pair,mlag-id=3
- fw01 is the active firewall; fw02 is passive. VRRP is configured on fw01/fw02, using grouped VRRP instances. Only the group authority on the management VLAN sends VRRP advertisements.
Problem
During an iperf test between 10.10.0.4 and 10.10.8.4, fw02 receives a large amount of traffic even though it is passive.
The path here is 10.10.0.4 <-> leafsw03 <-> spinesw01 <-> fw01 <-> spinesw01/02 <-> leafsw01/02 <-> 10.10.8.4.
A packet capture on fw02's sfp1 shows frames like:
SRC MAC: 40:3F:8C:CC:74:D7
DST MAC: 00:00:5E:00:01:6C
VLAN: 1080
SRC IP: 10.10.8.4
DST IP: 10.10.0.4
00:00:5E:00:01:6C is the VRRP virtual MAC belonging to fw01.
The corresponding bridge host entry on both spines is:
mac-address=00:00:5E:00:01:6C
vid=1080
interface=po1
This entry is not present most of the time. If added manually TCP retransmissions drop from several thousands to only few hundrets during iperf test. This is only done to test the behaviour as this manual entry defeats the purpose of VRRP (redundancy)
Performance impact
A 60-second iperf test with four parallel streams gives approximately:
| Test | Throughput | TCP retransmissions |
| 10.10.0.4 β 10.10.8.4 (routed through firewalls and spines) | 940 Mbit/s | 4,418 |
| 10.10.8.2 β 10.10.8.4 (same subnet, both connected to the same leaf-pair (with MLAG)) | 941 Mbit/s | 110 |
In another routed test, retransmissions increased to 11,376.
During these tests, fw02's CPU usage rises significantly, sometimes reaching 100%. Its counters show approximately 7.4 GB received on sfp1, but only a few MB transmitted.
The connection from the notebook is wired, no wireless is being used in this case.
What I've tried
- The VRRP MAC is dynamically learned on
po1on both spines after fw01 sends an ARP reply using that MAC. - When the FDB entry exists, fw02's CPU load and the retransmission count are significantly lower. When it disappears, both increase.
The current bridge-port configuration has hardware offload enabled (H flag), and unknown-unicast-flood=yes on po2.
There are no obvious physical link errors or FCS errors during the tests.
Questions
- Could this be related to MLAG forwarding, FDB synchronisation, or hardware offloading on the CRS309/Prestera switch chip?
- Is there a known RouterOS 7.25 issue or configuration detail that could explain this behaviour?
- What would be the best way to determine why these frames are sent to fw02?
I would particularly appreciate suggestions for diagnosing the actual hardware forwarding behaviour, rather than simply disabling unknown-unicast flooding or adding static FDB entries.
[user@fw01] > /interface/export
# 2026-11-01 11:01:45 by RouterOS 7.25
# software id = <redacted>
# model = CCR2116-12G-4S+
# serial number = <redacted>
add name=mgmt
add name=wan
add name=lan
set [ find default-name=ether1 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether2 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether3 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether4 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether5 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether6 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether7 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether8 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether9 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether10 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether11 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether12 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether13 ] comment=";;;" l2mtu=1598
set [ find default-name=sfp-sfpplus1 ] comment="Core;spinesw01 sfp-sfpplus1;C0000118;" l2mtu=1598
