Does anyone know if there is any plan to include Mobile IP support in V3 or a future product? We have a need to work with the cisco mobile ip product.
Thanks in advance.
Mike
Thanks in advance.
Mike
You mean to tell me cisco isn’t using standard IP protocols?
Cisco not adhere to standards???
Get outa here… !!! ![]()
I think that IS their standard… ![]()
Things that make you go Hmmmmm…
Craig
No, not just the Cisco implementation. You may want to take a look at
http://www.ietf.org/html.charters/OLD/mobileip-charter.html
It’s also refered as MANET
The purpose of the MANET working group is to standardize IP routing
protocol functionality suitable for wireless routing application within
both static and dynamic topologies with increased dynamics due to node
motion or other factors.
something called roaming and mesh? ![]()
