Mobile phones unable to connect after enabling management protection
Hi all,
I have been experiencing wireless deauth attacks. I have a RB751g-2hnd router running router OS 6.39.1. I have a mix of wired and wireless clients. This setup is in a home environment. I enabled management protection and the iPhone can see the SSID but cannot connect. I am pasting the export of my wireless settings below. Can I adjust the router such that I get deauth protection and can connect my mobile phones to it? I own an iPhone SE and a moto g4-play.
may/24/2017 21:57:39 by RouterOS 6.39.1
software id = 7S88-QHXW
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors
frequency=auto hw-protection-mode=rts-cts mode=ap-bridge ssid=Periscope
wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk management-protection=
required mode=dynamic-keys supplicant-identity=MikroTik
wpa2-pre-shared-key="some value"
Pranav
Hi.
Remember management-protection feature is a proprietary security for MikroTik device. It means, if you mark as required only MikroTik device with the same management-protection key will connect.
Hi Gustavo,
Thanks for the clarification. What can I do? I want to prevent deauth attacks but setting management protection is making my wireless network useless. Is there any other way?
Pranav
Does it a wifi network in a office?. What is the main propose?
You can secure your network
Using 802.1x authentication
Adding access-list for your MAC clients.
Prevent deauth attacks is a complex wifi problem,
https://www.cwnp.com/hacking-solutions-802-11-protocol-attacks-deauthentication/
This is a home network. I do not run any servers on it. I do have one access point connected to the router via a cable.
I am curious, do you have deauth attacks in a your home network?.
Maybe you can decrease your power level to have less attacks
<snip I am curious, do you have deauth attacks in a your home network?.
PL] Yes. I am happy to decrease the power levels. Where do I do this from if I am using the terminal?
You can use this
interface wireless set tx-power=10 wlan1
where “wlan1” is your interface wireless name and “10” is your tx-power level you want. If you have few walls you can have signal with low level power