set [ find default-name=sfp-sfpplus2 ] comment="Core;spinesw02 sfp-sfpplus1;C0000119;" l2mtu=1598
set [ find default-name=sfp-sfpplus3 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=sfp-sfpplus4 ] comment=";;;" disabled=yes l2mtu=1598
/interface bonding
add comment="LACP to spinesw0[12]" lacp-rate=1sec min-links=1 mode=802.3ad name=bond1 slaves=sfp-sfpplus1,sfp-sfpplus2 transmit-hash-policy=layer-2-and-3
/interface ethernet switch
set switch1 l3-hw-offloading=yes
/interface vlan
add interface=bond1 name=vl-900-uplink vlan-id=900
add interface=bond1 name=vl-999-mgmt vlan-id=999
add interface=bond1 name=vl-1000-int vlan-id=1000
add interface=bond1 name=vl-1010-media vlan-id=1010
add interface=bond1 name=vl-1030-tools vlan-id=1030
add interface=bond1 name=vl-1040-lab vlan-id=1040
add interface=bond1 name=vl-1050-iot vlan-id=1050
add interface=bond1 name=vl-1060-work vlan-id=1060
add interface=bond1 name=vl-1070-ff vlan-id=1070
add interface=bond1 name=vl-1080-virt vlan-id=1080
add interface=bond1 name=vl-1090-ipmi vlan-id=1090
add interface=bond1 name=vl-1100-unk vlan-id=1100
add interface=vl-999-mgmt list=mgmt
add interface=vl-999-mgmt list=lan
add interface=vl-1000-int list=lan
add interface=vl-1010-media list=lan
add interface=vl-1030-tools list=lan
add interface=vl-1040-lab list=lan
add interface=vl-1050-iot list=lan
add interface=vl-1060-work list=lan
add interface=vl-1070-ff list=lan
add interface=vl-1080-virt list=lan
add interface=vl-1090-ipmi list=lan
add interface=vl-900-uplink list=wan
/interface vrrp
add group-authority=self interface=vl-999-mgmt name=vrrp-mgmt priority=254 remote-address=10.10.99.252 sync-connection-tracking=yes vrid=99
add group-authority=vrrp-mgmt interface=vl-1030-tools name=vrrp-tools priority=254 vrid=103
add group-authority=vrrp-mgmt interface=vl-1100-unk name=vrrp-unk priority=254 vrid=110
add group-authority=vrrp-mgmt interface=vl-900-uplink name=vrrp-uplink priority=254 vrid=90
add group-authority=vrrp-mgmt interface=vl-1080-virt name=vrrp-virt priority=254 vrid=108
add group-authority=vrrp-mgmt interface=vl-1060-work name=vrrp-work priority=254 vrid=106
add interface=vrrp-mgmt list=lan
add interface=vrrp-tools list=lan
add interface=vrrp-virt list=lan
add interface=vrrp-work list=lan
add interface=vrrp-uplink list=wan
/interface vrrp
add group-authority=vrrp-mgmt interface=vl-1070-ff name=vrrp-ff priority=254 vrid=107
add group-authority=vrrp-mgmt interface=vl-1000-int name=vrrp-int priority=254 vrid=100
add group-authority=vrrp-mgmt interface=vl-1050-iot name=vrrp-iot priority=254 vrid=105
add group-authority=vrrp-mgmt interface=vl-1090-ipmi name=vrrp-ipmi priority=254 vrid=109
add group-authority=vrrp-mgmt interface=vl-1040-lab name=vrrp-lab priority=254 vrid=104
add group-authority=vrrp-mgmt interface=vl-1010-media name=vrrp-media priority=254 vrid=101
add interface=vrrp-ff list=lan
add interface=vrrp-int list=lan
add interface=vrrp-iot list=lan
add interface=vrrp-ipmi list=lan
add interface=vrrp-lab list=lan
add interface=vrrp-media list=lan
[user@fw02] > /interface/export
# 2026-11-01 11:18:59 by RouterOS 7.25
# model = RB3011UiAS
add name=mgmt
add name=wan
add name=lan
set [ find default-name=ether1 ] comment="Core;spinesw02 sfp-sfpplus2;C000005;"
set [ find default-name=sfp1 ] auto-negotiation=no comment="Core;spinesw01 sfp-sfpplus2;C000048;" l2mtu=1598 speed=1G-baseT-full
/interface bonding
add comment="LACP to spinesw0[12]" lacp-rate=1sec min-links=1 mode=802.3ad name=bond1 slaves=ether1,sfp1 transmit-hash-policy=layer-2-and-3
/interface vlan
/interface vrrp
add group-authority=self interface=vl-999-mgmt name=vrrp-mgmt remote-address=10.10.99.253 sync-connection-tracking=yes vrid=99
add group-authority=vrrp-mgmt interface=vl-1030-tools name=vrrp-tools vrid=103
add group-authority=vrrp-mgmt interface=vl-1100-unk name=vrrp-unk vrid=110
add group-authority=vrrp-mgmt interface=vl-900-uplink name=vrrp-uplink vrid=90
add group-authority=vrrp-mgmt interface=vl-1080-virt name=vrrp-virt vrid=108
add group-authority=vrrp-mgmt interface=vl-1060-work name=vrrp-work vrid=106
/interface vrrp
add group-authority=vrrp-mgmt interface=vl-1070-ff name=vrrp-ff vrid=107
add group-authority=vrrp-mgmt interface=vl-1000-int name=vrrp-int vrid=100
add group-authority=vrrp-mgmt interface=vl-1050-iot name=vrrp-iot vrid=105
add group-authority=vrrp-mgmt interface=vl-1090-ipmi name=vrrp-ipmi vrid=109
add group-authority=vrrp-mgmt interface=vl-1040-lab name=vrrp-lab vrid=104
add group-authority=vrrp-mgmt interface=vl-1010-media name=vrrp-media vrid=101
[user@spinesw01] > /interface/export
# 2026-11-01 11:21:31 by RouterOS 7.25
# model = CRS309-1G-8S+
add name=mgmt
set [ find default-name=sfp-sfpplus1 ] comment="Core;fw01 sfp-sfpplus1;C0000118;"
set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no comment="Core;fw02 sfp1;C000048;" speed=1G-baseT-full
set [ find default-name=sfp-sfpplus3 ] comment="Core;leafsw01 sfp-sfpplus1;C0000116;"
set [ find default-name=sfp-sfpplus4 ] comment="Access;PP-Basement-01 23;C0000113;"
set [ find default-name=sfp-sfpplus5 ] comment="Access;PP-Basement-01 24;C0000112;"
set [ find default-name=sfp-sfpplus6 ] comment=";;;" disabled=yes
set [ find default-name=sfp-sfpplus7 ] comment="Core;spinesw02 sfp-sfpplus7;C0000114;ICC"
set [ find default-name=sfp-sfpplus8 ] comment="Core;spinesw02 sfp-sfpplus8;C0000115;ICC"
/interface bonding
add comment="LACP to fw01" lacp-rate=1sec min-links=1 mlag-id=1 mode=802.3ad name=po1 slaves=sfp-sfpplus1 transmit-hash-policy=layer-2-and-3
add comment="LACP to fw02" lacp-rate=1sec min-links=1 mlag-id=2 mode=802.3ad name=po2 slaves=sfp-sfpplus2 transmit-hash-policy=layer-2-and-3
add comment="LACP to leafsw0[12]" lacp-rate=1sec min-links=1 mlag-id=3 mode=802.3ad name=po3 slaves=sfp-sfpplus3 transmit-hash-policy=layer-2-and-3
add comment="LACP to leafsw03" lacp-rate=1sec min-links=1 mode=802.3ad name=po4 slaves=sfp-sfpplus4 transmit-hash-policy=layer-2-and-3
add comment="ICC bond" lacp-rate=1sec min-links=1 mode=802.3ad name=po1000 slaves=sfp-sfpplus7,sfp-sfpplus8 transmit-hash-policy=layer-2-and-3
add admin-mac=02:00:00:99:00:11 auto-mac=no frame-types=admit-only-vlan-tagged mlag-peer-port=po1000 mlag-priority=50 mtu=1500 name=general-bridge priority=0x1000 vlan-filtering=yes
/interface vlan
add interface=general-bridge name=vl-999-mgmt vlan-id=999
/interface bridge host
add bridge=general-bridge interface=po1 mac-address=00:00:5E:00:01:6C vid=1080
add bridge=general-bridge edge=yes frame-types=admit-only-vlan-tagged interface=po1
add bridge=general-bridge edge=yes frame-types=admit-only-vlan-tagged interface=po2
add bridge=general-bridge edge=no frame-types=admit-only-vlan-tagged interface=po3
add bridge=general-bridge edge=no frame-types=admit-only-vlan-tagged interface=sfp-sfpplus5
add bridge=general-bridge edge=no frame-types=admit-only-vlan-tagged interface=po4
add bridge=general-bridge edge=no interface=po1000 pvid=100
/interface bridge vlan
add bridge=general-bridge tagged=general-bridge,po1,po2,po3,po4,po1000,sfp-sfpplus5 vlan-ids=999
add bridge=general-bridge tagged=po1,po2,po4,po1000 vlan-ids=900
add bridge=general-bridge tagged=po1,po2,po4,po1000 vlan-ids=1000
add bridge=general-bridge tagged=po1,po2,po3,po4,po1000,sfp-sfpplus5 vlan-ids=1010
add bridge=general-bridge tagged=po1,po2,po3,po1000 vlan-ids=1030
add bridge=general-bridge tagged=po1,po2,po3,po1000 vlan-ids=1040
add bridge=general-bridge tagged=po1,po2,po4,po1000 vlan-ids=1050
add bridge=general-bridge tagged=po1,po2,po4,po1000 vlan-ids=1060
add bridge=general-bridge tagged=po1,po2,po4,po1000 vlan-ids=1070
add bridge=general-bridge tagged=po1,po2,po3,po1000 vlan-ids=1080
add bridge=general-bridge tagged=po1,po2,po3,po1000 vlan-ids=1090
add bridge=general-bridge tagged=po1,po2,po4,po1000 vlan-ids=1100
[user@spinesw02] > /interface/export
# 2026-11-01 11:21:48 by RouterOS 7.25
add name=mgmt
set [ find default-name=sfp-sfpplus1 ] comment="Core;fw01 sfp-sfpplus2;C0000119;"
set [ find default-name=sfp-sfpplus2 ] comment="Core;fw02 ether1;C000005;"
set [ find default-name=sfp-sfpplus3 ] comment="Core;leafsw02 sfp-sfpplus1;C0000117;"
set [ find default-name=sfp-sfpplus5 ] comment=";;;" disabled=yes
set [ find default-name=sfp-sfpplus7 ] comment="Core;spinesw01 sfp-sfpplus7;C0000114;"
set [ find default-name=sfp-sfpplus8 ] comment="Core;spinesw01 sfp-sfpplus8;C0000115;"
/interface bonding
add admin-mac=02:00:00:99:00:12 auto-mac=no frame-types=admit-only-vlan-tagged mlag-peer-port=po1000 mlag-priority=100 mtu=1500 name=general-bridge priority=0x1000 vlan-filtering=yes
/interface vlan
add bridge=general-bridge tagged=general-bridge,po1,po2,po3,po1000 vlan-ids=999
add bridge=general-bridge tagged=po1,po2,po1000 vlan-ids=900
add bridge=general-bridge tagged=po1,po2,po1000 vlan-ids=1000
add bridge=general-bridge tagged=po1,po2,po3,po1000 vlan-ids=1010
add bridge=general-bridge tagged=po1,po2,po1000 vlan-ids=1050
add bridge=general-bridge tagged=po1,po2,po1000 vlan-ids=1060
add bridge=general-bridge tagged=po1,po2,po1000 vlan-ids=1070
add bridge=general-bridge tagged=po1,po2,po1000 vlan-ids=1100
[user@leafsw01] > /interface/export
# 2026-11-01 11:22:10 by RouterOS 7.25
# model = CRS326-24G-2S+
add name=mgmt
set [ find default-name=ether1 ] comment="Core;leafsw02 ether1;C000100;" l2mtu=1598
set [ find default-name=ether2 ] comment="Core;leafsw02 ether2;C000144;" l2mtu=1598
set [ find default-name=ether3 ] comment="Access;nas01 eth0;C000145;" l2mtu=1598
set [ find default-name=ether4 ] comment="Access;vhost01 eno1;C000028;" l2mtu=1598
set [ find default-name=ether5 ] comment="Access;vhost02 enp2s0;C000150;" l2mtu=1598
set [ find default-name=ether6 ] comment="Access;vhost03 enp9s0;C000149;" l2mtu=1598
set [ find default-name=ether7 ] comment="Access;vhost04 enp8s0;C000152;" l2mtu=1598
set [ find default-name=ether8 ] comment="Access;monitoring02 eth0;C000004;" l2mtu=1598
set [ find default-name=ether9 ] comment="Access;log01 eth0;C000014;" l2mtu=1598
set [ find default-name=ether10 ] comment="Access;cs01 eth0;C000039;" l2mtu=1598
set [ find default-name=ether11 ] comment="Access;tools02 eth0;C000026;" l2mtu=1598
set [ find default-name=ether13 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether14 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether15 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether16 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether17 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether18 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether19 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether20 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether21 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether22 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether23 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=ether24 ] comment="Access;vhost01 iDRAC;;" l2mtu=1598
set [ find default-name=sfp-sfpplus1 ] comment="Core;spinesw01 sfp-sfpplus3;C0000116;" l2mtu=1598
set [ find default-name=sfp-sfpplus2 ] comment=";;;" disabled=yes l2mtu=1598
/interface bonding
add comment="LACP to spinesw0[12]" lacp-rate=1sec min-links=1 mlag-id=1 mode=802.3ad name=po1 slaves=sfp-sfpplus1 transmit-hash-policy=layer-2-and-3
add comment="LACP to nas01" lacp-rate=1sec min-links=1 mlag-id=2 mode=802.3ad name=po2 slaves=ether3 transmit-hash-policy=layer-2-and-3
add comment="LACP to vhost01" lacp-rate=1sec min-links=1 mlag-id=3 mode=802.3ad name=po3 slaves=ether4 transmit-hash-policy=layer-2-and-3
add comment="LACP to vhost02" lacp-rate=1sec min-links=1 mlag-id=4 mode=802.3ad name=po4 slaves=ether5 transmit-hash-policy=layer-2-and-3
add comment="LACP to vhost04" lacp-rate=1sec min-links=1 mlag-id=5 mode=802.3ad name=po5 slaves=ether7 transmit-hash-policy=layer-2-and-3
add comment="ICC bond" lacp-rate=1sec min-links=1 mode=802.3ad name=po1000 slaves=ether1,ether2 transmit-hash-policy=layer-2-and-3
add admin-mac=02:00:00:99:00:21 auto-mac=no frame-types=admit-only-vlan-tagged mlag-peer-port=po1000 mlag-priority=50 mtu=1500 name=general-bridge priority=0x2000 vlan-filtering=yes
/interface vlan
add bridge=general-bridge edge=yes interface=ether6 pvid=1080
add bridge=general-bridge edge=yes frame-types=admit-only-untagged-and-priority-tagged interface=ether8 pvid=1030
add bridge=general-bridge edge=yes frame-types=admit-only-untagged-and-priority-tagged interface=ether9 pvid=1030
add bridge=general-bridge edge=yes frame-types=admit-only-untagged-and-priority-tagged interface=ether10 pvid=1030
add bridge=general-bridge edge=yes frame-types=admit-only-untagged-and-priority-tagged interface=ether11 pvid=1030
add bridge=general-bridge edge=yes frame-types=admit-only-untagged-and-priority-tagged interface=ether24 pvid=1090
add bridge=general-bridge edge=no frame-types=admit-only-vlan-tagged interface=po1
add bridge=general-bridge edge=yes frame-types=admit-only-untagged-and-priority-tagged interface=po2 pvid=1010
add bridge=general-bridge edge=yes interface=po3 pvid=1080
add bridge=general-bridge edge=yes interface=po4 pvid=1080
add bridge=general-bridge edge=yes interface=po5 pvid=1080
add bridge=general-bridge tagged=general-bridge,po1,po1000 vlan-ids=999
add bridge=general-bridge tagged=po1000 vlan-ids=1000
add bridge=general-bridge tagged=ether6,po1,po3,po4,po5,po1000 vlan-ids=1010
add bridge=general-bridge tagged=ether6,po1,po3,po4,po5,po1000 vlan-ids=1030
add bridge=general-bridge tagged=po1000 vlan-ids=1060
add bridge=general-bridge tagged=po1000 vlan-ids=1070
add bridge=general-bridge tagged=po1000 vlan-ids=1100
add bridge=general-bridge tagged=po1,po1000 vlan-ids=1090
add bridge=general-bridge tagged=po1,po1000 vlan-ids=1080
add bridge=general-bridge tagged=ether6,po1,po3,po4,po5,po1000 vlan-ids=1040
add bridge=general-bridge tagged=po1000 vlan-ids=1050
[user@leafsw02] > /interface/export
# 2026-11-01 11:22:22 by RouterOS 7.25
add name=mgmt
set [ find default-name=ether1 ] comment="Core;leafsw01 ether1;C000100;" l2mtu=1598
set [ find default-name=ether2 ] comment="Core;leafsw01 ether2;C000144;" l2mtu=1598
set [ find default-name=ether3 ] comment="Access;nas01 eth1;C000146;" l2mtu=1598
set [ find default-name=ether4 ] comment="Access;vhost01 eno2;;" l2mtu=1598
set [ find default-name=ether5 ] comment="Access;vhost02 enp1s0;C0000151;" l2mtu=1598
set [ find default-name=ether6 ] comment="Access;vhost03 enx00249b3acc74;C000013;" l2mtu=1598
set [ find default-name=ether7 ] comment="Access;vhost04 enp6s0;C000153;" l2mtu=1598
set [ find default-name=ether8 ] comment="Access;monitoring02 enp1s0u2c2;C000027;" l2mtu=1598
set [ find default-name=ether9 ] comment="Access;log01 eth1;;" l2mtu=1598
set [ find default-name=ether24 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=sfp-sfpplus1 ] comment="Core;spinesw02 sfp-sfpplus3;C0000117;" l2mtu=1598
/interface bonding
add comment="nas01 LACP" lacp-rate=1sec min-links=1 mlag-id=2 mode=802.3ad name=po2 slaves=ether3 transmit-hash-policy=layer-2-and-3
add comment="vhost01 LACP" lacp-rate=1sec min-links=1 mlag-id=3 mode=802.3ad name=po3 slaves=ether4 transmit-hash-policy=layer-2-and-3
add comment="vhost02 LACP" lacp-rate=1sec min-links=1 mlag-id=4 mode=802.3ad name=po4 slaves=ether5 transmit-hash-policy=layer-2-and-3
add comment="vhost04 LACP" lacp-rate=1sec min-links=1 mlag-id=5 mode=802.3ad name=po5 slaves=ether7 transmit-hash-policy=layer-2-and-3
add admin-mac=02:00:00:99:00:22 auto-mac=no frame-types=admit-only-vlan-tagged mlag-peer-port=po1000 mlag-priority=100 mtu=1500 name=general-bridge priority=0x2000 vlan-filtering=yes
/interface vlan
add bridge=general-bridge tagged=po1000 vlan-ids=1090
[user@leafsw03] > /interface/export
# 2026-11-01 11:22:41 by RouterOS 7.25
add name=mgmt
add admin-mac=02:00:00:99:00:23 auto-mac=no frame-types=admit-only-vlan-tagged mtu=1500 name=general-bridge priority=0x3000 vlan-filtering=yes
set [ find default-name=ether1 ] comment="Access;PP-Office-01 1;C000133;pc"
set [ find default-name=ether2 ] comment="Access;PP-Office-01 2;C000134;notebook"
set [ find default-name=ether3 ] comment="Access;PP-Office-01 3;C000135;printer"
set [ find default-name=ether4 ] comment="Access;PP-Office-01 4;C000136;" disabled=yes
set [ find default-name=ether5 ] comment="Access;PP-Office-01 5;C000137;notebook work"
set [ find default-name=ether6 ] comment="Access;PP-Office-01 6;C000138;" disabled=yes
set [ find default-name=ether7 ] comment="Access;PP-Office-01 7;C000139;tv"
set [ find default-name=ether8 ] comment="Access;PP-Office-01 8;C000140;" disabled=yes
set [ find default-name=ether9 ] comment="Access;PP-Office-01 9;C000141;"
set [ find default-name=ether10 ] comment="Access;PP-Office-01 10;C000142;"
set [ find default-name=ether21 ] comment="Core;ff01 br-wan;C000143;"
set [ find default-name=ether22 ] comment="Core;modem01 LAN 1;C000132;"
set [ find default-name=sfp-sfpplus1 ] comment="Access;PP-Office-01 24;C000120;"
/interface vlan
/interface bonding
add lacp-rate=1sec min-links=1 mlag-id=1 mode=802.3ad name=po1 slaves=sfp-sfpplus1 transmit-hash-policy=layer-2-and-3
add bridge=general-bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether21 pvid=1070
add bridge=general-bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether22 pvid=900
add bridge=general-bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=1000
add bridge=general-bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether1 pvid=1000
add bridge=general-bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=1010
add bridge=general-bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=1060
add bridge=general-bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether7 pvid=1010
add bridge=general-bridge frame-types=admit-only-vlan-tagged interface=ether9
add bridge=general-bridge frame-types=admit-only-vlan-tagged interface=ether10
add bridge=general-bridge tagged=ether9,ether10,general-bridge,po1 vlan-ids=999
add bridge=general-bridge tagged=po1 vlan-ids=900
add bridge=general-bridge tagged=ether9,ether10,po1 vlan-ids=1000
add bridge=general-bridge tagged=ether9,ether10,po1 vlan-ids=1010
add bridge=general-bridge tagged=ether9,ether10,po1 vlan-ids=1060
add bridge=general-bridge tagged=po1 vlan-ids=1070
